[quote]If you can do
Alt+F2
and type
killall gnome-panel
and click Run.
Or, rt-click the desktop>Open terminal>type
killall gnome-panel
and press Enter.
If you end up with no panel do;
ps -A
and make sure gnome-panel isn’t running. If it is, again
killall gnome-panel
then run in the terminal
gnome-panel
when you close the terminal the gnome-panel will die again and come back, or should. That should do it. If not, do any of the above that is necaessary again, and when you do ps -A and are certain you only have one panel running do
Alt+F2
type
gnome-session-save
and click Run. See if that fixes it.[/quote]
gnomesupport.org/forums/viewtopi … dcc78b61e5
[quote]It’s an applet not closing that is causing the problem. To identify the offending one, log in another way (console or xterm) and do:
$ps aux
find a line like this:
seb 5012 0.0 1.7 31424 18268 ? S 20:42 0:01 /usr/lib/gnome-applets/mixer_applet2…
You can see that the mixer applet was the one that was causing the problem for me. I fixed it this way:
I logged back in gnome, removed the mixer applet from the panel and logged out (without any problems).
Then I logged back in and put back the mixer applet. And it works. No more locks up. No idea why.
Hope this helps.[/quote]
ubuntuforums.org/showthread.php?t=145312&page=2
j’avais eu ça également et en supprimant l’applet qui posait probleme, bah tout était à nouveau ok
