La config correspondant à celle que tu as actuellement peut se simplifier comme ça:[code]Section "ServerLayout"
Identifier "Layout manuel avec config fine"
Screen 0 “Screen manuel” 0 0
InputDevice "Clavier"
InputDevice "Souris"
EndSection
Section “Files”
# local font server
# if the local font server has problems, we can fall back on these
FontPath "unix/:7100"
FontPath "/usr/lib/X11/fonts/misc"
FontPath "/usr/lib/X11/fonts/cyrillic"
FontPath "/usr/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/lib/X11/fonts/75dpi/:unscaled"
FontPath "/usr/lib/X11/fonts/Type1"
FontPath "/usr/lib/X11/fonts/CID"
FontPath "/usr/lib/X11/fonts/100dpi"
FontPath "/usr/lib/X11/fonts/75dpi"
EndSection
Section "Module"
Load "bitmap"
Load "dbe"
Load "ddc"
Load "dri"
Load "evdev"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "record"
Load "type1"
Load "record"
Load "type1"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Clavier"
Driver "keyboard"
Option "CoreKeyboard"
Option “XkbRules” "xorg"
Option “XkbModel” "pc105"
Option “XkbLayout” "fr"
Option “XkbVariant” "latin9"
EndSection
Identifier "Souris"
Driver "mouse"
Option "CorePointer"
Option “Device” "/dev/input/mice"
Option “Protocol” "ImPS/2"
Option “Emulate3Buttons” "true"
Option “ZAxisMapping” "4 5"
EndSection
Section "Monitor"
Identifier "Moniteur en autodetection"
EndSection
Section "Device"
Identifier "Carte ATI"
Driver "fglrx"
BusID "PCI:1:0:0"
EndSection
Section "Screen"
Identifier "Screen manuel"
Device "Carte ATI"
Monitor "Moniteur en autodetection"
DefaultDepth 24
DefaultDepth 24
SubSection "Display"
Viewport 0 0
Depth 24
EndSubSection
EndSection
Section "DRI"
Mode 0666
EndSection[/code]
Mais je te conseillerais plutot quelquechose du genre:[code]Section "ServerLayout"
Screen 0 “Screen manuel avec config fine” 0 0
EndSection
Section “Files”
# local font server
EndSection
Section "Module"
Load "bitmap"
Load "dbe"
Load "ddc"
Load "dri"
Load "evdev"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "record"
Load "type1"
Load "record"
Load "type1"
Load "vbe"
EndSection
Driver "keyboard"
EndSection
Identifier "Souris"
Driver "mouse"
EndSection
Section "Monitor"
Identifier "4311 FA"
HorizSync 30.0 - 70.0
VertRefresh 50.0 - 160.0
Option "DPMS"
EndSection
Section "Device"
Driver "fglrx"
BusID "PCI:1:0:0"
EndSection
Section "Screen"
Identifier "Screen manuel avec config fine"
Device "Carte ATI"
Monitor "4311 FA"
DefaultDepth 24
Depth 1
Modes “1280x1024” “1024x768” “800x600” “720x400” "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "DRI"
Mode 0666
EndSection[/code]
tu peux aussi mettre les deux “layouts” ensemble (en ne répètant pas les parties communes), il prendra le premier qu’il trouvera, sauf si tu lances X avec ‘startx --layout “Layout manuel avec config fine”’, auquel cas par exemple, il démarrera avec le layout “Screen manuel avec config fine”.
Tu remarqueras que les deux layouts utilisent le flgrx.
Enfin tout ça pour la comprehension, parcequ’il faudrait gèrer une éventuelle deuxiême tête (sur le DVI), et ne disposant que de nVidia, je ne sais pas comment on fait du multihead avec une ATI.
