bonjour.
Je boot donc avec mon câble Ethernet branché. Je connecte via putty à travers la carte wifi de ma debian pour lancer ceci. Je n’arrive pas à remonter au début de ma commande à travers ma fenêtre “putty”. J’espère que la première ligne correspond bien au début de la réponse.
dmesg:
ACPI: PCI Interrupt Link [APCI] (IRQs 20 21 22) *0, disabled.
ACPI: PCI Interrupt Link [APCJ] (IRQs 20 21 22) *0, disabled.
ACPI: PCI Interrupt Link [APCK] (IRQs 20 21 22) *0, disabled.
ACPI: PCI Interrupt Link [APCS] (IRQs *23), disabled.
ACPI: PCI Interrupt Link [APCL] (IRQs 20 21 22) *0, disabled.
ACPI: PCI Interrupt Link [APCM] (IRQs 20 21 22) *0, disabled.
ACPI: PCI Interrupt Link [AP3C] (IRQs 20 21 22) *0, disabled.
ACPI: PCI Interrupt Link [APCZ] (IRQs 20 21 22) *0, disabled.
Linux Plug and Play Support v0.97 (c) Adam Belay
pnp: PnP ACPI init
pnp: PnP ACPI: found 15 devices
PnPBIOS: Disabled by ACPI PNP
PCI: Using ACPI for IRQ routing
PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
pnp: 00:00: ioport range 0x4000-0x407f could not be reserved
pnp: 00:00: ioport range 0x4080-0x40ff has been reserved
pnp: 00:00: ioport range 0x4400-0x447f has been reserved
pnp: 00:00: ioport range 0x4480-0x44ff could not be reserved
pnp: 00:00: ioport range 0x4200-0x427f has been reserved
pnp: 00:00: ioport range 0x4280-0x42ff has been reserved
pnp: 00:01: ioport range 0x5000-0x503f has been reserved
pnp: 00:01: ioport range 0x5500-0x553f has been reserved
PCI: Bridge: 0000:00:08.0
IO window: disabled.
MEM window: e6000000-e6ffffff
PREFETCH window: disabled.
PCI: Bridge: 0000:00:1e.0
IO window: d000-dfff
MEM window: e4000000-e5ffffff
PREFETCH window: c0000000-dfffffff
PCI: Setting latency timer of device 0000:00:08.0 to 64
NET: Registered protocol family 2
IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
TCP established hash table entries: 16384 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 16384 bind 8192)
TCP reno registered
audit: initializing netlink socket (disabled)
audit(1223343377.892:1): initialized
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Initializing Cryptographic API
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
00:0a: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
00:0b: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
serio: i8042 AUX port at 0x60,0x64 irq 12
serio: i8042 KBD port at 0x60,0x64 irq 1
mice: PS/2 mouse device common for all mice
EISA: Probing bus 0 at eisa.0
Cannot allocate resource for EISA slot 4
Cannot allocate resource for EISA slot 5
EISA: Detected 0 cards.
TCP bic registered
NET: Registered protocol family 1
NET: Registered protocol family 17
NET: Registered protocol family 8
NET: Registered protocol family 20
Using IPI Shortcut mode
ACPI: (supports S0 S1 S4 S5)
Freeing unused kernel memory: 256k freed
Time: tsc clocksource has been installed.
input: AT Translated Set 2 keyboard as /class/input/input0
usbcore: registered new driver usbfs
usbcore: registered new driver hub
ohci_hcd: 2005 April 22 USB 1.1 'Open' Host Controller (OHCI) Driver (PCI)
ACPI: PCI Interrupt Link [APCF] enabled at IRQ 22
ACPI: PCI Interrupt 0000:00:02.0[A] -> Link [APCF] -> GSI 22 (level, high) -> IRQ 177
PCI: Setting latency timer of device 0000:00:02.0 to 64
ohci_hcd 0000:00:02.0: OHCI Host Controller
ohci_hcd 0000:00:02.0: new USB bus registered, assigned bus number 1
ohci_hcd 0000:00:02.0: irq 177, io mem 0xe7002000
forcedeth.c: Reverse Engineered nForce ethernet driver. Version 0.56.
