hello.
petite explication:
j’ai une interface eth1 en dhcp:
je voudrai obtenir 2 interface supplémentaire . je parviens a en obtenir 1 mai pas la deuxième.
je me suis inspirer du tutoriel ici:
doc.ubuntu-fr.org/virtualbox_reseau
Fichier : /etc/network/interfaces
GNU nano 2.0.2 Fichier : /etc/network/interfaces
# This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5).
#auto lo
#iface lo inet loopback
#new ok
auto eth1
iface eth1 inet manual
auto tap0
iface tap0 inet manual
tunctl_user tnt
auto bridge0
iface bridge0 inet dhcp
post-up chmod ugo+rw /dev/net/tun
bridge-ports eth1 tap0
bridge-ageing 7200
bridge-fd 2
#new
auto tap1
iface tap1 inet manual
tunctl_user tnt
auto bridge1
iface bridge1 inet dhcp
bridge-ports eth1 tap1
bridge-ageing 7200
bridge-fd 2
après un /etc/init.d/networking restart
Reconfiguring network interfaces...There is already a pid file /var/run/dhclient.bridge0.pid with pid 12899
killed old client process, removed PID file
Internet Systems Consortium DHCP Client V3.0.4
Copyright 2004-2006 Internet Systems Consortium.
All rights reserved.
For info, please visit http://www.isc.org/sw/dhcp/
Listening on LPF/bridge0/00:0a:e4:5e:21:8f
Sending on LPF/bridge0/00:0a:e4:5e:21:8f
Sending on Socket/fallback
DHCPRELEASE on bridge0 to 192.168.1.254 port 67
There is already a pid file /var/run/dhclient.bridge1.pid with pid 13632
Listening on LPF/bridge1/b6:cb:18:d0:21:2b
Sending on LPF/bridge1/b6:cb:18:d0:21:2b
device eth1 is not a slave of bridge1
Set 'tap0' persistent and owned by uid 1000
Waiting for bridge0 to get ready (MAXWAIT is 6 seconds).
DHCPDISCOVER on bridge0 to 255.255.255.255 port 67 interval 3
DHCPOFFER from 192.168.1.254
DHCPREQUEST on bridge0 to 255.255.255.255 port 67
DHCPACK from 192.168.1.254
bound to 192.168.1.65 -- renewal in 40983 seconds.
Set 'tap1' persistent and owned by uid 1000
device eth1 is already a member of a bridge; can't enslave it to bridge bridge1.
Waiting for bridge1 to get ready (MAXWAIT is 6 seconds).
DHCPDISCOVER on bridge1 to 255.255.255.255 port 67 interval 5
DHCPDISCOVER on bridge1 to 255.255.255.255 port 67 interval 6
DHCPDISCOVER on bridge1 to 255.255.255.255 port 67 interval 8
DHCPDISCOVER on bridge1 to 255.255.255.255 port 67 interval 9
DHCPDISCOVER on bridge1 to 255.255.255.255 port 67 interval 10
DHCPDISCOVER on bridge1 to 255.255.255.255 port 67 interval 13
No DHCPOFFERS received.
No working leases in persistent database - sleeping.
done.
ifconfig
bridge0 Lien encap:Ethernet HWaddr 00:0A:E4:5E:21:8F
inet adr:192.168.1.65 Bcast:192.168.1.255 Masque:255.255.255.0
adr inet6: fe80::20a:e4ff:fe5e:218f/64 Scope:Lien
RX packets:128 errors:0 dropped:0 overruns:0 frame:0
TX packets:103 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:8012 (7.8 KiB) TX bytes:18112 (17.6 KiB)
bridge1 Lien encap:Ethernet HWaddr B6:CB:18:D0:21:2B
adr inet6: fe80::b4cb:18ff:fed0:212b/64 Scope:Lien
TX packets:30 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 b) TX bytes:8676 (8.4 KiB)
eth1 Lien encap:Ethernet HWaddr 00:0A:E4:5E:21:8F
RX packets:2492 errors:0 dropped:0 overruns:0 frame:0
TX packets:2090 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:214420 (209.3 KiB) TX bytes:318929 (311.4 KiB)
Interruption:201 Adresse de base:0x1800
tap0 Lien encap:Ethernet HWaddr 2E:23:A3:A7:AE:34
adr inet6: fe80::2c23:a3ff:fea7:ae34/64 Scope:Lien
TX packets:0 errors:0 dropped:842 overruns:0 carrier:0
collisions:0 lg file transmission:500
RX bytes:0 (0.0 b) TX bytes:0 (0.0 b)
tap1 Lien encap:Ethernet HWaddr B6:CB:18:D0:21:2B
TX packets:0 errors:0 dropped:99 overruns:0 carrier:0
On voi bien que bridge0 a reçus une ip et que bridge1 n’en a pas.
Meme en activant
auto lo
sa ne change rien
Merci d’avance parce que la je seche, surtout que la configuration réseaux c’est pas ma tasse de thé.
