[RESOLU] failed code 4
bonjour,
quand je lance mon ordi, j’ai une erreur 4
Je fais Control-D et j’arrive à utilisé mon ordi.
Voici ce que me rapporte la commande smartctl --all /dev/sda:
pourriez-vous me dire s’il y a des erreurs à corriger?
Merci d’avance pour votre patience…
[code]smartctl 5.41 2011-06-09 r3365 [x86_64-linux-3.2.0-4-amd64] (local build)
Copyright © 2002-11 by Bruce Allen, http://smartmontools.sourceforge.net
=== START OF INFORMATION SECTION ===
Model Family: Hitachi Travelstar 5K320
Device Model: Hitachi HTS543225L9A300
Serial Number: 090412FBCE06YKH55HSC
LU WWN Device Id: 5 000cca 5b2d07209
Firmware Version: FBEOC40J
User Capacity: 250 059 350 016 bytes [250 GB]
Sector Size: 512 bytes logical/physical
Device is: In smartctl database [for details use: -P show]
ATA Version is: 8
ATA Standard is: ATA-8-ACS revision 3f
Local Time is: Mon Aug 17 16:54:07 2015 CEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x80) Offline data collection activity
was never started.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 645) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 102) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000f 100 094 062 Pre-fail Always - 0
2 Throughput_Performance 0x0005 100 100 040 Pre-fail Offline - 0
3 Spin_Up_Time 0x0023 253 100 033 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 093 093 000 Old_age Always - 12148
5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 1 (0, 1)
7 Seek_Error_Rate 0x000f 100 100 067 Pre-fail Always - 0
8 Seek_Time_Performance 0x0005 100 100 040 Pre-fail Offline - 0
9 Power_On_Hours 0x0032 082 082 000 Old_age Always - 7984
10 Spin_Retry_Count 0x0033 100 100 060 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 096 096 000 Old_age Always - 7822
184 End-to-End_Error 0x0033 100 100 097 Pre-fail Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 12309376401435
188 Command_Timeout 0x0032 100 098 000 Old_age Always - 15
190 Airflow_Temperature_Cel 0x0022 051 043 000 Old_age Always - 49 (Min/Max 45/52)
191 G-Sense_Error_Rate 0x000a 100 094 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 8847495
193 Load_Cycle_Count 0x0032 087 087 000 Old_age Always - 131872
194 Temperature_Celsius 0x0022 112 096 000 Old_age Always - 49 (Min/Max 8/57)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 1
197 Current_Pending_Sector 0x0032 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x002a 200 200 000 Old_age Always - 0
223 Load_Retry_Count 0x002a 100 100 000 Old_age Always - 0
SMART Error Log Version: 1
ATA Error Count: 45 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It “wraps” after 49.710 days.
Error 45 occurred at disk power-on lifetime: 6966 hours (290 days + 6 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
10 51 01 70 59 1c 40 Error: IDNF at LBA = 0x001c5970 = 1857904
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
60 01 d8 70 59 1c 40 00 01:08:02.300 READ FPDMA QUEUED
2f 00 01 10 00 00 40 00 01:08:02.300 READ LOG EXT
60 01 d0 70 59 1c 40 00 01:08:02.200 READ FPDMA QUEUED
2f 00 01 10 00 00 40 00 01:08:02.200 READ LOG EXT
60 01 c8 70 59 1c 40 00 01:08:02.200 READ FPDMA QUEUED
Error 44 occurred at disk power-on lifetime: 6966 hours (290 days + 6 hours)
60 01 b8 70 59 1c 40 00 01:08:02.100 READ FPDMA QUEUED
Error 43 occurred at disk power-on lifetime: 6966 hours (290 days + 6 hours)
2f 00 01 10 00 00 40 00 01:08:02.100 READ LOG EXT
60 01 b0 70 59 1c 40 00 01:08:02.000 READ FPDMA QUEUED
Error 42 occurred at disk power-on lifetime: 6966 hours (290 days + 6 hours)
2f 00 01 10 00 00 40 00 01:08:02.000 READ LOG EXT
60 01 a0 70 59 1c 40 00 01:08:01.900 READ FPDMA QUEUED
Error 41 occurred at disk power-on lifetime: 6966 hours (290 days + 6 hours)
2f 00 01 10 00 00 40 00 01:08:01.900 READ LOG EXT
60 01 98 70 59 1c 40 00 01:08:01.800 READ FPDMA QUEUED
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
1 Short offline Completed without error 00% 7984 -
2 Short offline Completed without error 00% 7983 -
3 Short offline Completed without error 00% 6719 -
4 Short offline Completed without error 00% 3 -
5 Short offline Completed without error 00% 2 -
6 Short offline Completed without error 00% 2 -
7 Short offline Completed without error 00% 1 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay[/code]
up
petit rajout: il me demande de faire: RUN fsck(???) MANUALLY.
Bonjour cyfred73
Je n’ai pas regardé en détail le long coller mais un fsck manuel se fait plus facilement en ayant amorcé avec une unité externe (CD/DVD/USB) - d’ailleurs ça peut être obligé - et il se fait sur la partition en question mais il faut qu’elle ne soit pas montée.
Il est aussi possible d’ajouter un “init=/bin/sh” dans le contexte de Grub pour le faire tranquillement.
Prend ton temps et laisse le fil se dérouler pour qu’il t’aide.
Je suis.
édition :
Error 45 occurred at disk power-on lifetime: 6966 hours (290 days + 6 hours) When the command that caused the error occurred, the device was active or idle.
L’erreur numéro 45 ne signifie pas forcément que ton disque est HS ; pas du tout suivant l’indication de la durée d’utilisation :
[quote=“man fsck”]FSCK(8) Administration système FSCK(8)
NOM
fsck - Vérifier et réparer un système de fichiers Linux[/quote]
Merci beaucoup pour votre réponse…
mais j’avoue qu’étant néofite j’ai rien compris :cry:
Je vais essayé de chercher ce que cela veut dire sur un moteur de recherche…en attendant que vous éclairiez ma lanterne ([size=50]là il fait plus que noir…[/size])
Avec la commande suivante je retrouve l’erreur qui m’est adressé:
11.494953] EXT4-fs (sda5): re-mounted. Opts: (null)
[ 11.781178] EXT4-fs (sda5): re-mounted. Opts: errors=remount-ro
[ 11.915354] loop: module loaded
[ 69.762441] EXT4-fs (sda7): warning: mounting fs with errors, running e2fsck is recommended
[ 69.762936] EXT4-fs (sda7): mounted filesystem with ordered data mode. Opts: (null)
[ 71.013643] RPC: Registered named UNIX socket transport module.
[ 71.013650] RPC: Registered udp transport module.
[ 71.013655] RPC: Registered tcp transport module.
[ 71.013661] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 71.050359] FS-Cache: Loaded
[ 71.098648] FS-Cache: Netfs ‘nfs’ registered for caching
[ 71.120738] Installing knfsd (copyright © 1996 okir@monad.swb.de).
[ 72.618390] vboxdrv: Found 2 processor cores.
[ 72.618637] vboxdrv: fAsync=0 offMin=0x1b8 offMax=0x852
[ 72.618702] vboxdrv: TSC mode is ‘synchronous’, kernel timer mode is ‘normal’.
[ 72.618704] vboxdrv: Successfully loaded version 4.1.18_Debian (interface 0x00190000).
[ 72.899146] vboxpci: IOMMU not found (not registered)
[ 73.055589] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input12
J’espère que c’est pas trop grâve… :pray:
En mode dépannage, est-ce que cette commande pourrait m’aider? [size=50]Je cherche…[/size]
Je crois que j’ai réussi à faire une photo de mon écran :smiley:
up
bonjour,
quelqu’un pourrait-il répondre à ma question svp :
merci.
une meilleure image :smiley:
Je me suis fait confirmer la commande, et cela à résolu mon problème
Tu as changé ta photo pour une meilleure résolution, j’avais essayé de lire et c’était impossible.
Tant mieux pour toi.
