il met les options après “kernel…”, et moi je les mets après “#defoptions=”.
En ce qui concerne l’essai sans la ligne apm power_off=1, cela ne marche pas.
voici mon fichier /boot/configxxxx :
[code]
Automatically generated make config: don’t edit
Linux kernel version: 2.6.18
Mon Mar 26 16:32:45 2007
CONFIG_X86_32=y
CONFIG_GENERIC_TIME=y
CONFIG_LOCKDEP_SUPPORT=y
CONFIG_STACKTRACE_SUPPORT=y
CONFIG_SEMAPHORE_SLEEPERS=y
CONFIG_X86=y
CONFIG_MMU=y
CONFIG_GENERIC_ISA_DMA=y
CONFIG_GENERIC_IOMAP=y
CONFIG_GENERIC_HWEIGHT=y
CONFIG_ARCH_MAY_HAVE_PC_FDC=y
CONFIG_DMI=y
CONFIG_DEFCONFIG_LIST="/lib/modules/$UNAME_RELEASE/.config"
Code maturity level options
CONFIG_EXPERIMENTAL=y
CONFIG_LOCK_KERNEL=y
CONFIG_INIT_ENV_ARG_LIMIT=32
General setup
CONFIG_LOCALVERSION=""
CONFIG_LOCALVERSION_AUTO is not set
CONFIG_SWAP=y
CONFIG_SYSVIPC=y
CONFIG_POSIX_MQUEUE=y
CONFIG_BSD_PROCESS_ACCT=y
CONFIG_BSD_PROCESS_ACCT_V3=y
CONFIG_TASKSTATS is not set
CONFIG_AUDIT=y
CONFIG_AUDITSYSCALL is not set
CONFIG_IKCONFIG is not set
CONFIG_CPUSETS=y
CONFIG_RELAY is not set
CONFIG_INITRAMFS_SOURCE=""
CONFIG_CC_OPTIMIZE_FOR_SIZE=y
CONFIG_EMBEDDED is not set
CONFIG_UID16=y
CONFIG_SYSCTL=y
CONFIG_KALLSYMS=y
CONFIG_KALLSYMS_EXTRA_PASS is not set
CONFIG_HOTPLUG=y
CONFIG_PRINTK=y
CONFIG_BUG=y
CONFIG_ELF_CORE=y
CONFIG_BASE_FULL=y
CONFIG_FUTEX=y
CONFIG_EPOLL=y
CONFIG_SHMEM=y
CONFIG_SLAB=y
CONFIG_VM_EVENT_COUNTERS=y
CONFIG_RT_MUTEXES=y
CONFIG_TINY_SHMEM is not set
CONFIG_BASE_SMALL=0
CONFIG_SLOB is not set
Loadable module support
CONFIG_MODULES=y
CONFIG_MODULE_UNLOAD=y
CONFIG_MODULE_FORCE_UNLOAD=y
CONFIG_MODVERSIONS=y
CONFIG_MODULE_SRCVERSION_ALL is not set
CONFIG_KMOD=y
CONFIG_STOP_MACHINE=y
Block layer
CONFIG_LBD=y
CONFIG_BLK_DEV_IO_TRACE is not set
CONFIG_LSF=y
IO Schedulers
CONFIG_IOSCHED_NOOP=y
CONFIG_IOSCHED_AS=y
CONFIG_IOSCHED_DEADLINE=y
CONFIG_IOSCHED_CFQ=y
CONFIG_DEFAULT_AS is not set
CONFIG_DEFAULT_DEADLINE is not set
CONFIG_DEFAULT_CFQ=y
CONFIG_DEFAULT_NOOP is not set
CONFIG_DEFAULT_IOSCHED=“cfq”
Processor type and features
CONFIG_SMP=y
CONFIG_X86_PC=y
CONFIG_X86_ELAN is not set
CONFIG_X86_VOYAGER is not set
CONFIG_X86_NUMAQ is not set
CONFIG_X86_SUMMIT is not set
CONFIG_X86_BIGSMP is not set
CONFIG_X86_VISWS is not set
CONFIG_X86_GENERICARCH is not set
CONFIG_X86_ES7000 is not set
CONFIG_M386 is not set
CONFIG_M486 is not set
CONFIG_M586 is not set
CONFIG_M586TSC is not set
CONFIG_M586MMX is not set
CONFIG_M686 is not set
CONFIG_MPENTIUMII is not set
CONFIG_MPENTIUMIII is not set
CONFIG_MPENTIUMM is not set
CONFIG_MPENTIUM4 is not set
CONFIG_MK6 is not set
CONFIG_MK7=y
CONFIG_MK8 is not set
CONFIG_MCRUSOE is not set
CONFIG_MEFFICEON is not set
CONFIG_MWINCHIPC6 is not set
CONFIG_MWINCHIP2 is not set
CONFIG_MWINCHIP3D is not set
CONFIG_MGEODEGX1 is not set
CONFIG_MGEODE_LX is not set
CONFIG_MCYRIXIII is not set
CONFIG_MVIAC3_2 is not set
CONFIG_X86_GENERIC is not set
CONFIG_X86_CMPXCHG=y
CONFIG_X86_XADD=y
CONFIG_X86_L1_CACHE_SHIFT=6
CONFIG_RWSEM_XCHGADD_ALGORITHM=y
CONFIG_GENERIC_CALIBRATE_DELAY=y
CONFIG_X86_WP_WORKS_OK=y
CONFIG_X86_INVLPG=y
CONFIG_X86_BSWAP=y
CONFIG_X86_POPAD_OK=y
CONFIG_X86_CMPXCHG64=y
CONFIG_X86_GOOD_APIC=y
CONFIG_X86_INTEL_USERCOPY=y
CONFIG_X86_USE_PPRO_CHECKSUM=y
CONFIG_X86_USE_3DNOW=y
CONFIG_X86_TSC=y
CONFIG_HPET_TIMER=y
CONFIG_NR_CPUS=8
CONFIG_SCHED_SMT=y
CONFIG_SCHED_MC=y
CONFIG_PREEMPT_NONE=y
CONFIG_PREEMPT_VOLUNTARY is not set
CONFIG_PREEMPT is not set
CONFIG_PREEMPT_BKL is not set
CONFIG_X86_LOCAL_APIC=y
CONFIG_X86_IO_APIC=y
CONFIG_X86_MCE=y
CONFIG_X86_MCE_NONFATAL=m
CONFIG_X86_MCE_P4THERMAL=y
CONFIG_VM86=y
CONFIG_TOSHIBA=m
CONFIG_I8K=m
CONFIG_X86_REBOOTFIXUPS is not set
CONFIG_MICROCODE=m
CONFIG_X86_MSR=m
CONFIG_X86_CPUID=m
Firmware Drivers
CONFIG_EDD=m
CONFIG_EFI_VARS=m
CONFIG_DELL_RBU=m
CONFIG_DCDBAS=m
CONFIG_NOHIGHMEM is not set
CONFIG_HIGHMEM4G=y
CONFIG_HIGHMEM64G is not set
CONFIG_PAGE_OFFSET=0xC0000000
CONFIG_HIGHMEM=y
CONFIG_ARCH_FLATMEM_ENABLE=y
CONFIG_ARCH_SPARSEMEM_ENABLE=y
CONFIG_ARCH_SELECT_MEMORY_MODEL=y
CONFIG_SELECT_MEMORY_MODEL=y
CONFIG_FLATMEM_MANUAL=y
CONFIG_DISCONTIGMEM_MANUAL is not set
CONFIG_SPARSEMEM_MANUAL is not set
CONFIG_FLATMEM=y
CONFIG_FLAT_NODE_MEM_MAP=y
CONFIG_SPARSEMEM_STATIC=y
CONFIG_SPLIT_PTLOCK_CPUS=4
CONFIG_RESOURCES_64BIT is not set
CONFIG_HIGHPTE is not set
CONFIG_MATH_EMULATION is not set
CONFIG_MTRR=y
CONFIG_EFI=y
CONFIG_IRQBALANCE=y
CONFIG_BOOT_IOREMAP=y
CONFIG_REGPARM=y
CONFIG_SECCOMP is not set
CONFIG_HZ_100 is not set
CONFIG_HZ_250=y
CONFIG_HZ_1000 is not set
CONFIG_HZ=250
CONFIG_KEXEC=y
CONFIG_CRASH_DUMP is not set
CONFIG_PHYSICAL_START=0x100000
CONFIG_HOTPLUG_CPU=y
CONFIG_COMPAT_VDSO=y
CONFIG_ARCH_ENABLE_MEMORY_HOTPLUG=y
Power management options (ACPI, APM)
CONFIG_PM=y
CONFIG_PM_LEGACY=y
CONFIG_PM_DEBUG is not set
CONFIG_SOFTWARE_SUSPEND=y
CONFIG_PM_STD_PARTITION=""
CONFIG_SUSPEND_SMP=y
ACPI (Advanced Configuration and Power Interface) Support
CONFIG_ACPI=y
CONFIG_ACPI_SLEEP=y
CONFIG_ACPI_SLEEP_PROC_FS=y
CONFIG_ACPI_SLEEP_PROC_SLEEP is not set
CONFIG_ACPI_AC=m
CONFIG_ACPI_BATTERY=m
CONFIG_ACPI_BUTTON=m
CONFIG_ACPI_VIDEO=m
CONFIG_ACPI_HOTKEY=m
CONFIG_ACPI_FAN=m
CONFIG_ACPI_DOCK=m
CONFIG_ACPI_PROCESSOR=m
CONFIG_ACPI_HOTPLUG_CPU=y
CONFIG_ACPI_THERMAL=m
CONFIG_ACPI_ASUS=m
CONFIG_ACPI_IBM=m
CONFIG_ACPI_TOSHIBA=m
CONFIG_ACPI_BLACKLIST_YEAR=0
CONFIG_ACPI_DEBUG is not set
CONFIG_ACPI_EC=y
CONFIG_ACPI_POWER=y
CONFIG_ACPI_SYSTEM=y
CONFIG_X86_PM_TIMER=y
CONFIG_ACPI_CONTAINER=m
CONFIG_ACPI_SBS=m
APM (Advanced Power Management) BIOS Support
CONFIG_APM=m
CONFIG_APM_IGNORE_USER_SUSPEND is not set
CONFIG_APM_DO_ENABLE is not set
CONFIG_APM_CPU_IDLE is not set
CONFIG_APM_DISPLAY_BLANK is not set
CONFIG_APM_RTC_IS_GMT is not set
CONFIG_APM_ALLOW_INTS is not set
CONFIG_APM_REAL_MODE_POWER_OFF is not set
CPU Frequency scaling
CONFIG_CPU_FREQ=y
CONFIG_CPU_FREQ_TABLE=m
CONFIG_CPU_FREQ_DEBUG is not set
CONFIG_CPU_FREQ_STAT=m
CONFIG_CPU_FREQ_STAT_DETAILS is not set
CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE=y
CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE is not set
CONFIG_CPU_FREQ_GOV_PERFORMANCE=y
CONFIG_CPU_FREQ_GOV_POWERSAVE=m
CONFIG_CPU_FREQ_GOV_USERSPACE=m
CONFIG_CPU_FREQ_GOV_ONDEMAND=m
CONFIG_CPU_FREQ_GOV_CONSERVATIVE=m
CPUFreq processor drivers
CONFIG_X86_ACPI_CPUFREQ=m
CONFIG_X86_POWERNOW_K6=m
CONFIG_X86_POWERNOW_K7=m
CONFIG_X86_POWERNOW_K7_ACPI=y
CONFIG_X86_POWERNOW_K8=m
CONFIG_X86_POWERNOW_K8_ACPI=y
CONFIG_X86_GX_SUSPMOD=m
CONFIG_X86_SPEEDSTEP_CENTRINO=m
CONFIG_X86_SPEEDSTEP_CENTRINO_ACPI=y
CONFIG_X86_SPEEDSTEP_CENTRINO_TABLE=y
CONFIG_X86_SPEEDSTEP_ICH=m
CONFIG_X86_SPEEDSTEP_SMI=m
CONFIG_X86_P4_CLOCKMOD=m
CONFIG_X86_CPUFREQ_NFORCE2=m
CONFIG_X86_LONGRUN=m
CONFIG_X86_LONGHAUL=m
shared options
CONFIG_X86_ACPI_CPUFREQ_PROC_INTF is not set
CONFIG_X86_SPEEDSTEP_LIB=m
CONFIG_X86_SPEEDSTEP_RELAXED_CAP_CHECK=y
Bus options (PCI, PCMCIA, EISA, MCA, ISA)
CONFIG_PCI=y
CONFIG_PCI_GOBIOS is not set
CONFIG_PCI_GOMMCONFIG is not set
CONFIG_PCI_GODIRECT is not set
CONFIG_PCI_GOANY=y
CONFIG_PCI_BIOS=y
CONFIG_PCI_DIRECT=y
CONFIG_PCI_MMCONFIG=y
CONFIG_PCIEPORTBUS=y
CONFIG_HOTPLUG_PCI_PCIE=m
CONFIG_HOTPLUG_PCI_PCIE_POLL_EVENT_MODE is not set
CONFIG_PCI_MSI=y
CONFIG_ISA_DMA_API=y
CONFIG_ISA=y
CONFIG_EISA is not set
CONFIG_MCA is not set
CONFIG_SCx200=m
CONFIG_SCx200HR_TIMER=m
CONFIG_K8_NB=y
PCCARD (PCMCIA/CardBus) support
CONFIG_PCCARD=m
CONFIG_PCMCIA_DEBUG is not set
CONFIG_PCMCIA=m
CONFIG_PCMCIA_LOAD_CIS=y
CONFIG_PCMCIA_IOCTL=y
CONFIG_CARDBUS=y
PC-card bridges
CONFIG_YENTA=m
CONFIG_YENTA_O2=y
CONFIG_YENTA_RICOH=y
CONFIG_YENTA_TI=y
CONFIG_YENTA_ENE_TUNE=y
