[résolu]firewall shorewall.+ routeur
J’ai un serveur vhcs debian sarge.
J’aurais voulu un petit coup de main sur le paramétrage de mon firewall shorewall.+ routeur netgear
a chaque fois que active le firewall shorewall.+ routeur arrive plus aller sur le net
simon dans /etc/shorewall/rules il faut il changer les ip
ici
[code]#
Shorewall version 3.0 - Sample Rules File for one-interface configuration.
Rules in this file govern connection establishment. Requests and
responses are automatically allowed using connection tracking. For any
particular (source,dest) pair of zones, the rules are evaluated in the
order in which they appear in this file and the first match is the one
that determines the disposition of the request.
In most places where an IP address or subnet is allowed, you
can preceed the address/subnet with “!” (e.g., !192.168.1.0/24) to
indicate that the rule matches all addresses except the address/subnet
given. Notice that no white space is permitted between “!” and the
address/subnet.
WARNING: If you masquerade or use SNAT from a local system to the internet,
you cannot use an ACCEPT rule to allow traffic from the internet to
that system. You must use a DNAT rule instead.
The rules file is divided into sections. Each section is introduced by
a “Section Header” which is a line beginning with SECTION followed by the
section name.
Sections are as follows and must appear in the order listed:
ESTABLISHED Packets in the ESTABLISHED state are processed
by rules in this section.
The only ACTIONs allowed in this section are
ACCEPT, DROP, REJECT, LOG and QUEUE
There is an implicit ACCEPT rule inserted
at the end of this section.
RELATED Packets in the RELATED state are processed by
NEW Packets in the NEW and INVALID states are
processed by rules in this section.
WARNING: If you specify FASTACCEPT=Yes in shorewall.conf then the
ESTABLISHED and RELATED sections must be empty.
Note: If you are not familiar with Netfilter to the point where you are
comfortable with the differences between the various connection
tracking states, then I suggest that you omit the ESTABLISHED and
RELATED sections and place all of your rules in the NEW section.
You may omit any section that you don’t need. If no Section Headers appear
in the file then all rules are assumed to be in the NEW section.
Columns are:
ACTION ACCEPT, DROP, REJECT, DNAT, DNAT-, REDIRECT, CONTINUE,
LOG, QUEUE or an .
ACCEPT – allow the connection request
ACCEPT+ – like ACCEPT but also excludes the
connection from any subsequent
DNAT[-] or REDIRECT[-] rules
NONAT – Excludes the connection from any
subsequent DNAT[-] or REDIRECT[-]
rules but doesn’t generate a rule
to accept the traffic.
DROP – ignore the request
REJECT – disallow the request and return an
icmp-unreachable or an RST packet.
DNAT – Forward the request to another
system (and optionally another
port).
DNAT- – Advanced users only.
Like DNAT but only generates the
DNAT iptables rule and not
the companion ACCEPT rule.
SAME – Similar to DNAT except that the
port may not be remapped and when
multiple server addresses are
listed, all requests from a given
remote system go to the same
server.
SAME- – Advanced users only.
Like SAME but only generates the
REDIRECT – Redirect the request to a local
port on the firewall.
REDIRECT-
Like REDIRET but only generates the
REDIRECT iptables rule and not
CONTINUE – (For experts only). Do not process
any of the following rules for this
(source zone,destination zone). If
The source and/or destination IP
address falls into a zone defined
later in /etc/shorewall/zones, this
connection request will be passed
to the rules defined for that
(those) zone(s).
LOG – Simply log the packet and continue.
QUEUE – Queue the packet to a user-space
application such as ftwall
(http://p2pwall.sf.net).
– The name of an action defined in
/etc/shorewall/actions or in
/usr/share/shorewall/actions.std.
– The name of a macro defined in a
file named macro.. If
the macro accepts an action
parameter (Look at the macro
source to see if it has PARAM in
the TARGET column) then the macro
name is followed by “/” and the
action (ACCEPT, DROP, REJECT, …)
to be substituted for the
parameter. Example: FTP/ACCEPT.
The ACTION may optionally be followed
by “:” and a syslog log level (e.g, REJECT:info or
DNAT:debug). This causes the packet to be
logged at the specified level.
If the ACTION names an action defined in
/usr/share/shorewall/actions.std then:
- If the log level is followed by "!’ then all rules
in the action are logged at the log level.
- If the log level is not followed by “!” then only
those rules in the action that do not specify
logging are logged at the specified level.
