Bonjour, je “subis” depuis peu, un bug aparu dans mon syslog que je n’arrive pas a comprendre/definir.
Paquets installés :
[quote]
dpkg -l | grep apache
rc apache 1.3.34-4.1 versatile, high-performance HTTP server
rc apache-common 1.3.34-4.1 support files for all Apache webservers
ii apache2 2.2.3-4+etch3 Next generation, scalable, extendable web se
ii apache2-mpm-prefork 2.2.3-4+etch3 Traditional model for Apache HTTPD 2.1
ii apache2-utils 2.2.3-4+etch3 utility programs for webservers
ii apache2.2-common 2.2.3-4+etch3 Next generation, scalable, extendable web se
ii libapache2-mod-php5 5.2.0-8+etch10 server-side, HTML-embedded scripting languag[/quote]
Je suis actuellement sur une dedibox, 2.6.24.2dedibox-r8-1-c7 (debian etch)
Mar 14 19:31:46 sd-3754 kernel: iret exception: 0000 [#27 ]
Mar 14 19:31:46 sd-3754 kernel: Modules linked in: ipt_LOG xt_state iptable_nat nf_nat nf_conntrack_ipv4 nf_conntrack iptable_mangle xt_tcpudp iptable_filter ip_tables x_tables uhci_hcd i2c_viapro i2c_core
Mar 14 19:31:46 sd-3754 kernel: Pid: 28166, comm: apache2 Tainted: G D (2.6.24.2dedibox-r8-1-c7 #1 )
Mar 14 19:31:46 sd-3754 kernel: EIP: 0199:[] EFLAGS: 00210246 CPU: 0
Mar 14 19:31:46 sd-3754 kernel: EIP is at iret_exc+0x67b/0x8a9
Mar 14 19:31:46 sd-3754 kernel: EAX: 00000000 EBX: 0820cea0 ECX: 00000060 EDX: df704000
Mar 14 19:31:46 sd-3754 kernel: ESI: df704703 EDI: 0820c978 EBP: db609ea8 ESP: db609e08
Mar 14 19:31:46 sd-3754 kernel: DS: 007b ES: 007b FS: 0000 GS: 0033 SS: 0068
Mar 14 19:31:46 sd-3754 kernel: Process apache2 (pid: 28166, ti=db608000 task=f7507a90 task.ti=db608000)
Mar 14 19:31:46 sd-3754 kernel: Stack: df704000 00000c2b c0144671 00000000 c13ee080 00000c2b 00000000 c13ee080
Mar 14 19:31:46 sd-3754 kernel: 00008ecb c8c12858 c0145e2a 00001000 00003612 f7be7e40 08ec9ceb 00000000
Mar 14 19:31:46 sd-3754 kernel: c01445a0 db609ea8 db609f20 f75c6dc0 f75c6e04 c8c127c0 00008ecc 00008eca
Mar 14 19:31:46 sd-3754 kernel: Call Trace:
Mar 14 19:31:46 sd-3754 kernel: [] file_read_actor+0xd1/0x110
Mar 14 19:31:46 sd-3754 kernel: [] do_generic_mapping_read+0x1ca/0x410
Mar 14 19:31:46 sd-3754 kernel: [] file_read_actor+0x0/0x110
Mar 14 19:31:46 sd-3754 kernel: [] generic_file_aio_read+0xe4/0x1d0
Mar 14 19:31:46 sd-3754 kernel: [] do_sync_read+0xc6/0x130
Mar 14 19:31:46 sd-3754 kernel: [] autoremove_wake_function+0x0/0x50
Mar 14 19:31:46 sd-3754 kernel: [] sock_aio_write+0x0/0x120
