Réplication MYSQL Master/Slave Debian 7
J’ai déjà auparavant fait fonctionner une réplication MASTER SLAVE. Cependant en essayant de refaire fonctionner cette réplication sur Debian 7 je possède une erreur "Connecting to Master"
Vous trouverez ci-joint mes fichiers de configuration.
SRV-MYSQL1 : 192.168.0.80
SRV-MYSQL2 : 192.168.0.82
SRV-MYSQL1 : 192.168.0.80 /etc/mysql/my.cnf
[code]#
The MySQL database server configuration file.
You can copy this to one of:
- “/etc/mysql/my.cnf” to set global options,
- “~/.my.cnf” to set user-specific options.
One can use all long options that the program supports.
Run program with --help to get a list of available options and with
–print-defaults to see which it would actually understand and use.
For explanations see
http://dev.mysql.com/doc/mysql/en/server-system-variables.html
This will be passed to all mysql clients
It has been reported that passwords should be enclosed with ticks/quotes
escpecially if they contain “#” chars…
Remember to edit /etc/mysql/debian.cnf when changing the socket location.
[client]
port = 3306
socket = /var/run/mysqld/mysqld.sock
Here is entries for some specific programs
The following values assume you have at least 32M ram
This was formally known as [safe_mysqld]. Both versions are currently parsed.
[mysqld_safe]
nice = 0
[mysqld]
* Basic Settings
user = mysql
pid-file = /var/run/mysqld/mysqld.pid
port = 3306
basedir = /usr
datadir = /var/lib/mysql
tmpdir = /tmp
lc-messages-dir = /usr/share/mysql
skip-external-locking
Instead of skip-networking the default is now to listen only on
localhost which is more compatible and is not less secure.
bind-address = 127.0.0.1
server-id=1
log-bin
* Fine Tuning
key_buffer = 16M
max_allowed_packet = 16M
thread_stack = 192K
thread_cache_size = 8
This replaces the startup script and checks MyISAM tables if needed
the first time they are touched
myisam-recover = BACKUP
#max_connections = 100
#table_cache = 64
#thread_concurrency = 10
* Query Cache Configuration
query_cache_limit = 1M
query_cache_size = 16M
* Logging and Replication
Both location gets rotated by the cronjob.
Be aware that this log type is a performance killer.
As of 5.1 you can enable the log at runtime!
#general_log_file = /var/log/mysql/mysql.log
#general_log = 1
Error logging goes to syslog due to /etc/mysql/conf.d/mysqld_safe_syslog.cnf.
Here you can see queries with especially long duration
#log_slow_queries = /var/log/mysql/mysql-slow.log
#long_query_time = 2
#log-queries-not-using-indexes
The following can be used as easy to replay backup logs or for replication.
note: if you are setting up a replication slave, see README.Debian about
other settings you may need to change.
#server-id = 1
#log_bin = /var/log/mysql/mysql-bin.log
expire_logs_days = 10
max_binlog_size = 100M
#binlog_do_db = include_database_name
#binlog_ignore_db = include_database_name
* InnoDB
InnoDB is enabled by default with a 10MB datafile in /var/lib/mysql/.
Read the manual for more InnoDB related options. There are many!
* Security Features
Read the manual, too, if you want chroot!
chroot = /var/lib/mysql/
For generating SSL certificates I recommend the OpenSSL GUI “tinyca”.
ssl-ca=/etc/mysql/cacert.pem
ssl-cert=/etc/mysql/server-cert.pem
ssl-key=/etc/mysql/server-key.pem
[mysqldump]
quick
quote-names
[mysql]
#no-auto-rehash # faster start of mysql but no tab completition
[isamchk]
key_buffer = 16M
* IMPORTANT: Additional settings that can override those from this file!
The files must end with ‘.cnf’, otherwise they’ll be ignored.
!includedir /etc/mysql/conf.d/
SRV-MYSQL2 : 192.168.0.81 /etc/mysql/my.cnf
[code]#
[client]
port = 3306
[mysqld_safe]
nice = 0
[mysqld]
* Basic Settings
user = mysql
port = 3306
basedir = /usr
tmpdir = /tmp
#bind-address = 127.0.0.1
server-id=2
#log-bin
* Fine Tuning
key_buffer = 16M
thread_stack = 192K
#table_cache = 64
#general_log = 1
#server-id = 1
* InnoDB
* Security Features
[mysqldump]
quick
quote-names
[mysql]
[isamchk]
key_buffer = 16M
J’ai effectué un change master to master_host=‘192.168.0.80’, master_user=‘replicateur’, master_password=‘replicateur’, master_port=3306, master_log_file=‘mysqld-bin.000002’, master_log_pos=107;
En ayant fait un FLUSH TABLES WITH READ LOCK; sur le Maître.