CONFIG_YENTA_TOSHIBA=y
CONFIG_PD6729=m
CONFIG_I82092=m
CONFIG_I82365=m
CONFIG_TCIC=m
CONFIG_PCMCIA_PROBE=y
CONFIG_PCCARD_NONSTATIC=m
PCI Hotplug Support
CONFIG_HOTPLUG_PCI=m
CONFIG_HOTPLUG_PCI_FAKE=m
CONFIG_HOTPLUG_PCI_COMPAQ=m
CONFIG_HOTPLUG_PCI_COMPAQ_NVRAM is not set
CONFIG_HOTPLUG_PCI_IBM=m
CONFIG_HOTPLUG_PCI_ACPI=m
CONFIG_HOTPLUG_PCI_ACPI_IBM=m
CONFIG_HOTPLUG_PCI_CPCI=y
CONFIG_HOTPLUG_PCI_CPCI_ZT5550=m
CONFIG_HOTPLUG_PCI_CPCI_GENERIC=m
CONFIG_HOTPLUG_PCI_SHPC=m
CONFIG_HOTPLUG_PCI_SHPC_POLL_EVENT_MODE is not set
Executable file formats
CONFIG_BINFMT_ELF=y
CONFIG_BINFMT_AOUT=m
CONFIG_BINFMT_MISC=m
Networking
CONFIG_NET=y
Networking options
CONFIG_NETDEBUG is not set
CONFIG_PACKET=y
CONFIG_PACKET_MMAP=y
CONFIG_UNIX=y
CONFIG_XFRM=y
CONFIG_XFRM_USER=m
CONFIG_NET_KEY=m
CONFIG_INET=y
CONFIG_IP_MULTICAST=y
CONFIG_IP_ADVANCED_ROUTER=y
CONFIG_ASK_IP_FIB_HASH=y
CONFIG_IP_FIB_TRIE is not set
CONFIG_IP_FIB_HASH=y
CONFIG_IP_MULTIPLE_TABLES=y
CONFIG_IP_ROUTE_FWMARK=y
CONFIG_IP_ROUTE_MULTIPATH=y
CONFIG_IP_ROUTE_MULTIPATH_CACHED=y
CONFIG_IP_ROUTE_MULTIPATH_RR=m
CONFIG_IP_ROUTE_MULTIPATH_RANDOM=m
CONFIG_IP_ROUTE_MULTIPATH_WRANDOM=m
CONFIG_IP_ROUTE_MULTIPATH_DRR=m
CONFIG_IP_ROUTE_VERBOSE=y
CONFIG_IP_PNP is not set
CONFIG_NET_IPIP=m
CONFIG_NET_IPGRE=m
CONFIG_NET_IPGRE_BROADCAST=y
CONFIG_IP_MROUTE=y
CONFIG_IP_PIMSM_V1=y
CONFIG_IP_PIMSM_V2=y
CONFIG_ARPD is not set
CONFIG_SYN_COOKIES=y
CONFIG_INET_AH=m
CONFIG_INET_ESP=m
CONFIG_INET_IPCOMP=m
CONFIG_INET_XFRM_TUNNEL=m
CONFIG_INET_TUNNEL=m
CONFIG_INET_XFRM_MODE_TRANSPORT=m
CONFIG_INET_XFRM_MODE_TUNNEL=m
CONFIG_INET_DIAG=m
CONFIG_INET_TCP_DIAG=m
CONFIG_TCP_CONG_ADVANCED=y
TCP congestion control
CONFIG_TCP_CONG_BIC=y
CONFIG_TCP_CONG_CUBIC=m
CONFIG_TCP_CONG_WESTWOOD=m
CONFIG_TCP_CONG_HTCP=m
CONFIG_TCP_CONG_HSTCP=m
CONFIG_TCP_CONG_HYBLA=m
CONFIG_TCP_CONG_VEGAS=m
CONFIG_TCP_CONG_SCALABLE=m
CONFIG_TCP_CONG_LP=m
CONFIG_TCP_CONG_VENO=m
IP: Virtual Server Configuration
CONFIG_IP_VS=m
CONFIG_IP_VS_DEBUG is not set
CONFIG_IP_VS_TAB_BITS=12
IPVS transport protocol load balancing support
CONFIG_IP_VS_PROTO_TCP=y
CONFIG_IP_VS_PROTO_UDP=y
CONFIG_IP_VS_PROTO_ESP=y
CONFIG_IP_VS_PROTO_AH=y
IPVS scheduler
CONFIG_IP_VS_RR=m
CONFIG_IP_VS_WRR=m
CONFIG_IP_VS_LC=m
CONFIG_IP_VS_WLC=m
CONFIG_IP_VS_LBLC=m
CONFIG_IP_VS_LBLCR=m
CONFIG_IP_VS_DH=m
CONFIG_IP_VS_SH=m
CONFIG_IP_VS_SED=m
CONFIG_IP_VS_NQ=m
IPVS application helper
CONFIG_IP_VS_FTP=m
CONFIG_IPV6=m
CONFIG_IPV6_PRIVACY=y
CONFIG_IPV6_ROUTER_PREF is not set
CONFIG_INET6_AH=m
CONFIG_INET6_ESP=m
CONFIG_INET6_IPCOMP=m
CONFIG_INET6_XFRM_TUNNEL=m
CONFIG_INET6_TUNNEL=m
CONFIG_INET6_XFRM_MODE_TRANSPORT=m
CONFIG_INET6_XFRM_MODE_TUNNEL=m
CONFIG_IPV6_TUNNEL=m
CONFIG_NETWORK_SECMARK=y
CONFIG_NETFILTER=y
CONFIG_NETFILTER_DEBUG is not set
CONFIG_BRIDGE_NETFILTER=y
Core Netfilter Configuration
CONFIG_NETFILTER_NETLINK=m
CONFIG_NETFILTER_NETLINK_QUEUE=m
CONFIG_NETFILTER_NETLINK_LOG=m
CONFIG_NETFILTER_XTABLES=m
CONFIG_NETFILTER_XT_TARGET_CLASSIFY=m
CONFIG_NETFILTER_XT_TARGET_CONNMARK=m
CONFIG_NETFILTER_XT_TARGET_MARK=m
CONFIG_NETFILTER_XT_TARGET_NFQUEUE=m
CONFIG_NETFILTER_XT_TARGET_NOTRACK=m
CONFIG_NETFILTER_XT_TARGET_SECMARK=m
CONFIG_NETFILTER_XT_MATCH_COMMENT=m
CONFIG_NETFILTER_XT_MATCH_CONNBYTES=m
CONFIG_NETFILTER_XT_MATCH_CONNMARK=m
CONFIG_NETFILTER_XT_MATCH_CONNTRACK=m
CONFIG_NETFILTER_XT_MATCH_DCCP=m
CONFIG_NETFILTER_XT_MATCH_ESP=m
CONFIG_NETFILTER_XT_MATCH_HELPER=m
CONFIG_NETFILTER_XT_MATCH_LENGTH=m
CONFIG_NETFILTER_XT_MATCH_LIMIT=m
CONFIG_NETFILTER_XT_MATCH_MAC=m
CONFIG_NETFILTER_XT_MATCH_MARK=m
CONFIG_NETFILTER_XT_MATCH_POLICY=m
CONFIG_NETFILTER_XT_MATCH_MULTIPORT=m
CONFIG_NETFILTER_XT_MATCH_PHYSDEV=m
CONFIG_NETFILTER_XT_MATCH_PKTTYPE=m
CONFIG_NETFILTER_XT_MATCH_QUOTA=m
CONFIG_NETFILTER_XT_MATCH_REALM=m
CONFIG_NETFILTER_XT_MATCH_SCTP=m
CONFIG_NETFILTER_XT_MATCH_STATE=m
CONFIG_NETFILTER_XT_MATCH_STATISTIC=m
CONFIG_NETFILTER_XT_MATCH_STRING=m
CONFIG_NETFILTER_XT_MATCH_TCPMSS=m
IP: Netfilter Configuration
CONFIG_IP_NF_CONNTRACK=m
CONFIG_IP_NF_CT_ACCT=y
CONFIG_IP_NF_CONNTRACK_MARK=y
CONFIG_IP_NF_CONNTRACK_SECMARK is not set
CONFIG_IP_NF_CONNTRACK_EVENTS=y
CONFIG_IP_NF_CONNTRACK_NETLINK=m
CONFIG_IP_NF_CT_PROTO_SCTP=m
CONFIG_IP_NF_FTP=m
CONFIG_IP_NF_IRC=m
CONFIG_IP_NF_NETBIOS_NS=m
CONFIG_IP_NF_TFTP=m
CONFIG_IP_NF_AMANDA=m
CONFIG_IP_NF_PPTP=m
CONFIG_IP_NF_H323=m
CONFIG_IP_NF_SIP=m
CONFIG_IP_NF_QUEUE=m
CONFIG_IP_NF_IPTABLES=m
CONFIG_IP_NF_MATCH_IPRANGE=m
CONFIG_IP_NF_MATCH_TOS=m
CONFIG_IP_NF_MATCH_RECENT=m
CONFIG_IP_NF_MATCH_ECN=m
CONFIG_IP_NF_MATCH_DSCP=m
CONFIG_IP_NF_MATCH_AH=m
CONFIG_IP_NF_MATCH_TTL=m
CONFIG_IP_NF_MATCH_OWNER=m
CONFIG_IP_NF_MATCH_ADDRTYPE=m
CONFIG_IP_NF_MATCH_HASHLIMIT=m
CONFIG_IP_NF_FILTER=m
CONFIG_IP_NF_TARGET_REJECT=m
CONFIG_IP_NF_TARGET_LOG=m
CONFIG_IP_NF_TARGET_ULOG=m
CONFIG_IP_NF_TARGET_TCPMSS=m
CONFIG_IP_NF_NAT=m
CONFIG_IP_NF_NAT_NEEDED=y
CONFIG_IP_NF_TARGET_MASQUERADE=m
CONFIG_IP_NF_TARGET_REDIRECT=m
CONFIG_IP_NF_TARGET_NETMAP=m
CONFIG_IP_NF_TARGET_SAME=m
CONFIG_IP_NF_NAT_SNMP_BASIC=m
CONFIG_IP_NF_NAT_IRC=m
CONFIG_IP_NF_NAT_FTP=m
CONFIG_IP_NF_NAT_TFTP=m
CONFIG_IP_NF_NAT_AMANDA=m
CONFIG_IP_NF_NAT_PPTP=m
CONFIG_IP_NF_NAT_H323=m
CONFIG_IP_NF_NAT_SIP=m
CONFIG_IP_NF_MANGLE=m
CONFIG_IP_NF_TARGET_TOS=m
CONFIG_IP_NF_TARGET_ECN=m
CONFIG_IP_NF_TARGET_DSCP=m
CONFIG_IP_NF_TARGET_TTL=m
CONFIG_IP_NF_TARGET_CLUSTERIP=m
CONFIG_IP_NF_RAW=m
CONFIG_IP_NF_ARPTABLES=m
CONFIG_IP_NF_ARPFILTER=m
CONFIG_IP_NF_ARP_MANGLE=m
IPv6: Netfilter Configuration (EXPERIMENTAL)
CONFIG_IP6_NF_QUEUE=m
CONFIG_IP6_NF_IPTABLES=m
CONFIG_IP6_NF_MATCH_RT=m
CONFIG_IP6_NF_MATCH_OPTS=m
CONFIG_IP6_NF_MATCH_FRAG=m
CONFIG_IP6_NF_MATCH_HL=m
CONFIG_IP6_NF_MATCH_OWNER=m
CONFIG_IP6_NF_MATCH_IPV6HEADER=m
CONFIG_IP6_NF_MATCH_AH=m
CONFIG_IP6_NF_MATCH_EUI64=m
CONFIG_IP6_NF_FILTER=m
CONFIG_IP6_NF_TARGET_LOG=m
CONFIG_IP6_NF_TARGET_REJECT=m
CONFIG_IP6_NF_MANGLE=m
CONFIG_IP6_NF_TARGET_HL=m
CONFIG_IP6_NF_RAW=m
DECnet: Netfilter Configuration
CONFIG_DECNET_NF_GRABULATOR=m
Bridge: Netfilter Configuration
CONFIG_BRIDGE_NF_EBTABLES=m
CONFIG_BRIDGE_EBT_BROUTE=m
CONFIG_BRIDGE_EBT_T_FILTER=m
CONFIG_BRIDGE_EBT_T_NAT=m
CONFIG_BRIDGE_EBT_802_3=m
CONFIG_BRIDGE_EBT_AMONG=m
CONFIG_BRIDGE_EBT_ARP=m
CONFIG_BRIDGE_EBT_IP=m
CONFIG_BRIDGE_EBT_LIMIT=m
CONFIG_BRIDGE_EBT_MARK=m
CONFIG_BRIDGE_EBT_PKTTYPE=m
CONFIG_BRIDGE_EBT_STP=m
CONFIG_BRIDGE_EBT_VLAN=m
CONFIG_BRIDGE_EBT_ARPREPLY=m
CONFIG_BRIDGE_EBT_DNAT=m
CONFIG_BRIDGE_EBT_MARK_T=m
CONFIG_BRIDGE_EBT_REDIRECT=m
CONFIG_BRIDGE_EBT_SNAT=m
CONFIG_BRIDGE_EBT_LOG=m
CONFIG_BRIDGE_EBT_ULOG=m
DCCP Configuration (EXPERIMENTAL)
CONFIG_IP_DCCP=m
CONFIG_INET_DCCP_DIAG=m
CONFIG_IP_DCCP_ACKVEC=y
DCCP CCIDs Configuration (EXPERIMENTAL)
CONFIG_IP_DCCP_CCID2=m
CONFIG_IP_DCCP_CCID3=m
CONFIG_IP_DCCP_TFRC_LIB=m
SCTP Configuration (EXPERIMENTAL)
CONFIG_IP_SCTP=m
CONFIG_SCTP_DBG_MSG is not set
CONFIG_SCTP_DBG_OBJCNT is not set
CONFIG_SCTP_HMAC_NONE is not set
CONFIG_SCTP_HMAC_SHA1 is not set
CONFIG_SCTP_HMAC_MD5=y
TIPC Configuration (EXPERIMENTAL)
CONFIG_TIPC=m
CONFIG_TIPC_ADVANCED=y
CONFIG_TIPC_ZONES=3
CONFIG_TIPC_CLUSTERS=1
CONFIG_TIPC_NODES=255
CONFIG_TIPC_SLAVE_NODES=0
CONFIG_TIPC_PORTS=8191
CONFIG_TIPC_LOG=0
CONFIG_TIPC_DEBUG is not set
CONFIG_ATM=y
CONFIG_ATM_CLIP=y
CONFIG_ATM_CLIP_NO_ICMP is not set
CONFIG_ATM_LANE=m
CONFIG_ATM_MPOA=m
CONFIG_ATM_BR2684=m
CONFIG_ATM_BR2684_IPFILTER is not set
CONFIG_BRIDGE=m
CONFIG_VLAN_8021Q=m
CONFIG_DECNET=m
CONFIG_DECNET_ROUTER is not set
CONFIG_LLC=y
CONFIG_LLC2=m
CONFIG_IPX=m
CONFIG_IPX_INTERN is not set
CONFIG_ATALK=m
CONFIG_DEV_APPLETALK=m
CONFIG_LTPC=m
CONFIG_IPDDP=m
CONFIG_IPDDP_ENCAP=y
CONFIG_IPDDP_DECAP=y
CONFIG_X25=m
