Salut à tous,
voilà j’ai installé cacti pour un monitoring réseau, j’ai suivi la manuel d’install pour les version Linux mais après avoir configuré cacti, les graphs ne s’affichent pas :
Voilà si quelqu’un a déjà eu le problème et qu’il a trouvé la solution qu’il me donne un coup de main svp.
Voici le tuto du package :
Chapter 2. Installing Under Unix
1. Extract the distribution tarball.
shell> tar xzvf cacti-version.tar.gz
2. Create the MySQL database:
shell> mysqladmin --user=root create cacti
3. Import the default cacti database:
shell> mysql cacti < cacti.sql
4. Optional: Create a MySQL username and password for Cacti.
shell> mysql --user=root mysql
mysql> GRANT ALL ON cacti.* TO cactiuser@localhost IDENTIFIED BY 'somepassword';
mysql> flush privileges;
5. Edit include/config.php and specify the MySQL user, password and
database for your Cacti configuration.
$database_default = "cacti";
$database_hostname = "localhost";
$database_username = "cactiuser";
$database_password = "cacti";
6. Set the appropriate permissions on cacti's directories for graph/log
generation. You should execute these commands from inside cacti's
directory to change the permissions.
shell> chown -R cactiuser rra/ log/
(Enter a valid username for cactiuser, this user will also be used in
the next step for data gathering.)
7. Add a line to your /etc/crontab file similar to:
*/5 * * * * cactiuser php /var/www/html/cacti/poller.php > /dev/null 2>&1
Replace cactiuser with the valid user specified in the previous step.
Replace /var/www/html/cacti/ with your full Cacti path.
8. Point your web browser to:
http://your-server/cacti/
Log in the with a username/password of admin. You will be required to
change this password immediately. Make sure to fill in all of the path
variables carefully and correctly on the following screen.
et voici les requirements :
Chapter 1. Requirements
Cacti requires that the following software is installed on your system.
* RRDTool 1.0.49 or 1.2.x or greater
* MySQL 3.23 or greater, 4.0.20d or greater highly recommended for
advanced features
* PHP 4.1 or greater, 4.3.6 or greater highly recommended for advanced
features
Packages for RPM-based Operating Systems
* httpd
* php
* php-mysql
* php-snmp
* mysql
* mysql-server
* net-snmp
Ports for FreeBSD
* www/apache2
* net/rrdtool
* net/net-snmp
* www/php4-cgi
* lang/php4 (With MySQL and SNMP Support)
* databases/mysql323-server
