Je viens de commander un pc portable sur LDLC, et je teste pour la première fois Debian (même si en réalité je viens d’Ubuntu).
Mon soucis est que je n’arrive pas à trouver de pilotes pour ma carte graphique (Intel HD Graphics 620) et pour ma carte wi-fi (Intel ???).
Voici un détail des périphériques:
leorphalis@leorphalis:~$ lspci -vnn 00:00.0 Host bridge [0600]: Intel Corporation Device [8086:5904] (rev 02) Subsystem: CLEVO/KAPOK Computer Device [1558:0750] Flags: bus master, fast devsel, latency 0 Capabilities:`
00:02.0 VGA compatible controller [0300]: Intel Corporation Device [8086:5916] (rev 02) (prog-if 00 [VGA controller])
Flags: bus master, fast devsel, latency 0, IRQ 255
Memory at de000000 (64-bit, non-prefetchable) [size=16M]
Memory at c0000000 (64-bit, prefetchable) [size=256M]
I/O ports at f000 [size=64]
Expansion ROM at <unassigned> [disabled]
Capabilities: <access denied>
00:08.0 System peripheral [0880]: Intel Corporation Device [8086:1911]
Flags: fast devsel, IRQ 255
Memory at df22f000 (64-bit, non-prefetchable) [disabled] [size=4K]
00:14.0 USB controller [0c03]: Intel Corporation Device [8086:9d2f] (rev 21) (prog-if 30 [XHCI])
Flags: bus master, medium devsel, latency 0, IRQ 138
Memory at df210000 (64-bit, non-prefetchable) [size=64K]
Kernel driver in use: xhci_hcd
00:14.2 Signal processing controller [1180]: Intel Corporation Device [8086:9d31] (rev 21)
Memory at df22e000 (64-bit, non-prefetchable) [size=4K]
00:16.0 Communication controller [0780]: Intel Corporation Device [8086:9d3a] (rev 21)
Memory at df22d000 (64-bit, non-prefetchable) [disabled] [size=4K]
00:17.0 SATA controller [0106]: Intel Corporation Device [8086:9d03] (rev 21) (prog-if 01 [AHCI 1.0])
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 141
Memory at df228000 (32-bit, non-prefetchable) [size=8K]
Memory at df22c000 (32-bit, non-prefetchable) [size=256]
I/O ports at f090 [size=8]
I/O ports at f080 [size=4]
I/O ports at f060 [size=32]
Memory at df22b000 (32-bit, non-prefetchable) [size=2K]
Kernel driver in use: ahci
00:1c.0 PCI bridge [0604]: Intel Corporation Device [8086:9d10] (rev f1) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 00002000-00002fff
Memory behind bridge: 8cc00000-8cdfffff
Prefetchable memory behind bridge: 000000008ce00000-000000008cffffff
Kernel driver in use: pcieport
00:1c.3 PCI bridge [0604]: Intel Corporation Device [8086:9d13] (rev f1) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 0000e000-0000efff
Memory behind bridge: df100000-df1fffff
Capabilities:<access denied>
00:1c.4 PCI bridge [0604]: Intel Corporation Device [8086:9d14] (rev f1) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
Memory behind bridge: df000000-df0fffff
00:1f.0 ISA bridge [0601]: Intel Corporation Device [8086:9d4e] (rev 21)
00:1f.2 Memory controller [0580]: Intel Corporation Device [8086:9d21] (rev 21)
Flags: fast devsel
Memory at df224000 (32-bit, non-prefetchable) [disabled] [size=16K]
00:1f.3 Audio device [0403]: Intel Corporation Device [8086:9d71] (rev 21)
Subsystem: CLEVO/KAPOK Computer Device [1558:0751]
Flags: bus master, fast devsel, latency 32, IRQ 142
Memory at df220000 (64-bit, non-prefetchable) [size=16K]
Memory at df200000 (64-bit, non-prefetchable) [size=64K]
Kernel driver in use: snd_hda_intel
00:1f.4 SMBus [0c05]: Intel Corporation Device [8086:9d23] (rev 21)
Flags: medium devsel, IRQ 255
Memory at df22a000 (64-bit, non-prefetchable) [size=256]
I/O ports at f040 [size=32]
02:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. Device [10ec:5287] (rev 01)
Flags: bus master, fast devsel, latency 0, IRQ 140
Memory at df115000 (32-bit, non-prefetchable) [size=4K]
Expansion ROM at df100000 [disabled] [size=64K]
Kernel driver in use: rtsx_pci
02:00.1 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 12)
Flags: bus master, fast devsel, latency 0, IRQ 139
I/O ports at e000 [size=256]
Memory at df114000 (64-bit, non-prefetchable) [size=4K]
Memory at df110000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: r8169
03:00.0 Network controller [0280]: Intel Corporation Device [8086:24fb] (rev 10)
Subsystem: Intel Corporation Device [8086:2110]
Memory at df000000 (64-bit, non-prefetchable) [disabled] [size=8K]
Capabilities:` ``
Je ne trouve pas de drivers adéquats sur le site d’Intel, et je ne sais pas vraiment dans quelle direction aller. Dans cette situation, avez-vous une idée ou des conseils? Merci!
) Merci beaucoup beaucoup pour votre aide. Le dernier message de robert2a a synthétisé tous vos conseils, et mes composants fonctionnent enfin!
