c’est un peut long
[code]
X Window System Version 7.1.1
Release Date: 12 May 2006
X Protocol Version 11, Revision 0, Release 7.1.1
Build Operating System: UNKNOWN
Current Operating System: Linux debian 2.6.18-4-486 #1 Wed Feb 21 15:25:16 UTC 2007 i686
Build Date: 07 March 2007
Before reporting problems, check http://wiki.x.org
Module Loader present
Markers: (–) probed, () from config file, (==) default setting,
(==) Log file: “/var/log/Xorg.0.log”, Time: Fri Mar 23 23:38:29 2007
(==) Using config file: “/etc/X11/xorg.conf”
(==) ServerLayout “Default Layout”
() |–>Screen “aticonfig-Screen[0]” (0)
() | |–>Monitor “aticonfig-Monitor[0]”
() | |–>Device “aticonfig-Device[0]”
() |–>Input Device “Generic Keyboard”
() |–>Input Device “Configured Mouse”
(WW) The directory “/usr/X11R6/lib/X11/fonts/misc” does not exist.
Entry deleted from font path.
(WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
(WW) The directory “/usr/X11R6/lib/X11/fonts/Type1” does not exist.
(WW) The directory “/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType” does not exist.
(==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
(==) RgbPath set to “/etc/X11/rgb”
(==) ModulePath set to “/usr/lib/xorg/modules”
(II) Open ACPI successful (/var/run/acpid.socket)
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.3
X.Org Video Driver: 1.0
X.Org XInput driver : 0.6
X.Org Server Extension : 0.3
X.Org Font Renderer : 0.5
(II) Loader running on linux
(II) LoadModule: “bitmap”
(II) Loading /usr/lib/xorg/modules/fonts/libbitmap.so
(II) Module bitmap: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 1.0.0
Module class: X.Org Font Renderer
ABI class: X.Org Font Renderer, version 0.5
(II) Loading font Bitmap
(II) LoadModule: “pcidata”
(II) Loading /usr/lib/xorg/modules/libpcidata.so
(II) Module pcidata: vendor="X.Org Foundation"
ABI class: X.Org Video Driver, version 1.0
(++) using VT number 7
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 10de,01e0 card 1849,01e0 rev c1 class 06,00,00 hdr 80
(II) PCI: 00:00:1: chip 10de,01eb card 1849,01eb rev c1 class 05,00,00 hdr 80
(II) PCI: 00:00:2: chip 10de,01ee card 1849,01ee rev c1 class 05,00,00 hdr 80
(II) PCI: 00:00:3: chip 10de,01ed card 1849,01ed rev c1 class 05,00,00 hdr 80
(II) PCI: 00:00:4: chip 10de,01ec card 1849,01ec rev c1 class 05,00,00 hdr 80
(II) PCI: 00:00:5: chip 10de,01ef card 1849,01ef rev c1 class 05,00,00 hdr 80
(II) PCI: 00:01:0: chip 10de,0080 card 1849,0080 rev a3 class 06,01,00 hdr 80
(II) PCI: 00:01:1: chip 10de,0084 card 1849,0084 rev a1 class 0c,05,00 hdr 80
(II) PCI: 00:02:0: chip 10de,0087 card 1849,0087 rev a1 class 0c,03,10 hdr 80
(II) PCI: 00:02:1: chip 10de,0087 card 1849,0087 rev a1 class 0c,03,10 hdr 80
(II) PCI: 00:02:2: chip 10de,0088 card 1849,0088 rev a2 class 0c,03,20 hdr 80
(II) PCI: 00:04:0: chip 10de,008c card 1849,0900 rev a3 class 06,80,00 hdr 00
(II) PCI: 00:06:0: chip 10de,008a card 1849,9761 rev a1 class 04,01,00 hdr 00
(II) PCI: 00:08:0: chip 10de,008b card 0000,0000 rev a3 class 06,04,00 hdr 01
(II) PCI: 00:09:0: chip 10de,0085 card 1849,0085 rev a3 class 01,01,8a hdr 00
(II) PCI: 00:0b:0: chip 10de,008e card 1849,008e rev a3 class 01,01,85 hdr 00
(II) PCI: 00:1e:0: chip 10de,01e8 card 0000,0000 rev c1 class 06,04,00 hdr 01
(II) PCI: 01:00:0: chip 1002,5962 card 174b,0e06 rev 01 class 03,00,00 hdr 80
(II) PCI: 01:00:1: chip 1002,5942 card 174b,0e07 rev 01 class 03,80,00 hdr 00
(II) PCI: 02:0a:0: chip 10ec,8139 card 10ec,8139 rev 10 class 02,00,00 hdr 00
(II) PCI: End of PCI scan
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,2), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
(II) Bus 0 prefetchable memory range:
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:1:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(II) PCI-to-PCI bridge:
(II) Bus 2: bridge is at (0:8:0), (0,2,2), BCTRL: 0x0002 (VGA_EN is cleared)
(II) Bus 2 I/O range:
[0] -1 0 0x0000c000 - 0x0000cfff (0x1000) IX[B]
(II) Bus 2 non-prefetchable memory range:
[0] -1 0 0xff500000 - 0xff5fffff (0x100000) MX[B]
(II) Bus 1: bridge is at (0:30:0), (0,1,1), BCTRL: 0x000b (VGA_EN is set)
(II) Bus 1 I/O range:
[0] -1 0 0x0000b000 - 0x0000bfff (0x1000) IX[B]
(II) Bus 1 non-prefetchable memory range:
[0] -1 0 0xff400000 - 0xff4fffff (0x100000) MX[B]
(II) Bus 1 prefetchable memory range:
[0] -1 0 0xd6b00000 - 0xf6afffff (0x20000000) MX[B]
(–) PCI:*(1:0:0) ATI Technologies Inc RV280 [Radeon 9200] rev 1, Mem @ 0xe8000000/27, 0xff4f0000/16, I/O @ 0xb800/8, BIOS @ 0xff4c0000/17
(–) PCI: (1:0:1) ATI Technologies Inc unknown chipset (0x5942) rev 1, Mem @ 0xe0000000/27, 0xff4e0000/16
(II) Addressable bus resource ranges are
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
[0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[5] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) PCI Memory resource overlap reduced 0xf8000000 from 0xfbffffff to 0xf7ffffff
(II) Active PCI resource ranges:
[0] -1 0 0xff5ffc00 - 0xff5ffcff (0x100) MX[B]
[1] -1 0 0xff6ff000 - 0xff6fffff (0x1000) MX[B]
[2] -1 0 0xff6fe000 - 0xff6fefff (0x1000) MX[B]
[3] -1 0 0xff6fdc00 - 0xff6fdcff (0x100) MX[B]
[4] -1 0 0xff6fc000 - 0xff6fcfff (0x1000) MX[B]
[5] -1 0 0xff6fb000 - 0xff6fbfff (0x1000) MX[B]
[6] -1 0 0xf8000000 - 0xf7ffffff (0x0) MX[B]O
[7] -1 0 0xff4e0000 - 0xff4effff (0x10000) MXB
[8] -1 0 0xe0000000 - 0xe7ffffff (0x8000000) MXB
[9] -1 0 0xff4c0000 - 0xff4dffff (0x20000) MXB
[10] -1 0 0xff4f0000 - 0xff4fffff (0x10000) MXB
[11] -1 0 0xe8000000 - 0xefffffff (0x8000000) MXB
[12] -1 0 0x0000c800 - 0x0000c8ff (0x100) IX[B]
[13] -1 0 0x0000e000 - 0x0000e07f (0x80) IX[B]
[14] -1 0 0x0000e400 - 0x0000e40f (0x10) IX[B]
[15] -1 0 0x00000fe0 - 0x00000fe3 (0x4) IX[B]
[16] -1 0 0x00000fe8 - 0x00000fef (0x8) IX[B]
[17] -1 0 0x00000ff0 - 0x00000ff3 (0x4) IX[B]
[18] -1 0 0x00000ff8 - 0x00000fff (0x8) IX[B]
[19] -1 0 0x0000ffa0 - 0x0000ffaf (0x10) IX[B]
[20] -1 0 0x0000e800 - 0x0000e87f (0x80) IX[B]
[21] -1 0 0x0000d800 - 0x0000d8ff (0x100) IX[B]
[22] -1 0 0x0000dc00 - 0x0000dc07 (0x8) IX[B]
[23] -1 0 0x0000d480 - 0x0000d49f (0x20) IX[B]
[24] -1 0 0x0000b800 - 0x0000b8ff (0x100) IXB
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[4] -1 0 0xff5ffc00 - 0xff5ffcff (0x100) MX[B]
[5] -1 0 0xff6ff000 - 0xff6fffff (0x1000) MX[B]
[6] -1 0 0xff6fe000 - 0xff6fefff (0x1000) MX[B]
[7] -1 0 0xff6fdc00 - 0xff6fdcff (0x100) MX[B]
[8] -1 0 0xff6fc000 - 0xff6fcfff (0x1000) MX[B]
[9] -1 0 0xff6fb000 - 0xff6fbfff (0x1000) MX[B]
[10] -1 0 0xf8000000 - 0xf7ffffff (0x0) MX[B]O
[11] -1 0 0xff4e0000 - 0xff4effff (0x10000) MXB
[12] -1 0 0xe0000000 - 0xe7ffffff (0x8000000) MXB
[13] -1 0 0xff4c0000 - 0xff4dffff (0x20000) MXB
[14] -1 0 0xff4f0000 - 0xff4fffff (0x10000) MXB
[15] -1 0 0xe8000000 - 0xefffffff (0x8000000) MXB
[16] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[17] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[18] -1 0 0x0000c800 - 0x0000c8ff (0x100) IX[B]
[19] -1 0 0x0000e000 - 0x0000e07f (0x80) IX[B]
[20] -1 0 0x0000e400 - 0x0000e40f (0x10) IX[B]
[21] -1 0 0x00000fe0 - 0x00000fe3 (0x4) IX[B]
[22] -1 0 0x00000fe8 - 0x00000fef (0x8) IX[B]
[23] -1 0 0x00000ff0 - 0x00000ff3 (0x4) IX[B]
[24] -1 0 0x00000ff8 - 0x00000fff (0x8) IX[B]
[25] -1 0 0x0000ffa0 - 0x0000ffaf (0x10) IX[B]
[26] -1 0 0x0000e800 - 0x0000e87f (0x80) IX[B]
[27] -1 0 0x0000d800 - 0x0000d8ff (0x100) IX[B]
