[RESOLU] au démarrage : IPv6 over IPv4 tunneling driver
Lors du démarrage de ma machine, j’ai ceci qui apparait :
Debian GNU/Linux 4.0 server tty1
server login : NET : Registered protocol family 10
lo: Disabled Privacy Extensions
Et il faut que j’appuie sur la touche <Entrée> pour avoir le prompt de connexion…
C’est normal ?
Ce serait ma Livebox qui ferait ca ? L’ordi avec Debian est branché dessus…
Une fois logger tu peux pinger l’exterieur ?
Et montre moi l’execution de ‘dmesg’
Pour le ping :
C’est normal que je dois l’arrêter à la main ?
[code]PING www.free.fr (212.27.48.10) 56(84) bytes of data.
64 bytes from 212.27.48.10: icmp_seq=1 ttl=119 time=50.9 ms
64 bytes from 212.27.48.10: icmp_seq=2 ttl=119 time=51.1 ms
64 bytes from 212.27.48.10: icmp_seq=3 ttl=119 time=50.2 ms
64 bytes from 212.27.48.10: icmp_seq=4 ttl=119 time=51.0 ms
64 bytes from 212.27.48.10: icmp_seq=5 ttl=119 time=51.3 ms
64 bytes from 212.27.48.10: icmp_seq=6 ttl=119 time=51.4 ms
64 bytes from 212.27.48.10: icmp_seq=7 ttl=119 time=51.1 ms
64 bytes from 212.27.48.10: icmp_seq=8 ttl=119 time=52.1 ms
64 bytes from 212.27.48.10: icmp_seq=9 ttl=119 time=50.8 ms
64 bytes from 212.27.48.10: icmp_seq=10 ttl=119 time=51.1 ms
64 bytes from 212.27.48.10: icmp_seq=11 ttl=119 time=51.0 ms
64 bytes from 212.27.48.10: icmp_seq=12 ttl=119 time=51.0 ms
www.free.fr ping statistics —
12 packets transmitted, 12 received, 0% packet loss, time 110582ms
rtt min/avg/max/mdev = 50.288/51.126/52.114/0.496 ms[/code]
Voici ce que “dmesg” donne :
Linux version 2.6.18-6-686 (Debian 2.6.18.dfsg.1-22) (dannf@debian.org) (gcc version 4.1.2 20061115 (prerelease) (Debian 4.1.1-21)) #1 SMP Tue Jun 17 21:31:27 UTC 2008 BIOS-provided physical RAM map: BIOS-e820: 0000000000000000 - 000000000009fc00 (usable) BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved) BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved) BIOS-e820: 0000000000100000 - 000000000fff0000 (usable) BIOS-e820: 000000000fff0000 - 000000000fff3000 (ACPI NVS) BIOS-e820: 000000000fff3000 - 0000000010000000 (ACPI data) BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved) BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved) BIOS-e820: 00000000ffff0000 - 0000000100000000 (reserved) 0MB HIGHMEM available. 255MB LOWMEM available. found SMP MP-table at 000f4960 On node 0 totalpages: 65520 DMA zone: 4096 pages, LIFO batch:0 Normal zone: 61424 pages, LIFO batch:15 DMI 2.3 present. ACPI: RSDP (v000 GBT ) @ 0x000f6220 ACPI: RSDT (v001 GBT AWRDACPI 0x42302e31 AWRD 0x01010101) @ 0x0fff3000 ACPI: FADT (v001 GBT AWRDACPI 0x42302e31 AWRD 0x01010101) @ 0x0fff3040 ACPI: MADT (v001 GBT AWRDACPI 0x42302e31 AWRD 0x01010101) @ 0x0fff68c0 ACPI: DSDT (v001 GBT AWRDACPI 0x00001000 MSFT 0x0100000c) @ 0x00000000 ACPI: PM-Timer IO Port: 0x4008 ACPI: Local APIC address 0xfee00000 ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled) Processor #0 6:6 APIC version 16 ACPI: LAPIC_NMI (acpi_id[0x00] dfl dfl lint[0x1]) ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0]) IOAPIC[0]: apic_id 2, version 3, address 