depuis le serveur
[quote]cat /etc/resolv.conf
domain home
search home
nameserver 192.168.1.1
nameserver 192.168.1.1[/quote]
depuis un client
[quote]ubuntu:~$ cat /etc/resolv.conf
Dynamic resolv.conf(5) file for glibc resolver(3) generated by resolvconf(8)
DO NOT EDIT THIS FILE BY HAND – YOUR CHANGES WILL BE OVERWRITTEN
nameserver 81.253.149.9
nameserver 80.10.246.1
search monreseau[/quote]
[quote]ubuntu:~$ ping -n -c 4 192.168.1.1
PING 192.168.1.1 (192.168.1.1) 56(84) bytes of data.
— 192.168.1.1 ping statistics —
4 packets transmitted, 0 received, 100% packet loss, time 2999ms[/quote]
[quote]ubuntu:~$ ip -4 neigh
172.16.10.1 dev eth0 lladdr 00:08:a1:6d:be:ef REACHABLE
tristan@tristan-ubuntu:~$ cat /etc/resolv.conf
J’ai déjà eu ce problème mais la réponse ne résout pas le problème :
Un problème dans le noyau ?
[quote]uname -r
3.2.0-4-686-pae[/quote]
[quote]grep NF_NAT /boot/config-$(uname -r)
CONFIG_NF_NAT=m
CONFIG_NF_NAT_NEEDED=y
CONFIG_NF_NAT_SNMP_BASIC=m
CONFIG_NF_NAT_PROTO_DCCP=m
CONFIG_NF_NAT_PROTO_GRE=m
CONFIG_NF_NAT_PROTO_UDPLITE=m
CONFIG_NF_NAT_PROTO_SCTP=m
CONFIG_NF_NAT_FTP=m
CONFIG_NF_NAT_IRC=m
CONFIG_NF_NAT_TFTP=m
CONFIG_NF_NAT_AMANDA=m
CONFIG_NF_NAT_PPTP=m
CONFIG_NF_NAT_H323=m
CONFIG_NF_NAT_SIP=m[/quote]
[quote]# find /lib/modules/uname -r
/kernel/net/ipv4/netfilter
/lib/modules/3.2.0-4-686-pae/kernel/net/ipv4/netfilter
/lib/modules/3.2.0-4-686-pae/kernel/net/ipv4/netfilter/nf_conntrack_ipv4.ko
/lib/modules/3.2.0-4-686-pae/kernel/net/ipv4/netfilter/nf_nat_proto_sctp.ko
/lib/modules/3.2.0-4-686-pae/kernel/net/ipv4/netfilter/ipt_NETMAP.ko
/lib/modules/3.2.0-4-686-pae/kernel/net/ipv4/netfilter/ipt_LOG.ko
/lib/modules/3.2.0-4-686-pae/kernel/net/ipv4/netfilter/ip_tables.ko
/lib/modules/3.2.0-4-686-pae/kernel/net/ipv4/netfilter/nf_nat_tftp.ko
/lib/modules/3.2.0-4-686-pae/kernel/net/ipv4/netfilter/nf_nat_pptp.ko
/lib/modules/3.2.0-4-686-pae/kernel/net/ipv4/netfilter/ipt_REJECT.ko
/lib/modules/3.2.0-4-686-pae/kernel/net/ipv4/netfilter/nf_nat_snmp_basic.ko
/lib/modules/3.2.0-4-686-pae/kernel/net/ipv4/netfilter/ipt_ah.ko
/lib/modules/3.2.0-4-686-pae/kernel/net/ipv4/netfilter/ipt_MASQUERADE.ko
/lib/modules/3.2.0-4-686-pae/kernel/net/ipv4/netfilter/ipt_ecn.ko
/lib/modules/3.2.0-4-686-pae/kernel/net/ipv4/netfilter/iptable_nat.ko
/lib/modules/3.2.0-4-686-pae/kernel/net/ipv4/netfilter/arpt_mangle.ko
/lib/modules/3.2.0-4-686-pae/kernel/net/ipv4/netfilter/ipt_ULOG.ko
/lib/modules/3.2.0-4-686-pae/kernel/net/ipv4/netfilter/nf_nat_irc.ko
/lib/modules/3.2.0-4-686-pae/kernel/net/ipv4/netfilter/iptable_filter.ko
/lib/modules/3.2.0-4-686-pae/kernel/net/ipv4/netfilter/iptable_security.ko
/lib/modules/3.2.0-4-686-pae/kernel/net/ipv4/netfilter/ip_queue.ko
/lib/modules/3.2.0-4-686-pae/kernel/net/ipv4/netfilter/nf_nat_sip.ko
/lib/modules/3.2.0-4-686-pae/kernel/net/ipv4/netfilter/nf_nat_h323.ko
/lib/modules/3.2.0-4-686-pae/kernel/net/ipv4/netfilter/nf_nat_proto_udplite.ko
/lib/modules/3.2.0-4-686-pae/kernel/net/ipv4/netfilter/nf_defrag_ipv4.ko
/lib/modules/3.2.0-4-686-pae/kernel/net/ipv4/netfilter/ipt_CLUSTERIP.ko
/lib/modules/3.2.0-4-686-pae/kernel/net/ipv4/netfilter/iptable_mangle.ko
/lib/modules/3.2.0-4-686-pae/kernel/net/ipv4/netfilter/arp_tables.ko
/lib/modules/3.2.0-4-686-pae/kernel/net/ipv4/netfilter/nf_nat.ko
/lib/modules/3.2.0-4-686-pae/kernel/net/ipv4/netfilter/nf_nat_proto_dccp.ko
/lib/modules/3.2.0-4-686-pae/kernel/net/ipv4/netfilter/nf_nat_ftp.ko
/lib/modules/3.2.0-4-686-pae/kernel/net/ipv4/netfilter/nf_nat_proto_gre.ko
/lib/modules/3.2.0-4-686-pae/kernel/net/ipv4/netfilter/iptable_raw.ko
/lib/modules/3.2.0-4-686-pae/kernel/net/ipv4/netfilter/nf_nat_amanda.ko
/lib/modules/3.2.0-4-686-pae/kernel/net/ipv4/netfilter/arptable_filter.ko
/lib/modules/3.2.0-4-686-pae/kernel/net/ipv4/netfilter/ipt_REDIRECT.ko
/lib/modules/3.2.0-4-686-pae/kernel/net/ipv4/netfilter/ipt_ECN.ko[/quote]
Tout à l’air ok pourtant.
Je ne comprends pas ou je ne vois pas