[28] -1 0 0x0000dc00 - 0x0000dc07 (0x8) IX[B]
[29] -1 0 0x0000d480 - 0x0000d49f (0x20) IX[B]
[30] -1 0 0x0000b800 - 0x0000b8ff (0x100) IXB
(II) Reloading /usr/lib/xorg/modules/fonts/libbitmap.so
(II) LoadModule: “ddc”
(II) Loading /usr/lib/xorg/modules/libddc.so
(II) Module ddc: vendor="X.Org Foundation"
(II) LoadModule: “dri”
(II) Loading /usr/lib/xorg/modules/extensions/libdri.so
(II) Module dri: vendor="X.Org Foundation"
ABI class: X.Org Server Extension, version 0.3
(II) Loading sub module “drm”
(II) LoadModule: “drm”
(II) Loading /usr/lib/xorg/modules/linux/libdrm.so
(II) Module drm: vendor="X.Org Foundation"
(II) Loading extension XFree86-DRI
(II) LoadModule: “extmod”
(II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
Module class: X.Org Server Extension
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: “freetype”
(II) Loading /usr/lib/xorg/modules/fonts/libfreetype.so
(II) Module freetype: vendor="X.Org Foundation & the After X-TT Project"
compiled for 7.1.1, module version = 2.1.0
(II) Loading font FreeType
(II) LoadModule: “glx”
(II) Loading /usr/lib/xorg/modules/extensions/libglx.so
(II) Module glx: vendor="X.Org Foundation"
(==) AIGLX enabled
(II) Loading extension GLX
(II) LoadModule: “int10”
(II) Loading /usr/lib/xorg/modules/libint10.so
(II) Module int10: vendor="X.Org Foundation"
(II) LoadModule: “vbe”
(II) Loading /usr/lib/xorg/modules/libvbe.so
(II) Module vbe: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 1.1.0
(II) LoadModule: “fglrx”
(II) Loading /usr/lib/xorg/modules/drivers/fglrx_drv.so
(II) Module fglrx: vendor="FireGL - ATI Technologies Inc."
compiled for 7.1.0, module version = 8.28.8
Module class: X.Org Video Driver
(II) LoadModule: “kbd”
(II) Loading /usr/lib/xorg/modules/input/kbd_drv.so
(II) Module kbd: vendor="X.Org Foundation"
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 0.6
(II) LoadModule: “mouse”
(II) Loading /usr/lib/xorg/modules/input/mouse_drv.so
(II) Module mouse: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 1.1.1
(II) ATI Radeon/FireGL: The following chipsets are supported:
RADEON 9000/9000 PRO (RV250 4966), RADEON 9000 LE (RV250 4967),
MOBILITY FireGL 9000 (M9 4C64), MOBILITY RADEON 9000 (M9 4C66),
RADEON 9000 PRO (D9 4C67), RADEON 9250 (RV280 5960),
RADEON 9250/9200 Series (RV280 5961),
RADEON 9250/9200 Series (RV280 5962),
RADEON 9250/9200 Series (RV280 5964), FireMV 2200 PCI (RV280 5965),
MOBILITY RADEON 9200 (M9+ 5C61), MOBILITY RADEON 9200 (M9+ 5C63),
FireGL 8800 (R200 5148), RADEON 8500 (R200 514C),
RADEON 9100 (R200 514D), RADEON 8500 AIW (R200 4242),
RADEON 9600 (RV350 4150), RADEON 9600 SE (RV350 4151),
RADEON 9600 PRO (RV360 4152), RADEON 9600 (RV350 4E51),
MOBILITY RADEON 9600/9700 (M10/M11 4E50),
MOBILITY RADEON 9500 (M11 4E52), MOBILITY RADEON 9550 (M12 4E56),
RADEON 9500 (R300 4144), RADEON 9600 TX (R300 4146),
FireGL Z1 (R300 4147), RADEON 9700 PRO (R300 4E44),
RADEON 9500 PRO/9700 (R300 4E45), RADEON 9600 TX (R300 4E46),
FireGL X1 (R300 4E47), RADEON 9800 SE (R350 4148),
RADEON 9500 (R350 4149), RADEON 9550 (RV350 4153),
FireGL T2 (RV350 4154), RADEON 9600 (RV351 4155),
RADEON 9800 PRO (R350 4E48), RADEON 9800 (R350 4E49),
RADEON 9800 XT (R360 4E4A), FireGL X2-256/X2-256t (R350 4E4B),
MOBILITY FireGL T2/T2e (M10/M11 4E54), RADEON X300/X550 (RV370 5B60),
RADEON X600 (RV380 5B62), RADEON X550 (RV370 5B63),
FireGL V3100 (RV370 5B64), FireMV 2200 (RV370 5B65),
MOBILITY RADEON X300 (M22 5460), MOBILITY RADEON X300 (M22 5461),
MOBILITY RADEON X600 SE (M24 5462), MOBILITY FireGL V3100 (M22 5464),
RADEON X600/X550 Series (RV380 3E50), FireGL V3200 (RV380 3E54),
MOBILITY RADEON X600 (M24 3150), MOBILITY RADEON X300 (M22 3152),