0xfec00000, GSI 0-23 ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl) ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level) ACPI: IRQ0 used by override. ACPI: IRQ2 used by override. ACPI: IRQ9 used by override. Enabling APIC mode: Flat. Using 1 I/O APICs Using ACPI (MADT) for SMP configuration information Allocating PCI resources starting at 20000000 (gap: 10000000:eec00000) Detected 1666.805 MHz processor. Built 1 zonelists. Total pages: 65520 Kernel command line: root=/dev/hda1 ro mapped APIC to ffffd000 (fee00000) mapped IOAPIC to ffffc000 (fec00000) Enabling fast FPU save and restore... done. Enabling unmasked SIMD FPU exception support... done. Initializing CPU#0 PID hash table entries: 1024 (order: 10, 4096 bytes) Console: colour VGA+ 80x25 Dentry cache hash table entries: 32768 (order: 5, 131072 bytes) Inode-cache hash table entries: 16384 (order: 4, 65536 bytes) Memory: 252212k/262080k available (1541k kernel code, 9312k reserved, 580k data, 196k init, 0k highmem) Checking if this processor honours the WP bit even in supervisor mode... Ok. Calibrating delay using timer specific routine.. 3336.74 BogoMIPS (lpj=6673484) Security Framework v1.0.0 initialized SELinux: Disabled at boot. Capability LSM initialized Mount-cache hash table entries: 512 CPU: After generic identify, caps: 0383fbff c1c3fbff 00000000 00000000 00000000 00000000 00000000 CPU: After vendor identify, caps: 0383fbff c1c3fbff 00000000 00000000 00000000 00000000 00000000 CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line) CPU: L2 Cache: 256K (64 bytes/line) CPU: After all inits, caps: 0383fbff c1c3fbff 00000000 00000420 00000000 00000000 00000000 Intel machine check architecture supported. Intel machine check reporting enabled on CPU#0. Compat vDSO mapped to ffffe000. Checking 'hlt' instruction... OK. SMP alternatives: switching to UP code Freeing SMP alternatives: 12k freed ACPI: Core revision 20060707 CPU0: AMD Athlon(tm) XP 2000+ stepping 02 Total of 1 processors activated (3336.74 BogoMIPS). ENABLING IO-APIC IRQs ..TIMER: vector=0x31 apic1=0 pin1=2 apic2=-1 pin2=-1 Brought up 1 CPUs migration_cost=0 checking if image is initramfs... it is Freeing initrd memory: 4387k freed NET: Registered protocol family 16 ACPI: bus type pci registered PCI: PCI BIOS revision 2.10 entry at 0xf99a0, last bus=1 PCI: Using configuration type 1 Setting up standard PCI resources ACPI: Interpreter enabled ACPI: Using IOAPIC for interrupt routing ACPI: PCI Root Bridge [PCI0] (0000:00) PCI: Probing PCI hardware (bus 00) ACPI: Assume root bridge [\_SB_.PCI0] bus is 0 PCI quirk: region 4000-407f claimed by vt8235 PM PCI quirk: region 5000-500f claimed by vt8235 SMB Boot video device is 0000:01:00.0 ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT] ACPI: PCI Interrupt Link [LNKA] (IRQs 1 3 4 5 6 7 10 *11 12 14 15) ACPI: PCI Interrupt Link [LNKB] (IRQs 1 3 4 5 6 7 10 *11 12 14 15) ACPI: PCI Interrupt Link [LNKC] (IRQs 1 3 4 5 6 7 *10 11 12 14 15) ACPI: PCI Interrupt Link [LNKD] (IRQs 1 3 4 *5 6 7 10 11 12 14 15) ACPI: PCI