Reinstaller gnome
Suite a ma tentative de passer sous sid, ça a foutu le gros bordel. Et en gros en faisant un upgrade il m’a quasiment tout viré gnome.
(je suis encore sous gnome mais ça doit être la base)
Donc pour le remettre je fais un apt-get install gnome-desktop-environment
Et voilà ce qu’il me répond
root@helm:/home/ed# apt-get dist-upgrade
Reading package lists... Done
Building dependency tree
Reading state information... Done
Calculating upgrade... Done
The following packages have been kept back:
  libbonoboui2-common libgnome2-common
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
root@helm:/home/ed# apt-get install gnome-desktop-environment
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
  gnome-desktop-environment: Depends: gnome-core (= 1:2.22.2~5) but it is not going to be installed
                             Depends: nautilus-cd-burner (>= 2.20.0) but it is not going to be installed
                             Recommends: gnome-accessibility but it is not going to be installed
E: Broken packages
Pas drole
Et voici mon source.list et mon fichier /etc/apt/preferences
sources.list
# deb http://ftp.fr.debian.org/debian/ lenny main
## lenny
deb http://ftp.fr.debian.org/debian/ lenny main contrib non-free
deb-src http://ftp.fr.debian.org/debian/ lenny main contrib non-free
## lenny security
deb http://security.debian.org/ lenny/updates main contrib non-free
deb-src http://security.debian.org/ lenny/updates main contrib non-free
## volatile
deb http://volatile.debian.org/debian-volatile/ lenny/volatile main contrib non-free
deb-src http://volatile.debian.org/debian-volatile/ lenny/volatile main contrib non-free
## lenny multimedia
deb http://www.debian-multimedia.org/ lenny main
deb-src http://www.debian-multimedia.org/ lenny main
## lenny multimedia alternative
#deb http://mirror.home-dn.net/debian-multimedia lenny main
#deb-src http://mirror.home-dn.net/debian-multimedia lenny main
## squeeze
#deb http://ftp.fr.debian.org/debian/ squeeze main contrib non-free
#deb-src http://ftp.fr.debian.org/debian/ squeeze main contrib non-free
## squeeze multimedia
#deb http://mirror.home-dn.net/debian-multimedia squeeze main
#deb-src http://mirror.home-dn.net/debian-multimedia squeeze main
## squeeze security
#deb http://security.debian.org/ squeeze/updates main contrib non-free
#deb-src http://security.debian.org/ squeeze/updates main contrib non-free
## sid
deb http://ftp.fr.debian.org/debian/ sid main contrib non-free
deb-src http://ftp.fr.debian.org/debian/ sid main contrib non-free
## sid multimedia
deb http://www.debian-multimedia.org/ sid main
deb-src http://www.debian-multimedia.org/ sid main
## sid multimedia alternative
#deb http://mirror.home-dn.net/debian-multimedia sid main
#deb-src http://mirror.home-dn.net/debian-multimedia sid main
## experimental
#deb http://ftp.fr.debian.org/debian/ experimental main contrib non-free
#deb-src http://ftp.fr.debian.org/debian/ experimental main contrib non-free
## experimental multimedia
#deb http://www.debian-multimedia.org/ experimental main
#deb-src http://www.debian-multimedia.org/ experimental main
# experimental multimedia alternative
#deb http://mirror.home-dn.net/debian-multimedia experimental main
#deb-src http://mirror.home-dn.net/debian-multimedia experimental main
preferences
Package: *
Pin: release o=apt-build
Pin-Priority: 989
Package: *
Pin: release o=Unofficial Multimedia Packages,a=unstable,l=Unofficial Multimedia Packages
Pin-Priority: 988
Package: *
Pin: release o=Debian,a=unstable,l=Debian
Pin-Priority: 987
Package: *
Pin: release o=volatile.debian.org,a=stable,l=debian-volatile
Pin-Priority: 986
Package: *
Pin: release o=Debian,a=stable,l=Debian-Security
Pin-Priority: 985
Package: *
Pin: release o=Unofficial Multimedia Packages,a=stable,l=Unofficial Multimedia Packages
Pin-Priority: 984
Package: *
Pin-Priority: 983
Package: *
Pin: release o=Debian,a=testing,l=Debian-Security
Pin-Priority: 982
Package: *
Pin: release o=Unofficial Multimedia Packages,a=testing,l=Unofficial Multimedia Packages
Pin-Priority: 981
Package: *
Pin-Priority: 980
Package: *
Pin: release o=Unofficial Multimedia Packages,a=experimental,l=Unofficial Multimedia Packages
Pin-Priority: 99
Package: *
Pin: release o=Debian,a=experimental,l=Debian
Pin-Priority: 98
[quote=“Ptilutin”]Salut
Ouais, suite a un apt-get upgrade récent, il m’a aussi viré GNOME… Étrange non?
Ton problème est en rapport avec ce topic visiblement.