MOBILITY FireGL V3200 (M24 3154), RADEON X800 (R420 4A48),
RADEON X800 PRO (R420 4A49), RADEON X800 SE (R420 4A4A),
RADEON X800 XT (R420 4A4B), RADEON X800 (R420 4A4C),
FireGL X3-256 (R420 4A4D), MOBILITY RADEON 9800 (M18 4A4E),
RADEON X800 SE (R420 4A4F),
RADEON X800 XT Platinum Edition (R420 4A50),
RADEON X800 VE (R420 4A54), RADEON X800 (R423 5548),
RADEON X800 GTO (R423 5549),
RADEON X800 XT Platinum Edition (R423 554A),
RADEON X800 GT (R423 554B), RADEON X800 XT (R423 5D57),
FireGL V7100 (R423 5550), FireGL V5100 (R423 5551),
MOBILITY RADEON X800 XT (M28 5D48), MOBILITY FireGL V5100 (M28 5D49),
MOBILITY RADEON X800 (M28 5D4A), RADEON X800 XL (R430 554D),
RADEON X800 GT (R430 554E), RADEON X800 GTO (R430 554F),
RADEON X850 XT Platinum Edition (R480 5D4D),
RADEON X800 GTO (R480 5D4F), FireGL V7200 (R480 5D50),
RADEON X850 XT (R480 5D52), RADEON X850 (R481 4B48),
RADEON X850 XT (R481 4B49), RADEON X850 SE (R481 4B4A),
RADEON X850 PRO (R481 4B4B),
RADEON X850 XT Platinum Edition (R481 4B4C),
MOBILITY FireGL V5000 (M26 564A), MOBILITY FireGL V5000 (M26 564B),
FireGL V5000 (RV410 5E48), RADEON X700 XT (RV410 5E4A),
RADEON X700 PRO (RV410 5E4B), RADEON X700 SE (RV410 5E4C),
RADEON X700 (RV410 5E4D), RADEON X700/X550 Series (RV410 5E4F),
MOBILITY RADEON X700 (M26 5652), MOBILITY RADEON X700 (M26 5653),
MOBILITY RADEON X700 XL (M26-XC 564F),
RADEON 9000/9100 IGP Series (RS300 5834),
RADEON 9000 PRO/9100 PRO IGP (RS350 7834),
MOBILITY RADEON 9000 IGP (RL300MB 7835),
MOBILITY RADEON 9000/9100 IGP (RS300M 5835),
RADEON XPRESS 200 (RS400 5A41), RADEON XPRESS 200M (RS400 5A42),
RADEON XPRESS 200 (RS480 5954), RADEON XPRESS 200M (RS480 5955),
RADEON XPRESS 200 (RS482 5974), RADEON XPRESS 200M (RS482 5975),
RADEON XPRESS 200 (RC410 5A61), RADEON XPRESS 200M (RC410 5A62),
RADEON X1800 (R520 7100), MOBILITY RADEON X1800 XT (M58 7101),
MOBILITY RADEON X1800 (M58 7102), MOBILITY FireGL V7200 (M58 7103),
FireGL V7200 (R520 7104), FireGL V5300 (R520 7105),
MOBILITY FireGL V7100 (M58 7106), RADEON X1800 Series (R520 7108),
RADEON X1800 Series (R520 7109), RADEON X1800 Series (R520 710A),
RADEON X1800 Series (R520 710B), RADEON X1800 Series (R520 710C),
FireGL V7300 (R520 710E), FireGL V7350 (R520 710F),
MOBILITY RADEON X1300 (M52 714B), MOBILITY RADEON X1300 (M52 714C),
RADEON X1600 Series (RV515 7140), RADEON X1300 Series (RV515 7142),
MOBILITY FireGL (M54 GL 7144), MOBILITY RADEON X1400 (M54 7145),
RADEON X1300 Series (RV515 7146), MOBILITY RADEON X1300 (M52 7149),
MOBILITY RADEON X1300 (M52 714A), RADEON X1300 Series (RV515 714D),
RADEON X1300 Series (RV515 714E), FireGL V3300 (RV515 7152),
RADEON X1300 Series (RV515 715E), RADEON X1300 (RV516 7180),
RADEON X1600 Series (RV516 7181), RADEON X1300 (RV516 7183),
MOBILITY RADEON X1450 (M64P 7186), RADEON X1300 (RV516 7187),
MOBILITY RADEON X1350 (M62P 718B),
MOBILITY RADEON X1350 (M62CSP 718C),
MOBILITY RADEON X1450 (M64CSP 718D),
MOBILITY RADEON X1350 (M62S 7196), RADEON X1900 (R580 7240),
RADEON X1900 (R580 7243), RADEON X1900 (R580 7244),
RADEON X1900 (R580 7245), RADEON X1900 (R580 7246),
RADEON X1900 (R580 7247), RADEON X1900 (R580 7248),
RADEON X1900 (R580 7249), RADEON X1900 (R580 724A),
RADEON X1900 (R580 724B), RADEON X1900 (R580 724C),
RADEON X1900 (R580 724D), FireStream 2U (R580 724E),
FireStream 2U (R580 724F), RADEON X1600 Series (RV530 71C0),
RADEON X1600 Series (RV530 71C2), MOBILITY FireGL V5200 (M56 71C4),
MOBILITY RADEON X1600 (M56 71C5),
RADEON X1600 Series (RV530 LE 71C6),
RADEON X1600 Series (RV530 VE 71CE), FireGL V3400 (RV530 71D2),
MOBILITY RADEON X1700 (M66-XT 71D6), FireGL V5200 (RV530 71DA),
RADEON X1600 Series (RV530 SE 71DE), RADEON X1600 XT (RV535 XT 71C1),