CONFIG_LAPB=m
CONFIG_ECONET=m
CONFIG_ECONET_AUNUDP=y
CONFIG_ECONET_NATIVE=y
CONFIG_WAN_ROUTER=m
QoS and/or fair queueing
CONFIG_NET_SCHED=y
CONFIG_NET_SCH_CLK_JIFFIES=y
CONFIG_NET_SCH_CLK_GETTIMEOFDAY is not set
CONFIG_NET_SCH_CLK_CPU is not set
Queueing/Scheduling
CONFIG_NET_SCH_CBQ=m
CONFIG_NET_SCH_HTB=m
CONFIG_NET_SCH_HFSC=m
CONFIG_NET_SCH_ATM=m
CONFIG_NET_SCH_PRIO=m
CONFIG_NET_SCH_RED=m
CONFIG_NET_SCH_SFQ=m
CONFIG_NET_SCH_TEQL=m
CONFIG_NET_SCH_TBF=m
CONFIG_NET_SCH_GRED=m
CONFIG_NET_SCH_DSMARK=m
CONFIG_NET_SCH_NETEM=m
CONFIG_NET_SCH_INGRESS=m
Classification
CONFIG_NET_CLS=y
CONFIG_NET_CLS_BASIC=m
CONFIG_NET_CLS_TCINDEX=m
CONFIG_NET_CLS_ROUTE4=m
CONFIG_NET_CLS_ROUTE=y
CONFIG_NET_CLS_FW=m
CONFIG_NET_CLS_U32=m
CONFIG_CLS_U32_PERF=y
CONFIG_CLS_U32_MARK=y
CONFIG_NET_CLS_RSVP=m
CONFIG_NET_CLS_RSVP6=m
CONFIG_NET_EMATCH=y
CONFIG_NET_EMATCH_STACK=32
CONFIG_NET_EMATCH_CMP=m
CONFIG_NET_EMATCH_NBYTE=m
CONFIG_NET_EMATCH_U32=m
CONFIG_NET_EMATCH_META=m
CONFIG_NET_EMATCH_TEXT=m
CONFIG_NET_CLS_ACT=y
CONFIG_NET_ACT_POLICE=m
CONFIG_NET_ACT_GACT=m
CONFIG_GACT_PROB=y
CONFIG_NET_ACT_MIRRED=m
CONFIG_NET_ACT_IPT=m
CONFIG_NET_ACT_PEDIT=m
CONFIG_NET_ACT_SIMP=m
CONFIG_NET_CLS_IND=y
CONFIG_NET_ESTIMATOR=y
Network testing
CONFIG_NET_PKTGEN=m
CONFIG_HAMRADIO=y
Packet Radio protocols
CONFIG_AX25=m
CONFIG_AX25_DAMA_SLAVE is not set
CONFIG_NETROM=m
CONFIG_ROSE=m
AX.25 network device drivers
CONFIG_MKISS=m
CONFIG_6PACK=m
CONFIG_BPQETHER=m
CONFIG_SCC=m
CONFIG_SCC_DELAY is not set
CONFIG_SCC_TRXECHO is not set
CONFIG_BAYCOM_SER_FDX=m
CONFIG_BAYCOM_SER_HDX=m
CONFIG_BAYCOM_PAR=m
CONFIG_BAYCOM_EPP=m
CONFIG_YAM=m
CONFIG_IRDA=m
IrDA protocols
CONFIG_IRLAN=m
CONFIG_IRNET=m
CONFIG_IRCOMM=m
CONFIG_IRDA_ULTRA is not set
IrDA options
CONFIG_IRDA_CACHE_LAST_LSAP=y
CONFIG_IRDA_FAST_RR=y
CONFIG_IRDA_DEBUG=y
Infrared-port device drivers
SIR device drivers
CONFIG_IRTTY_SIR=m
Dongle support
CONFIG_DONGLE=y
CONFIG_ESI_DONGLE=m
CONFIG_ACTISYS_DONGLE=m
CONFIG_TEKRAM_DONGLE=m
CONFIG_TOIM3232_DONGLE=m
CONFIG_LITELINK_DONGLE=m
CONFIG_MA600_DONGLE=m
CONFIG_GIRBIL_DONGLE=m
CONFIG_MCP2120_DONGLE=m
CONFIG_OLD_BELKIN_DONGLE=m
CONFIG_ACT200L_DONGLE=m
Old SIR device drivers
Old Serial dongle support
FIR device drivers
CONFIG_USB_IRDA=m
CONFIG_SIGMATEL_FIR=m
CONFIG_NSC_FIR=m
CONFIG_WINBOND_FIR=m
CONFIG_TOSHIBA_FIR=m
CONFIG_SMC_IRCC_FIR=m
CONFIG_ALI_FIR=m
CONFIG_VLSI_FIR=m
CONFIG_VIA_FIR=m
CONFIG_MCS_FIR=m
CONFIG_BT=m
CONFIG_BT_L2CAP=m
CONFIG_BT_SCO=m
CONFIG_BT_RFCOMM=m
CONFIG_BT_RFCOMM_TTY=y
CONFIG_BT_BNEP=m
CONFIG_BT_BNEP_MC_FILTER=y
CONFIG_BT_BNEP_PROTO_FILTER=y
CONFIG_BT_CMTP=m
CONFIG_BT_HIDP=m
Bluetooth device drivers
CONFIG_BT_HCIUSB=m
CONFIG_BT_HCIUSB_SCO=y
CONFIG_BT_HCIUART=m
CONFIG_BT_HCIUART_H4=y
CONFIG_BT_HCIUART_BCSP=y
CONFIG_BT_HCIBCM203X=m
CONFIG_BT_HCIBPA10X=m
CONFIG_BT_HCIBFUSB=m
CONFIG_BT_HCIDTL1=m
CONFIG_BT_HCIBT3C=m
CONFIG_BT_HCIBLUECARD=m
CONFIG_BT_HCIBTUART=m
CONFIG_BT_HCIVHCI=m
CONFIG_IEEE80211=m
CONFIG_IEEE80211_DEBUG is not set
CONFIG_IEEE80211_CRYPT_WEP=m
CONFIG_IEEE80211_CRYPT_CCMP=m
CONFIG_IEEE80211_CRYPT_TKIP=m
CONFIG_IEEE80211_SOFTMAC=m
CONFIG_IEEE80211_SOFTMAC_DEBUG is not set
CONFIG_WIRELESS_EXT=y
Device Drivers
Generic Driver Options
CONFIG_STANDALONE=y
CONFIG_PREVENT_FIRMWARE_BUILD=y
CONFIG_FW_LOADER=m
CONFIG_SYS_HYPERVISOR is not set
Connector - unified userspace <-> kernelspace linker
CONFIG_CONNECTOR=m
Memory Technology Devices (MTD)
CONFIG_MTD=m
CONFIG_MTD_DEBUG is not set
CONFIG_MTD_CONCAT=m
CONFIG_MTD_PARTITIONS=y
CONFIG_MTD_REDBOOT_PARTS=m
CONFIG_MTD_REDBOOT_DIRECTORY_BLOCK=-1
CONFIG_MTD_REDBOOT_PARTS_UNALLOCATED is not set
CONFIG_MTD_REDBOOT_PARTS_READONLY is not set
CONFIG_MTD_CMDLINE_PARTS is not set
User Modules And Translation Layers
CONFIG_MTD_CHAR=m
CONFIG_MTD_BLOCK=m
CONFIG_MTD_BLOCK_RO=m
CONFIG_FTL=m
CONFIG_NFTL=m
CONFIG_NFTL_RW=y
CONFIG_INFTL=m
CONFIG_RFD_FTL=m
RAM/ROM/Flash chip drivers
CONFIG_MTD_CFI=m
CONFIG_MTD_JEDECPROBE=m
CONFIG_MTD_GEN_PROBE=m
CONFIG_MTD_CFI_ADV_OPTIONS is not set
CONFIG_MTD_MAP_BANK_WIDTH_1=y
CONFIG_MTD_MAP_BANK_WIDTH_2=y
CONFIG_MTD_MAP_BANK_WIDTH_4=y
CONFIG_MTD_MAP_BANK_WIDTH_8 is not set
CONFIG_MTD_MAP_BANK_WIDTH_16 is not set
CONFIG_MTD_MAP_BANK_WIDTH_32 is not set
CONFIG_MTD_CFI_I1=y
CONFIG_MTD_CFI_I2=y
CONFIG_MTD_CFI_I4 is not set
CONFIG_MTD_CFI_I8 is not set
CONFIG_MTD_CFI_INTELEXT=m
CONFIG_MTD_CFI_AMDSTD=m
CONFIG_MTD_CFI_STAA=m
CONFIG_MTD_CFI_UTIL=m
CONFIG_MTD_RAM=m
CONFIG_MTD_ROM=m
CONFIG_MTD_ABSENT=m
CONFIG_MTD_OBSOLETE_CHIPS is not set
Mapping drivers for chip access
CONFIG_MTD_COMPLEX_MAPPINGS=y
CONFIG_MTD_PHYSMAP=m
CONFIG_MTD_PHYSMAP_START=0x8000000
CONFIG_MTD_PHYSMAP_LEN=0x4000000
CONFIG_MTD_PHYSMAP_BANKWIDTH=2
CONFIG_MTD_PNC2000=m
CONFIG_MTD_SC520CDP=m
CONFIG_MTD_NETSC520=m
CONFIG_MTD_TS5500=m
CONFIG_MTD_SBC_GXX=m
CONFIG_MTD_SCx200_DOCFLASH=m
CONFIG_MTD_AMD76XROM is not set
CONFIG_MTD_ICHXROM is not set
CONFIG_MTD_SCB2_FLASH is not set
CONFIG_MTD_NETtel=m
CONFIG_MTD_DILNETPC=m
CONFIG_MTD_DILNETPC_BOOTSIZE=0x80000
CONFIG_MTD_L440GX is not set
CONFIG_MTD_PCI=m
CONFIG_MTD_PLATRAM=m
Self-contained MTD device drivers
CONFIG_MTD_PMC551=m
CONFIG_MTD_PMC551_BUGFIX is not set
CONFIG_MTD_PMC551_DEBUG is not set
CONFIG_MTD_DATAFLASH=m
CONFIG_MTD_M25P80=m
CONFIG_MTD_SLRAM=m
CONFIG_MTD_PHRAM=m
CONFIG_MTD_MTDRAM=m
CONFIG_MTDRAM_TOTAL_SIZE=4096
CONFIG_MTDRAM_ERASE_SIZE=128
CONFIG_MTD_BLOCK2MTD=m
Disk-On-Chip Device Drivers
CONFIG_MTD_DOC2000=m
CONFIG_MTD_DOC2001=m
CONFIG_MTD_DOC2001PLUS=m
CONFIG_MTD_DOCPROBE=m
CONFIG_MTD_DOCECC=m
CONFIG_MTD_DOCPROBE_ADVANCED is not set
CONFIG_MTD_DOCPROBE_ADDRESS=0
NAND Flash Device Drivers
CONFIG_MTD_NAND=m
CONFIG_MTD_NAND_VERIFY_WRITE is not set
CONFIG_MTD_NAND_ECC_SMC is not set
CONFIG_MTD_NAND_IDS=m
CONFIG_MTD_NAND_DISKONCHIP=m
CONFIG_MTD_NAND_DISKONCHIP_PROBE_ADVANCED is not set
CONFIG_MTD_NAND_DISKONCHIP_PROBE_ADDRESS=0
CONFIG_MTD_NAND_DISKONCHIP_BBTWRITE is not set
CONFIG_MTD_NAND_CS553X=m
CONFIG_MTD_NAND_NANDSIM is not set
OneNAND Flash Device Drivers
CONFIG_MTD_ONENAND=m
CONFIG_MTD_ONENAND_VERIFY_WRITE=y
CONFIG_MTD_ONENAND_OTP is not set
Parallel port support
CONFIG_PARPORT=m
CONFIG_PARPORT_PC=m
CONFIG_PARPORT_SERIAL=m
CONFIG_PARPORT_PC_FIFO=y
CONFIG_PARPORT_PC_SUPERIO is not set
CONFIG_PARPORT_PC_PCMCIA=m
CONFIG_PARPORT_NOT_PC=y
CONFIG_PARPORT_GSC is not set
CONFIG_PARPORT_AX88796=m
CONFIG_PARPORT_1284=y
Plug and Play support
CONFIG_PNP=y
CONFIG_PNP_DEBUG is not set
Protocols
CONFIG_ISAPNP=y
CONFIG_PNPBIOS=y
CONFIG_PNPBIOS_PROC_FS=y
CONFIG_PNPACPI=y
Block devices
CONFIG_BLK_DEV_FD=m
CONFIG_BLK_DEV_XD=m
CONFIG_PARIDE=m
CONFIG_PARIDE_PARPORT=m
Parallel IDE high-level drivers
CONFIG_PARIDE_PD=m
CONFIG_PARIDE_PCD=m
CONFIG_PARIDE_PF=m
CONFIG_PARIDE_PT=m
CONFIG_PARIDE_PG=m
Parallel IDE protocol modules
CONFIG_PARIDE_ATEN=m
CONFIG_PARIDE_BPCK=m
CONFIG_PARIDE_BPCK6=m
CONFIG_PARIDE_COMM=m
CONFIG_PARIDE_DSTR=m
CONFIG_PARIDE_FIT2=m
CONFIG_PARIDE_FIT3=m
CONFIG_PARIDE_EPAT=m
CONFIG_PARIDE_EPATC8 is not set
CONFIG_PARIDE_EPIA=m
CONFIG_PARIDE_FRIQ=m
CONFIG_PARIDE_FRPW=m
CONFIG_PARIDE_KBIC=m
CONFIG_PARIDE_KTTI=m
CONFIG_PARIDE_ON20=m
CONFIG_PARIDE_ON26=m
CONFIG_BLK_CPQ_DA=m
CONFIG_BLK_CPQ_CISS_DA=m
CONFIG_CISS_SCSI_TAPE=y
CONFIG_BLK_DEV_DAC960=m
CONFIG_BLK_DEV_UMEM=m
CONFIG_BLK_DEV_COW_COMMON is not set
CONFIG_BLK_DEV_LOOP=m
CONFIG_BLK_DEV_CRYPTOLOOP=m
CONFIG_BLK_DEV_NBD=m
CONFIG_BLK_DEV_SX8=m
CONFIG_BLK_DEV_UB is not set
CONFIG_BLK_DEV_RAM=y
CONFIG_BLK_DEV_RAM_COUNT=16
CONFIG_BLK_DEV_RAM_SIZE=8192
CONFIG_BLK_DEV_RAM_BLOCKSIZE=1024
CONFIG_BLK_DEV_INITRD=y
CONFIG_CDROM_PKTCDVD=m
CONFIG_CDROM_PKTCDVD_BUFFERS=8
CONFIG_CDROM_PKTCDVD_WCACHE is not set
CONFIG_ATA_OVER_ETH=m
ATA/ATAPI/MFM/RLL support
CONFIG_IDE=m
CONFIG_BLK_DEV_IDE=m
Please see Documentation/ide.txt for help/info on IDE drives
CONFIG_BLK_DEV_IDE_SATA is not set
CONFIG_BLK_DEV_HD_IDE is not set
CONFIG_BLK_DEV_IDEDISK=m
CONFIG_IDEDISK_MULTI_MODE is not set
CONFIG_BLK_DEV_IDECS=m
CONFIG_BLK_DEV_IDECD=m
CONFIG_BLK_DEV_IDETAPE=m
CONFIG_BLK_DEV_IDEFLOPPY=m
CONFIG_BLK_DEV_IDESCSI is not set
CONFIG_IDE_TASK_IOCTL is not set
IDE chipset support/bugfixes
CONFIG_IDE_GENERIC=m
CONFIG_BLK_DEV_CMD640=y
CONFIG_BLK_DEV_CMD640_ENHANCED is not set
CONFIG_BLK_DEV_IDEPNP=m
CONFIG_BLK_DEV_IDEPCI=y
CONFIG_IDEPCI_SHARE_IRQ=y
CONFIG_BLK_DEV_OFFBOARD is not set
CONFIG_BLK_DEV_GENERIC=m
CONFIG_BLK_DEV_OPTI621=m
CONFIG_BLK_DEV_RZ1000=m
CONFIG_BLK_DEV_IDEDMA_PCI=y
CONFIG_BLK_DEV_IDEDMA_FORCED is not set
CONFIG_IDEDMA_PCI_AUTO=y
CONFIG_IDEDMA_ONLYDISK is not set
CONFIG_BLK_DEV_AEC62XX=m
CONFIG_BLK_DEV_ALI15X3=m
CONFIG_WDC_ALI15X3 is not set
CONFIG_BLK_DEV_AMD74XX=m
CONFIG_BLK_DEV_ATIIXP=m
CONFIG_BLK_DEV_CMD64X=m
CONFIG_BLK_DEV_TRIFLEX=m
CONFIG_BLK_DEV_CY82C693=m
CONFIG_BLK_DEV_CS5520=m
CONFIG_BLK_DEV_CS5530=m
CONFIG_BLK_DEV_CS5535=m
CONFIG_BLK_DEV_HPT34X=m
CONFIG_HPT34X_AUTODMA is not set
CONFIG_BLK_DEV_HPT366=m
CONFIG_BLK_DEV_JMICRON=m
CONFIG_BLK_DEV_SC1200=m
CONFIG_BLK_DEV_PIIX=m
CONFIG_BLK_DEV_IT821X=m
CONFIG_BLK_DEV_NS87415=m
CONFIG_BLK_DEV_PDC202XX_OLD=m
CONFIG_PDC202XX_BURST=y
CONFIG_BLK_DEV_PDC202XX_NEW=m
CONFIG_BLK_DEV_SVWKS=m
CONFIG_BLK_DEV_SIIMAGE=m
CONFIG_BLK_DEV_SIS5513=m
CONFIG_BLK_DEV_SLC90E66=m
CONFIG_BLK_DEV_TRM290=m
CONFIG_BLK_DEV_VIA82CXXX=m
CONFIG_IDE_ARM is not set
CONFIG_IDE_CHIPSETS is not set
CONFIG_BLK_DEV_IDEDMA=y
CONFIG_IDEDMA_IVB is not set
CONFIG_IDEDMA_AUTO=y
CONFIG_BLK_DEV_HD is not set
SCSI device support
CONFIG_RAID_ATTRS=m
CONFIG_SCSI=m
CONFIG_SCSI_PROC_FS=y
SCSI support type (disk, tape, CD-ROM)
CONFIG_BLK_DEV_SD=m
CONFIG_CHR_DEV_ST=m
CONFIG_CHR_DEV_OSST=m
CONFIG_BLK_DEV_SR=m
CONFIG_BLK_DEV_SR_VENDOR=y
CONFIG_CHR_DEV_SG=m
CONFIG_CHR_DEV_SCH=m
Some SCSI devices (e.g. CD jukebox) support multiple LUNs
CONFIG_SCSI_MULTI_LUN=y
CONFIG_SCSI_CONSTANTS=y
CONFIG_SCSI_LOGGING=y
SCSI Transport Attributes
CONFIG_SCSI_SPI_ATTRS=m
CONFIG_SCSI_FC_ATTRS=m
CONFIG_SCSI_ISCSI_ATTRS=m
CONFIG_SCSI_SAS_ATTRS=m
SCSI low-level drivers
CONFIG_ISCSI_TCP=m
CONFIG_BLK_DEV_3W_XXXX_RAID=m
CONFIG_SCSI_3W_9XXX=m
CONFIG_SCSI_7000FASST=m
CONFIG_SCSI_ACARD=m
CONFIG_SCSI_AHA152X=m
CONFIG_SCSI_AHA1542=m
CONFIG_SCSI_AACRAID=m
CONFIG_SCSI_AIC7XXX=m
CONFIG_AIC7XXX_CMDS_PER_DEVICE=8
CONFIG_AIC7XXX_RESET_DELAY_MS=15000
CONFIG_AIC7XXX_DEBUG_ENABLE=y
CONFIG_AIC7XXX_DEBUG_MASK=0
CONFIG_AIC7XXX_REG_PRETTY_PRINT=y
CONFIG_SCSI_AIC7XXX_OLD=m
CONFIG_SCSI_AIC79XX=m
CONFIG_AIC79XX_CMDS_PER_DEVICE=32
CONFIG_AIC79XX_RESET_DELAY_MS=15000
CONFIG_AIC79XX_ENABLE_RD_STRM=y
CONFIG_AIC79XX_DEBUG_ENABLE=y
CONFIG_AIC79XX_DEBUG_MASK=0
CONFIG_AIC79XX_REG_PRETTY_PRINT=y
CONFIG_SCSI_DPT_I2O=m
CONFIG_SCSI_ADVANSYS=m
CONFIG_SCSI_IN2000=m
CONFIG_SCSI_ARCMSR=m
CONFIG_MEGARAID_NEWGEN=y
CONFIG_MEGARAID_MM=m
CONFIG_MEGARAID_MAILBOX=m
CONFIG_MEGARAID_LEGACY=m
CONFIG_MEGARAID_SAS=m
CONFIG_SCSI_SATA=m
CONFIG_SCSI_SATA_AHCI=m
CONFIG_SCSI_SATA_SVW=m
CONFIG_SCSI_ATA_PIIX=m
CONFIG_SCSI_SATA_MV=m
CONFIG_SCSI_SATA_NV=m
CONFIG_SCSI_PDC_ADMA=m
CONFIG_SCSI_HPTIOP=m
CONFIG_SCSI_SATA_QSTOR=m
CONFIG_SCSI_SATA_PROMISE=m
CONFIG_SCSI_SATA_SX4=m
CONFIG_SCSI_SATA_SIL=m
CONFIG_SCSI_SATA_SIL24=m
CONFIG_SCSI_SATA_SIS=m
CONFIG_SCSI_SATA_ULI=m
CONFIG_SCSI_SATA_VIA=m
CONFIG_SCSI_SATA_VITESSE=m
CONFIG_SCSI_BUSLOGIC=m
CONFIG_SCSI_OMIT_FLASHPOINT is not set
CONFIG_SCSI_DMX3191D=m
CONFIG_SCSI_DTC3280=m
CONFIG_SCSI_EATA=m
CONFIG_SCSI_EATA_TAGGED_QUEUE=y
CONFIG_SCSI_EATA_LINKED_COMMANDS=y
CONFIG_SCSI_EATA_MAX_TAGS=16
CONFIG_SCSI_FUTURE_DOMAIN=m
CONFIG_SCSI_GDTH=m
CONFIG_SCSI_GENERIC_NCR5380=m
CONFIG_SCSI_GENERIC_NCR5380_MMIO=m
CONFIG_SCSI_GENERIC_NCR53C400=y
CONFIG_SCSI_IPS=m
CONFIG_SCSI_INITIO=m
CONFIG_SCSI_INIA100 is not set
CONFIG_SCSI_PPA=m
CONFIG_SCSI_IMM=m
CONFIG_SCSI_IZIP_EPP16 is not set
CONFIG_SCSI_IZIP_SLOW_CTR is not set
CONFIG_SCSI_NCR53C406A=m
CONFIG_SCSI_SYM53C8XX_2=m
CONFIG_SCSI_SYM53C8XX_DMA_ADDRESSING_MODE=1
CONFIG_SCSI_SYM53C8XX_DEFAULT_TAGS=16
CONFIG_SCSI_SYM53C8XX_MAX_TAGS=64
CONFIG_SCSI_SYM53C8XX_MMIO=y
CONFIG_SCSI_IPR=m
CONFIG_SCSI_IPR_TRACE is not set
CONFIG_SCSI_IPR_DUMP is not set
CONFIG_SCSI_PAS16=m
CONFIG_SCSI_PSI240I=m
CONFIG_SCSI_QLOGIC_FAS=m
CONFIG_SCSI_QLOGIC_1280=m
CONFIG_SCSI_QLA_FC=m
CONFIG_SCSI_LPFC=m
CONFIG_SCSI_SYM53C416=m
CONFIG_SCSI_DC395x=m
CONFIG_SCSI_DC390T=m
CONFIG_SCSI_T128=m
CONFIG_SCSI_U14_34F=m
CONFIG_SCSI_U14_34F_TAGGED_QUEUE=y
CONFIG_SCSI_U14_34F_LINKED_COMMANDS=y
CONFIG_SCSI_U14_34F_MAX_TAGS=8
CONFIG_SCSI_ULTRASTOR=m
CONFIG_SCSI_NSP32=m
CONFIG_SCSI_DEBUG=m
PCMCIA SCSI adapter support
CONFIG_PCMCIA_AHA152X=m
CONFIG_PCMCIA_FDOMAIN=m
CONFIG_PCMCIA_NINJA_SCSI=m
CONFIG_PCMCIA_QLOGIC=m
CONFIG_PCMCIA_SYM53C500=m
Old CD-ROM drivers (not SCSI, not IDE)
CONFIG_CD_NO_IDESCSI=y
CONFIG_AZTCD=m
CONFIG_GSCD=m
CONFIG_MCDX=m
CONFIG_OPTCD=m
CONFIG_SJCD=m
CONFIG_ISP16_CDI=m
CONFIG_CDU535=m
Multi-device support (RAID and LVM)
CONFIG_MD=y
CONFIG_BLK_DEV_MD=m
CONFIG_MD_LINEAR=m
CONFIG_MD_RAID0=m
CONFIG_MD_RAID1=m
CONFIG_MD_RAID10=m
CONFIG_MD_RAID456=m
CONFIG_MD_RAID5_RESHAPE=y
CONFIG_MD_MULTIPATH=m
CONFIG_MD_FAULTY=m
CONFIG_BLK_DEV_DM=m
CONFIG_DM_CRYPT=m
CONFIG_DM_SNAPSHOT=m
CONFIG_DM_MIRROR=m
CONFIG_DM_ZERO=m
CONFIG_DM_MULTIPATH=m
CONFIG_DM_MULTIPATH_EMC=m
Fusion MPT device support
CONFIG_FUSION=y
CONFIG_FUSION_SPI=m
CONFIG_FUSION_FC=m
CONFIG_FUSION_SAS=m
CONFIG_FUSION_MAX_SGE=40
CONFIG_FUSION_CTL=m
CONFIG_FUSION_LAN=m
IEEE 1394 (FireWire) support
CONFIG_IEEE1394=m
Subsystem Options
CONFIG_IEEE1394_VERBOSEDEBUG is not set
CONFIG_IEEE1394_OUI_DB is not set
CONFIG_IEEE1394_EXTRA_CONFIG_ROMS=y
CONFIG_IEEE1394_CONFIG_ROM_IP1394=y
CONFIG_IEEE1394_EXPORT_FULL_API is not set
Device Drivers
CONFIG_IEEE1394_PCILYNX=m
CONFIG_IEEE1394_OHCI1394=m
Protocol Drivers
CONFIG_IEEE1394_VIDEO1394=m
CONFIG_IEEE1394_SBP2=m
CONFIG_IEEE1394_SBP2_PHYS_DMA is not set
CONFIG_IEEE1394_ETH1394=m
CONFIG_IEEE1394_DV1394=m
CONFIG_IEEE1394_RAWIO=m
I2O device support
CONFIG_I2O=m
CONFIG_I2O_LCT_NOTIFY_ON_CHANGES=y
CONFIG_I2O_EXT_ADAPTEC=y
CONFIG_I2O_CONFIG=m
CONFIG_I2O_CONFIG_OLD_IOCTL=y
CONFIG_I2O_BUS=m
CONFIG_I2O_BLOCK=m
CONFIG_I2O_SCSI=m
CONFIG_I2O_PROC=m
Network device support
CONFIG_NETDEVICES=y
CONFIG_IFB=m
CONFIG_DUMMY=m
CONFIG_BONDING=m
CONFIG_EQUALIZER=m
CONFIG_TUN=m
CONFIG_NET_SB1000=m
ARCnet devices
CONFIG_ARCNET=m
CONFIG_ARCNET_1201=m
CONFIG_ARCNET_1051=m
CONFIG_ARCNET_RAW=m
CONFIG_ARCNET_CAP=m
CONFIG_ARCNET_COM90xx=m
CONFIG_ARCNET_COM90xxIO=m
CONFIG_ARCNET_RIM_I=m
CONFIG_ARCNET_COM20020=m
CONFIG_ARCNET_COM20020_ISA=m
CONFIG_ARCNET_COM20020_PCI=m
PHY device support
CONFIG_PHYLIB=m
MII PHY device drivers
CONFIG_MARVELL_PHY=m
CONFIG_DAVICOM_PHY=m
CONFIG_QSEMI_PHY=m
CONFIG_LXT_PHY=m
CONFIG_CICADA_PHY=m
CONFIG_VITESSE_PHY=m
CONFIG_SMSC_PHY=m
CONFIG_FIXED_PHY=m
CONFIG_FIXED_MII_10_FDX is not set
CONFIG_FIXED_MII_100_FDX is not set
Ethernet (10 or 100Mbit)
CONFIG_NET_ETHERNET=y
CONFIG_MII=m
CONFIG_HAPPYMEAL=m
CONFIG_SUNGEM=m
CONFIG_CASSINI=m
CONFIG_NET_VENDOR_3COM=y
CONFIG_EL1=m
CONFIG_EL2=m
CONFIG_ELPLUS=m
CONFIG_EL16=m
CONFIG_EL3=m
CONFIG_3C515=m
CONFIG_VORTEX=m
CONFIG_TYPHOON=m
CONFIG_LANCE=m
CONFIG_NET_VENDOR_SMC=y
CONFIG_WD80x3=m
CONFIG_ULTRA=m
CONFIG_SMC9194=m
CONFIG_NET_VENDOR_RACAL=y
CONFIG_NI52=m
CONFIG_NI65=m
Tulip family network device support
CONFIG_NET_TULIP=y
CONFIG_DE2104X=m
CONFIG_TULIP=m
CONFIG_TULIP_MWI is not set
CONFIG_TULIP_MMIO is not set
CONFIG_TULIP_NAPI=y
CONFIG_TULIP_NAPI_HW_MITIGATION=y
CONFIG_DE4X5=m
CONFIG_WINBOND_840=m
CONFIG_DM9102=m
CONFIG_ULI526X=m
CONFIG_PCMCIA_XIRCOM=m
CONFIG_AT1700=m
CONFIG_DEPCA=m
CONFIG_HP100=m
CONFIG_NET_ISA=y
CONFIG_E2100=m
CONFIG_EWRK3=m
CONFIG_EEXPRESS=m
CONFIG_EEXPRESS_PRO=m
CONFIG_HPLAN_PLUS=m
CONFIG_HPLAN=m
CONFIG_LP486E=m
CONFIG_ETH16I=m
CONFIG_NE2000=m
CONFIG_ZNET=m
CONFIG_SEEQ8005=m
CONFIG_NET_PCI=y
CONFIG_PCNET32=m
CONFIG_AMD8111_ETH=m
CONFIG_AMD8111E_NAPI=y
CONFIG_ADAPTEC_STARFIRE=m
CONFIG_ADAPTEC_STARFIRE_NAPI=y
CONFIG_AC3200=m
CONFIG_APRICOT=m
CONFIG_B44=m
CONFIG_FORCEDETH=m
CONFIG_CS89x0=m
CONFIG_EEPRO100=m
CONFIG_E100=m
CONFIG_FEALNX=m
CONFIG_NATSEMI=m
CONFIG_NE2K_PCI=m
CONFIG_8139CP=m
CONFIG_8139TOO=m
CONFIG_8139TOO_PIO=y
CONFIG_8139TOO_TUNE_TWISTER=y
CONFIG_8139TOO_8129=y
CONFIG_8139_OLD_RX_RESET is not set
CONFIG_SIS900=m
CONFIG_EPIC100=m
CONFIG_SUNDANCE=m
CONFIG_SUNDANCE_MMIO is not set
CONFIG_TLAN=m
CONFIG_VIA_RHINE=m
CONFIG_VIA_RHINE_MMIO is not set
CONFIG_VIA_RHINE_NAPI=y
CONFIG_NET_POCKET is not set
Ethernet (1000 Mbit)
CONFIG_ACENIC=m
CONFIG_ACENIC_OMIT_TIGON_I is not set
CONFIG_DL2K=m
CONFIG_E1000=m
CONFIG_E1000_NAPI=y
CONFIG_E1000_DISABLE_PACKET_SPLIT is not set
CONFIG_NS83820=m
CONFIG_HAMACHI=m
CONFIG_YELLOWFIN=m
CONFIG_R8169=m
CONFIG_R8169_NAPI=y
CONFIG_R8169_VLAN=y
CONFIG_SIS190=m
CONFIG_SKGE=m
CONFIG_SKY2=m
CONFIG_SK98LIN is not set
CONFIG_VIA_VELOCITY=m
CONFIG_TIGON3=m
CONFIG_BNX2=m
Ethernet (10000 Mbit)
CONFIG_CHELSIO_T1=m
CONFIG_IXGB=m
CONFIG_IXGB_NAPI=y
CONFIG_S2IO=m
CONFIG_S2IO_NAPI=y
CONFIG_MYRI10GE=m
Token Ring devices
CONFIG_TR=y
CONFIG_IBMTR=m
CONFIG_IBMOL=m
CONFIG_IBMLS=m
CONFIG_TMS380TR=m
CONFIG_TMSPCI=m
CONFIG_SKISA=m
CONFIG_PROTEON=m
CONFIG_ABYSS=m
Wireless LAN (non-hamradio)
CONFIG_NET_RADIO=y
CONFIG_NET_WIRELESS_RTNETLINK=y
Obsolete Wireless cards support (pre-802.11)
CONFIG_STRIP=m
CONFIG_ARLAN=m
CONFIG_WAVELAN=m
CONFIG_PCMCIA_WAVELAN=m
CONFIG_PCMCIA_NETWAVE=m
Wireless 802.11 Frequency Hopping cards support
CONFIG_PCMCIA_RAYCS=m
Wireless 802.11b ISA/PCI cards support
CONFIG_IPW2100=m
CONFIG_IPW2100_MONITOR=y
CONFIG_IPW2100_DEBUG is not set
CONFIG_IPW2200=m
CONFIG_IPW2200_MONITOR=y
CONFIG_IPW2200_RADIOTAP is not set
CONFIG_IPW2200_PROMISCUOUS is not set
CONFIG_IPW2200_QOS=y
CONFIG_IPW2200_DEBUG is not set
CONFIG_AIRO=m
CONFIG_HERMES=m
CONFIG_PLX_HERMES=m
CONFIG_TMD_HERMES=m
CONFIG_NORTEL_HERMES=m
CONFIG_PCI_HERMES=m
CONFIG_ATMEL=m
CONFIG_PCI_ATMEL=m
Wireless 802.11b Pcmcia/Cardbus cards support
CONFIG_PCMCIA_HERMES=m
CONFIG_PCMCIA_SPECTRUM=m
CONFIG_AIRO_CS=m
CONFIG_PCMCIA_ATMEL=m
CONFIG_PCMCIA_WL3501=m
Prism GT/Duette 802.11(a/b/g) PCI/Cardbus support
CONFIG_PRISM54=m
CONFIG_USB_ZD1201=m
CONFIG_HOSTAP=m
CONFIG_HOSTAP_FIRMWARE=y
CONFIG_HOSTAP_FIRMWARE_NVRAM is not set
CONFIG_HOSTAP_PLX=m
CONFIG_HOSTAP_PCI=m
CONFIG_HOSTAP_CS=m
CONFIG_BCM43XX=m
CONFIG_BCM43XX_DEBUG=y
CONFIG_BCM43XX_DMA=y
CONFIG_BCM43XX_PIO=y
CONFIG_BCM43XX_DMA_AND_PIO_MODE=y
CONFIG_BCM43XX_DMA_MODE is not set
CONFIG_BCM43XX_PIO_MODE is not set
CONFIG_ZD1211RW=m
CONFIG_ZD1211RW_DEBUG is not set
CONFIG_NET_WIRELESS=y
PCMCIA network device support
CONFIG_NET_PCMCIA=y
CONFIG_PCMCIA_3C589=m
CONFIG_PCMCIA_3C574=m
CONFIG_PCMCIA_FMVJ18X=m
CONFIG_PCMCIA_PCNET=m
CONFIG_PCMCIA_NMCLAN=m
CONFIG_PCMCIA_SMC91C92=m
CONFIG_PCMCIA_XIRC2PS=m
CONFIG_PCMCIA_AXNET=m
CONFIG_ARCNET_COM20020_CS=m
CONFIG_PCMCIA_IBMTR=m
Wan interfaces
CONFIG_WAN=y
CONFIG_HOSTESS_SV11=m
CONFIG_COSA=m
CONFIG_DSCC4=m
CONFIG_DSCC4_PCISYNC=y
CONFIG_DSCC4_PCI_RST=y
CONFIG_LANMEDIA=m
CONFIG_SEALEVEL_4021=m
CONFIG_HDLC=m
CONFIG_HDLC_RAW=y
CONFIG_HDLC_RAW_ETH=y
CONFIG_HDLC_CISCO=y
CONFIG_HDLC_FR=y
CONFIG_HDLC_PPP=y
CONFIG_HDLC_X25=y
CONFIG_PCI200SYN=m
CONFIG_WANXL=m
CONFIG_PC300=m
CONFIG_PC300_MLPPP=y
CONFIG_N2=m
CONFIG_C101=m
CONFIG_FARSYNC=m
CONFIG_DLCI=m
CONFIG_DLCI_COUNT=24
CONFIG_DLCI_MAX=8
CONFIG_SDLA=m
CONFIG_WAN_ROUTER_DRIVERS=y
CONFIG_CYCLADES_SYNC=m
CONFIG_CYCLOMX_X25=y
CONFIG_LAPBETHER=m
CONFIG_X25_ASY=m
CONFIG_SBNI=m
CONFIG_SBNI_MULTILINE is not set
ATM drivers
CONFIG_ATM_DUMMY=m
CONFIG_ATM_TCP=m
CONFIG_ATM_LANAI=m
CONFIG_ATM_ENI=m
CONFIG_ATM_ENI_DEBUG is not set
CONFIG_ATM_ENI_TUNE_BURST is not set
CONFIG_ATM_FIRESTREAM=m
CONFIG_ATM_ZATM=m
CONFIG_ATM_ZATM_DEBUG is not set
CONFIG_ATM_NICSTAR=m
CONFIG_ATM_NICSTAR_USE_SUNI is not set
CONFIG_ATM_NICSTAR_USE_IDT77105 is not set
CONFIG_ATM_IDT77252=m
CONFIG_ATM_IDT77252_DEBUG is not set
CONFIG_ATM_IDT77252_RCV_ALL is not set
CONFIG_ATM_IDT77252_USE_SUNI=y
CONFIG_ATM_AMBASSADOR=m
CONFIG_ATM_AMBASSADOR_DEBUG is not set
CONFIG_ATM_HORIZON=m
CONFIG_ATM_HORIZON_DEBUG is not set
CONFIG_ATM_IA=m
CONFIG_ATM_IA_DEBUG is not set
CONFIG_ATM_FORE200E_MAYBE=m
CONFIG_ATM_FORE200E_PCA=y
CONFIG_ATM_FORE200E_PCA_DEFAULT_FW=y
CONFIG_ATM_FORE200E_USE_TASKLET is not set
CONFIG_ATM_FORE200E_TX_RETRY=16
CONFIG_ATM_FORE200E_DEBUG=0
CONFIG_ATM_FORE200E=m
CONFIG_ATM_HE=m
CONFIG_ATM_HE_USE_SUNI=y
CONFIG_FDDI=y
CONFIG_DEFXX=m
CONFIG_SKFP=m
CONFIG_HIPPI=y
CONFIG_ROADRUNNER=m
CONFIG_ROADRUNNER_LARGE_RINGS is not set
CONFIG_PLIP=m
CONFIG_PPP=m
CONFIG_PPP_MULTILINK=y
CONFIG_PPP_FILTER=y
CONFIG_PPP_ASYNC=m
CONFIG_PPP_SYNC_TTY=m
CONFIG_PPP_DEFLATE=m
CONFIG_PPP_BSDCOMP=m
CONFIG_PPP_MPPE=m
CONFIG_PPPOE=m
CONFIG_PPPOATM=m
CONFIG_SLIP=m
CONFIG_SLIP_COMPRESSED=y
CONFIG_SLIP_SMART=y
CONFIG_SLIP_MODE_SLIP6=y
CONFIG_NET_FC=y
CONFIG_SHAPER=m
CONFIG_NETCONSOLE=m
CONFIG_NETPOLL=y
CONFIG_NETPOLL_RX is not set
CONFIG_NETPOLL_TRAP is not set
CONFIG_NET_POLL_CONTROLLER=y
ISDN subsystem
CONFIG_ISDN=m
Old ISDN4Linux
CONFIG_ISDN_I4L=m
CONFIG_ISDN_PPP=y
CONFIG_ISDN_PPP_VJ=y
CONFIG_ISDN_MPP=y
CONFIG_IPPP_FILTER=y
CONFIG_ISDN_PPP_BSDCOMP=m
CONFIG_ISDN_AUDIO=y
CONFIG_ISDN_TTY_FAX=y
CONFIG_ISDN_X25=y
ISDN feature submodules
CONFIG_ISDN_DIVERSION is not set
ISDN4Linux hardware drivers
Passive cards
CONFIG_ISDN_DRV_HISAX=m
D-channel protocol features
CONFIG_HISAX_EURO=y
CONFIG_DE_AOC=y
CONFIG_HISAX_NO_SENDCOMPLETE is not set
CONFIG_HISAX_NO_LLC is not set
CONFIG_HISAX_NO_KEYPAD is not set
CONFIG_HISAX_1TR6=y
CONFIG_HISAX_NI1=y
CONFIG_HISAX_MAX_CARDS=8
HiSax supported cards
CONFIG_HISAX_16_0=y
CONFIG_HISAX_16_3=y
CONFIG_HISAX_TELESPCI=y
CONFIG_HISAX_S0BOX=y
CONFIG_HISAX_AVM_A1=y
CONFIG_HISAX_FRITZPCI=y
CONFIG_HISAX_AVM_A1_PCMCIA=y
CONFIG_HISAX_ELSA=y
CONFIG_HISAX_IX1MICROR2=y
CONFIG_HISAX_DIEHLDIVA=y
CONFIG_HISAX_ASUSCOM=y
CONFIG_HISAX_TELEINT=y
CONFIG_HISAX_HFCS=y
CONFIG_HISAX_SEDLBAUER=y
CONFIG_HISAX_SPORTSTER=y
CONFIG_HISAX_MIC=y
CONFIG_HISAX_NETJET=y
CONFIG_HISAX_NETJET_U=y
CONFIG_HISAX_NICCY=y
CONFIG_HISAX_ISURF=y
CONFIG_HISAX_HSTSAPHIR=y
CONFIG_HISAX_BKM_A4T=y
CONFIG_HISAX_SCT_QUADRO=y
CONFIG_HISAX_GAZEL=y
CONFIG_HISAX_HFC_PCI=y
CONFIG_HISAX_W6692=y
CONFIG_HISAX_HFC_SX=y
CONFIG_HISAX_ENTERNOW_PCI=y
CONFIG_HISAX_DEBUG is not set
HiSax PCMCIA card service modules
CONFIG_HISAX_SEDLBAUER_CS=m
CONFIG_HISAX_ELSA_CS=m
CONFIG_HISAX_AVM_A1_CS=m
CONFIG_HISAX_TELES_CS=m
HiSax sub driver modules
CONFIG_HISAX_ST5481=m
CONFIG_HISAX_HFCUSB=m
CONFIG_HISAX_HFC4S8S=m
CONFIG_HISAX_FRITZ_PCIPNP=m
CONFIG_HISAX_HDLC=y
Active cards
CONFIG_ISDN_DRV_ICN=m
CONFIG_ISDN_DRV_PCBIT=m
CONFIG_ISDN_DRV_SC=m
CONFIG_ISDN_DRV_ACT2000=m
Siemens Gigaset
CONFIG_ISDN_DRV_GIGASET=m
CONFIG_GIGASET_BASE=m
CONFIG_GIGASET_M105=m
CONFIG_GIGASET_DEBUG is not set
CONFIG_GIGASET_UNDOCREQ is not set
CAPI subsystem
CONFIG_ISDN_CAPI=m
CONFIG_ISDN_DRV_AVMB1_VERBOSE_REASON=y
CONFIG_ISDN_CAPI_MIDDLEWARE=y
CONFIG_ISDN_CAPI_CAPI20=m
CONFIG_ISDN_CAPI_CAPIFS_BOOL=y
CONFIG_ISDN_CAPI_CAPIFS=m
CONFIG_ISDN_CAPI_CAPIDRV=m
CAPI hardware drivers
Active AVM cards
CONFIG_CAPI_AVM=y
CONFIG_ISDN_DRV_AVMB1_B1ISA=m
CONFIG_ISDN_DRV_AVMB1_B1PCI=m
CONFIG_ISDN_DRV_AVMB1_B1PCIV4 is not set
CONFIG_ISDN_DRV_AVMB1_T1ISA=m
CONFIG_ISDN_DRV_AVMB1_B1PCMCIA=m
CONFIG_ISDN_DRV_AVMB1_AVM_CS is not set
CONFIG_ISDN_DRV_AVMB1_T1PCI=m
CONFIG_ISDN_DRV_AVMB1_C4=m
Active Eicon DIVA Server cards
CONFIG_CAPI_EICON=y
CONFIG_ISDN_DIVAS=m
CONFIG_ISDN_DIVAS_BRIPCI=y
CONFIG_ISDN_DIVAS_PRIPCI=y
CONFIG_ISDN_DIVAS_DIVACAPI=m
CONFIG_ISDN_DIVAS_USERIDI=m
CONFIG_ISDN_DIVAS_MAINT=m
Telephony Support
CONFIG_PHONE=m
CONFIG_PHONE_IXJ=m
CONFIG_PHONE_IXJ_PCMCIA=m
Input device support
CONFIG_INPUT=y
Userland interfaces
CONFIG_INPUT_MOUSEDEV=y
CONFIG_INPUT_MOUSEDEV_PSAUX=y
CONFIG_INPUT_MOUSEDEV_SCREEN_X=1024
CONFIG_INPUT_MOUSEDEV_SCREEN_Y=768
CONFIG_INPUT_JOYDEV=m
CONFIG_INPUT_TSDEV=m
CONFIG_INPUT_TSDEV_SCREEN_X=240
CONFIG_INPUT_TSDEV_SCREEN_Y=320
CONFIG_INPUT_EVDEV=m
CONFIG_INPUT_EVBUG is not set
Input Device Drivers
CONFIG_INPUT_KEYBOARD=y
CONFIG_KEYBOARD_ATKBD=y
CONFIG_KEYBOARD_SUNKBD=m
CONFIG_KEYBOARD_LKKBD=m
CONFIG_KEYBOARD_XTKBD=m
CONFIG_KEYBOARD_NEWTON=m
CONFIG_INPUT_MOUSE=y
CONFIG_MOUSE_PS2=m
CONFIG_MOUSE_SERIAL=m
CONFIG_MOUSE_INPORT=m
CONFIG_MOUSE_ATIXL is not set
CONFIG_MOUSE_LOGIBM=m
CONFIG_MOUSE_PC110PAD=m
CONFIG_MOUSE_VSXXXAA=m
CONFIG_INPUT_JOYSTICK=y
CONFIG_JOYSTICK_ANALOG=m
CONFIG_JOYSTICK_A3D=m
CONFIG_JOYSTICK_ADI=m
CONFIG_JOYSTICK_COBRA=m
CONFIG_JOYSTICK_GF2K=m
CONFIG_JOYSTICK_GRIP=m
CONFIG_JOYSTICK_GRIP_MP=m
CONFIG_JOYSTICK_GUILLEMOT=m
CONFIG_JOYSTICK_INTERACT=m
CONFIG_JOYSTICK_SIDEWINDER=m
CONFIG_JOYSTICK_TMDC=m
CONFIG_JOYSTICK_IFORCE=m
CONFIG_JOYSTICK_IFORCE_USB=y
CONFIG_JOYSTICK_IFORCE_232=y
CONFIG_JOYSTICK_WARRIOR=m
CONFIG_JOYSTICK_MAGELLAN=m
CONFIG_JOYSTICK_SPACEORB=m
CONFIG_JOYSTICK_SPACEBALL=m
CONFIG_JOYSTICK_STINGER=m
CONFIG_JOYSTICK_TWIDJOY=m
CONFIG_JOYSTICK_DB9=m
CONFIG_JOYSTICK_GAMECON=m
CONFIG_JOYSTICK_TURBOGRAFX=m
CONFIG_JOYSTICK_JOYDUMP=m
CONFIG_INPUT_TOUCHSCREEN=y
CONFIG_TOUCHSCREEN_ADS7846=m
CONFIG_TOUCHSCREEN_GUNZE=m
CONFIG_TOUCHSCREEN_ELO=m
CONFIG_TOUCHSCREEN_MTOUCH=m
CONFIG_TOUCHSCREEN_MK712=m
CONFIG_INPUT_MISC=y
CONFIG_INPUT_PCSPKR=m
CONFIG_INPUT_WISTRON_BTNS=m
CONFIG_INPUT_UINPUT=m
Hardware I/O ports
CONFIG_SERIO=y
CONFIG_SERIO_I8042=y
CONFIG_SERIO_SERPORT=m
CONFIG_SERIO_CT82C710=m
CONFIG_SERIO_PARKBD=m
CONFIG_SERIO_PCIPS2=m
CONFIG_SERIO_LIBPS2=y
CONFIG_SERIO_RAW=m
CONFIG_GAMEPORT=m
CONFIG_GAMEPORT_NS558=m
CONFIG_GAMEPORT_L4=m
CONFIG_GAMEPORT_EMU10K1=m
CONFIG_GAMEPORT_FM801=m
Character devices
CONFIG_VT=y
CONFIG_VT_CONSOLE=y
CONFIG_HW_CONSOLE=y
CONFIG_VT_HW_CONSOLE_BINDING is not set
CONFIG_SERIAL_NONSTANDARD=y
CONFIG_COMPUTONE is not set
CONFIG_ROCKETPORT=m
CONFIG_CYCLADES=m
CONFIG_CYZ_INTR is not set
CONFIG_DIGIEPCA is not set
CONFIG_ESPSERIAL is not set
CONFIG_MOXA_INTELLIO is not set
CONFIG_MOXA_SMARTIO=m
CONFIG_ISI is not set
CONFIG_SYNCLINK=m
CONFIG_SYNCLINKMP=m
CONFIG_SYNCLINK_GT=m
CONFIG_N_HDLC=m
CONFIG_SPECIALIX is not set
CONFIG_SX=m
CONFIG_RIO is not set
CONFIG_STALDRV=y
Serial drivers
CONFIG_SERIAL_8250=y
CONFIG_SERIAL_8250_CONSOLE=y
CONFIG_SERIAL_8250_PCI=y
CONFIG_SERIAL_8250_PNP=y
CONFIG_SERIAL_8250_CS=m
CONFIG_SERIAL_8250_NR_UARTS=16
CONFIG_SERIAL_8250_RUNTIME_UARTS=4
CONFIG_SERIAL_8250_EXTENDED=y
CONFIG_SERIAL_8250_MANY_PORTS=y
CONFIG_SERIAL_8250_SHARE_IRQ=y
CONFIG_SERIAL_8250_DETECT_IRQ is not set
CONFIG_SERIAL_8250_RSA=y
CONFIG_SERIAL_8250_FOURPORT=m
CONFIG_SERIAL_8250_ACCENT=m
CONFIG_SERIAL_8250_BOCA=m
CONFIG_SERIAL_8250_HUB6=m
Non-8250 serial port support
CONFIG_SERIAL_CORE=y
CONFIG_SERIAL_CORE_CONSOLE=y
CONFIG_SERIAL_JSM=m
CONFIG_UNIX98_PTYS=y
CONFIG_LEGACY_PTYS=y
CONFIG_LEGACY_PTY_COUNT=16
CONFIG_PRINTER=m
CONFIG_LP_CONSOLE is not set
CONFIG_PPDEV=m
CONFIG_TIPAR=m
IPMI
CONFIG_IPMI_HANDLER=m
CONFIG_IPMI_PANIC_EVENT is not set
CONFIG_IPMI_DEVICE_INTERFACE=m
CONFIG_IPMI_SI=m
CONFIG_IPMI_WATCHDOG=m
CONFIG_IPMI_POWEROFF=m
Watchdog Cards
CONFIG_WATCHDOG=y
CONFIG_WATCHDOG_NOWAYOUT is not set
Watchdog Device Drivers
CONFIG_SOFT_WATCHDOG=m
CONFIG_ACQUIRE_WDT=m
CONFIG_ADVANTECH_WDT=m
CONFIG_ALIM1535_WDT=m
CONFIG_ALIM7101_WDT=m
CONFIG_SC520_WDT=m
CONFIG_EUROTECH_WDT=m
CONFIG_IB700_WDT=m
CONFIG_IBMASR=m
CONFIG_WAFER_WDT=m
CONFIG_I6300ESB_WDT=m
CONFIG_I8XX_TCO=m
CONFIG_SC1200_WDT=m
CONFIG_SCx200_WDT=m
CONFIG_60XX_WDT=m
CONFIG_SBC8360_WDT=m
CONFIG_CPU5_WDT=m
CONFIG_W83627HF_WDT=m
CONFIG_W83877F_WDT=m
CONFIG_W83977F_WDT=m
CONFIG_MACHZ_WDT=m
CONFIG_SBC_EPX_C3_WATCHDOG=m
ISA-based Watchdog Cards
CONFIG_PCWATCHDOG=m
CONFIG_MIXCOMWD=m
CONFIG_WDT=m
CONFIG_WDT_501=y
PCI-based Watchdog Cards
CONFIG_PCIPCWATCHDOG=m
CONFIG_WDTPCI=m
CONFIG_WDT_501_PCI=y
USB-based Watchdog Cards
CONFIG_USBPCWATCHDOG=m
CONFIG_HW_RANDOM=y
CONFIG_HW_RANDOM_INTEL=m
CONFIG_HW_RANDOM_AMD=m
CONFIG_HW_RANDOM_GEODE=m
CONFIG_HW_RANDOM_VIA=m
CONFIG_NVRAM=m
CONFIG_RTC=m
CONFIG_GEN_RTC=m
CONFIG_GEN_RTC_X=y
CONFIG_DTLK=m
CONFIG_R3964=m
CONFIG_APPLICOM=m
CONFIG_SONYPI=m
Ftape, the floppy tape device driver
CONFIG_AGP=m
CONFIG_AGP_ALI=m
CONFIG_AGP_ATI=m
CONFIG_AGP_AMD=m
CONFIG_AGP_AMD64=m
CONFIG_AGP_INTEL=m
CONFIG_AGP_NVIDIA=m
CONFIG_AGP_SIS=m
CONFIG_AGP_SWORKS=m
CONFIG_AGP_VIA=m
CONFIG_AGP_EFFICEON=m
CONFIG_DRM=m
CONFIG_DRM_TDFX=m
CONFIG_DRM_R128=m
CONFIG_DRM_RADEON=m
CONFIG_DRM_I810=m
CONFIG_DRM_I830=m
CONFIG_DRM_I915=m
CONFIG_DRM_MGA=m
CONFIG_DRM_SIS=m
CONFIG_DRM_VIA=m
CONFIG_DRM_SAVAGE=m
PCMCIA character devices
CONFIG_SYNCLINK_CS=m
CONFIG_CARDMAN_4000=m
CONFIG_CARDMAN_4040=m
CONFIG_MWAVE=m
CONFIG_SCx200_GPIO=m
CONFIG_PC8736x_GPIO=m
CONFIG_NSC_GPIO=m
CONFIG_CS5535_GPIO=m
CONFIG_RAW_DRIVER=m
CONFIG_MAX_RAW_DEVS=256
CONFIG_HPET=y
CONFIG_HPET_RTC_IRQ is not set
CONFIG_HPET_MMAP=y
CONFIG_HANGCHECK_TIMER=m
TPM devices
CONFIG_TCG_TPM is not set
CONFIG_TELCLOCK=m
I2C support
CONFIG_I2C=m
CONFIG_I2C_CHARDEV=m
I2C Algorithms
CONFIG_I2C_ALGOBIT=m
CONFIG_I2C_ALGOPCF=m
CONFIG_I2C_ALGOPCA=m
I2C Hardware Bus support
CONFIG_I2C_ALI1535=m
CONFIG_I2C_ALI1563=m
CONFIG_I2C_ALI15X3=m
CONFIG_I2C_AMD756=m
CONFIG_I2C_AMD756_S4882=m
CONFIG_I2C_AMD8111=m
CONFIG_I2C_ELEKTOR is not set
CONFIG_I2C_I801=m
CONFIG_I2C_I810=m
CONFIG_I2C_PIIX4=m
CONFIG_I2C_ISA=m
CONFIG_I2C_NFORCE2=m
CONFIG_I2C_OCORES=m
CONFIG_I2C_PARPORT=m
CONFIG_I2C_PARPORT_LIGHT=m
CONFIG_I2C_PROSAVAGE=m
CONFIG_I2C_SAVAGE4=m
CONFIG_SCx200_I2C=m
CONFIG_SCx200_I2C_SCL=12
CONFIG_SCx200_I2C_SDA=13
CONFIG_SCx200_ACB=m
CONFIG_I2C_SIS5595=m
CONFIG_I2C_SIS630=m
CONFIG_I2C_SIS96X=m
CONFIG_I2C_STUB=m
CONFIG_I2C_VIA=m
CONFIG_I2C_VIAPRO=m
CONFIG_I2C_VOODOO3=m
CONFIG_I2C_PCA_ISA=m
Miscellaneous I2C Chip support
CONFIG_SENSORS_DS1337=m
CONFIG_SENSORS_DS1374=m
CONFIG_SENSORS_EEPROM=m
CONFIG_SENSORS_PCF8574=m
CONFIG_SENSORS_PCA9539=m
CONFIG_SENSORS_PCF8591=m
CONFIG_SENSORS_MAX6875=m
CONFIG_I2C_DEBUG_CORE is not set
CONFIG_I2C_DEBUG_ALGO is not set
CONFIG_I2C_DEBUG_BUS is not set
CONFIG_I2C_DEBUG_CHIP is not set
SPI support
CONFIG_SPI=y
CONFIG_SPI_MASTER=y
SPI Master Controller Drivers
CONFIG_SPI_BITBANG=m
CONFIG_SPI_BUTTERFLY=m
SPI Protocol Masters
Dallas’s 1-wire bus
CONFIG_W1=m
CONFIG_W1_CON=y
1-wire Bus Masters
CONFIG_W1_MASTER_MATROX=m
CONFIG_W1_MASTER_DS2490=m
CONFIG_W1_MASTER_DS2482=m
1-wire Slaves
CONFIG_W1_SLAVE_THERM=m
CONFIG_W1_SLAVE_SMEM=m
CONFIG_W1_SLAVE_DS2433=m
CONFIG_W1_SLAVE_DS2433_CRC is not set
Hardware Monitoring support
CONFIG_HWMON=y
CONFIG_HWMON_VID=m
CONFIG_SENSORS_ABITUGURU=m
CONFIG_SENSORS_ADM1021=m
CONFIG_SENSORS_ADM1025=m
CONFIG_SENSORS_ADM1026=m
CONFIG_SENSORS_ADM1031=m
CONFIG_SENSORS_ADM9240=m
CONFIG_SENSORS_ASB100=m
CONFIG_SENSORS_ATXP1=m
CONFIG_SENSORS_DS1621=m
CONFIG_SENSORS_F71805F=m
CONFIG_SENSORS_F75375S is not set
CONFIG_SENSORS_FSCHER=m
