bon, je viens de m’apercevoir que j’ai plus de son, problème récurrent s’il en est; aucune lecture de post ou google ne m’ayant apporté la solution, j’expose :
le matos et les modules :
debian:/home/jcode# lspci | grep AC; lsmod | grep -E 'snd|audio'
00:1f.5 Multimedia audio controller: Intel Corporation 82801EB/ER (ICH5/ICH5R) AC'97 Audio Controller (rev 02)
snd_intel8x0 32517 0
snd_ac97_codec 93561 1 snd_intel8x0
ac97_bus 2404 1 snd_ac97_codec
snd_pcm_oss 38511 0
snd_mixer_oss 16100 1 snd_pcm_oss
snd_pcm 65869 3 snd_intel8x0,snd_ac97_codec,snd_pcm_oss
snd_timer 21231 1 snd_pcm
snd 48922 6 snd_intel8x0,snd_ac97_codec,snd_pcm_oss,snd_mixer_oss,snd_pcm,snd_timer
snd_page_alloc 10025 2 snd_intel8x0,snd_pcm
des symptômes :
Bureau -> Préférences -> Sélecteur de systèmes multimédia -> onglet audio:
Greffon de sortie par défaut: alsa …
Greffon d’entrée par défaut: alsa … et idem !
alsaconf:
Running update-modules...
Loading driver...
Setting up ALSA...warning: 'alsactl restore' failed with error message 'alsactl: load_state:1327: No soundcards found...'
...Invalid card number.
Usage: amixer <options> [command]
Available options:
-h,--help this help
-c,--card N select the card
-D,--device N select the device, default 'default'
-d,--debug debug mode
-n,--nocheck do not perform range checking
-v,--version print version of this program
-q,--quiet be quiet
-i,--inactive show also inactive controls
-a,--abstract L select abstraction level (none or basic)
-s,--stdin Read and execute commands from stdin sequentially
Available commands:
scontrols show all mixer simple controls
scontents show contents of all mixer simple controls (default command)
sset sID P set contents for one mixer simple control
sget sID get contents for one mixer simple control
controls show all controls for given card
contents show contents of all controls for given card
cset cID P set control contents for one control
cget cID get control contents for one control
Est-ce qu’on pourrait résoudre ce fâcheux problème avec méthode s’il vous plait ?
et tu as du son avec certains noyaux .