MOBILITY FireGL V5250 (M66GL 71D4),
MOBILITY RADEON X1700 (M66-P 71D5), RADEON Xpress 1200 (RS600 7941),
RADEON Xpress 1200 (RS600 7942)
(II) Primary Device is: PCI 01:00:0
(II) ATI Proprietary Linux Driver Version Identifier:8.28.8
(II) ATI Proprietary Linux Driver Release Identifier: LGDr8.28g1
(II) ATI Proprietary Linux Driver Build Date: Aug 17 2006 09:28:12
(II) ATI Proprietary Linux Driver Build Information: autobuild-rel-r6-8.28.1.1.2.3-driver-lnx-x86-x86_64-287161
(–) Assigning device section with no busID to primary device
(WW) fglrx: No matching Device section for instance (BusID PCI:1:0:1) found
(–) Chipset RADEON 9250/9200 Series (RV280 5962) found
(II) resource ranges after xf86ClaimFixedResources() call:
(II) fglrx(0): pEnt->device->identifier=0x81e3400
(II) resource ranges after probing:
[16] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
[17] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
[18] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
[19] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[20] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[21] -1 0 0x0000c800 - 0x0000c8ff (0x100) IX[B]
[22] -1 0 0x0000e000 - 0x0000e07f (0x80) IX[B]
[23] -1 0 0x0000e400 - 0x0000e40f (0x10) IX[B]
[24] -1 0 0x00000fe0 - 0x00000fe3 (0x4) IX[B]
[25] -1 0 0x00000fe8 - 0x00000fef (0x8) IX[B]
[26] -1 0 0x00000ff0 - 0x00000ff3 (0x4) IX[B]
[27] -1 0 0x00000ff8 - 0x00000fff (0x8) IX[B]
[28] -1 0 0x0000ffa0 - 0x0000ffaf (0x10) IX[B]
[29] -1 0 0x0000e800 - 0x0000e87f (0x80) IX[B]
[30] -1 0 0x0000d800 - 0x0000d8ff (0x100) IX[B]
[31] -1 0 0x0000dc00 - 0x0000dc07 (0x8) IX[B]
[32] -1 0 0x0000d480 - 0x0000d49f (0x20) IX[B]
[33] -1 0 0x0000b800 - 0x0000b8ff (0x100) IXB
[34] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
[35] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
(II) fglrx(0): === [R200PreInit] === begin, [s]
(II) Loading sub module “vgahw”
(II) LoadModule: “vgahw”
(II) Loading /usr/lib/xorg/modules/libvgahw.so
(II) Module vgahw: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 0.1.0
(II) fglrx(0): PCI bus 1 card 0 func 0
() fglrx(0): Depth 24, (–) framebuffer bpp 32
(II) fglrx(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
(==) fglrx(0): Default visual is TrueColor
() fglrx(0): Option “OpenGLOverlay” “off”
() fglrx(0): Option “VideoOverlay” “on”
() fglrx(0): Option “DesktopSetup” “horizontal”
() fglrx(0): Option “OverlayOnCRTC2” “1”
() fglrx(0): Option “DPMS” “true”
(==) fglrx(0): RGB weight 888
(II) fglrx(0): Using 8 bits per RGB (8 bit DAC)
(==) fglrx(0): Gamma Correction for I is 0x06419064
(==) fglrx(0): Gamma Correction for II is 0x06419064
(==) fglrx(0): Buffer Tiling is ON
(II) Loading sub module “int10”
(II) Reloading /usr/lib/xorg/modules/libint10.so
(II) Loading sub module “vm86”
(II) LoadModule: “vm86”
(II) Loading /usr/lib/xorg/modules/libvm86.so
(II) Module vm86: vendor="X.Org Foundation"
(II) fglrx(0): Primary V_BIOS segment is: 0xc000
(–) fglrx(0): Chipset: “RADEON 9250/9200 Series (RV280 5962)” (Chipset = 0x5962)
(–) fglrx(0): (PciSubVendor = 0x174b, PciSubDevice = 0x0e06)
(–) fglrx(0): board vendor info: third party graphics adapter - NOT original ATI
(–) fglrx(0): Linear framebuffer (phys) at 0xe8000000
(–) fglrx(0): MMIO registers at 0xff4f0000
(==) fglrx(0): ROM-BIOS at 0x000c0000
(II) Loading sub module “vbe”
(II) Reloading /usr/lib/xorg/modules/libvbe.so
(II) fglrx(0): VESA BIOS detected
(II) fglrx(0): VESA VBE Version 2.0
(II) fglrx(0): VESA VBE Total Mem: 16384 kB
(II) fglrx(0): VESA VBE OEM: ATI RADEON 9200
(II) fglrx(0): VESA VBE OEM Software Rev: 1.0
(II) fglrx(0): VESA VBE OEM Vendor: ATI Technologies Inc.
