hello
j’ai installé le noyau 2.6.9 sur ma debian sid mais il m’est imposible d’utiliser azureus, en fait je le lance, il demmare puis il check les fichiers en telechargement puis au moment ou il commence a telecharger il se coupe, et j’ai un long message dans la console, j’ai essayé de reinstaller j2re mais rien n’y fait…; il fonctionne uniquement quand je suis en noyau 2.4
si vous avez une idée… c’est assez embetant
merci
voila le message :
[quote]An unexpected exception has been detected in native code outside the VM.
Unexpected Signal : 11 occurred at PC=0x403F404
Function=
Library=(N/A)
NOTE: We are unable to locate the function name symbol for the error
just occurred. Please refer to release documentation for possible
reason and solutions.
Current Java thread:
at sun.nio.ch.NativeThread.signal(Native Method)
at sun.nio.ch.SocketChannelImpl.implCloseSelectableChannel(SocketChannelImpl.java:627)
- locked <0xa7eadb98> (a java.lang.Object)
at java.nio.channels.spi.AbstractSelectableChannel.implCloseChannel(AbstractSelectableChannel.java:202)
at java.nio.channels.spi.AbstractInterruptibleChannel.close(AbstractInterruptibleCh annel.java:97) - locked <0xa7eadb70> (a java.lang.Object)
at sun.nio.ch.SocketChannelImpl.finishConnect(SocketChannelImpl.java:550) - locked <0xa7eadb90> (a java.lang.Object)
- locked <0xa7eadb88> (a java.lang.Object)
at com.aelitis.azureus.core.networkmanager.ConnectDisconnectManager$3.selectSuccess(ConnectDisconnectManager.java:140)
at com.aelitis.azureus.core.networkmanager.VirtualChannelSelector.select(VirtualCha nnelSelector.java:176)
at com.aelitis.azureus.core.networkmanager.ConnectDisconnectManager.runSelect(Conne ctDisconnectManager.java:300)
at com.aelitis.azureus.core.networkmanager.ConnectDisconnectManager.mainLoop(Connec tDisconnectManager.java:92)
at com.aelitis.azureus.core.networkmanager.ConnectDisconnectManager.access$4(Connec tDisconnectManager.java:89)
at com.aelitis.azureus.core.networkmanager.ConnectDisconnectManager$2.runSupport(Co nnectDisconnectManager.java:81)
at org.gudy.azureus2.core3.util.AEThread.run(AEThread.java:45)
Dynamic libraries:
08048000-0804d000 r-xp 00000000 03:43 1783061 /usr/lib/j2se/1.4/bin/java
0804d000-0804e000 rwxp 00004000 03:43 1783061 /usr/lib/j2se/1.4/bin/java
a611b000-a617b000 rwxs 00000000 00:06 1409027 /SYSV00000000 (deleted)
a617b000-a618b000 r-xp 00000000 03:43 2125784 /usr/share/fonts/truetype/ttf-bitstream-vera/VeraBI.ttf
a618b000-a619b000 r-xp 00000000 03:43 2125785 /usr/share/fonts/truetype/ttf-bitstream-vera/VeraIt.ttf
a641b000-a642a000 r-xp 00000000 03:43 2665437 /lib/tls/libresolv-2.3.2.so
a642a000-a642b000 rwxp 0000f000 03:43 2665437 /lib/tls/libresolv-2.3.2.so
a642d000-a6430000 r-xp 00000000 03:43 2665430 /lib/tls/libnss_dns-2.3.2.so
a6430000-a6431000 rwxp 00003000 03:43 2665430 /lib/tls/libnss_dns-2.3.2.so
a6431000-a6440000 r-xp 00000000 03:43 2125783 /usr/share/fonts/truetype/ttf-bitstream-vera/VeraBd.ttf
a65c0000-a65f6000 r-xs 00000000 03:43 344093 /home/boomslang/azureus/plugins/azplugins/azplugins_0.8.7.jar
