[RESOLU]
Bonsoir,
Sur une fraîche install wheezy (crunch) sur une machine toute neuve j 'ai un soucis avec apcusd:
/etc/init.d/apcupsd status
lsusb
vim /etc/network/interfaces
[code]# This file describes the network interfaces available on your system
auto lo
iface lo inet loopback
#pour le wakeonlan-4:
WOL=1[/code]
vim /etc/default/apcupsd
[code]# Defaults for apcupsd initscript
Apcupsd-devel internal configuration
APCACCESS=/sbin/apcaccess
ISCONFIGURED=yes[/code]
[quote]## apcupsd.conf v1.1 ##
for apcupsd release 3.14.6 (16 May 2009) - debian
“apcupsd” POSIX config file
========= General configuration parameters ============
UPSNAME xxx
Use this to give your UPS a name in log files and such. This
is particulary useful if you have multiple UPSes. This does not
set the EEPROM. It should be 8 characters or less.
UPSNAME Eaton-800
UPSCABLE
Defines the type of cable connecting the UPS to your computer.
Possible generic choices for are:
simple, smart, ether, usb
Or a specific cable model number may be used:
940-0119A, 940-0127A, 940-0128A, 940-0020B,
940-0020C, 940-0023A, 940-0024B, 940-0024C,
940-1524C, 940-0024G, 940-0095A, 940-0095B,
940-0095C, M-04-02-2000
UPSCABLE usb
To get apcupsd to work, in addition to defining the cable
above, you must also define a UPSTYPE, which corresponds to
the type of UPS you have (see the Description for more details).
You must also specify a DEVICE, sometimes referred to as a port.
For USB UPSes, please leave the DEVICE directive blank. For
other UPS types, you must specify an appropriate port or address.
UPSTYPE DEVICE Description
apcsmart /dev/tty** Newer serial character device,
appropriate for SmartUPS models using
a serial cable (not USB).
usb Most new UPSes are USB. A blank DEVICE
setting enables autodetection, which is
the best choice for most installations.
net hostname:port Network link to a master apcupsd
through apcupsd’s Network Information
Server. This is used if you don’t have
a UPS directly connected to your computer.
snmp hostname:port:vendor:community
SNMP Network link to an SNMP-enabled
UPS device. Vendor is the MIB used by
the UPS device: can be “APC”, “APC_NOTRAP”
or “RFC” where APC is the powernet MIB,
“APC_NOTRAP” is powernet with SNMP trap
catching disabled, and RFC is the IETF’s
rfc1628 UPS-MIB. You usually want “APC”.
Port is usually 161. Community is usually
“private”.
dumb /dev/tty** Old serial character device for use
with simple-signaling UPSes.
pcnet ipaddr:username:passphrase
PowerChute Network Shutdown protocol
which can be used as an alternative to SNMP
with AP9617 family of smart slot cards.
ipaddr is the IP address of the UPS mgmt
card. username and passphrase are the
credentials for which the card has been
configured.
UPSTYPE usb
DEVICE /dev/ttyS0
DEVICE
POLLTIME
Interval (in seconds) at which apcupsd polls the UPS for status. This
setting applies both to directly-attached UPSes (UPSTYPE apcsmart, usb,
dumb) and networked UPSes (UPSTYPE net, snmp). Lowering this setting
will improve apcupsd’s responsiveness to certain events at the cost of
higher CPU utilization. The default of 60 is appropriate for most
situations.
#POLLTIME 60
LOCKFILE
Path for device lock file. Not used on Win32.
LOCKFILE /var/lock
SCRIPTDIR
Directory in which apccontrol and event scripts are located.
SCRIPTDIR /etc/apcupsd
PWRFAILDIR
Directory in which to write the powerfail flag file. This file
is created when apcupsd initiates a system shutdown and is
checked in the OS halt scripts to determine if a killpower
(turning off UPS output power) is required.
PWRFAILDIR /etc/apcupsd
NOLOGINDIR
Directory in which to write the nologin file. The existence
of this flag file tells the OS to disallow new logins.
NOLOGINDIR /etc
======== Configuration parameters used during power failures ==========
The ONBATTERYDELAY is the time in seconds from when a power failure
is detected until we react to it with an onbattery event.
This means that, apccontrol will be called with the powerout argument
immediately when a power failure is detected. However, the
onbattery argument is passed to apccontrol only after the
ONBATTERYDELAY time. If you don’t want to be annoyed by short
powerfailures, make sure that apccontrol powerout does nothing
i.e. comment out the wall.
ONBATTERYDELAY 6
Note: BATTERYLEVEL, MINUTES, and TIMEOUT work in conjunction, so
the first that occurs will cause the initation of a shutdown.
If during a power failure, the remaining battery percentage
(as reported by the UPS) is below or equal to BATTERYLEVEL,
apcupsd will initiate a system shutdown.
BATTERYLEVEL 5
If during a power failure, the remaining runtime in minutes
(as calculated internally by the UPS) is below or equal to MINUTES,
apcupsd, will initiate a system shutdown.
MINUTES 3
If during a power failure, the UPS has run on batteries for TIMEOUT
many seconds or longer, apcupsd will initiate a system shutdown.
A value of 0 disables this timer.
Note, if you have a Smart UPS, you will most likely want to disable
this timer by setting it to zero. That way, you UPS will continue
on batteries until either the % charge remaing drops to or below BATTERYLEVEL,
or the remaining battery runtime drops to or below MINUTES. Of course,
if you are testing, setting this to 60 causes a quick system shutdown
if you pull the power plug.