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 3 ports detected
ACPI: PCI Interrupt Link [APCG] enabled at IRQ 21
ACPI: PCI Interrupt 0000:00:02.1[B] -> Link [APCG] -> GSI 21 (level, high) -> IRQ 185
PCI: Setting latency timer of device 0000:00:02.1 to 64
ohci_hcd 0000:00:02.1: OHCI Host Controller
ohci_hcd 0000:00:02.1: new USB bus registered, assigned bus number 2
ohci_hcd 0000:00:02.1: irq 185, io mem 0xe7003000
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 3 ports detected
ACPI: PCI Interrupt Link [APCL] enabled at IRQ 20
ACPI: PCI Interrupt 0000:00:02.2[C] -> Link [APCL] -> GSI 20 (level, high) -> IRQ 193
PCI: Setting latency timer of device 0000:00:02.2 to 64
ehci_hcd 0000:00:02.2: EHCI Host Controller
ehci_hcd 0000:00:02.2: new USB bus registered, assigned bus number 3
ehci_hcd 0000:00:02.2: debug port 1
PCI: cache line size of 64 is not supported by device 0000:00:02.2
ehci_hcd 0000:00:02.2: irq 193, io mem 0xe7004000
ehci_hcd 0000:00:02.2: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb3: configuration #1 chosen from 1 choice
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 6 ports detected
ACPI: PCI Interrupt Link [APCH] enabled at IRQ 22
ACPI: PCI Interrupt 0000:00:04.0[A] -> Link [APCH] -> GSI 22 (level, high) -> IRQ 177
PCI: Setting latency timer of device 0000:00:04.0 to 64
eth0: forcedeth.c: subsystem: 01043:80a7 bound to 0000:00:04.0
NFORCE2: IDE controller at PCI slot 0000:00:09.0
NFORCE2: chipset revision 162
NFORCE2: not 100% native mode: will probe irqs later
NFORCE2: BIOS didn't set cable bits correctly. Enabling workaround.
NFORCE2: 0000:00:09.0 (rev a2) UDMA133 controller
ide0: BM-DMA at 0xf000-0xf007, BIOS settings: hda:DMA, hdb:DMA
ide1: BM-DMA at 0xf008-0xf00f, BIOS settings: hdc:DMA, hdd:DMA
Probing IDE interface ide0...
hda: HDS722580VLAT20, ATA DISK drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Probing IDE interface ide1...
hdc: HL-DT-STDVD-ROM GDR8161B, ATAPI CD/DVD-ROM drive
hdd: HL-DT-ST GCE-8525B, ATAPI CD/DVD-ROM drive
ide1 at 0x170-0x177,0x376 on irq 15
SCSI subsystem initialized
libata version 2.00 loaded.
hda: max request size: 512KiB
hda: 160836480 sectors (82348 MB) w/1794KiB Cache, CHS=16383/255/63, UDMA(100)
hda: cache flushes supported
hda: hda1 hda2 < hda5 >
hdc: ATAPI 48X DVD-ROM drive, 256kB Cache, UDMA(33)
Uniform CD-ROM driver Revision: 3.20
hdd: ATAPI 52X CD-ROM CD-R/RW drive, 2048kB Cache, UDMA(33)
Attempting manual resume
kjournald starting. Commit interval 5 seconds
EXT3-fs: mounted filesystem with ordered data mode.
Linux agpgart interface v0.101 (c) Dave Jones
agpgart: Detected NVIDIA nForce2 chipset
agpgart: AGP aperture is 64M @ 0xe0000000
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
i2c_adapter i2c-0: nForce2 SMBus adapter at 0x5000
i2c_adapter i2c-1: nForce2 SMBus adapter at 0x5500
input: PC Speaker as /class/input/input1
ACPI: PCI Interrupt Link [APCJ] enabled at IRQ 21
ACPI: PCI Interrupt 0000:00:06.0[A] -> Link [APCJ] -> GSI 21 (level, high) -> IRQ 185
PCI: Setting latency timer of device 0000:00:06.0 to 64
parport: PnPBIOS parport detected.
parport0: PC-style at 0x378 (0x778), irq 7, dma 3 [PCSPP,TRISTATE,COMPAT,ECP,DMA]
Loading module: rt61pci - CVS (N/A) by http://rt2x00.serialmonkey.com.
intel8x0_measure_ac97_clock: measured 52793 usecs
intel8x0: clocking to 48000
ACPI: PCI Interrupt Link [APC4] enabled at IRQ 19
ACPI: PCI Interrupt 0000:02:00.0[A] -> Link [APC4] -> GSI 19 (level, high) -> IRQ 201
radeonfb: Found Intel x86 BIOS ROM Image
radeonfb: Retrieved PLL infos from BIOS
radeonfb: Reference=27.00 MHz (RefDiv=12) Memory=500.00 Mhz, System=297.00 MHz
radeonfb: PLL min 20000 max 40000
input: ImExPS/2 Generic Explorer Mouse as /class/input/input2
ts: Compaq touchscreen protocol output
radeonfb: Monitor 1 type CRT found
radeonfb: EDID probed
radeonfb: Monitor 2 type no found
Console: switching to colour frame buffer device 160x64
radeonfb (0000:02:00.0): ATI Radeon AR
ACPI: PCI Interrupt 0000:01:07.0[A] -> Link [APC4] -> GSI 19 (level, high) -> IRQ 201
wmaster0: Selected rate control algorithm 'simple'
rt61: module license 'unspecified' taints kernel.
