Bonjour les gens
J’ai un bug assez lourd, m’empêchant de mettre à jour correctement ma debian, ou bien d’installer un nouveau paquet … tout ce qui passe par apt bloque à cause de cette erreur :
(Lecture de la base de données... dpkg : erreur fatale irréversible, abandon :
files list file for package `exim4-config' is missing final newline
J’ai donc tenté de localiser ce fichier “exim4-config” et d’éditer à la mano, mais voici tout ce que je trouve =>
root@ks306074:~# locate exim4-config
/etc/exim4/conf.d/acl/00_exim4-config_header
/etc/exim4/conf.d/acl/20_exim4-config_local_deny_exceptions
/etc/exim4/conf.d/acl/30_exim4-config_check_mail
/etc/exim4/conf.d/acl/30_exim4-config_check_rcpt
/etc/exim4/conf.d/acl/40_exim4-config_check_data
/etc/exim4/conf.d/auth/00_exim4-config_header
/etc/exim4/conf.d/auth/30_exim4-config_examples
/etc/exim4/conf.d/main/01_exim4-config_listmacrosdefs
/etc/exim4/conf.d/main/02_exim4-config_options
/etc/exim4/conf.d/main/03_exim4-config_tlsoptions
/etc/exim4/conf.d/main/90_exim4-config_log_selector
/etc/exim4/conf.d/retry/00_exim4-config_header
/etc/exim4/conf.d/retry/30_exim4-config
/etc/exim4/conf.d/rewrite/00_exim4-config_header
/etc/exim4/conf.d/rewrite/31_exim4-config_rewriting
/etc/exim4/conf.d/router/00_exim4-config_header
/etc/exim4/conf.d/router/100_exim4-config_domain_literal
/etc/exim4/conf.d/router/150_exim4-config_hubbed_hosts
/etc/exim4/conf.d/router/200_exim4-config_primary
/etc/exim4/conf.d/router/300_exim4-config_real_local
/etc/exim4/conf.d/router/400_exim4-config_system_aliases
/etc/exim4/conf.d/router/500_exim4-config_hubuser
/etc/exim4/conf.d/router/600_exim4-config_userforward
/etc/exim4/conf.d/router/700_exim4-config_procmail
/etc/exim4/conf.d/router/800_exim4-config_maildrop
/etc/exim4/conf.d/router/850_exim4-config_lowuid
/etc/exim4/conf.d/router/900_exim4-config_local_user
/etc/exim4/conf.d/transport/00_exim4-config_header
/etc/exim4/conf.d/transport/10_exim4-config_transport-macros
/etc/exim4/conf.d/transport/30_exim4-config_address_file
/etc/exim4/conf.d/transport/30_exim4-config_address_pipe
/etc/exim4/conf.d/transport/30_exim4-config_address_reply
/etc/exim4/conf.d/transport/30_exim4-config_mail_spool
/etc/exim4/conf.d/transport/30_exim4-config_maildir_home
/etc/exim4/conf.d/transport/30_exim4-config_maildrop_pipe
/etc/exim4/conf.d/transport/30_exim4-config_procmail_pipe
/etc/exim4/conf.d/transport/30_exim4-config_remote_smtp
/etc/exim4/conf.d/transport/30_exim4-config_remote_smtp_smarthost
/etc/exim4/conf.d/transport/35_exim4-config_address_directory
/usr/share/bug/exim4-config
/usr/share/bug/exim4-config/script
/usr/share/doc/exim4-config
/usr/share/doc/exim4-config/NEWS.Debian.gz
/usr/share/doc/exim4-config/README.Debian.gz
/usr/share/doc/exim4-config/changelog.Debian.gz
/usr/share/doc/exim4-config/copyright
/usr/share/lintian/overrides/exim4-config
/usr/share/man/man5/exim4-config_files.5.gz
/var/lib/dpkg/info/exim4-config.conffiles
/var/lib/dpkg/info/exim4-config.config
/var/lib/dpkg/info/exim4-config.list
/var/lib/dpkg/info/exim4-config.md5sums
/var/lib/dpkg/info/exim4-config.postinst
/var/lib/dpkg/info/exim4-config.postrm
/var/lib/dpkg/info/exim4-config.preinst
/var/lib/dpkg/info/exim4-config.templates
J’ai quand même tenté de modif quelques fichiers mais sans succès ^^’
J’ai aussi tenté un apt-get remove exim4-config et bien que des dépendances allées sauter avec, l’erreur cité précédemment à bloquer la manip …
Donc si vous pouviez m’éclairer de vos lumières, j’en serais très heureux