Mar 14 19:31:46 sd-3754 kernel: [] vfs_read+0xa1/0x130
Mar 14 19:31:46 sd-3754 kernel: [] vfs_llseek+0x3c/0x50
Mar 14 19:31:46 sd-3754 kernel: [] do_sync_read+0x0/0x130
Mar 14 19:31:46 sd-3754 kernel: [] sys_read+0x41/0x70
Mar 14 19:31:46 sd-3754 kernel: [] syscall_call+0x7/0xb
Mar 14 19:31:46 sd-3754 kernel: =======================
Mar 14 19:31:46 sd-3754 kernel: Code: f7 c4 ea ff ba f2 ff ff ff e9 3d c5 ea ff 8d 0c 8b e9 7c c5 ea ff 31 c0 e9 c5 c5 ea ff b0 01 e9 be c5 ea ff 01 c1 e9 12 c6 ea ff <8d> 0c 88 e9 0a c6 ea ff 01 c1 eb 03 8d 0c 88 51 50 31 c0 f3 aa
Mar 14 19:31:46 sd-3754 kernel: EIP: [] iret_exc+0x67b/0x8a9 SS:ESP 0068:db609e08
Mar 14 19:31:46 sd-3754 kernel: —[ end trace 4a7df1dd00a786ee ]—
Mar 14 19:31:46 sd-3754 kernel: note: apache2[28166] exited with preempt_count 1
Mar 14 19:31:46 sd-3754 kernel: BUG: scheduling while atomic: apache2/28166/0x10000001
Mar 14 19:31:46 sd-3754 kernel: Pid: 28166, comm: apache2 Tainted: G D 2.6.24.2dedibox-r8-1-c7 #1
Mar 14 19:31:46 sd-3754 kernel: [] schedule+0x1cb/0x270
Mar 14 19:31:46 sd-3754 kernel: [] __cond_resched+0x13/0x30
Mar 14 19:31:46 sd-3754 kernel: [] cond_resched+0x27/0x30
Mar 14 19:31:46 sd-3754 kernel: [] unmap_vmas+0x566/0x580
Mar 14 19:31:46 sd-3754 kernel: [] exit_mmap+0x5c/0xd0
Mar 14 19:31:46 sd-3754 kernel: [] mmput+0x1e/0x70
Mar 14 19:31:46 sd-3754 kernel: [] do_exit+0x128/0x750
Mar 14 19:31:46 sd-3754 kernel: [] printk+0x1b/0x20
Mar 14 19:31:46 sd-3754 kernel: [] die+0x1ef/0x1f0
Mar 14 19:31:46 sd-3754 kernel: [] do_iret_error+0x0/0x90
Mar 14 19:31:46 sd-3754 kernel: [] do_iret_error+0x83/0x90
Mar 14 19:31:46 sd-3754 kernel: [] skb_release_all+0x4d/0x100
Mar 14 19:31:46 sd-3754 kernel: [] __kfree_skb+0x8/0x80
Mar 14 19:31:46 sd-3754 kernel: [] net_tx_action+0x38/0xd0
Mar 14 19:31:46 sd-3754 kernel: [] restore_nocheck+0xe/0xf
Mar 14 19:31:46 sd-3754 kernel: [] search_exception_tables+0x14/0x30
Mar 14 19:31:46 sd-3754 kernel: [] fixup_exception+0xb/0x20
Mar 14 19:31:46 sd-3754 kernel: [] do_general_protection+0x4d/0x250
Mar 14 19:31:46 sd-3754 kernel: [] do_IRQ+0x4a/0x80
Mar 14 19:31:46 sd-3754 kernel: [] do_general_protection+0x0/0x250
Mar 14 19:31:46 sd-3754 kernel: [] error_code+0x6a/0x70
Mar 14 19:31:46 sd-3754 kernel: [] iret_exc+0x67b/0x8a9
Mar 14 19:31:46 sd-3754 kernel: [] put_files_struct+0x6b/0xb0
Mar 14 19:31:46 sd-3754 kernel: [] do_exit+0x136/0x750
Pourriez-vous m’indiquer de quoi il s’agit ?
