Ayant voulu réaliser aujourd’hui un aptitude update, je me heurte au souci suivant:
à priori il y a un souci avec boinc-client.
J’ai tenté un purge, un remove, un reinstall, même erreur:
0 packages upgraded, 0 newly installed, 1 to remove and 18 not upgraded.
Need to get 0B of archives. After unpacking 1094kB will be freed.
Writing extended state information… Done
dpkg: error processing boinc-client (–remove):
Package is in a very bad inconsistent state - you should
reinstall it before attempting a removal.
terminate called after throwing an instance of 'std::logic_error’
what(): basic_string::_S_construct NULL not valid
Aborted
demonaz:/home/abbath# Errors were encountered while processing:
Une idée?
Merci.