a68f6000-a68fb000 r-xp 00000000 03:43 114 /usr/lib/j2se/1.4/jre/lib/i386/libnio.so
a68fb000-a68fc000 rwxp 00004000 03:43 114 /usr/lib/j2se/1.4/jre/lib/i386/libnio.so
a6afc000-a6afe000 r-xp 00000000 03:43 1716990 /usr/lib/pango/1.4.0/modules/pango-basic-fc.so
a6afe000-a6aff000 rwxp 00001000 03:43 1716990 /usr/lib/pango/1.4.0/modules/pango-basic-fc.so
a6aff000-a6b10000 r-xp 00000000 03:43 2125792 /usr/share/fonts/truetype/ttf-bitstream-vera/Vera.ttf
a6b10000-a6b12000 r-xp 00000000 03:43 16684 /usr/lib/gconv/ISO8859-15.so
a6b12000-a6b13000 rwxp 00001000 03:43 16684 /usr/lib/gconv/ISO8859-15.so
a6b13000-a6b30000 r-xp 00000000 03:43 1733314 /usr/share/locale/fr/LC_MESSAGES/libc.mo
a6b30000-a6b90000 rwxs 00000000 00:06 1376258 /SYSV00000000 (deleted)
a6c10000-a6c36000 r-xp 00000000 03:43 344084 /home/boomslang/azureus/libswt-gtk-3106.so
a6c36000-a6c38000 rwxp 00026000 03:43 344084 /home/boomslang/azureus/libswt-gtk-3106.so
a6c38000-a6c3a000 r-xp 00000000 03:43 16679 /usr/lib/gconv/ISO8859-1.so
a6c3a000-a6c3b000 rwxp 00001000 03:43 16679 /usr/lib/gconv/ISO8859-1.so
a6c3b000-a6c54000 r-xp 00000000 03:43 1733356 /usr/share/locale/fr/LC_MESSAGES/gtk20-properties.mo
a6c54000-a6c71000 r-xp 00000000 03:43 572331 /usr/lib/libexpat.so.1.0.0
a6c71000-a6c74000 rwxp 0001d000 03:43 572331 /usr/lib/libexpat.so.1.0.0
a6c74000-a6c98000 r-xp 00000000 03:43 572500 /usr/lib/libpangoft2-1.0.so.0.400.1
a6c98000-a6c99000 rwxp 00024000 03:43 572500 /usr/lib/libpangoft2-1.0.so.0.400.1
a6c99000-a6ca0000 r-xp 00000000 03:43 572422 /usr/lib/libXrender.so.1.2.2
a6ca0000-a6ca1000 rwxp 00006000 03:43 572422 /usr/lib/libXrender.so.1.2.2
a6ca1000-a6ca9000 r-xp 00000000 03:43 572507 /usr/lib/libXcursor.so.1.0.2
a6ca9000-a6caa000 rwxp 00007000 03:43 572507 /usr/lib/libXcursor.so.1.0.2
a6caa000-a6ccd000 r-xp 00000000 03:43 572355 /usr/lib/libfontconfig.so.1.0.4
a6ccd000-a6cd0000 rwxp 00023000 03:43 572355 /usr/lib/libfontconfig.so.1.0.4
a6cd1000-a6ce2000 r-xp 00000000 03:43 573476 /usr/lib/libz.so.1.2.2
a6ce2000-a6ce3000 rwxp 00010000 03:43 573476 /usr/lib/libz.so.1.2.2
a6ce3000-a6d49000 r-xp 00000000 03:43 572334 /usr/lib/libfreetype.so.6.3.5
a6d49000-a6d50000 rwxp 00066000 03:43 572334 /usr/lib/libfreetype.so.6.3.5
a6d50000-a6d61000 r-xp 00000000 03:43 572497 /usr/lib/libXft.so.2.1.1
a6d61000-a6d62000 rwxp 00011000 03:43 572497 /usr/lib/libXft.so.2.1.1
a6d62000-a6d6f000 r-xp 00000000 03:43 2322092 /usr/X11R6/lib/libXext.so.6.4
a6d6f000-a6d70000 rwxp 0000c000 03:43 2322092 /usr/X11R6/lib/libXext.so.6.4
a6d70000-a6d77000 r-xp 00000000 03:43 2322096 /usr/X11R6/lib/libXi.so.6.0
a6d77000-a6d78000 rwxp 00006000 03:43 2322096 /usr/X11R6/lib/libXi.so.6.0
a6d78000-a6d7b000 r-xp 00000000 03:43 2322108 /usr/X11R6/lib/libXrandr.so.2.0
a6d7b000-a6d7c000 rwxp 00002000 03:43 2322108 /usr/X11R6/lib/libXrandr.so.2.0
a6d7c000-a6e40000 r-xp 00000000 03:43 2322086 /usr/X11R6/lib/libX11.so.6.2
a6e40000-a6e43000 rwxp 000c4000 03:43 2322086 /usr/X11R6/lib/libX11.so.6.2
a6e43000-a6e47000 r-xp 00000000 03:43 2322112 /usr/X11R6/lib/libXtst.so.6.1
a6e47000-a6e48000 rwxp 00004000 03:43 2322112 /usr/X11R6/lib/libXtst.so.6.1