Je ne comprends pas pourquoi l’esclave ne se connecte pas ’ Connecting to Master"
+----------------------+--------------+-------------+-------------+---------------+-------------------+---------------------+-------------------------+---------------+-----------------------+------------------+-------------------+-----------------+---------------------+--------------------+------------------------+-------------------------+-----------------------------+------------+------------+--------------+---------------------+-----------------+-----------------+----------------+---------------+--------------------+--------------------+--------------------+-----------------+-------------------+----------------+-----------------------+-------------------------------+---------------+---------------------------------------------------------------------------------------------+----------------+----------------+-----------------------------+------------------+ | Slave_IO_State | Master_Host | Master_User | Master_Port | Connect_Retry | Master_Log_File | Read_Master_Log_Pos | Relay_Log_File | Relay_Log_Pos | Relay_Master_Log_File | Slave_IO_Running | Slave_SQL_Running | Replicate_Do_DB | Replicate_Ignore_DB | Replicate_Do_Table | Replicate_Ignore_Table | Replicate_Wild_Do_Table | Replicate_Wild_Ignore_Table | Last_Errno | Last_Error | Skip_Counter | Exec_Master_Log_Pos | Relay_Log_Space | Until_Condition | Until_Log_File | Until_Log_Pos | Master_SSL_Allowed | Master_SSL_CA_File | Master_SSL_CA_Path | Master_SSL_Cert | Master_SSL_Cipher | Master_SSL_Key | Seconds_Behind_Master | Master_SSL_Verify_Server_Cert | Last_IO_Errno | Last_IO_Error | Last_SQL_Errno | Last_SQL_Error | Replicate_Ignore_Server_Ids | Master_Server_Id | +----------------------+--------------+-------------+-------------+---------------+-------------------+---------------------+-------------------------+---------------+-----------------------+------------------+-------------------+-----------------+---------------------+--------------------+------------------------+-------------------------+-----------------------------+------------+------------+--------------+---------------------+-----------------+-----------------+----------------+---------------+--------------------+--------------------+--------------------+-----------------+-------------------+----------------+-----------------------+-------------------------------+---------------+---------------------------------------------------------------------------------------------+----------------+----------------+-----------------------------+------------------+ | Connecting to master | 192.168.0.80 | replicateur | 3306 | 60 | mysqld-bin.000002 | 107 | mysqld-relay-bin.000002 | 4 | mysqld-bin.000002 | Connecting | Yes | | | | | | | 0 | | 0 | 107 | 107 | None | | 0 | No | | | | | | NULL | No | 2003 | error connecting to master 'replicateur@192.168.0.80:3306' - retry-time: 60 retries: 86400 | 0 | | | 0 | +----------------------+--------------+-------------+-------------+---------------+-------------------+---------------------+-------------------------+---------------+-----------------------+------------------+-------------------+-----------------+---------------------+--------------------+------------------------+-------------------------+-----------------------------+------------+------------+--------------+---------------------+-----------------+-----------------+----------------+---------------+--------------------+--------------------+--------------------+-----------------+-------------------+----------------+-----------------------+-------------------------------+---------------+---------------------------------------------------------------------------------------------+----------------+----------------+-----------------------------+------------------+ 1 row in set (0.01 sec)
Cordialement
Arrives tu as te connecté à la machine DB2 à partir de DB1 avec les users/mdp de la réplication?
Et Inversement?
Ah non.
Même en local avec un
Je n’arrive pas à me connecter. Normalement juste créer l’utilisateur ne suffit pas ?
Nope il lui faut des droits :
GRANT REPLICATION SLAVE ON *.* TO ‘replication_user’@'192.168.10.20’ IDENTIFIED BY 'motdepasse';
Après si ti on user arrive pas à te co tu sais ou est ton erreur maintenant^^
Edit : Joli fran , j’avais check que la 2ème config et les servers-id sur les 2, j’avais loupé cette erreur.
Ton master refuse toutes les connexions mis à part sur le loopback, commente la ligne
ou met 0.0.0.0 à la place de 127.0.0.1
Grace à vous j’ai résolu mon problème.
Voici un lien vers MEGA pour télécharger les machines virtuelles VMWARE WORKSTATION avec la configuration adéquat.
Machines virtuelles : https://mega.co.nz/#!wEozhb5B!B96P3AloF8TnGa1GjYvUYm4IkDN2qOHneJSubJOuC24
Documentation : https://mega.co.nz/#!UdpFlYBa!oURoUTlGO7sj3uKyOfZYlPe0IrrZ6aDEAG5-HMAta2c
user: administrateur
mdp : P@ssw0rd
user : root
mdp : P@ssw0rd
Je sais à quel point c’est chiant de ne pas trouver, si vous voulez épingler ce topic pour les futures demandent concernant la réplication MYSQL cela serait avec plaisir, je tâcherai de laisser le dossier MEGA à sa place.
Si un jour une personne déterre se topic et souhaite de l’aide ou des fichiers de configuration elle peut me contacter à : verger.remy@gmail.com
Oni’
Pour être précis, quel était le problème de configuration finalement?
Un ensemble de choses.
Je n’avais pas commenté le bind-adress.
L’utilisateur n’était pas crée sur le second serveur.
Mauvais droits.
Et un des deux users de réplications n’avaient pas de droit pour la réplication.
