root:~# apt-cache policy apache2
apache2:
Installé : (aucun)
Candidat : 2.2.16-6+squeeze6
Table de version :
2.2.16-6+squeeze6 0
500 security.debian.org/ squeeze/updates/main amd64 Packages
2.2.16-6+squeeze4 0
500 mirror.ovh.net/debian/ squeeze/main amd64 Packages
root:~# aptitude search ~c
c apache2.2-common - Apache HTTP Server common files
c autoconf - automatic configure script builder
c binutils - The GNU assembler, linker and binary utilities
c fontconfig-config - generic font configuration library - configuration
c libapache2-mod-auth-pam - module for Apache2 which authenticate using PAM
c libapache2-mod-php5 - server-side, HTML-embedded scripting language (Apache 2 module)
c libc-client2007e - c-client library for mail protocols - library files
c libfontconfig1 - generic font configuration library - runtime
c libgd2-xpm - GD Graphics Library version 2
c libgmp3c2 - Multiprecision arithmetic library
c libgomp1 - GCC OpenMP (GOMP) support library
c libltdl7 - A system independent dlopen wrapper for GNU libtool
c libmcrypt4 - De-/Encryption Library
c libmpfr4 - multiple precision floating-point computation
c libonig2 - Oniguruma regular expressions library
c libqdbm14 - QDBM Database Libraries [runtime]
c libt1-5 - Type 1 font rasterizer library - runtime
c libtidy-0.99-0 - HTML syntax checker and reformatter - library
c libx11-6 - X11 client-side library
c libxpm4 - X11 pixmap library
c odbcinst - Helper program for accessing odbc ini files
c odbcinst1debian2 - Support library for accessing odbc ini files
c php-pear - PEAR - PHP Extension and Application Repository
c php5-cli - command-line interpreter for the php5 scripting language
c php5-common - Common files for packages built from the php5 source
c php5-gd - GD module for php5
c php5-gmp - GMP module for php5
c php5-imap - IMAP module for php5
c php5-ldap - LDAP module for php5
c php5-mcrypt - MCrypt module for php5
c php5-mysql - MySQL module for php5
c php5-odbc - ODBC module for php5
c php5-pgsql - PostgreSQL module for php5
c php5-suhosin - advanced protection module for php5
c php5-tidy - tidy module for php5
c unixodbc - ODBC tools libraries
root:~# aptitude -s install apache2
apache2 apache2-mpm-worker{a} apache2-utils{a} apache2.2-bin{a} apache2.2-common{a}
0 paquets mis à jour, 5 nouvellement installés, 0 à enlever et 0 non mis à jour.
Il est nécessaire de télécharger 0 o/1 916 ko d’archives. Après dépaquetage, 6 644 ko seront utilisés.
Voulez-vous continuer ? [Y/n/?] y
Réponse incorrecte. Veuillez entrer une commande correcte ou « ? » pour obtenir de l’aide.
Voulez-vous continuer ? [Y/n/?] Y
Charger/installer/enlever des paquets.
root:~# aptitude -s reinstall apache2
apache2 n’est pas actuellement installé, il ne sera donc pas réinstallé.
Aucun paquet ne va être installé, mis à jour ou enlevé.
0 paquets mis à jour, 0 nouvellement installés, 0 à enlever et 0 non mis à jour.
Il est nécessaire de télécharger 0 o d’archives. Après dépaquetage, 0 o seront utilisés.
root:~# apt-get -s install apache2
apache2-mpm-worker apache2-utils apache2.2-bin apache2.2-common
Paquets suggérés :
apache2-doc apache2-suexec apache2-suexec-custom
apache2 apache2-mpm-worker apache2-utils apache2.2-bin apache2.2-common
0 mis à jour, 5 nouvellement installés, 0 à enlever et 0 non mis à jour.
Inst apache2.2-bin (2.2.16-6+squeeze6 Debian-Security:6.0/stable [amd64])
Inst apache2-utils (2.2.16-6+squeeze6 Debian-Security:6.0/stable [amd64])
Inst apache2.2-common (2.2.16-6+squeeze6 Debian-Security:6.0/stable [amd64])
Inst apache2-mpm-worker (2.2.16-6+squeeze6 Debian-Security:6.0/stable [amd64])
Inst apache2 (2.2.16-6+squeeze6 Debian-Security:6.0/stable [amd64])
Conf apache2.2-bin (2.2.16-6+squeeze6 Debian-Security:6.0/stable [amd64])
Conf apache2-utils (2.2.16-6+squeeze6 Debian-Security:6.0/stable [amd64])
Conf apache2.2-common (2.2.16-6+squeeze6 Debian-Security:6.0/stable [amd64])
Conf apache2-mpm-worker (2.2.16-6+squeeze6 Debian-Security:6.0/stable [amd64])
Conf apache2 (2.2.16-6+squeeze6 Debian-Security:6.0/stable [amd64])
