Bonjou,
J’ai installé sur mon ordinateur portable de marque Lenovo, en double boot avec windows 7, la Debian 9, tou s’est passé sans problème.
Mais quand j’ouvre le navigateur firefox pour aller sur internet la page authentification ne s’affiche pas.
En ligne de commande et en mode root j’ai exécuter les commandes suivantes:
#dhclient enp5s0
You are connected to enp5s0: vous etez connecté à enp5s0
#cat /etc/issue
Debian GNU/Linux 9 \n \l
#ifconfig -a
enp5s0: flags=4099<UP,BROADCAST,MULTICAST mtu 1500
ether 28:d2:44:59:b4:58 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
enp5s0:avahi: flags=4099<UP,BROADCAST,MULTICAST mtu 1500
inet 169.254.7.238 netmask 255.255.0.0 broadcast 169.254.255.255
lo: flags=73<UP,LOOPBACK,RUNNING mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host
loop txqueuelen 1 (Boucle locale)
RX packets 2408 bytes 194880 (190.3 KiB)
TX packets 2408 bytes 194880 (190.3 KiB)
#ifconfig enp5s0 up
ça se passe sans problème, sans message d’erreur.
#iwlist scan
lo Interface doesn't support scanning.
enp5s0 Interface doesn't support scanning.
#lspci -v
00:00.0 Host bridge: Intel Corporation 3rd Gen Core processor DRAM Controller (rev 09)
Subsystem: Lenovo 3rd Gen Core processor DRAM Controller
Flags: bus master, fast devsel, latency 0
Capabilities: [e0] Vendor Specific Information: Len=0c <?
Kernel driver in use: ivb_uncore
00:02.0 VGA compatible controller: Intel Corporation 3rd Gen Core processor Graphics Controller (rev 09) (prog-if 00 [VGA controller])
Subsystem: Lenovo 3rd Gen Core processor Graphics Controller
Flags: bus master, fast devsel, latency 0, IRQ 30
Memory at f0000000 (64-bit, non-prefetchable) [size=4M]
Memory at e0000000 (64-bit, prefetchable) [size=256M]
I/O ports at 5000 [size=64]
[virtual] Expansion ROM at 000c0000 [disabled] [size=128K]
Capabilities: [90] MSI: Enable+ Count=1/1 Maskable- 64bit-
Capabilities: [d0] Power Management version 2
Capabilities: [a4] PCI Advanced Features
Kernel driver in use: i915
Kernel modules: i915
00:14.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB xHCI Host Controller (rev 04) (prog-if 30 [XHCI])
Subsystem: Lenovo 7 Series/C210 Series Chipset Family USB xHCI Host Controller
Flags: bus master, medium devsel, latency 0, IRQ 26
Memory at f3700000 (64-bit, non-prefetchable) [size=64K]
Capabilities: [70] Power Management version 2
Capabilities: [80] MSI: Enable+ Count=1/8 Maskable- 64bit+
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
00:16.0 Communication controller: Intel Corporation 7 Series/C216 Chipset Family MEI Controller #1 (rev 04)
Subsystem: Lenovo 7 Series/C216 Chipset Family MEI Controller
Flags: bus master, fast devsel, latency 0, IRQ 28
Memory at f3715000 (64-bit, non-prefetchable) [size=16]
Capabilities: [50] Power Management version 3
Capabilities: [8c] MSI: Enable+ Count=1/1 Maskable- 64bit+
Kernel driver in use: mei_me
Kernel modules: mei_me
00:1a.0 USB controller: Intel Corporation 7 Series/C216 Chipset Family USB Enhanced Host Controller #2 (rev 04) (prog-if 20 [EHCI])
Subsystem: Lenovo 7 Series/C216 Chipset Family USB Enhanced Host Controller
Flags: bus master, medium devsel, latency 0, IRQ 16
Memory at f371a000 (32-bit, non-prefetchable) [size=1K]
Capabilities: [50] Power Management version 2
Capabilities: [58] Debug port: BAR=1 offset=00a0
Capabilities: [98] PCI Advanced Features
Kernel driver in use: ehci-pci
Kernel modules: ehci_pci
00:1b.0 Audio device: Intel Corporation 7 Series/C216 Chipset Family High Definition Audio Controller (rev 04)
Subsystem: Lenovo 7 Series/C216 Chipset Family High Definition Audio Controller
Flags: bus master, fast devsel, latency 0, IRQ 29
Memory at f3710000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
Capabilities: [100] Virtual Channel
Capabilities: [130] Root Complex Link
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
00:1c.0 PCI bridge: Intel Corporation 7 Series/C216 Chipset Family PCI Express Root Port 1 (rev c4) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 16
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
I/O behind bridge: 00004000-00004fff
Memory behind bridge: f2f00000-f36fffff
Prefetchable memory behind bridge: 00000000f0400000-00000000f0bfffff
Capabilities: [40] Express Root Port (Slot+), MSI 00
Capabilities: [80] MSI: Enable- Count=1/1 Maskable- 64bit-
Capabilities: [90] Subsystem: Lenovo 7 Series/C216 Chipset Family PCI Express Root Port 1
Capabilities: [a0] Power Management version 2
Kernel driver in use: pcieport
Kernel modules: shpchp
00:1c.1 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 2 (rev c4) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 17
Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
I/O behind bridge: 00003000-00003fff
Memory behind bridge: f2600000-f2efffff
Prefetchable memory behind bridge: 00000000f0c00000-00000000f13fffff
Capabilities: [90] Subsystem: Lenovo 7 Series/C210 Series Chipset Family PCI Express Root Port 2
00:1c.3 PCI bridge: Intel Corporation 7 Series/C216 Chipset Family PCI Express Root Port 4 (rev c4) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 19
Bus: primary=00, secondary=05, subordinate=05, sec-latency=0
I/O behind bridge: 00002000-00002fff
Memory behind bridge: f1d00000-f25fffff
Prefetchable memory behind bridge: 00000000f1400000-00000000f1cfffff
Capabilities: [90] Subsystem: Lenovo 7 Series/C216 Chipset Family PCI Express Root Port 4
00:1d.0 USB controller: Intel Corporation 7 Series/C216 Chipset Family USB Enhanced Host Controller #1 (rev 04) (prog-if 20 [EHCI])
Flags: bus master, medium devsel, latency 0, IRQ 23
Memory at f3719000 (32-bit, non-prefetchable) [size=1K]
00:1f.0 ISA bridge: Intel Corporation HM77 Express Chipset LPC Controller (rev 04)
Subsystem: Lenovo HM77 Express Chipset LPC Controller
Kernel driver in use: lpc_ich
Kernel modules: lpc_ich
00:1f.2 SATA controller: Intel Corporation 7 Series Chipset Family 6-port SATA Controller [AHCI mode] (rev 04) (prog-if 01 [AHCI 1.0])
Subsystem: Lenovo 7 Series Chipset Family 6-port SATA Controller [AHCI mode]
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 27
I/O ports at 5088 [size=8]
I/O ports at 509c [size=4]
I/O ports at 5080 [size=8]
I/O ports at 5098 [size=4]
I/O ports at 5060 [size=32]
Memory at f3718000 (32-bit, non-prefetchable) [size=2K]
Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit-
Capabilities: [70] Power Management version 3
Capabilities: [a8] SATA HBA v1.0
Capabilities: [b0] PCI Advanced Features
Kernel driver in use: ahci
Kernel modules: ahci
00:1f.3 SMBus: Intel Corporation 7 Series/C216 Chipset Family SMBus Controller (rev 04)
Subsystem: Lenovo 7 Series/C216 Chipset Family SMBus Controller
Flags: medium devsel, IRQ 18
Memory at f3714000 (64-bit, non-prefetchable) [size=256]
I/O ports at efa0 [size=32]
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
03:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS5229 PCI Express Card Reader (rev 01)
Subsystem: Lenovo RTS5229 PCI Express Card Reader
Flags: bus master, fast devsel, latency 0, IRQ 24
Memory at f2f00000 (32-bit, non-prefetchable) [size=4K]
Capabilities: [40] Power Management version 3
Capabilities: [50] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [70] Express Endpoint, MSI 00
Capabilities: [100] Advanced Error Reporting
Capabilities: [140] Device Serial Number 00-00-00-01-00-4c-e0-00
Kernel driver in use: rtsx_pci
Kernel modules: rtsx_pci
04:00.0 Network controller: Intel Corporation Centrino Wireless-N 2230 (rev c4)
Subsystem: Intel Corporation Centrino Wireless-N 2230 BGN
Flags: fast devsel, IRQ 17
Memory at f2600000 (64-bit, non-prefetchable) [size=8K]
Capabilities: [c8] Power Management version 3
Capabilities: [d0] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [e0] Express Endpoint, MSI 00
Capabilities: [140] Device Serial Number 00-c2-c6-ff-ff-3a-fd-e0
Kernel modules: iwlwifi
05:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 07)
Subsystem: Lenovo RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
Flags: bus master, fast devsel, latency 0, IRQ 25
I/O ports at 2000 [size=256]
Memory at f1d00000 (64-bit, non-prefetchable) [size=4K]
Memory at f1400000 (64-bit, prefetchable) [size=16K]
Capabilities: [70] Express Endpoint, MSI 01
Capabilities: [b0] MSI-X: Enable- Count=4 Masked-
Capabilities: [d0] Vital Product Data
Capabilities: [140] Virtual Channel
Capabilities: [160] Device Serial Number 01-00-00-00-68-4c-e0-00
Kernel driver in use: r8169
Kernel modules: r8169
root@debian:/home/chaouch# lspci -v | grep network
root@debian:/home/chaouch# lspci -v | grep Network controller
grep: controller: Aucun fichier ou dossier de ce type
root@debian:/home/chaouch# lspci -v | grep Centrino Wireless
grep: Wireless: Aucun fichier ou dossier de ce type
Ce qui correspond à la carte wifi est :
(Je me connecte grâce au Wifi).
#route
Table de routage IP du noyau
Destination Passerelle Genmask Indic Metric Ref Use Iface
default 0.0.0.0 0.0.0.0 U 1002 0 0 enp5s0
link-local 0.0.0.0 255.255.0.0 U 0 0 0 enp5s0
#cat /etc/network/interfaces
# This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5).
auto lo
iface lo inet loopback
Ma question est donc:comment dois-je palier à ce probleme de wifi pour aller sur le net? et je vous remercie d’avance pour vos réponses.
