le manque de lo, c’est bizarre. Fais un ifconfig -a pour avoir aussi les interfaces non configurées.
Par ailleurs, si tu veux des conseils, montre un peu ta config. Par ex, /etc/network/interfaces, la version de ton noyau, etc…
Pour les outils que tu cherches utilises 'aptitude search pour voir ce qui est dispo. Par exemple:
console@mailgw:~$ aptitude search pcmcia
p bluez-pcmcia-support - PCMCIA support files for BlueZ 2.0 Bluetooth tools
p kernel-pcmcia-modules-2.4-386 - Mainstream PCMCIA modules for version 2.4 on 386
p kernel-pcmcia-modules-2.4-586tsc - Mainstream PCMCIA modules for version 2.4 on Pentium-Classic
p kernel-pcmcia-modules-2.4-686 - Mainstream PCMCIA modules for version 2.4 on PPro/Celeron/PII/PI
p kernel-pcmcia-modules-2.4-686-smp - Mainstream PCMCIA modules for version 2.4 on PPro/Celeron/PII/PI
p kernel-pcmcia-modules-2.4-k6 - Mainstream PCMCIA modules for version 2.4 on AMD K6/K6-II/K6-III
p kernel-pcmcia-modules-2.4-k7 - Mainstream PCMCIA modules for version 2.4 on AMD K7
p kernel-pcmcia-modules-2.4-k7-smp - Mainstream PCMCIA modules for version 2.4 on AMD K7 SMP
v kernel-pcmcia-modules-2.4.18-1-386 -
v kernel-pcmcia-modules-2.4.18-1-586tsc -
v kernel-pcmcia-modules-2.4.18-1-686 -
v kernel-pcmcia-modules-2.4.18-1-686-smp -
v kernel-pcmcia-modules-2.4.18-1-k6 -
v kernel-pcmcia-modules-2.4.18-1-k7 -
v kernel-pcmcia-modules-2.4.18-386 -
v kernel-pcmcia-modules-2.4.18-586tsc -
v kernel-pcmcia-modules-2.4.18-686 -
v kernel-pcmcia-modules-2.4.18-686-smp -
v kernel-pcmcia-modules-2.4.18-k6 -
v kernel-pcmcia-modules-2.4.18-k7 -
p kernel-pcmcia-modules-2.4.27-2-386 - Mainstream PCMCIA modules 2.4.27 on 386
p kernel-pcmcia-modules-2.4.27-2-586tsc - Mainstream PCMCIA modules 2.4.27 on Pentium-Classic
p kernel-pcmcia-modules-2.4.27-2-686 - Mainstream PCMCIA modules 2.4.27 on PPro/Celeron/PII/PIII/P4
p kernel-pcmcia-modules-2.4.27-2-686-smp - Mainstream PCMCIA modules 2.4.27 on PPro/Celeron/PII/PIII/P4 SMP
p kernel-pcmcia-modules-2.4.27-2-k6 - Mainstream PCMCIA modules 2.4.27 on AMD K6/K6-II/K6-III
p kernel-pcmcia-modules-2.4.27-2-k7 - Mainstream PCMCIA modules 2.4.27 on AMD K7
p kernel-pcmcia-modules-2.4.27-2-k7-smp - Mainstream PCMCIA modules 2.4.27 on AMD K7 SMP
p kernel-pcmcia-modules-2.4.27-3-386 - Mainstream PCMCIA modules 2.4.27 on 386
p kernel-pcmcia-modules-2.4.27-3-586tsc - Mainstream PCMCIA modules 2.4.27 on Pentium-Classic
p kernel-pcmcia-modules-2.4.27-3-686 - Mainstream PCMCIA modules 2.4.27 on PPro/Celeron/PII/PIII/P4
p kernel-pcmcia-modules-2.4.27-3-686-smp - Mainstream PCMCIA modules 2.4.27 on PPro/Celeron/PII/PIII/P4 SMP
p kernel-pcmcia-modules-2.4.27-3-k6 - Mainstream PCMCIA modules 2.4.27 on AMD K6/K6-II/K6-III
p kernel-pcmcia-modules-2.4.27-3-k7 - Mainstream PCMCIA modules 2.4.27 on AMD K7
p kernel-pcmcia-modules-2.4.27-3-k7-smp - Mainstream PCMCIA modules 2.4.27 on AMD K7 SMP
p pcmcia-cs - PCMCIA Card Services for Linux (deprecated)
v pcmcia-cs-source -
v pcmcia-modules -
v pcmcia-modules-2.2.20-reiserfs -
v pcmcia-modules-2.4.18-bf2.4 -
v pcmcia-modules-2.4.26-1-386 -
v pcmcia-modules-2.4.26-1-586tsc -
v pcmcia-modules-2.4.26-1-686 -
v pcmcia-modules-2.4.26-1-686-smp -
v pcmcia-modules-2.4.26-1-k6 -
v pcmcia-modules-2.4.26-1-k7 -
v pcmcia-modules-2.4.26-1-k7-smp -
p pcmcia-modules-2.4.27-2-386 - PCMCIA Modules for Linux (kernel 2.4.27-2-386)
p pcmcia-modules-2.4.27-2-586tsc - PCMCIA Modules for Linux (kernel 2.4.27-2-586tsc)
p pcmcia-modules-2.4.27-2-686 - PCMCIA Modules for Linux (kernel 2.4.27-2-686)
p pcmcia-modules-2.4.27-2-686-smp - PCMCIA Modules for Linux (kernel 2.4.27-2-686-smp)
p pcmcia-modules-2.4.27-2-k6 - PCMCIA Modules for Linux (kernel 2.4.27-2-k6)
p pcmcia-modules-2.4.27-2-k7 - PCMCIA Modules for Linux (kernel 2.4.27-2-k7)
p pcmcia-modules-2.4.27-2-k7-smp - PCMCIA Modules for Linux (kernel 2.4.27-2-k7-smp)
p pcmcia-modules-2.4.27-3-386 - PCMCIA Modules for Linux (kernel 2.4.27-3-386)
p pcmcia-modules-2.4.27-3-586tsc - PCMCIA Modules for Linux (kernel 2.4.27-3-586tsc)
p pcmcia-modules-2.4.27-3-686 - PCMCIA Modules for Linux (kernel 2.4.27-3-686)
p pcmcia-modules-2.4.27-3-686-smp - PCMCIA Modules for Linux (kernel 2.4.27-3-686-smp)
p pcmcia-modules-2.4.27-3-k6 - PCMCIA Modules for Linux (kernel 2.4.27-3-k6)
p pcmcia-modules-2.4.27-3-k7 - PCMCIA Modules for Linux (kernel 2.4.27-3-k7)
p pcmcia-modules-2.4.27-3-k7-smp - PCMCIA Modules for Linux (kernel 2.4.27-3-k7-smp)
p pcmcia-source - PCMCIA Card Services source
p pcmciautils - PCMCIA utilities for Linux 2.6
Ensuite aptitude show te permet d’avoir des infos spécifiques et de choisir. Par exemple ici, de décider de faire un aptitude install pcmciautils.
Sinon, ça, c’est pour les outils de gestion de ce qui t’interresse, parceque les composants dont tu parles (tcp/ip, pcmcia, et les modules de ta carte - dont tu pourrais donner les caracs) sont à priori dans le noyau et tu n’as pas à les activer toi même le plus souvent.