Adding 1510068k swap on /dev/hda5. Priority:-1 extents:1 across:1510068k
EXT3 FS on hda1, internal journal
loop: loaded (max 8 devices)
device-mapper: ioctl: 4.7.0-ioctl (2006-06-24) initialised: dm-devel@redhat.com
wlan0: Initial auth_alg=0
wlan0: authenticate with AP 00:16:38:24:22:99
wlan0: RX authentication from 00:16:38:24:22:99 (alg=0 transaction=2 status=0)
wlan0: authenticated
wlan0: associate with AP 00:16:38:24:22:99
wlan0: RX AssocResp from 00:16:38:24:22:99 (capab=0x411 status=0 aid=2)
wlan0: associated
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
IPv6 over IPv4 tunneling driver
wlan0: duplicate address detected!
eth0: no IPv6 routers present
ACPI: Power Button (FF) [PWRF]
ACPI: Power Button (CM) [PWRB]
lp0: using parport0 (interrupt-driven).
ppdev: user-space parallel port driver
NET: Registered protocol family 5
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
NFSD: Using /var/lib/nfs/v4recovery as the NFSv4 state recovery directory
NFSD: starting 90-second grace period
[drm] Initialized drm 1.0.1 20051102
[drm] Initialized radeon 1.25.0 20060524 on minor 0
Bluetooth: Core ver 2.10
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP ver 2.8
Bluetooth: L2CAP socket layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM ver 1.8
agpgart: Found an AGP 3.0 compliant device at 0000:00:00.0.
agpgart: Putting AGP V3 device at 0000:00:00.0 into 4x mode
agpgart: Putting AGP V3 device at 0000:02:00.0 into 4x mode
[drm] Setting GART location based on new memory map
[drm] Loading R300 Microcode
[drm] writeback test succeeded in 1 usecs
parport0: FIFO is stuck
parport0: BUSY timeout (1) in compat_write_block_pio
[b]Quelle est l’information importante dans toutes ces lignes?
Les deux dernières me rappellent le message que je peux lire quand je tente de booter sans mon câble ethernet.
Je poste ici le contenu de mon fichier /var/log/messages. je m’excuse par avance pour la longueur de ce truc, je ne sais comment le réduire. Si quelqu’un comprend quelques chose à ces lignes je suis preneur:[/b]
Oct 7 03:36:36 localhost syslogd 1.4.1#18: restart.
Oct 7 03:36:36 localhost kernel: klogd 1.4.1#18, log source = /proc/kmsg started.
Oct 7 03:36:36 localhost kernel: Linux version 2.6.18-6-486 (Debian 2.6.18.dfsg.1-22etch2) (dannf@debian.org) (gcc version 4.1.2 20061115 (prerelease) (Debian 4.1.1-21)) #1 Mon Aug 18 08:05:56 UTC 2008
Oct 7 03:36:36 localhost kernel: BIOS-provided physical RAM map:
Oct 7 03:36:36 localhost kernel: BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
Oct 7 03:36:36 localhost kernel: BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
Oct 7 03:36:36 localhost kernel: BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
Oct 7 03:36:36 localhost kernel: BIOS-e820: 0000000000100000 - 000000001fff0000 (usable)
Oct 7 03:36:36 localhost kernel: BIOS-e820: 000000001fff0000 - 000000001fff3000 (ACPI NVS)
Oct 7 03:36:36 localhost kernel: BIOS-e820: 000000001fff3000 - 0000000020000000 (ACPI data)
Oct 7 03:36:36 localhost kernel: BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
Oct 7 03:36:36 localhost kernel: BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
Oct 7 03:36:36 localhost kernel: BIOS-e820: 00000000ffff0000 - 0000000100000000 (reserved)
Oct 7 03:36:36 localhost kernel: 511MB LOWMEM available.
Oct 7 03:36:36 localhost kernel: DMI 2.2 present.
Oct 7 03:36:36 localhost kernel: ACPI: PM-Timer IO Port: 0x4008
Oct 7 03:36:36 localhost kernel: ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
Oct 7 03:36:36 localhost kernel: Processor #0 6:10 APIC version 16
Oct 7 03:36:36 localhost kernel: ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
Oct 7 03:36:36 localhost kernel: ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
Oct 7 03:36:36 localhost kernel: IOAPIC[0]: apic_id 2, version 17, address 0xfec00000, GSI 0-23
Oct 7 03:36:36 localhost kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
Oct 7 03:36:36 localhost kernel: ACPI: BIOS IRQ0 pin2 override ignored.
Oct 7 03:36:36 localhost kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
Oct 7 03:36:36 localhost kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 14 global_irq 14 high edge)
Oct 7 03:36:36 localhost kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 15 global_irq 15 high edge)
Oct 7 03:36:36 localhost kernel: Enabling APIC mode: Flat. Using 1 I/O APICs
Oct 7 03:36:36 localhost kernel: Using ACPI (MADT) for SMP configuration information
Oct 7 03:36:36 localhost kernel: Allocating PCI resources starting at 30000000 (gap: 20000000:dec00000)
Oct 7 03:36:36 localhost kernel: Detected 2079.542 MHz processor.