(II) fglrx(0): VESA VBE OEM Product: V280
(II) fglrx(0): VESA VBE OEM Product Rev: 01.00
(II) Reloading /usr/lib/xorg/modules/linux/libdrm.so
drmOpenDevice: node name is /dev/dri/card0
drmOpenDevice: open result is 8, (OK)
drmGetBusid returned ‘’
(II) Loading sub module “fglrxdrm”
(II) LoadModule: “fglrxdrm”
(II) Loading /usr/lib/xorg/modules/linux/libfglrxdrm.so
(II) Module fglrxdrm: vendor="FireGL - ATI Technologies Inc."
(–) fglrx(0): VideoRAM: 131072 kByte, Type: DDR SGRAM / SDRAM
(II) fglrx(0): AGP card detected
(WW) fglrx(0): board is an unknown third party board, chipset is supported
(II) Loading sub module “ddc”
(II) Reloading /usr/lib/xorg/modules/libddc.so
(II) fglrx(0): Connected Display1: CRT on primary DAC
(II) fglrx(0): Display1 EDID data ---------------------------
(II) fglrx(0): Manufacturer: REL Model: 786 Serial#: 16843009
(II) fglrx(0): Year: 1998 Week: 44
(II) fglrx(0): EDID Version: 1.1
(II) fglrx(0): Analog Display Input, Input Voltage Level: 0.714/0.286 V
(II) fglrx(0): Sync: Separate Composite
(II) fglrx(0): Max H-Image Size [cm]: horiz.: 31 vert.: 23
(II) fglrx(0): Gamma: 1.35
(II) fglrx(0): DPMS capabilities: StandBy Suspend Off; RGB/Color Display
(II) fglrx(0): redX: 0.609 redY: 0.342 greenX: 0.298 greenY: 0.588
(II) fglrx(0): blueX: 0.150 blueY: 0.063 whiteX: 0.280 whiteY: 0.311
(II) fglrx(0): Supported VESA Video Modes:
(II) fglrx(0): 720x400@70Hz
(II) fglrx(0): 640x480@60Hz
(II) fglrx(0): 640x480@75Hz
(II) fglrx(0): 800x600@75Hz
(II) fglrx(0): 1280x1024@75Hz
(II) fglrx(0): Manufacturer’s mask: 0
(II) fglrx(0): Supported Future Video Modes:
(II) fglrx(0): #0: hsize: 640 vsize 480 refresh: 70 vid: 18993
(II) fglrx(0): #1: hsize: 800 vsize 600 refresh: 85 vid: 22853
(II) fglrx(0): #2: hsize: 1280 vsize 960 refresh: 60 vid: 16513
(II) fglrx(0): #3: hsize: 1280 vsize 960 refresh: 85 vid: 22913
(II) fglrx(0): Supported additional Video Mode:
(II) fglrx(0): clock: 148.5 MHz Image Size: 312 x 232 mm
(II) fglrx(0): h_active: 1280 h_sync: 1328 h_sync_end 1488 h_blank_end 1728 h_border: 0
(II) fglrx(0): v_active: 960 v_sync: 971 v_sync_end 974 v_blanking: 1011 v_border: 0
(II) fglrx(0): Ranges: V min: 40 V max: 160 Hz, H min: 30 H max: 88 kHz, PixClock max 130 MHz
(II) fglrx(0): Monitor name: Relisys 786
(II) fglrx(0): Serial No: TX88100706
(II) fglrx(0): End of Display1 EDID data --------------------
(II) fglrx(0): Primary Controller - CRT on primary DAC
(II) fglrx(0): Internal Desktop Setting: 0x00000010
(II) fglrx(0): POWERplay version 3. 1 power state available:
(II) fglrx(0): 1. 241/164MHz @ 50Hz [enable load balancing]
(==) fglrx(0): Qbs disabled
(==) fglrx(0): FAST_SWAP disabled
(==) fglrx(0): PseudoColor visuals disabled
(==) fglrx(0): Using gamma correction (1.0, 1.0, 1.0)
(==) fglrx(0): Center Mode is disabled
(==) fglrx(0): TMDS coherent mode is enabled
(II) fglrx(0): Total of 36 modes found for primary display.