a6e48000-a6ec6000 r-xp 00000000 03:43 572475 /usr/lib/libglib-2.0.so.0.400.7
a6ec6000-a6ec7000 rwxp 0007e000 03:43 572475 /usr/lib/libglib-2.0.so.0.400.7
a6ec7000-a6eca000 r-xp 00000000 03:43 572478 /usr/lib/libgmodule-2.0.so.0.400.7
a6eca000-a6ecb000 rwxp 00002000 03:43 572478 /usr/lib/libgmodule-2.0.so.0.400.7
a6ecb000-a6f03000 r-xp 00000000 03:43 572477 /usr/lib/libgobject-2.0.so.0.400.7
a6f03000-a6f04000 rwxp 00037000 03:43 572477 /usr/lib/libgobject-2.0.so.0.400.7
a6f05000-a6f35000 r-xp 00000000 03:43 572501 /usr/lib/libpango-1.0.so.0.400.1
a6f35000-a6f3a000 rwxp 0002f000 03:43 572501 /usr/lib/libpango-1.0.so.0.400.1
a6f3a000-a6f45000 r-xp 00000000 03:43 572502 /usr/lib/libpangox-1.0.so.0.400.1
a6f45000-a6f46000 rwxp 0000a000 03:43 572502 /usr/lib/libpangox-1.0.so.0.400.1
a6f46000-a6f4a000 r-xp 00000000 03:43 572499 /usr/lib/libpangoxft-1.0.so.0.400.1
a6f4a000-a6f4b000 rwxp 00003000 03:43 572499 /usr/lib/libpangoxft-1.0.so.0.400.1
a6f4b000-a6f60000 r-xp 00000000 03:43 572509 /usr/lib/libgdk_pixbuf-2.0.so.0.400.13
a6f60000-a6f61000 rwxp 00014000 03:43 572509 /usr/lib/libgdk_pixbuf-2.0.so.0.400.13
a6f61000-a6f7a000 r-xp 00000000 03:43 572483 /usr/lib/libatk-1.0.so.0.600.1
a6f7a000-a6f7c000 rwxp 00018000 03:43 572483 /usr/lib/libatk-1.0.so.0.600.1
a6f7c000-a6fe8000 r-xp 00000000 03:43 572510 /usr/lib/libgdk-x11-2.0.so.0.400.13
a6fe8000-a6fed000 rwxp 0006c000 03:43 572510 /usr/lib/libgdk-x11-2.0.so.0.400.13
a6fed000-a72b7000 r-xp 00000000 03:43 572511 /usr/lib/libgtk-x11-2.0.so.0.400.13
a72b7000-a72c1000 rwxp 002c9000 03:43 572511 /usr/lib/libgtk-x11-2.0.so.0.400.13
a72c6000-a72d0000 r-xp 00000000 03:43 1733355 /usr/share/locale/fr/LC_MESSAGES/gtk20.mo
a72d0000-a72d2000 r-xp 00000000 03:43 1995001 /usr/X11R6/lib/X11/locale/lib/common/xlcDef.so.2
a72d2000-a72d3000 rwxp 00001000 03:43 1995001 /usr/X11R6/lib/X11/locale/lib/common/xlcDef.so.2
a72d3000-a730e000 r-xp 00000000 03:43 344087 /home/boomslang/azureus/libswt-pi-gtk-3106.so
a730e000-a730f000 rwxp 0003b000 03:43 344087 /home/boomslang/azureus/libswt-pi-gtk-3106.so
a7390000-a73a2000 r-xp 00000000 03:43 113 /usr/lib/j2se/1.4/jre/lib/i386/libnet.so
a73a2000-a73a3000 rwxp 00011000 03:43 113 /usr/lib/j2se/1.4/jre/lib/i386/libnet.so
a73a3000-a73b7000 r-xs 00000000 03:43 344091 /home/boomslang/azureus/swt-mozilla.jar
a7437000-a7445000 r-xs 00000000 03:43 344092 /home/boomslang/azureus/swt-pi.jar
a7445000-a752a000 r-xs 00000000 03:43 344089 /home/boomslang/azureus/swt.jar
a752a000-a78d9000 r-xs 00000000 03:43 344073 /home/boomslang/azureus/Azureus2.jar
a78d9000-a7978000 r-xs 00000000 03:43 1292409 /usr/lib/j2se/1.4/jre/lib/ext/localedata.jar
a7978000-a797b000 r-xs 00000000 03:43 1292408 /usr/lib/j2se/1.4/jre/lib/ext/dnsns.jar
a797b000-a7998000 r-xs 00000000 03:43 1292407 /usr/lib/j2se/1.4/jre/lib/ext/sunjce_provider.jar
a7b98000-a7ba1000 r-xp 00000000 03:43 2665431 /lib/tls/libnss_files-2.3.2.so
a7ba1000-a7ba2000 rwxp 00008000 03:43 2665431 /lib/tls/libnss_files-2.3.2.so
a7ba2000-a7bab000 r-xp 00000000 03:43 2665433 /lib/tls/libnss_nis-2.3.2.so
a7bab000-a7bac000 rwxp 00008000 03:43 2665433 /lib/tls/libnss_nis-2.3.2.so
a7bac000-a7bb3000 r-xp 00000000 03:43 2665429 /lib/tls/libnss_compat-2.3.2.so
a7bb3000-a7bb4000 rwxp 00007000 03:43 2665429 /lib/tls/libnss_compat-2.3.2.so
a7bb4000-a7bb5000 r-xs 00000000 03:43 344095 /home/boomslang/azureus/plugins/azupdater/azupdaterpatcher_1.5.7.jar
a7bb5000-a7bc3000 r-xs 00000000 03:43 1292410 /usr/lib/j2se/1.4/jre/lib/ext/ldapsec.jar
a7bc3000-a7c12000 r-xp 00000000 03:43 1260321 /usr/lib/locale/locale-archive
b3e58000-b3e59000 r-xp 00000000 03:43 1455343 /usr/lib/gtk-2.0/2.4.0/immodules/im-cedilla.so
b3e59000-b3e5a000 rwxp 00000000 03:43 1455343 /usr/lib/gtk-2.0/2.4.0/immodules/im-cedilla.so
b5f02000-b61be000 r-xs 00000000 03:43 136 /usr/lib/j2se/1.4/jre/lib/charsets.jar
b61be000-b61d1000 r-xs 00000000 03:43 132 /usr/lib/j2se/1.4/jre/lib/jce.jar
b61d1000-b6242000 r-xs 00000000 03:43 133 /usr/lib/j2se/1.4/jre/lib/jsse.jar
b6242000-b6259000 r-xs 00000000 03:43 131 /usr/lib/j2se/1.4/jre/lib/sunrsasign.jar
b629c000-b7969000 r-xs 00000000 03:43 138 /usr/lib/j2se/1.4/jre/lib/rt.jar
b7969000-b797e000 r-xp 00000000 03:43 110 /usr/lib/j2se/1.4/jre/lib/i386/libzip.so
b797e000-b7981000 rwxp 00014000 03:43 110 /usr/lib/j2se/1.4/jre/lib/i386/libzip.so
b7981000-b79a0000 r-xp 00000000 03:43 108 /usr/lib/j2se/1.4/jre/lib/i386/libjava.so
b79a0000-b79a2000 rwxp 0001e000 03:43 108 /usr/lib/j2se/1.4/jre/lib/i386/libjava.so
b79a2000-b79b1000 r-xp 00000000 03:43 107 /usr/lib/j2se/1.4/jre/lib/i386/libverify.so
b79b1000-b79b3000 rwxp 0000e000 03:43 107 /usr/lib/j2se/1.4/jre/lib/i386/libverify.so
b79b3000-b79d5000 r-xp 00000000 03:43 2665426 /lib/tls/libm-2.3.2.so
b79d5000-b79d6000 rwxp 00022000 03:43 2665426 /lib/tls/libm-2.3.2.so
b79d6000-b79e8000 r-xp 00000000 03:43 2665428 /lib/tls/libnsl-2.3.2.so
b79e8000-b79e9000 rwxp 00011000 03:43 2665428 /lib/tls/libnsl-2.3.2.so
b79ef000-b79f8000 r-xp 00000000 03:43 102 /usr/lib/j2se/1.4/jre/lib/i386/native_threads/libhpi.so
b79f8000-b79f9000 —p 00009000 03:43 102 /usr/lib/j2se/1.4/jre/lib/i386/native_threads/libhpi.so
b79f9000-b79fa000 rwxp 00009000 03:43 102 /usr/lib/j2se/1.4/jre/lib/i386/native_threads/libhpi.so
b79fa000-b7e5e000 r-xp 00000000 03:43 1913856 /usr/lib/j2se/1.4/jre/lib/i386/client/libjvm.so
b7e5e000-b7e7b000 rwxp 00463000 03:43 1913856 /usr/lib/j2se/1.4/jre/lib/i386/client/libjvm.so
b7e8c000-b7fbc000 r-xp 00000000 03:43 2665423 /lib/tls/libc-2.3.2.so
b7fbc000-b7fc5000 rwxp 0012f000 03:43 2665423 /lib/tls/libc-2.3.2.so
b7fc7000-b7fc9000 r-xp 00000000 03:43 2665425 /lib/tls/libdl-2.3.2.so
b7fc9000-b7fca000 rwxp 00001000 03:43 2665425 /lib/tls/libdl-2.3.2.so
b7fcb000-b7fd7000 r-xp 00000000 03:43 2665436 /lib/tls/libpthread-0.60.so
b7fd7000-b7fd8000 rwxp 0000c000 03:43 2665436 /lib/tls/libpthread-0.60.so
b7fea000-b8000000 r-xp 00000000 03:43 719573 /lib/ld-2.3.2.so [/quote]
… peut etre en utilisant une autre VM…
comme il n’est pas dispo sur les ftp debian, j’ai été le cherché sur les ftp java-sun en .bin, mais il me cree un dossier la ou je le decompresse … comment l’installer ?