Oct 7 03:36:36 localhost kernel: Built 1 zonelists. Total pages: 131056
Oct 7 03:36:36 localhost kernel: Kernel command line: root=/dev/hda1 ro
Oct 7 03:36:36 localhost kernel: Enabling fast FPU save and restore… done.
Oct 7 03:36:36 localhost kernel: Enabling unmasked SIMD FPU exception support… done.
Oct 7 03:36:36 localhost kernel: Initializing CPU#0
Oct 7 03:36:36 localhost kernel: PID hash table entries: 2048 (order: 11, 8192 bytes)
Oct 7 03:36:36 localhost kernel: Console: colour VGA+ 80x25
Oct 7 03:36:36 localhost kernel: Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Oct 7 03:36:36 localhost kernel: Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Oct 7 03:36:36 localhost kernel: Memory: 511824k/524224k available (1499k kernel code, 11760k reserved, 599k data, 256k init, 0k highmem)
Oct 7 03:36:36 localhost kernel: Checking if this processor honours the WP bit even in supervisor mode… Ok.
Oct 7 03:36:36 localhost kernel: Calibrating delay using timer specific routine… 4162.11 BogoMIPS (lpj=8324237)
Oct 7 03:36:36 localhost kernel: Security Framework v1.0.0 initialized
Oct 7 03:36:36 localhost kernel: SELinux: Disabled at boot.
Oct 7 03:36:36 localhost kernel: Capability LSM initialized
Oct 7 03:36:36 localhost kernel: Mount-cache hash table entries: 512
Oct 7 03:36:36 localhost kernel: CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
Oct 7 03:36:36 localhost kernel: CPU: L2 Cache: 512K (64 bytes/line)
Oct 7 03:36:36 localhost kernel: Compat vDSO mapped to ffffe000.
Oct 7 03:36:36 localhost kernel: CPU: AMD Athlon™ XP 2800+ stepping 00
Oct 7 03:36:36 localhost kernel: Checking ‘hlt’ instruction… OK.
Oct 7 03:36:36 localhost kernel: ACPI: Core revision 20060707
Oct 7 03:36:36 localhost kernel: ENABLING IO-APIC IRQs
Oct 7 03:36:36 localhost kernel: …TIMER: vector=0x31 apic1=0 pin1=0 apic2=-1 pin2=-1
Oct 7 03:36:36 localhost kernel: checking if image is initramfs… it is
Oct 7 03:36:36 localhost kernel: Freeing initrd memory: 4644k freed
Oct 7 03:36:36 localhost kernel: NET: Registered protocol family 16
Oct 7 03:36:36 localhost kernel: EISA bus registered
Oct 7 03:36:36 localhost kernel: ACPI: bus type pci registered
Oct 7 03:36:36 localhost kernel: PCI: PCI BIOS revision 2.10 entry at 0xfb4a0, last bus=2
Oct 7 03:36:36 localhost kernel: PCI: Using configuration type 1
Oct 7 03:36:36 localhost kernel: Setting up standard PCI resources
Oct 7 03:36:36 localhost kernel: ACPI: Interpreter enabled
Oct 7 03:36:36 localhost kernel: ACPI: Using IOAPIC for interrupt routing
Oct 7 03:36:36 localhost kernel: ACPI: PCI Root Bridge [PCI0] (0000:00)
Oct 7 03:36:36 localhost kernel: PCI: nForce2 C1 Halt Disconnect fixup
Oct 7 03:36:36 localhost kernel: ACPI: PCI Interrupt Link [LNK1] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
Oct 7 03:36:36 localhost kernel: ACPI: PCI Interrupt Link [LNK2] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
Oct 7 03:36:36 localhost kernel: ACPI: PCI Interrupt Link [LNK3] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
Oct 7 03:36:36 localhost kernel: ACPI: PCI Interrupt Link [LNK4] (IRQs 3 4 5 6 7 *10 11 12 14 15)
Oct 7 03:36:36 localhost kernel: ACPI: PCI Interrupt Link [LNK5] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
Oct 7 03:36:36 localhost kernel: ACPI: PCI Interrupt Link [LUBA] (IRQs 3 4 *5 6 7 10 11 12 14 15)
Oct 7 03:36:36 localhost kernel: ACPI: PCI Interrupt Link [LUBB] (IRQs 3 4 5 6 7 *10 11 12 14 15)
Oct 7 03:36:36 localhost kernel: ACPI: PCI Interrupt Link [LMAC] (IRQs 3 4 5 6 7 10 *11 12 14 15)
Oct 7 03:36:36 localhost kernel: ACPI: PCI Interrupt Link [LAPU] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
Oct 7 03:36:36 localhost kernel: ACPI: PCI Interrupt Link [LACI] (IRQs 3 4 *5 6 7 10 11 12 14 15)
Oct 7 03:36:36 localhost kernel: ACPI: PCI Interrupt Link [LMCI] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
Oct 7 03:36:36 localhost kernel: ACPI: PCI Interrupt Link [LSMB] (IRQs 3 4 5 6 7 10 *11 12 14 15)
Oct 7 03:36:36 localhost kernel: ACPI: PCI Interrupt Link [LUB2] (IRQs 3 4 5 6 7 10 *11 12 14 15)
Oct 7 03:36:36 localhost kernel: ACPI: PCI Interrupt Link [LFIR] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
Oct 7 03:36:36 localhost kernel: ACPI: PCI Interrupt Link [L3CM] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
Oct 7 03:36:36 localhost kernel: ACPI: PCI Interrupt Link [LIDE] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
Oct 7 03:36:36 localhost kernel: ACPI: PCI Interrupt Link [APC1] (IRQs *16), disabled.