(–) fglrx(0): Virtual size is 1280x1024 (pitch 0)
() fglrx(0): *Mode “1280x1024”: 135.0 MHz (scaled from 0.0 MHz), 80.0 kHz, 75.0 Hz
(II) fglrx(0): Modeline “1280x1024” 135.00 1280 1296 1440 1688 1024 1025 1028 1066
() fglrx(0): Default mode “1280x1024”: 128.9 MHz (scaled from 0.0 MHz), 74.6 kHz, 70.0 Hz
(II) fglrx(0): Modeline “1280x1024” 128.94 1280 1368 1504 1728 1024 1025 1028 1066 +hsync
() fglrx(0): Default mode “1280x1024”: 108.0 MHz (scaled from 0.0 MHz), 64.0 kHz, 60.0 Hz
(II) fglrx(0): Modeline “1280x1024” 108.00 1280 1328 1440 1688 1024 1025 1028 1066
() fglrx(0): Default mode “1280x1024”: 85.5 MHz (scaled from 0.0 MHz), 50.9 kHz, 47.0 Hz (I)
(II) fglrx(0): Modeline “1280x1024” 85.51 1280 1344 1480 1680 1024 1025 1028 1083 interlace +hsync
() fglrx(0): Default mode “1280x1024”: 77.8 MHz (scaled from 0.0 MHz), 46.3 kHz, 43.0 Hz (I)
(II) fglrx(0): Modeline “1280x1024” 77.80 1280 1344 1480 1680 1024 1025 1028 1077 interlace +hsync
() fglrx(0): *Mode “1280x960”: 148.5 MHz (scaled from 0.0 MHz), 85.9 kHz, 85.0 Hz
(II) fglrx(0): Modeline “1280x960” 148.50 1280 1328 1488 1728 960 971 974 1011 +hsync +vsync
() fglrx(0): *Mode “1024x480”: 38.2 MHz (scaled from 0.0 MHz), 29.8 kHz, 60.0 Hz
(II) fglrx(0): Modeline “1024x480” 38.16 1024 1048 1152 1280 480 481 484 497 +hsync
() fglrx(0): *Mode “848x480”: 31.5 MHz (scaled from 0.0 MHz), 29.8 kHz, 60.0 Hz
(II) fglrx(0): Modeline “848x480” 31.48 848 864 952 1056 480 481 484 497 +hsync
() fglrx(0): *Mode “800x600”: 56.2 MHz (scaled from 0.0 MHz), 53.7 kHz, 85.0 Hz
(II) fglrx(0): Modeline “800x600” 56.25 800 832 896 1048 600 601 604 631
() fglrx(0): Default mode “800x600”: 49.5 MHz (scaled from 0.0 MHz), 46.9 kHz, 75.0 Hz
(II) fglrx(0): Modeline “800x600” 49.50 800 816 896 1056 600 601 604 625
() fglrx(0): Default mode “800x600”: 50.0 MHz (scaled from 0.0 MHz), 48.1 kHz, 72.0 Hz
(II) fglrx(0): Modeline “800x600” 50.00 800 856 976 1040 600 637 643 666
() fglrx(0): Default mode “800x600”: 45.5 MHz (scaled from 0.0 MHz), 43.8 kHz, 70.0 Hz
(II) fglrx(0): Modeline “800x600” 45.50 800 840 920 1040 600 601 604 625 +hsync
() fglrx(0): Default mode “800x600”: 40.0 MHz (scaled from 0.0 MHz), 37.9 kHz, 60.0 Hz
(II) fglrx(0): Modeline “800x600” 40.00 800 840 968 1056 600 601 605 628
() fglrx(0): Default mode “800x600”: 36.0 MHz (scaled from 0.0 MHz), 35.2 kHz, 56.0 Hz
(II) fglrx(0): Modeline “800x600” 36.00 800 824 896 1024 600 601 603 625
() fglrx(0): Default mode “800x600”: 29.6 MHz (scaled from 0.0 MHz), 29.8 kHz, 47.0 Hz (I)
(II) fglrx(0): Modeline “800x600” 29.60 800 816 896 992 600 601 604 635 interlace +hsync
() fglrx(0): Default mode “800x600”: 83.9 MHz (scaled from 0.0 MHz), 77.2 kHz, 120.0 Hz
(II) fglrx(0): Modeline “800x600” 83.94 800 856 944 1088 600 601 604 643 +hsync
() fglrx(0): Default mode “800x600”: 68.2 MHz (scaled from 0.0 MHz), 63.6 kHz, 100.0 Hz
(II) fglrx(0): Modeline “800x600” 68.17 800 848 936 1072 600 601 604 636 +hsync
() fglrx(0): Default mode “800x600”: 60.1 MHz (scaled from 0.0 MHz), 56.9 kHz, 90.0 Hz
(II) fglrx(0): Modeline “800x600” 60.06 800 840 928 1056 600 601 604 632 +hsync
