[Réseau] Problème de service networking
Meilleurs vœux pour tout le monde.
Dans ma Vm sous l’adresse 91.121.36.11
Voici mon fichier /etc/network/interfaces
[code]# This file describes the network interfaces available on your system
auto lo
iface lo inet loopback
The primary network interface
allow-hotplug eth0
iface eth0 inet static
address 91.121.36.11
netmask 255.255.255.0
network 91.121.36.0
broadcast 91.121.36.255
gateway 91.121.36.254
# dns-* options are implemented by the resolvconf package, if installed
dns-nameserver 213.186.33.99 #Serveur DNS OVH
dns-search ovh.net #Résoudre plus vite les hosts sur le réseau OVH
post-up route add 91.121.36.254 dev eth0
post-up route add default gw 91.121.36.254
pre-down route del 91.121.36.254 dev eth0
pre-down route del default gw 91.121.36.254
iface eth0 inet6 static
address 2001:41d0:8:523d::2
netmask 64
gateway 2001:41d0:8:52ff:ff:ff:ff:ff
post-up /sbin/ip -f inet6 route add 2001:41d0:8:52ff:ff:ff:ff:ff dev eth0
post-up /sbin/ip -f inet6 route add default gw 2001:41d0:8:52ff:ff:ff:ff:ff
post-up /sbin/ip -6 addr add 2001:41d0:8:523d::2/64 dev eth0
pre-down /sbin/ip -6 addr del 2001:41d0:8:523d::2/64 dev eth0
pre-down /sbin/ip -f inet6 route del default gw 2001:41d0:8:52ff:ff:ff:ff:ff
pre-down /sbin/ip -f inet6 route del 2001:41d0:8:52ff:ff:ff:ff:ff dev eth0[/code]
J’ai redémarré le service
Mais j’obtiens une erreur :
[quote][warn] Running /etc/init.d/networking restart is deprecated because it may not re-enable some interfaces … (warning).
[ ok ] Reconfiguring network interfaces…done.[/quote]
De plus, quand j’essais de mettre Ipv6 public elle n’apparaît pas.
Quand je fais un ifconfig
Code:
eth0 Link encap:Ethernet HWaddr 00:50:56:05:59:55
inet adr:91.121.36.11 Bcast:91.121.36.255 Masque:255.255.255.0
adr inet6: fe80::250:56ff:fe05:5955/64 Scope:Lien
RX packets:2853 errors:0 dropped:0 overruns:0 frame:0
TX packets:1409 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:494352 (482.7 KiB) TX bytes:501927 (490.1 KiB)
Ce que j’ai mis en gras c’est une adresse IPv6 en local.
A la place je devrais avoir Scope:Glogal.
Je devrais avoir une adresse ipv6 en global public.
J’ai regardé la documentation pour IPv6 sur Ovh.
J’ai remplacé via par gw et -family par -f.
ça fonctionne sur un domaine mais pas sur les autres
https://docs.ovh.com/display/public/GUD/Configurer+une+IPv6+sous+Debian
et
http://guides.ovh.com/Ipv4Ipv6
Coment puis-je faire ?
Cordialement,
Je ne vois pas d’erreur, juste une alerte :slightly_smiling:
Pareil. Ce n’est pas une erreur mais un avertissement (“warning”). Par contre tu as fait plusieurs erreurs qui n’ont pas été signalées.
  1. Comme indiqué, [mono]/etc/init.d/networking restart[/mono] n’est plus la bonne façon de faire pour reconfigurer une interface. En particulier elle n’affecte que les interfaces ayant [mono]auto[/mono] ou [mono]allow-auto[/mono] alors que dans ton fichier interfaces, eth0 n’a que [mono]allow-hotplug[/mono]. Utiliser plutôt [mono]ifdown[/mono] et [mono]ifup[/mono] avec le nom de l’interface.
  2. Ton fichier /etc/network/interface contient des erreurs.
  • Les 4 lignes suivantes sont inutiles :
post-up route add 91.121.36.254 dev eth0 post-up route add default gw 91.121.36.254 pre-down route del 91.121.36.254 dev eth0 pre-down route del default gw 91.121.36.254
Les 2 premières sont redondantes avec les options address, netmask et gateway ; les 2 suivantes ne servent à rien puisque la désactivation de l’interface va de toute façon supprimer toutes les routes qui lui sont attachées.
  • La ligne suivante est incompatible avec les options address et netmask qui précèdent car l’adresse de passerelle spécifiée n’est pas dans le préfixe 2001:41d0:8:523d::/64.
  • La ligne suivante a une erreur de syntaxe
[mono]ip route[/mono] utilise [mono]via[/mono] et non [mono]gw[/mono] pour spécifier l’adresse de routeur. C’est [mono]route[/mono] qui utilise [mono]gw[/mono].
  • La ligne suivante est redondante avec les options address et netmask :
[quote=“PascalHambourg”]Pareil. Ce n’est pas une erreur mais un avertissement (“warning”). Par contre tu as fait plusieurs erreurs qui n’ont pas été signalées.
Bonsoir,
Merci de votre réponse.
Mais concrètement que dois-je faire pour chaque VM ?
Cordialement,
Concrètement, il faut corriger les erreurs que j’ai signalées.
Lignes inutiles ou redondantes : à supprimer.
Ligne incompatible : à supprimer.