Oct 7 03:36:36 localhost kernel: ACPI: PCI Interrupt Link [APC2] (IRQs *17), disabled.
Oct 7 03:36:36 localhost kernel: ACPI: PCI Interrupt Link [APC3] (IRQs *18), disabled.
Oct 7 03:36:36 localhost kernel: ACPI: PCI Interrupt Link [APC4] (IRQs *19), disabled.
Oct 7 03:36:36 localhost kernel: ACPI: PCI Interrupt Link [APC5] (IRQs *16), disabled.
Oct 7 03:36:36 localhost kernel: ACPI: PCI Interrupt Link [APCF] (IRQs 20 21 22) *0, disabled.
Oct 7 03:36:36 localhost kernel: ACPI: PCI Interrupt Link [APCG] (IRQs 20 21 22) *0, disabled.
Oct 7 03:36:36 localhost kernel: ACPI: PCI Interrupt Link [APCH] (IRQs 20 21 22) *0, disabled.
Oct 7 03:36:36 localhost kernel: ACPI: PCI Interrupt Link [APCI] (IRQs 20 21 22) *0, disabled.
Oct 7 03:36:36 localhost kernel: ACPI: PCI Interrupt Link [APCJ] (IRQs 20 21 22) *0, disabled.
Oct 7 03:36:36 localhost kernel: ACPI: PCI Interrupt Link [APCK] (IRQs 20 21 22) *0, disabled.
Oct 7 03:36:36 localhost kernel: ACPI: PCI Interrupt Link [APCS] (IRQs *23), disabled.
Oct 7 03:36:36 localhost kernel: ACPI: PCI Interrupt Link [APCL] (IRQs 20 21 22) *0, disabled.
Oct 7 03:36:36 localhost kernel: ACPI: PCI Interrupt Link [APCM] (IRQs 20 21 22) *0, disabled.
Oct 7 03:36:36 localhost kernel: ACPI: PCI Interrupt Link [AP3C] (IRQs 20 21 22) *0, disabled.
Oct 7 03:36:36 localhost kernel: ACPI: PCI Interrupt Link [APCZ] (IRQs 20 21 22) *0, disabled.
Oct 7 03:36:36 localhost kernel: Linux Plug and Play Support v0.97 © Adam Belay
Oct 7 03:36:36 localhost kernel: pnp: PnP ACPI init
Oct 7 03:36:36 localhost kernel: pnp: PnP ACPI: found 15 devices
Oct 7 03:36:36 localhost kernel: PnPBIOS: Disabled by ACPI PNP
Oct 7 03:36:36 localhost kernel: PCI: Using ACPI for IRQ routing
Oct 7 03:36:36 localhost kernel: PCI: If a device doesn’t work, try “pci=routeirq”. If it helps, post a report
Oct 7 03:36:36 localhost kernel: pnp: 00:00: ioport range 0x4000-0x407f could not be reserved
Oct 7 03:36:36 localhost kernel: pnp: 00:00: ioport range 0x4080-0x40ff has been reserved
Oct 7 03:36:36 localhost kernel: pnp: 00:00: ioport range 0x4400-0x447f has been reserved
Oct 7 03:36:36 localhost kernel: pnp: 00:00: ioport range 0x4480-0x44ff could not be reserved
Oct 7 03:36:36 localhost kernel: pnp: 00:00: ioport range 0x4200-0x427f has been reserved
Oct 7 03:36:36 localhost kernel: pnp: 00:00: ioport range 0x4280-0x42ff has been reserved
Oct 7 03:36:36 localhost kernel: pnp: 00:01: ioport range 0x5000-0x503f has been reserved
Oct 7 03:36:36 localhost kernel: pnp: 00:01: ioport range 0x5500-0x553f has been reserved
Oct 7 03:36:36 localhost kernel: PCI: Bridge: 0000:00:08.0
Oct 7 03:36:36 localhost kernel: IO window: disabled.
Oct 7 03:36:36 localhost kernel: MEM window: e6000000-e6ffffff
Oct 7 03:36:36 localhost kernel: PREFETCH window: disabled.