If you have an older dumb UPS, you will want to set this to less than
the time you know you can run on batteries.
TIMEOUT 0
Time in seconds between annoying users to signoff prior to
system shutdown. 0 disables.
ANNOY 300
Initial delay after power failure before warning users to get
off the system.
ANNOYDELAY 60
The condition which determines when users are prevented from
logging in during a power failure.
NOLOGON [ disable | timeout | percent | minutes | always ]
NOLOGON disable
If KILLDELAY is non-zero, apcupsd will continue running after a
shutdown has been requested, and after the specified time in
seconds attempt to kill the power. This is for use on systems
where apcupsd cannot regain control after a shutdown.
KILLDELAY 0 disables
KILLDELAY 0
==== Configuration statements for Network Information Server ====
NETSERVER [ on | off ] on enables, off disables the network
information server. If netstatus is on, a network information
server process will be started for serving the STATUS and
EVENT data over the network (used by CGI programs).
NETSERVER on
NISIP
IP address on which NIS server will listen for incoming connections.
This is useful if your server is multi-homed (has more than one
network interface and IP address). Default value is 0.0.0.0 which
means any incoming request will be serviced. Alternatively, you can
configure this setting to any specific IP address of your server and
NIS will listen for connections only on that interface. Use the
loopback address (127.0.0.1) to accept connections only from the
local machine.
NISIP 127.0.0.1
NISPORT default is 3551 as registered with the IANA
port to use for sending STATUS and EVENTS data over the network.
It is not used unless NETSERVER is on. If you change this port,
you will need to change the corresponding value in the cgi directory
and rebuild the cgi programs.
NISPORT 3551
If you want the last few EVENTS to be available over the network
by the network information server, you must define an EVENTSFILE.
EVENTSFILE /var/log/apcupsd.events
EVENTSFILEMAX
By default, the size of the EVENTSFILE will be not be allowed to exceed
10 kilobytes. When the file grows beyond this limit, older EVENTS will
be removed from the beginning of the file (first in first out). The
parameter EVENTSFILEMAX can be set to a different kilobyte value, or set
to zero to allow the EVENTSFILE to grow without limit.
EVENTSFILEMAX 10
========== Configuration statements used if sharing =============
a UPS with more than one machine
Remaining items are for ShareUPS (APC expansion card) ONLY
UPSCLASS [ standalone | shareslave | sharemaster ]
Normally standalone unless you share an UPS using an APC ShareUPS
card.
UPSCLASS standalone
UPSMODE [ disable | share ]
Normally disable unless you share an UPS using an APC ShareUPS card.
UPSMODE disable
===== Configuration statements to control apcupsd system logging ========
Time interval in seconds between writing the STATUS file; 0 disables
STATTIME 0
Location of STATUS file (written to only if STATTIME is non-zero)
STATFILE /var/log/apcupsd.status
LOGSTATS [ on | off ] on enables, off disables
Note! This generates a lot of output, so if
you turn this on, be sure that the
file defined in syslog.conf for LOG_NOTICE is a named pipe.
You probably do not want this on.
LOGSTATS off
Time interval in seconds between writing the DATA records to
the log file. 0 disables.
DATATIME 0
FACILITY defines the logging facility (class) for logging to syslog.
If not specified, it defaults to “daemon”. This is useful
if you want to separate the data logged by apcupsd from other
programs.
#FACILITY DAEMON
========== Configuration statements used in updating the UPS EPROM =========
These statements are used only by apctest when choosing "Set EEPROM with conf
file values" from the EEPROM menu. THESE STATEMENTS HAVE NO EFFECT ON APCUPSD.
UPS name, max 8 characters
#UPSNAME UPS_IDEN
Battery date - 8 characters
#BATTDATE mm/dd/yy
Sensitivity to line voltage quality (H cause faster transfer to batteries)
SENSITIVITY H M L (default = H)
#SENSITIVITY H
UPS delay after power return (seconds)
WAKEUP 000 060 180 300 (default = 0)
#WAKEUP 60
UPS Grace period after request to power off (seconds)
SLEEP 020 180 300 600 (default = 20)
#SLEEP 180
Low line voltage causing transfer to batteries
The permitted values depend on your model as defined by last letter
of FIRMWARE or APCMODEL. Some representative values are:
D 106 103 100 097
M 177 172 168 182
A 092 090 088 086
I 208 204 200 196 (default = 0 => not valid)
#LOTRANSFER 208
High line voltage causing transfer to batteries
D 127 130 133 136
M 229 234 239 224
A 108 110 112 114
I 253 257 261 265 (default = 0 => not valid)
#HITRANSFER 253
Battery charge needed to restore power
RETURNCHARGE 00 15 50 90 (default = 15)
#RETURNCHARGE 15
Alarm delay
0 = zero delay after pwr fail, T = power fail + 30 sec, L = low battery, N = never
BEEPSTATE 0 T L N (default = 0)
#BEEPSTATE T
Low battery warning delay in minutes
LOWBATT 02 05 07 10 (default = 02)
#LOWBATT 2
UPS Output voltage when running on batteries
D 115
M 208
A 100
I 230 240 220 225 (default = 0 => not valid)
#OUTPUTVOLTS 230
Self test interval in hours 336=2 weeks, 168=1 week, ON=at power on
SELFTEST 336 168 ON OFF (default = 336)
#SELFTEST 336[/quote]
Je ne vois pas d’où cela peut provenir! Pouvez vous m 'aider?