CONFIG_SENSORS_FSCPOS=m
CONFIG_SENSORS_GL518SM=m
CONFIG_SENSORS_GL520SM=m
CONFIG_SENSORS_IT87=m
CONFIG_SENSORS_LM63=m
CONFIG_SENSORS_LM70=m
CONFIG_SENSORS_LM75=m
CONFIG_SENSORS_LM77=m
CONFIG_SENSORS_LM78=m
CONFIG_SENSORS_LM80=m
CONFIG_SENSORS_LM83=m
CONFIG_SENSORS_LM85=m
CONFIG_SENSORS_LM87=m
CONFIG_SENSORS_LM90=m
CONFIG_SENSORS_LM92=m
CONFIG_SENSORS_MAX1619=m
CONFIG_SENSORS_PC87360=m
CONFIG_SENSORS_SIS5595=m
CONFIG_SENSORS_SMSC47M1=m
CONFIG_SENSORS_SMSC47M192=m
CONFIG_SENSORS_SMSC47B397=m
CONFIG_SENSORS_VIA686A=m
CONFIG_SENSORS_VT8231=m
CONFIG_SENSORS_W83781D=m
CONFIG_SENSORS_W83791D=m
CONFIG_SENSORS_W83792D=m
CONFIG_SENSORS_W83L785TS=m
CONFIG_SENSORS_W83627HF=m
CONFIG_SENSORS_W83627EHF=m
CONFIG_SENSORS_HDAPS=m
CONFIG_HWMON_DEBUG_CHIP is not set
Misc devices
CONFIG_IBM_ASM=m
Multimedia devices
CONFIG_VIDEO_DEV=m
CONFIG_VIDEO_V4L1=y
CONFIG_VIDEO_V4L1_COMPAT=y
CONFIG_VIDEO_V4L2=y
Video Capture Adapters
CONFIG_VIDEO_ADV_DEBUG is not set
CONFIG_VIDEO_VIVI=m
CONFIG_VIDEO_BT848=m
CONFIG_VIDEO_BT848_DVB=y
CONFIG_VIDEO_SAA6588=m
CONFIG_VIDEO_PMS=m
CONFIG_VIDEO_BWQCAM=m
CONFIG_VIDEO_CQCAM=m
CONFIG_VIDEO_W9966=m
CONFIG_VIDEO_CPIA=m
CONFIG_VIDEO_CPIA_PP=m
CONFIG_VIDEO_CPIA_USB=m
CONFIG_VIDEO_CPIA2=m
CONFIG_VIDEO_SAA5246A=m
CONFIG_VIDEO_SAA5249=m
CONFIG_TUNER_3036=m
CONFIG_VIDEO_STRADIS=m
CONFIG_VIDEO_ZORAN=m
CONFIG_VIDEO_ZORAN_BUZ=m
CONFIG_VIDEO_ZORAN_DC10=m
CONFIG_VIDEO_ZORAN_DC30=m
CONFIG_VIDEO_ZORAN_LML33=m
CONFIG_VIDEO_ZORAN_LML33R10=m
CONFIG_VIDEO_ZORAN_AVS6EYES=m
CONFIG_VIDEO_MEYE=m
CONFIG_VIDEO_SAA7134=m
CONFIG_VIDEO_SAA7134_ALSA=m
CONFIG_VIDEO_SAA7134_OSS=m
CONFIG_VIDEO_SAA7134_DVB=m
CONFIG_VIDEO_SAA7134_DVB_ALL_FRONTENDS=y
CONFIG_VIDEO_MXB=m
CONFIG_VIDEO_DPC=m
CONFIG_VIDEO_HEXIUM_ORION=m
CONFIG_VIDEO_HEXIUM_GEMINI=m
CONFIG_VIDEO_CX88_VP3054=m
CONFIG_VIDEO_CX88=m
CONFIG_VIDEO_CX88_ALSA=m
CONFIG_VIDEO_CX88_BLACKBIRD=m
CONFIG_VIDEO_CX88_DVB=m
CONFIG_VIDEO_CX88_DVB_ALL_FRONTENDS=y
Encoders and Decoders
CONFIG_VIDEO_MSP3400=m
CONFIG_VIDEO_CS53L32A=m
CONFIG_VIDEO_TLV320AIC23B=m
CONFIG_VIDEO_WM8775=m
CONFIG_VIDEO_WM8739=m
CONFIG_VIDEO_CX2341X=m
CONFIG_VIDEO_CX25840=m
CONFIG_VIDEO_SAA711X=m
CONFIG_VIDEO_SAA7127=m
CONFIG_VIDEO_UPD64031A=m
CONFIG_VIDEO_UPD64083=m
V4L USB devices
CONFIG_VIDEO_PVRUSB2=m
CONFIG_VIDEO_PVRUSB2_24XXX=y
CONFIG_VIDEO_PVRUSB2_SYSFS=y
CONFIG_VIDEO_PVRUSB2_DEBUGIFC is not set
CONFIG_VIDEO_EM28XX=m
CONFIG_VIDEO_USBVIDEO=m
CONFIG_USB_VICAM=m
CONFIG_USB_IBMCAM=m
CONFIG_USB_KONICAWC=m
CONFIG_USB_QUICKCAM_MESSENGER=m
CONFIG_USB_ET61X251=m
CONFIG_VIDEO_OVCAMCHIP=m
CONFIG_USB_W9968CF=m
CONFIG_USB_OV511=m
CONFIG_USB_SE401=m
CONFIG_USB_SN9C102=m
CONFIG_USB_STV680=m
CONFIG_USB_ZC0301=m
CONFIG_USB_PWC=m
CONFIG_USB_PWC_DEBUG is not set
Radio Adapters
CONFIG_RADIO_CADET=m
CONFIG_RADIO_RTRACK=m
CONFIG_RADIO_RTRACK2=m
CONFIG_RADIO_AZTECH=m
CONFIG_RADIO_GEMTEK=m
CONFIG_RADIO_GEMTEK_PCI=m
CONFIG_RADIO_MAXIRADIO=m
CONFIG_RADIO_MAESTRO=m
CONFIG_RADIO_SF16FMI=m
CONFIG_RADIO_SF16FMR2=m
CONFIG_RADIO_TERRATEC=m
CONFIG_RADIO_TRUST=m
CONFIG_RADIO_TYPHOON=m
CONFIG_RADIO_TYPHOON_PROC_FS=y
CONFIG_RADIO_ZOLTRIX=m
CONFIG_USB_DSBR=m
Digital Video Broadcasting Devices
CONFIG_DVB=y
CONFIG_DVB_CORE=m
Supported SAA7146 based PCI Adapters
CONFIG_DVB_AV7110=m
CONFIG_DVB_AV7110_OSD=y
CONFIG_DVB_BUDGET=m
CONFIG_DVB_BUDGET_CI=m
CONFIG_DVB_BUDGET_AV=m
CONFIG_DVB_BUDGET_PATCH=m
Supported USB Adapters
CONFIG_DVB_USB=m
CONFIG_DVB_USB_DEBUG is not set
CONFIG_DVB_USB_A800=m
CONFIG_DVB_USB_DIBUSB_MB=m
CONFIG_DVB_USB_DIBUSB_MB_FAULTY=y
CONFIG_DVB_USB_DIBUSB_MC=m
CONFIG_DVB_USB_UMT_010=m
CONFIG_DVB_USB_CXUSB=m
CONFIG_DVB_USB_DIGITV=m
CONFIG_DVB_USB_VP7045=m
CONFIG_DVB_USB_VP702X=m
CONFIG_DVB_USB_GP8PSK=m
CONFIG_DVB_USB_NOVA_T_USB2=m
CONFIG_DVB_USB_DTT200U=m
CONFIG_DVB_TTUSB_BUDGET=m
CONFIG_DVB_TTUSB_DEC=m
CONFIG_DVB_CINERGYT2=m
CONFIG_DVB_CINERGYT2_TUNING is not set
Supported FlexCopII (B2C2) Adapters
CONFIG_DVB_B2C2_FLEXCOP=m
CONFIG_DVB_B2C2_FLEXCOP_PCI=m
CONFIG_DVB_B2C2_FLEXCOP_USB=m
CONFIG_DVB_B2C2_FLEXCOP_DEBUG is not set
Supported BT878 Adapters
CONFIG_DVB_BT8XX=m
Supported Pluto2 Adapters
CONFIG_DVB_PLUTO2=m
Supported DVB Frontends
Customise DVB Frontends
DVB-S (satellite) frontends
CONFIG_DVB_STV0299=m
CONFIG_DVB_CX24110=m
CONFIG_DVB_CX24123=m
CONFIG_DVB_TDA8083=m
CONFIG_DVB_MT312=m
CONFIG_DVB_VES1X93=m
CONFIG_DVB_S5H1420=m
DVB-T (terrestrial) frontends
CONFIG_DVB_SP8870=m
CONFIG_DVB_SP887X=m
CONFIG_DVB_CX22700=m
CONFIG_DVB_CX22702=m
CONFIG_DVB_L64781=m
CONFIG_DVB_TDA1004X=m
CONFIG_DVB_NXT6000=m
CONFIG_DVB_MT352=m
CONFIG_DVB_ZL10353=m
CONFIG_DVB_DIB3000MB=m
CONFIG_DVB_DIB3000MC=m
DVB-C (cable) frontends
CONFIG_DVB_VES1820=m
CONFIG_DVB_TDA10021=m
CONFIG_DVB_STV0297=m
ATSC (North American/Korean Terrestrial/Cable DTV) frontends
CONFIG_DVB_NXT200X=m
CONFIG_DVB_OR51211=m
CONFIG_DVB_OR51132=m
CONFIG_DVB_BCM3510=m
CONFIG_DVB_LGDT330X=m
Miscellaneous devices
CONFIG_DVB_PLL=m
CONFIG_DVB_LNBP21=m
CONFIG_DVB_ISL6421=m
CONFIG_VIDEO_SAA7146=m
CONFIG_VIDEO_SAA7146_VV=m
CONFIG_VIDEO_VIDEOBUF=m
CONFIG_VIDEO_TUNER=m
CONFIG_VIDEO_BUF=m
CONFIG_VIDEO_BUF_DVB=m
CONFIG_VIDEO_BTCX=m
CONFIG_VIDEO_IR=m
CONFIG_VIDEO_TVEEPROM=m
Graphics support
CONFIG_FIRMWARE_EDID=y
CONFIG_FB=y
CONFIG_FB_CFB_FILLRECT=y
CONFIG_FB_CFB_COPYAREA=y
CONFIG_FB_CFB_IMAGEBLIT=y
CONFIG_FB_MACMODES is not set
CONFIG_FB_BACKLIGHT is not set
CONFIG_FB_MODE_HELPERS=y
CONFIG_FB_TILEBLITTING=y
CONFIG_FB_CIRRUS=m
CONFIG_FB_PM2=m
CONFIG_FB_PM2_FIFO_DISCONNECT=y
CONFIG_FB_CYBER2000=m
CONFIG_FB_ARC=m
CONFIG_FB_ASILIANT is not set
CONFIG_FB_IMSTT is not set
CONFIG_FB_VGA16=m
CONFIG_FB_VESA=y
CONFIG_FB_IMAC is not set
CONFIG_FB_HGA=m
CONFIG_FB_HGA_ACCEL is not set
CONFIG_FB_S1D13XXX=m
CONFIG_FB_NVIDIA=m
CONFIG_FB_NVIDIA_I2C=y
CONFIG_FB_RIVA is not set
CONFIG_FB_I810=m
CONFIG_FB_I810_GTF is not set
CONFIG_FB_INTEL=m
CONFIG_FB_INTEL_DEBUG is not set
CONFIG_FB_MATROX=m
CONFIG_FB_MATROX_MILLENIUM=y
CONFIG_FB_MATROX_MYSTIQUE=y
CONFIG_FB_MATROX_G=y
CONFIG_FB_MATROX_I2C=m
CONFIG_FB_MATROX_MAVEN=m
CONFIG_FB_MATROX_MULTIHEAD=y
CONFIG_FB_RADEON=m
CONFIG_FB_RADEON_I2C=y
CONFIG_FB_RADEON_DEBUG is not set
CONFIG_FB_ATY128=m
CONFIG_FB_ATY=m
CONFIG_FB_ATY_CT=y
CONFIG_FB_ATY_GENERIC_LCD=y
CONFIG_FB_ATY_GX=y
CONFIG_FB_SAVAGE=m
CONFIG_FB_SAVAGE_I2C=y
CONFIG_FB_SAVAGE_ACCEL is not set
CONFIG_FB_SIS=m
CONFIG_FB_SIS_300=y
CONFIG_FB_SIS_315=y
CONFIG_FB_NEOMAGIC=m
CONFIG_FB_KYRO=m
CONFIG_FB_3DFX=m
CONFIG_FB_3DFX_ACCEL is not set
CONFIG_FB_VOODOO1=m
CONFIG_FB_CYBLA=m
CONFIG_FB_TRIDENT=m
CONFIG_FB_TRIDENT_ACCEL is not set
CONFIG_FB_GEODE=y
CONFIG_FB_GEODE_GX=m
CONFIG_FB_GEODE_GX1=m
CONFIG_FB_VIRTUAL=m
Console display driver support
CONFIG_VGA_CONSOLE=y
CONFIG_VGACON_SOFT_SCROLLBACK is not set
CONFIG_VIDEO_SELECT=y
CONFIG_MDA_CONSOLE=m
CONFIG_DUMMY_CONSOLE=y
CONFIG_FRAMEBUFFER_CONSOLE=y
CONFIG_FRAMEBUFFER_CONSOLE_ROTATION=y
CONFIG_FONTS is not set
CONFIG_FONT_8x8=y
CONFIG_FONT_8x16=y
Logo configuration
CONFIG_LOGO is not set
CONFIG_BACKLIGHT_LCD_SUPPORT=y
CONFIG_BACKLIGHT_CLASS_DEVICE=m
CONFIG_BACKLIGHT_DEVICE=y
CONFIG_LCD_CLASS_DEVICE is not set
Sound
CONFIG_SOUND=m
Advanced Linux Sound Architecture
CONFIG_SND=m
CONFIG_SND_TIMER=m
CONFIG_SND_PCM=m
CONFIG_SND_HWDEP=m
CONFIG_SND_RAWMIDI=m
CONFIG_SND_SEQUENCER=m
CONFIG_SND_SEQ_DUMMY=m
CONFIG_SND_OSSEMUL=y
CONFIG_SND_MIXER_OSS=m
CONFIG_SND_PCM_OSS=m
CONFIG_SND_PCM_OSS_PLUGINS=y
CONFIG_SND_SEQUENCER_OSS=y
CONFIG_SND_RTCTIMER=m
CONFIG_SND_SEQ_RTCTIMER_DEFAULT=y
CONFIG_SND_DYNAMIC_MINORS is not set
CONFIG_SND_SUPPORT_OLD_API=y
CONFIG_SND_VERBOSE_PROCFS=y
CONFIG_SND_VERBOSE_PRINTK is not set
CONFIG_SND_DEBUG is not set
Generic devices
CONFIG_SND_MPU401_UART=m