Oct 7 03:36:36 localhost kernel: PCI: Bridge: 0000:00:1e.0
Oct 7 03:36:36 localhost kernel: IO window: d000-dfff
Oct 7 03:36:36 localhost kernel: MEM window: e4000000-e5ffffff
Oct 7 03:36:36 localhost kernel: PREFETCH window: c0000000-dfffffff
Oct 7 03:36:36 localhost kernel: NET: Registered protocol family 2
Oct 7 03:36:36 localhost kernel: IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
Oct 7 03:36:36 localhost kernel: TCP established hash table entries: 16384 (order: 4, 65536 bytes)
Oct 7 03:36:36 localhost kernel: TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
Oct 7 03:36:36 localhost kernel: TCP: Hash tables configured (established 16384 bind 8192)
Oct 7 03:36:36 localhost kernel: TCP reno registered
Oct 7 03:36:36 localhost kernel: audit: initializing netlink socket (disabled)
Oct 7 03:36:36 localhost kernel: audit(1223343377.892:1): initialized
Oct 7 03:36:36 localhost kernel: VFS: Disk quotas dquot_6.5.1
Oct 7 03:36:36 localhost kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Oct 7 03:36:36 localhost kernel: Initializing Cryptographic API
Oct 7 03:36:36 localhost kernel: io scheduler noop registered
Oct 7 03:36:36 localhost kernel: io scheduler anticipatory registered
Oct 7 03:36:36 localhost kernel: io scheduler deadline registered
Oct 7 03:36:36 localhost kernel: io scheduler cfq registered (default)
Oct 7 03:36:36 localhost kernel: isapnp: Scanning for PnP cards…
Oct 7 03:36:36 localhost kernel: isapnp: No Plug & Play device found
Oct 7 03:36:36 localhost kernel: Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
Oct 7 03:36:36 localhost kernel: serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
Oct 7 03:36:36 localhost kernel: serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
Oct 7 03:36:36 localhost kernel: 00:0a: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
Oct 7 03:36:36 localhost kernel: 00:0b: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
Oct 7 03:36:36 localhost kernel: RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
Oct 7 03:36:36 localhost kernel: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
Oct 7 03:36:36 localhost kernel: serio: i8042 AUX port at 0x60,0x64 irq 12
Oct 7 03:36:36 localhost kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
Oct 7 03:36:36 localhost kernel: mice: PS/2 mouse device common for all mice
Oct 7 03:36:36 localhost kernel: EISA: Probing bus 0 at eisa.0
Oct 7 03:36:36 localhost kernel: Cannot allocate resource for EISA slot 4
Oct 7 03:36:36 localhost kernel: Cannot allocate resource for EISA slot 5
Oct 7 03:36:36 localhost kernel: EISA: Detected 0 cards.
Oct 7 03:36:36 localhost kernel: TCP bic registered
Oct 7 03:36:36 localhost kernel: NET: Registered protocol family 17
Oct 7 03:36:36 localhost kernel: NET: Registered protocol family 8
Oct 7 03:36:36 localhost kernel: NET: Registered protocol family 20
Oct 7 03:36:36 localhost kernel: Using IPI Shortcut mode
Oct 7 03:36:36 localhost kernel: ACPI: (supports S0 S1 S4 S5)
Oct 7 03:36:36 localhost kernel: Freeing unused kernel memory: 256k freed
Oct 7 03:36:36 localhost kernel: Time: tsc clocksource has been installed.
Oct 7 03:36:36 localhost kernel: input: AT Translated Set 2 keyboard as /class/input/input0
Oct 7 03:36:36 localhost kernel: usbcore: registered new driver usbfs
Oct 7 03:36:36 localhost kernel: usbcore: registered new driver hub
Oct 7 03:36:36 localhost kernel: ACPI: PCI Interrupt Link [APCF] enabled at IRQ 22
Oct 7 03:36:36 localhost kernel: ACPI: PCI Interrupt 0000:00:02.0[A] -> Link [APCF] -> GSI 22 (level, high) -> IRQ 177
Oct 7 03:36:36 localhost kernel: ohci_hcd 0000:00:02.0: OHCI Host Controller
Oct 7 03:36:36 localhost kernel: ohci_hcd 0000:00:02.0: new USB bus registered, assigned bus number 1
Oct 7 03:36:36 localhost kernel: ohci_hcd 0000:00:02.0: irq 177, io mem 0xe7002000
Oct 7 03:36:36 localhost kernel: forcedeth.c: Reverse Engineered nForce ethernet driver. Version 0.56.