Interrupt Link [ALKA] (IRQs 20) *0, disabled. ACPI: PCI Interrupt Link [ALKB] (IRQs 21) *0, disabled. ACPI: PCI Interrupt Link [ALKC] (IRQs 22) *0, disabled. ACPI: PCI Interrupt Link [ALKD] (IRQs 23) *0, disabled. Linux Plug and Play Support v0.97 (c) Adam Belay pnp: PnP ACPI init pnp: PnP ACPI: found 13 devices PnPBIOS: Disabled by ACPI PNP PCI: Using ACPI for IRQ routing PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report PCI: Bridge: 0000:00:01.0 IO window: disabled. MEM window: e0000000-e1ffffff PREFETCH window: d8000000-dfffffff PCI: Setting latency timer of device 0000:00:01.0 to 64 NET: Registered protocol family 2 IP route cache hash table entries: 2048 (order: 1, 8192 bytes) TCP established hash table entries: 8192 (order: 4, 65536 bytes) TCP bind hash table entries: 4096 (order: 3, 32768 bytes) TCP: Hash tables configured (established 8192 bind 4096) TCP reno registered audit: initializing netlink socket (disabled) audit(1217595942.884:1): initialized VFS: Disk quotas dquot_6.5.1 Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) Initializing Cryptographic API io scheduler noop registered io scheduler anticipatory registered io scheduler deadline registered io scheduler cfq registered (default) isapnp: Scanning for PnP cards... isapnp: No Plug & Play device found Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A 00:08: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A 00:09: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12 serio: i8042 AUX port at 0x60,0x64 irq 12 serio: i8042 KBD port at 0x60,0x64 irq 1 mice: PS/2 mouse device common for all mice TCP bic registered NET: Registered protocol family 1 NET: Registered protocol family 17 NET: Registered protocol family 8 NET: Registered protocol family 20 Using IPI No-Shortcut mode ACPI: (supports S0 S3 S4 S5) Freeing unused kernel memory: 196k freed Time: tsc clocksource has been installed. input: AT Translated Set 2 keyboard as /class/input/input0 ACPI: CPU0 (power states: C1[C1] C2[C2]) ACPI: Processor [CPU0] (supports 2 throttling states) 8139cp: 10/100 PCI Ethernet driver v1.2 (Mar 22, 2004) 8139cp 0000:00:0a.0: This (id 10ec:8139 rev 10) is not an 8139C+ compatible chip 8139cp 0000:00:0a.0: Try the "8139too" driver instead. 8139cp 0000:00:13.0: This (id 10ec:8139 rev 10) is not an 8139C+ compatible chip 8139cp 0000:00:13.0: Try the "8139too" driver instead. 8139too Fast Ethernet driver 0.9.27 ACPI: PCI Interrupt 0000:00:0a.0[A] -> GSI 18 (level, low) -> IRQ 169 eth0: RealTek RTL8139 at 0xd000, 00:08:54:43:60:f7, IRQ 169 eth0: Identified 8139 chip type 'RTL-8100B/8139D' ACPI: PCI Interrupt 0000:00:13.0[A] -> GSI 18 (level, low) -> IRQ 169 eth1: RealTek RTL8139 at 0xec00, 00:20:ed:47:01:f4, IRQ 169 eth1: Identified 8139 chip type 'RTL-8100B/8139D' usbcore: registered new driver usbfs usbcore: registered new driver hub USB Universal Host Controller Interface driver v3.0 ACPI: PCI Interrupt Link [ALKB] BIOS reported IRQ 0, using IRQ 21 ACPI: PCI Interrupt Link [ALKB] enabled at IRQ 21 ACPI: PCI Interrupt 0000:00:10.0[A] -> Link [ALKB] -> GSI 21 (level, low) -> IRQ 177 PCI: VIA IRQ fixup for 0000:00:10.0, from 11 to 1 uhci_hcd 0000:00:10.0: UHCI Host Controller uhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 1 uhci_hcd 0000:00:10.0: irq 177, io base 0x0000d400 usb usb1: configuration #1 chosen from 1 choice hub 1-0:1.0: USB hub found hub 1-0:1.0: 2 ports detected ACPI: PCI Interrupt 0000:00:10.1[B] -> Link [ALKB] -> GSI 21 (level, low) -> IRQ 177 PCI: VIA IRQ fixup for 0000:00:10.1, from 11 to 1 uhci_hcd 0000:00:10.1: UHCI Host Controller uhci_hcd 0000:00:10.1: new USB bus registered, assigned bus number 2 uhci_hcd 0000:00:10.1: irq 177, io base 0x0000d800 usb usb2: configuration #1 chosen from 1 choice hub 2-0:1.0: USB hub found hub 2-0:1.0: 2 ports detected Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2 ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx Time: acpi_pm clocksource has been installed. ACPI: PCI Interrupt 0000:00:10.2[C] -> Link [ALKB] -> GSI 21 (level, low) -> IRQ 177 PCI: VIA IRQ fixup for 0000:00:10.2, from 10 to 1 uhci_hcd 0000:00:10.2: UHCI Host Controller uhci_hcd 0000:00:10.2: new USB bus registered, assigned bus number 3 uhci_hcd 0000:00:10.2: irq 177, io base 0x0000dc00 usb usb3: configuration #1 chosen from 1 choice hub 3-0:1.0: USB hub found hub 3-0:1.0: 2 ports detected ACPI: PCI Interrupt 0000:00:10.3[D] -> Link [ALKB] -> GSI 21 (level, low) -> IRQ 177 PCI: VIA IRQ fixup for 0000:00:10.3, from 5 to 1 ehci_hcd 0000:00:10.3: EHCI Host Controller ehci_hcd 0000:00:10.3: new USB bus registered, assigned bus number 4 ehci_hcd 0000:00:10.3: irq 177, io mem 0xe2001000 ehci_hcd 0000:00:10.3: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004 usb usb4: configuration #1 chosen from 1 choice hub 4-0:1.0: USB hub found hub 4-0:1.0: 6 ports detected VP_IDE: IDE controller at PCI slot 0000:00:11.1 ACPI: PCI Interrupt Link [ALKA] BIOS reported IRQ 0, using IRQ 20 ACPI: PCI Interrupt Link [ALKA] enabled at IRQ 20 ACPI: PCI Interrupt 0000:00:11.1[A] -> Link [ALKA] -> GSI 20 (level, low) -> IRQ 185 PCI: VIA IRQ fixup for 0000:00:11.1, from 255 to 9 VP_IDE: chipset revision 6 VP_IDE: not 100% native mode: will probe irqs later VP_IDE: VIA vt8235 (rev 00) IDE UDMA133 controller on pci0000:00:11.1 ide0: BM-DMA at 0xe000-0xe007, BIOS settings: hda:DMA, hdb:pio ide1: BM-DMA at 0xe008-0xe00f, BIOS settings: hdc:DMA, hdd:DMA Probing IDE interface ide0... hda: WDC WD800BB-00CAA1, ATA DISK drive ide0 at 0x1f0-0x1f7,0x3f6 on irq 14 Probing IDE interface ide1... hdc: LITEON DVD-ROM LTD163, ATAPI CD/DVD-ROM drive hdd: LITE-ON DVDRW LH-20A1P, ATAPI CD/DVD-ROM drive ide1 at 0x170-0x177,0x376 on irq 15 hda: max request size: 128KiB hda: 156301488 sectors (80026 MB) w/2048KiB Cache, CHS=65535/16/63, UDMA(100) hda: cache flushes not supported hda: hda1 hda2 < hda5 hda6 hda7 hda8 hda9 > hdc: ATAPI 48X DVD-ROM drive, 512kB Cache, UDMA(33) Uniform CD-ROM driver Revision: 3.20 hdd: ATAPI 48X DVD-ROM DVD-R-RAM CD-R/RW drive, 2048kB Cache, UDMA(66) Attempting manual resume kjournald starting. Commit interval 