() fglrx(0): *Mode “720x576”: 32.7 MHz (scaled from 0.0 MHz), 35.8 kHz, 60.0 Hz
(II) fglrx(0): Modeline “720x576” 32.66 720 744 816 912 576 577 580 597 +hsync
() fglrx(0): *Mode “720x480”: 26.7 MHz (scaled from 0.0 MHz), 29.8 kHz, 60.0 Hz
(II) fglrx(0): Modeline “720x480” 26.71 720 736 808 896 480 481 484 497 +hsync
() fglrx(0): *Mode “640x480”: 36.0 MHz (scaled from 0.0 MHz), 43.3 kHz, 85.0 Hz
(II) fglrx(0): Modeline “640x480” 36.00 640 696 752 832 480 481 484 509 +hsync +vsync
() fglrx(0): Default mode “640x480”: 31.5 MHz (scaled from 0.0 MHz), 37.5 kHz, 75.0 Hz
(II) fglrx(0): Modeline “640x480” 31.50 640 656 720 840 480 481 484 500 +hsync +vsync
() fglrx(0): Default mode “640x480”: 31.5 MHz (scaled from 0.0 MHz), 37.9 kHz, 72.0 Hz
(II) fglrx(0): Modeline “640x480” 31.50 640 664 704 832 480 489 492 520 +hsync +vsync
() fglrx(0): Default mode “640x480”: 25.2 MHz (scaled from 0.0 MHz), 31.5 kHz, 60.0 Hz
(II) fglrx(0): Modeline “640x480” 25.18 640 656 752 800 480 490 492 525 +hsync +vsync
() fglrx(0): Default mode “640x480”: 72.8 MHz (scaled from 0.0 MHz), 84.3 kHz, 160.0 Hz
(II) fglrx(0): Modeline “640x480” 72.85 640 680 752 864 480 481 484 527 +hsync
() fglrx(0): Default mode “640x480”: 52.4 MHz (scaled from 0.0 MHz), 61.8 kHz, 120.0 Hz
(II) fglrx(0): Modeline “640x480” 52.40 640 680 744 848 480 481 484 515 +hsync
() fglrx(0): Default mode “640x480”: 43.2 MHz (scaled from 0.0 MHz), 50.9 kHz, 100.0 Hz
(II) fglrx(0): Modeline “640x480” 43.16 640 680 744 848 480 481 484 509 +hsync
() fglrx(0): Default mode “640x480”: 37.9 MHz (scaled from 0.0 MHz), 45.5 kHz, 90.0 Hz
(II) fglrx(0): Modeline “640x480” 37.89 640 672 736 832 480 481 484 506 +hsync
() fglrx(0): Default mode “640x400”: 28.1 MHz (scaled from 0.0 MHz), 33.7 kHz, 75.0 Hz
(II) fglrx(0): Modeline “640x400” 28.07 640 696 736 832 400 413 415 449
() fglrx(0): Default mode “640x400”: 24.9 MHz (scaled from 0.0 MHz), 31.5 kHz, 60.0 Hz
(II) fglrx(0): Modeline “640x400” 24.92 640 664 760 792 400 460 462 525
() fglrx(0): Default mode “400x300”: 24.8 MHz (scaled from 0.0 MHz), 46.9 kHz, 75.0 Hz (D)
(II) fglrx(0): Modeline “400x300” 24.75 400 408 448 528 300 601 602 625 doublescan
() fglrx(0): Default mode “400x300”: 22.3 MHz (scaled from 0.0 MHz), 45.0 kHz, 60.0 Hz (D)
(II) fglrx(0): Modeline “400x300” 22.33 400 416 480 496 300 601 605 742 doublescan
() fglrx(0): Default mode “320x240”: 15.8 MHz (scaled from 0.0 MHz), 37.9 kHz, 75.0 Hz (D)
(II) fglrx(0): Modeline “320x240” 15.75 320 328 360 416 240 481 482 501 doublescan
() fglrx(0): Default mode “320x240”: 12.6 MHz (scaled from 0.0 MHz), 31.5 kHz, 60.0 Hz (D)
(II) fglrx(0): Modeline “320x240” 12.59 320 328 376 400 240 491 493 525 doublescan
() fglrx(0): Default mode “320x200”: 13.1 MHz (scaled from 0.0 MHz), 31.5 kHz, 75.0 Hz (D)
(II) fglrx(0): Modeline “320x200” 13.10 320 352 368 416 200 406 407 417 doublescan
() fglrx(0): Default mode “320x200”: 12.6 MHz (scaled from 0.0 MHz), 31.5 kHz, 60.0 Hz (D)
(II) fglrx(0): Modeline “320x200” 12.59 320 336 384 400 200 457 459 524 doublescan
(++) fglrx(0): DPI set to (96, 96)
(–) fglrx(0): Virtual size is 2560x1024 (pitch 2560)