Oct 7 03:36:36 localhost kernel: Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
Oct 7 03:36:36 localhost kernel: ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
Oct 7 03:36:36 localhost kernel: usb usb1: configuration #1 chosen from 1 choice
Oct 7 03:36:36 localhost kernel: hub 1-0:1.0: USB hub found
Oct 7 03:36:36 localhost kernel: hub 1-0:1.0: 3 ports detected
Oct 7 03:36:36 localhost kernel: ACPI: PCI Interrupt Link [APCG] enabled at IRQ 21
Oct 7 03:36:36 localhost kernel: ACPI: PCI Interrupt 0000:00:02.1[B] -> Link [APCG] -> GSI 21 (level, high) -> IRQ 185
Oct 7 03:36:36 localhost kernel: ohci_hcd 0000:00:02.1: OHCI Host Controller
Oct 7 03:36:36 localhost kernel: ohci_hcd 0000:00:02.1: new USB bus registered, assigned bus number 2
Oct 7 03:36:36 localhost kernel: ohci_hcd 0000:00:02.1: irq 185, io mem 0xe7003000
Oct 7 03:36:36 localhost kernel: usb usb2: configuration #1 chosen from 1 choice
Oct 7 03:36:36 localhost kernel: hub 2-0:1.0: USB hub found
Oct 7 03:36:36 localhost kernel: hub 2-0:1.0: 3 ports detected
Oct 7 03:36:36 localhost kernel: ACPI: PCI Interrupt Link [APCL] enabled at IRQ 20
Oct 7 03:36:36 localhost kernel: ACPI: PCI Interrupt 0000:00:02.2[C] -> Link [APCL] -> GSI 20 (level, high) -> IRQ 193
Oct 7 03:36:36 localhost kernel: ehci_hcd 0000:00:02.2: EHCI Host Controller
Oct 7 03:36:36 localhost kernel: ehci_hcd 0000:00:02.2: new USB bus registered, assigned bus number 3
Oct 7 03:36:36 localhost kernel: ehci_hcd 0000:00:02.2: debug port 1
Oct 7 03:36:36 localhost kernel: ehci_hcd 0000:00:02.2: irq 193, io mem 0xe7004000
Oct 7 03:36:36 localhost kernel: ehci_hcd 0000:00:02.2: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
Oct 7 03:36:36 localhost kernel: usb usb3: configuration #1 chosen from 1 choice
Oct 7 03:36:36 localhost kernel: hub 3-0:1.0: USB hub found
Oct 7 03:36:36 localhost kernel: hub 3-0:1.0: 6 ports detected
Oct 7 03:36:36 localhost kernel: ACPI: PCI Interrupt Link [APCH] enabled at IRQ 22
Oct 7 03:36:36 localhost kernel: ACPI: PCI Interrupt 0000:00:04.0[A] -> Link [APCH] -> GSI 22 (level, high) -> IRQ 177
Oct 7 03:36:36 localhost kernel: eth0: forcedeth.c: subsystem: 01043:80a7 bound to 0000:00:04.0
Oct 7 03:36:36 localhost kernel: NFORCE2: IDE controller at PCI slot 0000:00:09.0
Oct 7 03:36:36 localhost kernel: NFORCE2: chipset revision 162
Oct 7 03:36:36 localhost kernel: NFORCE2: not 100%% native mode: will probe irqs later
Oct 7 03:36:36 localhost kernel: NFORCE2: BIOS didn’t set cable bits correctly. Enabling workaround.
Oct 7 03:36:36 localhost kernel: NFORCE2: 0000:00:09.0 (rev a2) UDMA133 controller
Oct 7 03:36:36 localhost kernel: ide0: BM-DMA at 0xf000-0xf007, BIOS settings: hda:DMA, hdb:DMA
Oct 7 03:36:36 localhost kernel: ide1: BM-DMA at 0xf008-0xf00f, BIOS settings: hdc:DMA, hdd:DMA
Oct 7 03:36:36 localhost kernel: hda: HDS722580VLAT20, ATA DISK drive
Oct 7 03:36:36 localhost kernel: ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Oct 7 03:36:36 localhost kernel: hdc: HL-DT-STDVD-ROM GDR8161B, ATAPI CD/DVD-ROM drive
Oct 7 03:36:36 localhost kernel: hdd: HL-DT-ST GCE-8525B, ATAPI CD/DVD-ROM drive
Oct 7 03:36:36 localhost kernel: ide1 at 0x170-0x177,0x376 on irq 15
Oct 7 03:36:36 localhost kernel: SCSI subsystem initialized
Oct 7 03:36:36 localhost kernel: hda: max request size: 512KiB
Oct 7 03:36:36 localhost kernel: hda: 160836480 sectors (82348 MB) w/1794KiB Cache, CHS=16383/255/63, UDMA(100)
Oct 7 03:36:36 localhost kernel: hda: cache flushes supported
Oct 7 03:36:36 localhost kernel: hda: hda1 hda2 < hda5 >
Oct 7 03:36:36 localhost kernel: hdc: ATAPI 48X DVD-ROM drive, 256kB Cache, UDMA(33)
Oct 7 03:36:36 localhost kernel: Uniform CD-ROM driver Revision: 3.20
Oct 7 03:36:36 localhost kernel: hdd: ATAPI 52X CD-ROM CD-R/RW drive, 2048kB Cache, UDMA(33)
Oct 7 03:36:36 localhost kernel: Attempting manual resume
Oct 7 03:36:36 localhost kernel: kjournald starting. Commit interval 5 seconds
Oct 7 03:36:36 localhost kernel: EXT3-fs: mounted filesystem with ordered data mode.