5 seconds EXT3-fs: mounted filesystem with ordered data mode. Linux agpgart interface v0.101 (c) Dave Jones agpgart: Detected VIA KT400/KT400A/KT600 chipset agpgart: AGP aperture is 128M @ 0xd0000000 pci_hotplug: PCI Hot Plug PCI Core version: 0.5 shpchp: Standard Hot Plug PCI Controller Driver version: 0.4 input: PC Speaker as /class/input/input1 Real Time Clock Driver v1.12ac irda_init() NET: Registered protocol family 23 Floppy drive(s): fd0 is 1.44M FDC 0 is a post-1991 82077 ACPI: PCI Interrupt Link [ALKC] BIOS reported IRQ 0, using IRQ 22 ACPI: PCI Interrupt Link [ALKC] enabled at IRQ 22 ACPI: PCI Interrupt 0000:00:11.5[C] -> Link [ALKC] -> GSI 22 (level, low) -> IRQ 193 PCI: Setting latency timer of device 0000:00:11.5 to 64 parport: PnPBIOS parport detected. parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE,EPP] input: ImPS/2 Logitech Wheel Mouse as /class/input/input2 ts: Compaq touchscreen protocol output Adding 755012k swap on /dev/hda7. Priority:-1 extents:1 across:755012k EXT3 FS on hda1, internal journal loop: loaded (max 8 devices) device-mapper: ioctl: 4.7.0-ioctl (2006-06-24) initialised: dm-devel@redhat.com kjournald starting. Commit interval 5 seconds EXT3 FS on hda9, internal journal EXT3-fs: mounted filesystem with ordered data mode. kjournald starting. Commit interval 5 seconds EXT3 FS on hda8, internal journal EXT3-fs: mounted filesystem with ordered data mode. kjournald starting. Commit interval 5 seconds EXT3 FS on hda5, internal journal EXT3-fs: mounted filesystem with ordered data mode. kjournald starting. Commit interval 5 seconds EXT3 FS on hda6, internal journal EXT3-fs: mounted filesystem with ordered data mode. eth0: link up, 100Mbps, full-duplex, lpa 0x45E1 ACPI: Power Button (FF) [PWRF] ACPI: Power Button (CM) [PWRB] ACPI: Sleep Button (CM) [SLPB] NET: Registered protocol family 10 lo: Disabled Privacy Extensions IPv6 over IPv4 tunneling driver eth0: no IPv6 routers present
Merci :slightly_smiling:
[quote=“italiasky”]Pour le ping :
Oui sinon utilise l’option ‘-c’.
[quote=“italiasky”]Bonjour,
C’est normal ?
Ce serait ma Livebox qui ferait ca ? L’ordi avec Debian est branché dessus…[/quote]Oui. C’est 100% normal. C’est juste un message de démarrage qui s’affiche en console mais pour un truc qui vient s’afficher aprés l’invite “Login:”, parceque ça arrive aprés le login dans le boot. Tu peux regarder dans les autres consoles (alt+F2…F6), et tu verras la même invite, mais sans le message de console. Si quand tu arrives la, tu ne fais pas “entrée”, et que tu tapes directement ton login, il te demandera ton password.
Mais tout est normal.
Pour le ping, c’est pareil: c’est normal.
Pourquoi en afficherait il un nombre arbitraire donné (4 par exemple :wink: ) ?
Donc sous linux (c’est même peut être un élément de POSIX), le ping est continu, le ctrl+Pause/Attn (<=>ctrl+break) te donne les statistiques intermédiaires et repart en continu, et le ping ne s’arrète définitivement que quand il reçoit un signal d’arret (et il te redonne les stats).
oki merci :slightly_smiling:
