hello
J’ ai bien un paquet nommé gxset…
“xset b on ne” ne me renvoie rien…
…xset donne:
[code]inox@toystory:~$ su
Mot de passe :
toystory:/home/inox# xset
usage: xset [-display host:dpy] option …
To turn bell off:
-b b off b 0
To set bell volume, pitch and duration:
b [vol [pitch [dur]]] b on
To disable bug compatibility mode:
-bc
To enable bug compatibility mode:
bc
To turn keyclick off:
-c c off c 0
To set keyclick volume:
c [0-100] c on
To control Energy Star (DPMS) features:
-dpms Energy Star features off
+dpms Energy Star features on
dpms [standby [suspend [off]]]
force standby
force suspend
force off
force on
(also implicitly enables DPMS features)
a timeout value of zero disables the mode
To set the font path:
fp= path[,path…]
To restore the default font path:
fp default
To have the server reread font databases:
fp rehash
To remove elements from font path:
-fp path[,path…] fp- path[,path…]
To prepend or append elements to font path:
+fp path[,path…] fp+ path[,path…]
To set LED states off or on:
-led [1-32] led off
led [1-32] led on
To set mouse acceleration and threshold:
m [acc_mult[/acc_div] [thr]] m default
To set pixel colors:
p pixel_value color_name
To turn auto-repeat off or on:
-r [keycode] r off
r [keycode] r on
r rate [delay [rate]]
For screen-saver control:
s [timeout [cycle]] s default s on
s blank s noblank s off
s expose s noexpose
s activate s reset
For status information: q