Oct 7 03:36:36 localhost kernel: Linux agpgart interface v0.101 © Dave Jones
Oct 7 03:36:36 localhost kernel: agpgart: Detected NVIDIA nForce2 chipset
Oct 7 03:36:36 localhost kernel: agpgart: AGP aperture is 64M @ 0xe0000000
Oct 7 03:36:36 localhost kernel: pci_hotplug: PCI Hot Plug PCI Core version: 0.5
Oct 7 03:36:36 localhost kernel: shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
Oct 7 03:36:36 localhost kernel: i2c_adapter i2c-0: nForce2 SMBus adapter at 0x5000
Oct 7 03:36:36 localhost kernel: i2c_adapter i2c-1: nForce2 SMBus adapter at 0x5500
Oct 7 03:36:36 localhost kernel: input: PC Speaker as /class/input/input1
Oct 7 03:36:36 localhost kernel: ACPI: PCI Interrupt Link [APCJ] enabled at IRQ 21
Oct 7 03:36:36 localhost kernel: ACPI: PCI Interrupt 0000:00:06.0[A] -> Link [APCJ] -> GSI 21 (level, high) -> IRQ 185
Oct 7 03:36:36 localhost kernel: parport: PnPBIOS parport detected.
Oct 7 03:36:36 localhost kernel: parport0: PC-style at 0x378 (0x778), irq 7, dma 3 [PCSPP,TRISTATE,COMPAT,ECP,DMA]
Oct 7 03:36:36 localhost kernel: Loading module: rt61pci - CVS (N/A) by rt2x00.serialmonkey.com.
Oct 7 03:36:36 localhost kernel: intel8x0_measure_ac97_clock: measured 52793 usecs
Oct 7 03:36:36 localhost kernel: intel8x0: clocking to 48000
Oct 7 03:36:36 localhost kernel: ACPI: PCI Interrupt Link [APC4] enabled at IRQ 19
Oct 7 03:36:36 localhost kernel: ACPI: PCI Interrupt 0000:02:00.0[A] -> Link [APC4] -> GSI 19 (level, high) -> IRQ 201
Oct 7 03:36:36 localhost kernel: radeonfb: Found Intel x86 BIOS ROM Image
Oct 7 03:36:36 localhost kernel: radeonfb: Retrieved PLL infos from BIOS
Oct 7 03:36:36 localhost kernel: radeonfb: Reference=27.00 MHz (RefDiv=12) Memory=500.00 Mhz, System=297.00 MHz
Oct 7 03:36:36 localhost kernel: radeonfb: PLL min 20000 max 40000
Oct 7 03:36:36 localhost kernel: input: ImExPS/2 Generic Explorer Mouse as /class/input/input2
Oct 7 03:36:36 localhost kernel: ts: Compaq touchscreen protocol output
Oct 7 03:36:36 localhost kernel: radeonfb: Monitor 1 type CRT found
Oct 7 03:36:36 localhost kernel: radeonfb: EDID probed
Oct 7 03:36:36 localhost kernel: radeonfb: Monitor 2 type no found
Oct 7 03:36:36 localhost kernel: Console: switching to colour frame buffer device 160x64
Oct 7 03:36:36 localhost kernel: radeonfb (0000:02:00.0): ATI Radeon AR
Oct 7 03:36:36 localhost kernel: ACPI: PCI Interrupt 0000:01:07.0[A] -> Link [APC4] -> GSI 19 (level, high) -> IRQ 201
Oct 7 03:36:36 localhost kernel: rt61: module license ‘unspecified’ taints kernel.
Oct 7 03:36:36 localhost kernel: Adding 1510068k swap on /dev/hda5. Priority:-1 extents:1 across:1510068k
Oct 7 03:36:36 localhost kernel: EXT3 FS on hda1, internal journal
Oct 7 03:36:36 localhost kernel: loop: loaded (max 8 devices)
Oct 7 03:36:36 localhost kernel: device-mapper: ioctl: 4.7.0-ioctl (2006-06-24) initialised: dm-devel@redhat.com
Oct 7 03:36:36 localhost kernel: NET: Registered protocol family 10
Oct 7 03:36:36 localhost kernel: lo: Disabled Privacy Extensions
Oct 7 03:36:36 localhost kernel: IPv6 over IPv4 tunneling driver
Oct 7 03:36:36 localhost kernel: wlan0: duplicate address detected!
Oct 7 03:36:38 localhost hpiod: 1.6.10 accepting connections at 2208…
Oct 7 03:36:44 localhost kernel: ACPI: Power Button (FF) [PWRF]
Oct 7 03:36:44 localhost kernel: ACPI: Power Button (CM) [PWRB]
Oct 7 03:36:44 localhost kernel: lp0: using parport0 (interrupt-driven).
Oct 7 03:36:44 localhost kernel: ppdev: user-space parallel port driver
Oct 7 03:36:47 localhost dhcdbd: Started up.
Oct 7 03:36:47 localhost lpd[2897]: restarted
Oct 7 03:36:47 localhost kernel: NET: Registered protocol family 5