CONFIG_SND_OPL3_LIB=m
CONFIG_SND_OPL4_LIB=m
CONFIG_SND_VX_LIB=m
CONFIG_SND_AC97_CODEC=m
CONFIG_SND_AC97_BUS=m
CONFIG_SND_DUMMY=m
CONFIG_SND_VIRMIDI=m
CONFIG_SND_MTPAV=m
CONFIG_SND_SERIAL_U16550=m
CONFIG_SND_MPU401=m
ISA devices
CONFIG_SND_AD1848_LIB=m
CONFIG_SND_CS4231_LIB=m
CONFIG_SND_ADLIB=m
CONFIG_SND_AD1816A=m
CONFIG_SND_AD1848=m
CONFIG_SND_ALS100=m
CONFIG_SND_AZT2320=m
CONFIG_SND_CMI8330=m
CONFIG_SND_CS4231=m
CONFIG_SND_CS4232=m
CONFIG_SND_CS4236=m
CONFIG_SND_DT019X=m
CONFIG_SND_ES968=m
CONFIG_SND_ES1688=m
CONFIG_SND_ES18XX=m
CONFIG_SND_GUS_SYNTH=m
CONFIG_SND_GUSCLASSIC=m
CONFIG_SND_GUSEXTREME=m
CONFIG_SND_GUSMAX=m
CONFIG_SND_INTERWAVE=m
CONFIG_SND_INTERWAVE_STB=m
CONFIG_SND_OPL3SA2=m
CONFIG_SND_OPTI92X_AD1848=m
CONFIG_SND_OPTI92X_CS4231=m
CONFIG_SND_OPTI93X=m
CONFIG_SND_MIRO=m
CONFIG_SND_SB8=m
CONFIG_SND_SB16=m
CONFIG_SND_SBAWE=m
CONFIG_SND_SB16_CSP=y
CONFIG_SND_SGALAXY=m
CONFIG_SND_SSCAPE=m
CONFIG_SND_WAVEFRONT=m
PCI devices
CONFIG_SND_AD1889=m
CONFIG_SND_ALS300=m
CONFIG_SND_ALS4000=m
CONFIG_SND_ALI5451=m
CONFIG_SND_ATIIXP=m
CONFIG_SND_ATIIXP_MODEM=m
CONFIG_SND_AU8810=m
CONFIG_SND_AU8820=m
CONFIG_SND_AU8830=m
CONFIG_SND_AZT3328=m
CONFIG_SND_BT87X=m
CONFIG_SND_BT87X_OVERCLOCK is not set
CONFIG_SND_CA0106=m
CONFIG_SND_CMIPCI=m
CONFIG_SND_CS4281=m
CONFIG_SND_CS46XX=m
CONFIG_SND_CS46XX_NEW_DSP=y
CONFIG_SND_CS5535AUDIO=m
CONFIG_SND_DARLA20=m
CONFIG_SND_GINA20=m
CONFIG_SND_LAYLA20=m
CONFIG_SND_DARLA24=m
CONFIG_SND_GINA24=m
CONFIG_SND_LAYLA24=m
CONFIG_SND_MONA=m
CONFIG_SND_MIA=m
CONFIG_SND_ECHO3G=m
CONFIG_SND_INDIGO=m
CONFIG_SND_INDIGOIO=m
CONFIG_SND_INDIGODJ=m
CONFIG_SND_EMU10K1=m
CONFIG_SND_EMU10K1X=m
CONFIG_SND_ENS1370=m
CONFIG_SND_ENS1371=m
CONFIG_SND_ES1938=m
CONFIG_SND_ES1968=m
CONFIG_SND_FM801=m
CONFIG_SND_FM801_TEA575X_BOOL=y
CONFIG_SND_FM801_TEA575X=m
CONFIG_SND_HDA_INTEL=m
CONFIG_SND_HDSP=m
CONFIG_SND_HDSPM=m
CONFIG_SND_ICE1712=m
CONFIG_SND_ICE1724=m
CONFIG_SND_INTEL8X0=m
CONFIG_SND_INTEL8X0M=m
CONFIG_SND_KORG1212=m
CONFIG_SND_MAESTRO3=m
CONFIG_SND_MIXART=m
CONFIG_SND_NM256=m
CONFIG_SND_PCXHR=m
CONFIG_SND_RIPTIDE=m
CONFIG_SND_RME32=m
CONFIG_SND_RME96=m
CONFIG_SND_RME9652=m
CONFIG_SND_SONICVIBES=m
CONFIG_SND_TRIDENT=m
CONFIG_SND_VIA82XX=m
CONFIG_SND_VIA82XX_MODEM=m
CONFIG_SND_VX222=m
CONFIG_SND_YMFPCI=m
USB devices
CONFIG_SND_USB_AUDIO=m
CONFIG_SND_USB_USX2Y=m
PCMCIA devices
CONFIG_SND_VXPOCKET=m
CONFIG_SND_PDAUDIOCF=m
Open Sound System
CONFIG_SOUND_PRIME=m
CONFIG_OSS_OBSOLETE_DRIVER is not set
CONFIG_SOUND_BT878=m
CONFIG_SOUND_ES1371=m
CONFIG_SOUND_ICH=m
CONFIG_SOUND_TRIDENT=m
CONFIG_SOUND_MSNDCLAS is not set
CONFIG_SOUND_MSNDPIN is not set
CONFIG_SOUND_VIA82CXXX=m
CONFIG_MIDI_VIA82CXXX=y
CONFIG_SOUND_OSS=m
CONFIG_SOUND_TRACEINIT is not set
CONFIG_SOUND_DMAP is not set
CONFIG_SOUND_CS4232=m
CONFIG_SOUND_SSCAPE=m
CONFIG_SOUND_VMIDI=m
CONFIG_SOUND_TRIX=m
CONFIG_SOUND_MSS=m
CONFIG_SOUND_MPU401=m
CONFIG_SOUND_PAS=m
CONFIG_SOUND_PSS=m
CONFIG_PSS_MIXER=y
CONFIG_SOUND_SB=m
CONFIG_SOUND_YM3812=m
CONFIG_SOUND_UART6850=m
CONFIG_SOUND_AEDSP16=m
CONFIG_SC6600=y
CONFIG_SC6600_JOY=y
CONFIG_SC6600_CDROM=4
CONFIG_SC6600_CDROMBASE=0x0
CONFIG_AEDSP16_MSS is not set
CONFIG_AEDSP16_SBPRO is not set
CONFIG_AEDSP16_MPU401 is not set
CONFIG_SOUND_TVMIXER=m
CONFIG_SOUND_KAHLUA=m
USB support
CONFIG_USB_ARCH_HAS_HCD=y
CONFIG_USB_ARCH_HAS_OHCI=y
CONFIG_USB_ARCH_HAS_EHCI=y
CONFIG_USB=m
CONFIG_USB_DEBUG is not set
Miscellaneous USB options
CONFIG_USB_DEVICEFS=y
CONFIG_USB_BANDWIDTH is not set
CONFIG_USB_DYNAMIC_MINORS is not set
CONFIG_USB_SUSPEND=y
CONFIG_USB_OTG is not set
USB Host Controller Drivers
CONFIG_USB_EHCI_HCD=m
CONFIG_USB_EHCI_SPLIT_ISO=y
CONFIG_USB_EHCI_ROOT_HUB_TT=y
CONFIG_USB_EHCI_TT_NEWSCHED is not set
CONFIG_USB_ISP116X_HCD=m
CONFIG_USB_OHCI_HCD=m
CONFIG_USB_OHCI_BIG_ENDIAN is not set
CONFIG_USB_OHCI_LITTLE_ENDIAN=y
CONFIG_USB_UHCI_HCD=m
CONFIG_USB_SL811_HCD=m
CONFIG_USB_SL811_CS=m
USB Device Class drivers
CONFIG_USB_ACM=m
CONFIG_USB_PRINTER=m
NOTE: USB_STORAGE enables SCSI, and ‘SCSI disk support’
may also be needed; see USB_STORAGE Help for more information
CONFIG_USB_STORAGE=m
CONFIG_USB_STORAGE_DEBUG is not set
CONFIG_USB_STORAGE_DATAFAB=y
CONFIG_USB_STORAGE_FREECOM=y
CONFIG_USB_STORAGE_ISD200=y
CONFIG_USB_STORAGE_DPCM=y
CONFIG_USB_STORAGE_USBAT=y
CONFIG_USB_STORAGE_SDDR09=y
CONFIG_USB_STORAGE_SDDR55=y
CONFIG_USB_STORAGE_JUMPSHOT=y
CONFIG_USB_STORAGE_ALAUDA=y
CONFIG_USB_LIBUSUAL is not set
USB Input Devices
CONFIG_USB_HID=m
CONFIG_USB_HIDINPUT=y
CONFIG_USB_HIDINPUT_POWERBOOK=y
CONFIG_HID_FF is not set
CONFIG_USB_HIDDEV=y
USB HID Boot Protocol drivers
CONFIG_USB_KBD=m
CONFIG_USB_MOUSE=m
CONFIG_USB_AIPTEK=m
CONFIG_USB_WACOM=m
CONFIG_USB_ACECAD=m
CONFIG_USB_KBTAB=m
CONFIG_USB_POWERMATE=m
CONFIG_USB_TOUCHSCREEN=m
CONFIG_USB_TOUCHSCREEN_EGALAX=y
CONFIG_USB_TOUCHSCREEN_PANJIT=y
CONFIG_USB_TOUCHSCREEN_3M=y
CONFIG_USB_TOUCHSCREEN_ITM=y
CONFIG_USB_YEALINK=m
CONFIG_USB_XPAD=m
CONFIG_USB_ATI_REMOTE=m
CONFIG_USB_ATI_REMOTE2=m
CONFIG_USB_KEYSPAN_REMOTE=m
CONFIG_USB_APPLETOUCH=m
USB Imaging devices
CONFIG_USB_MDC800=m
CONFIG_USB_MICROTEK=m
USB Network Adapters
CONFIG_USB_CATC=m
CONFIG_USB_KAWETH=m
CONFIG_USB_PEGASUS=m
CONFIG_USB_RTL8150=m
CONFIG_USB_USBNET=m
CONFIG_USB_NET_AX8817X=m
CONFIG_USB_NET_CDCETHER=m
CONFIG_USB_NET_GL620A=m
CONFIG_USB_NET_NET1080=m
CONFIG_USB_NET_PLUSB=m
CONFIG_USB_NET_RNDIS_HOST=m
CONFIG_USB_NET_CDC_SUBSET=m
CONFIG_USB_ALI_M5632=y
CONFIG_USB_AN2720=y
CONFIG_USB_BELKIN=y
CONFIG_USB_ARMLINUX=y
CONFIG_USB_EPSON2888=y
CONFIG_USB_NET_ZAURUS=m
CONFIG_USB_MON=y
USB port drivers
CONFIG_USB_USS720=m
USB Serial Converter support
CONFIG_USB_SERIAL=m
CONFIG_USB_SERIAL_GENERIC=y
CONFIG_USB_SERIAL_AIRPRIME=m
CONFIG_USB_SERIAL_ARK3116=m
CONFIG_USB_SERIAL_BELKIN=m
CONFIG_USB_SERIAL_WHITEHEAT is not set
CONFIG_USB_SERIAL_DIGI_ACCELEPORT=m
CONFIG_USB_SERIAL_CP2101=m
CONFIG_USB_SERIAL_CYPRESS_M8=m
CONFIG_USB_SERIAL_EMPEG=m
CONFIG_USB_SERIAL_FTDI_SIO=m
CONFIG_USB_SERIAL_FUNSOFT=m
CONFIG_USB_SERIAL_VISOR=m
CONFIG_USB_SERIAL_IPAQ=m
CONFIG_USB_SERIAL_IR=m
CONFIG_USB_SERIAL_EDGEPORT=m
CONFIG_USB_SERIAL_EDGEPORT_TI=m
CONFIG_USB_SERIAL_GARMIN=m
CONFIG_USB_SERIAL_IPW=m
CONFIG_USB_SERIAL_KEYSPAN_PDA=m
CONFIG_USB_SERIAL_KLSI=m
CONFIG_USB_SERIAL_KOBIL_SCT=m
CONFIG_USB_SERIAL_MCT_U232=m
CONFIG_USB_SERIAL_NAVMAN=m
CONFIG_USB_SERIAL_PL2303=m
CONFIG_USB_SERIAL_HP4X=m
CONFIG_USB_SERIAL_SAFE=m
CONFIG_USB_SERIAL_SAFE_PADDED is not set
CONFIG_USB_SERIAL_SIERRAWIRELESS=m
CONFIG_USB_SERIAL_TI=m
CONFIG_USB_SERIAL_CYBERJACK=m
CONFIG_USB_SERIAL_XIRCOM=m
CONFIG_USB_SERIAL_OPTION=m
CONFIG_USB_SERIAL_OMNINET=m
CONFIG_USB_EZUSB=y
USB Miscellaneous drivers
CONFIG_USB_AUERSWALD=m
CONFIG_USB_RIO500=m
CONFIG_USB_LEGOTOWER=m
CONFIG_USB_LCD=m
CONFIG_USB_LED=m
CONFIG_USB_CYPRESS_CY7C63=m
CONFIG_USB_CYTHERM=m
CONFIG_USB_PHIDGETKIT=m
CONFIG_USB_PHIDGETSERVO=m
CONFIG_USB_IDMOUSE=m
CONFIG_USB_APPLEDISPLAY=m
CONFIG_USB_SISUSBVGA=m
CONFIG_USB_SISUSBVGA_CON=y
CONFIG_USB_LD=m
CONFIG_USB_TEST=m
USB DSL modem support
CONFIG_USB_ATM=m
CONFIG_USB_SPEEDTOUCH=m
CONFIG_USB_CXACRU=m
CONFIG_USB_UEAGLEATM=m
CONFIG_USB_XUSBATM=m
USB Gadget Support
CONFIG_USB_GADGET=m
CONFIG_USB_GADGET_DEBUG_FILES is not set
CONFIG_USB_GADGET_SELECTED=y
CONFIG_USB_GADGET_NET2280=y
CONFIG_USB_NET2280=m
CONFIG_USB_GADGET_PXA2XX is not set
CONFIG_USB_GADGET_GOKU is not set
CONFIG_USB_GADGET_LH7A40X is not set
CONFIG_USB_GADGET_OMAP is not set
CONFIG_USB_GADGET_AT91 is not set
CONFIG_USB_GADGET_DUMMY_HCD is not set
CONFIG_USB_GADGET_DUALSPEED=y
CONFIG_USB_ZERO=m
CONFIG_USB_ETH=m
CONFIG_USB_ETH_RNDIS=y
CONFIG_USB_GADGETFS=m
CONFIG_USB_FILE_STORAGE=m [
