çà commence mal !
nmap adresseipprivélinux et windows
Starting Nmap 4.76 ( nmap.org ) at 2009-10-29 19:27 CET
Failed to resolve given hostname/IP: adresseipprivélinux. Note that you can’t use ‘/mask’ AND ‘1-4,7,100-’ style IP ranges
WARNING: No targets were specified, so 0 hosts scanned.
Nmap done: 0 IP addresses (0 hosts up) scanned in 0.39 seconds
parcontre ifconfig sous linux donne :
ifconfig
eth0 Link encap:Ethernet HWaddr 00:1e:68:93:f1:5b
collisions:0 txqueuelen:1000
Interrupt:28 Base address:0x8000
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
RX packets:46009 errors:0 dropped:0 overruns:0 frame:0
TX packets:46009 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:3847046 (3.8 MB) TX bytes:3847046 (3.8 MB)
wlan0 Link encap:Ethernet HWaddr 00:1f:e2:91:51:80
inet addr:192.168.1.110 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::21f:e2ff:fe91:5180/64 Scope:Link
RX packets:53082 errors:0 dropped:0 overruns:0 frame:0
TX packets:31634 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:48191265 (48.1 MB) TX bytes:4293572 (4.2 MB)
wmaster0 Link encap:UNSPEC HWaddr 00-1F-E2-91-51-80-31-38-00-00-00-00-00-00-00-00
UP RUNNING MTU:0 Metric:1
/sbin/ifconfig
RX packets:45211 errors:0 dropped:0 overruns:0 frame:0
TX packets:45211 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:3780070 (3.7 MB) TX bytes:3780070 (3.7 MB)
RX packets:52781 errors:0 dropped:0 overruns:0 frame:0
TX packets:31530 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:48169181 (48.1 MB) TX bytes:4268807 (4.2 MB)
ipconfig sous windows
carte ethernet pont réseau
suffixe dns propre à la connexion
adresse ip 192.168.1.162
masque 255.255.255.0
passerelle 192.168.1.1
Effectivement, dans tout ce que j’ai lu, l’adresse internet public ne sert à rien puisque je veux me connecter en local.
merci de ton aide.