Erreurs de syntaxe : à corriger.
PS : dans mon inventaire j’ai oublié de mentionner que les 3 dernières lignes [mono]pre-down[/mono] sont inutiles, comme les précédentes.
PPS : Inutile aussi de citer l’intégralité du message précédent. La citation doit être ciblée et n’est utile que pour répondre à un point particulier.
[quote=“PascalHambourg”]Concrètement, il faut corriger les erreurs que j’ai signalées.
Bonsoir,
J’ai corrigé les erreurs:
Donc j’ai mis :
# The primary network interface allow-hotplug eth0 iface eth0 inet static address 91.121.36.11 netmask 255.255.255.0 network 91.121.36.0 broadcast 91.121.36.255 gateway 91.121.36.254 dns-nameserver 213.186.33.99 dns-search ovh.net
J’ai supprimé tous les “post”.
Ensuite pour l’IPv6 j’ai fait la même chose :
iface eth0 inet6 static address 2001:41d0:8:523d::2 netmask 64 gateway 2001:41d0:8:52ff:ff:ff:ff:ff
Est-ce mieux dans le fichier ?
Mais toujours pas d’adresse IPv6 en public.
Comment faire ?
Cordialemment,
[quote=“rezolinux”]J’ai supprimé tous les “post”.
Ensuite pour l’IPv6 j’ai fait la même chose :[/quote]
Ce n’est pas ce que j’ai dit pour l’IPv6.
J’avais dit de supprimer l’option [mono]gateway[/mono] car l’adresse n’est pas compatible avec le préfixe.
Je n’avais pas dit de supprimer toutes les options [mono]post-up[/mono] mais de corriger l’erreur de syntaxe et de supprimer la redondante.
Bonsoir
Donc pour IPv6 je met :
iface eth0 inet6 static address 2001:41d0:8:523d::2 netmask 64 post-up /sbin/ip -f inet6 route add 2001:41d0:8:52ff:ff:ff:ff:ff dev eth0 post-up /sbin/ip -f inet6 route add default via 2001:41d0:8:52ff:ff:ff:ff:ff pre-down /sbin/ip -f inet6 route del default via 2001:41d0:8:52ff:ff:ff:ff:ff pre-down /sbin/ip -f inet6 route del 2001:41d0:8:52ff:ff:ff:ff:ff dev eth0
Comme ça ?
Si ne n’est pas ça pouvez-vous me montrer la correction pour bien comprendre ?
Cordialement,
Oui, mais j’avais dit que les [mono]pre-down[/mono] étaient inutiles.
Bonsoir,
J’ai fais ce que vous m’avez dit, mais je n’ai plus de réseau.
Comment faire ?
Cordialement,
Bonsoir,
Encore moi.
J’ai redémarré la VM maintenant j’ai bien une IPv4 et IPv6 en public.
eth0 Link encap:Ethernet HWaddr 00:50:56:05:59:55 inet adr:91.121.36.11 Bcast:91.121.36.255 Masque:255.255.255.0 adr inet6: fe80::250:56ff:fe05:5955/64 Scope:Lien [b]adr inet6: 2001:41d0:8:523d::2/64 Scope:Global[/b] UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:260 errors:0 dropped:0 overruns:0 frame:0 TX packets:159 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 lg file transmission:1000 RX bytes:38224 (37.3 KiB) TX bytes:151755 (148.1 KiB)
Et j’ai mis dans interfaces :
iface eth0 inet6 static address 2001:41d0:8:523d::2 netmask 64 post-up /sbin/ip -family inet6 route add 2001:41d0:8:52ff:ff:ff:ff:ff dev eth0 post-up /sbin/ip -family inet6 route add default via 2001:41d0:8:52ff:ff:ff:ff:ff pre-down /sbin/ip -family inet6 route del default via 2001:41d0:8:52ff:ff:ff:ff:ff pre-down /sbin/ip -family inet6 route del 2001:41d0:8:52ff:ff:ff:ff:ff dev eth0
J’enlève pre-down pendant j’écris ce message.
Qu’en pensez-vous ?
Cordialement,
Je répète que les pre-down sont inutiles.
Il reste à tester la connectivité IPv6 globale pour vérifier que la route IPv6 par défaut est correcte.
Bonsoir,
Voici ce que j’ai mis:
         netmask 64
         post-up /sbin/ip -family inet6 route add default via 2001:41d0:8:52ff:ff:ff:ff:ff[/code]
Je pense que c'est bon maintenant ?
j'ai fait un ping6 pour google et ça fonctionne.
J'ai fait un :
[code]ip -6 route
2001:41d0:8:523d::/64 dev eth0  proto kernel  metric 256
2001:41d0:8:52ff:ff:ff:ff:ff dev eth0  metric 1024[/code]
Et un ip -6 addr
[code]addr       addrlabel
root@cls:~# ip -6 addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 16436
    inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qlen 1000
    inet6 2001:41d0:8:523d::2/64 scope global
    inet6 fe80::250:56ff:fe05:5955/64 scope link
C’est bon maintenant ?
Cordialement,
On ne voit pas la route IPv6 par défaut dans la sortie de [mono]ip -6 route[/mono] qui est censée être créée par la seconde option [mono]post-up[/mono]. C’est contradictoire avec le fait que [mono]ping6[/mono] sur une adresse extérieure fonctionne. Copie tronquée de la sortie ?