- The special log level ‘none!’ suppresses logging
by the action.
You may also specify ULOG (must be in upper case) as a
log level.This will log to the ULOG target for routing
to a separate log through use of ulogd
(http://www.gnumonks.org/projects/ulogd).
Actions specifying logging may be followed by a
log tag (a string of alphanumeric characters)
are appended to the string generated by the
LOGPREFIX (in /etc/shorewall/shorewall.conf).
Example: ACCEPT:info:ftp would include 'ftp ’
at the end of the log prefix generated by the
LOGPREFIX setting.
SOURCE Source hosts to which the rule applies. May be a zone
defined in /etc/shorewall/zones, $FW to indicate the
firewall itself, “all”, “all+” or “none” If the ACTION
is DNAT or REDIRECT, sub-zones of the specified zone
may be excluded from the rule by following the zone
name with "!’ and a comma-separated list of sub-zone
names.
When “none” is used either in the SOURCE or DEST
column, the rule is ignored.
When “all” is used either in the SOURCE or DEST column
intra-zone traffic is not affected. When “all+” is
used, intra-zone traffic is affected.
Except when “all[+]” is specified, clients may be
further restricted to a list of subnets and/or hosts by
appending “:” and a comma-separated list of subnets
and/or hosts. Hosts may be specified by IP or MAC
address; mac addresses must begin with “~” and must use
“-” as a separator.
Hosts may be specified as an IP address range using the
syntax -. This requires that
your kernel and iptables contain iprange match support.
If you kernel and iptables have ipset match support
then you may give the name of an ipset prefaced by “+”.
The ipset name may be optionally followed by a number
from 1 to 6 enclosed in square brackets ([]) to
indicate the number of levels of source bindings to be
matched.
dmz:192.168.2.2 Host 192.168.2.2 in the DMZ
net:155.186.235.0/24 Subnet 155.186.235.0/24 on the
Internet
loc:192.168.1.1,192.168.1.2
Hosts 192.168.1.1 and
192.168.1.2 in the local zone.
loc:~00-A0-C9-15-39-78 Host in the local zone with
MAC address 00:A0:C9:15:39:78.
net:192.0.2.11-192.0.2.17
Hosts 192.0.2.11-192.0.2.17 in
the net zone.
Alternatively, clients may be specified by interface
by appending “:” to the zone name followed by the
interface name. For example, loc:eth1 specifies a
client that communicates with the firewall system
through eth1. This may be optionally followed by
another colon (":") and an IP/MAC/subnet address
as described above (e.g., loc:eth1:192.168.1.5).
DEST Location of Server. May be a zone defined in
/etc/shorewall/zones, $FW to indicate the firewall
itself, “all”. “all+” or “none”.
Except when “all[+]” is specified, the server may be
further restricted to a particular subnet, host or
interface by appending “:” and the subnet, host or
interface. See above.
Restrictions:
1. MAC addresses are not allowed.
2. In DNAT rules, only IP addresses are
allowed; no FQDNs or subnet addresses
are permitted.
3. You may not specify both an interface and
an address.
Like in the SOURCE column, you may specify a range of
up to 256 IP addresses using the syntax
-. When the ACTION is DNAT or DNAT-,
the connections will be assigned to addresses in the
range in a round-robin fashion.
indicate the number of levels of destination bindings
to be matched. Only one of the SOURCE and DEST columns
may specify an ipset name.
The port that the server is listening on may be
included and separated from the server’s IP address by
“:”. If omitted, the firewall will not modifiy the
destination port. A destination port may only be
included if the ACTION is DNAT or REDIRECT.
Example: loc:192.168.1.3:3128 specifies a local
server at IP address 192.168.1.3 and listening on port
3128. The port number MUST be specified as an integer
and not as a name from /etc/services.
if the ACTION is REDIRECT, this column needs only to
contain the port number on the firewall that the
request should be redirected to.
PROTO Protocol - Must be “tcp”, “udp”, “icmp”, “ipp2p”,
“ipp2p:udp”, “ipp2p:all” a number, or “all”.
“ipp2p*” requires ipp2p match support in your kernel
and iptables.
DEST PORT(S) Destination Ports. A comma-separated list of Port
names (from /etc/services), port numbers or port
ranges; if the protocol is “icmp”, this column is
interpreted as the destination icmp-type(s).
If the protocol is ipp2p, this column is interpreted
as an ipp2p option without the leading “–” (example
“bit” for bit-torrent). If no port is given, “ipp2p” is
assumed.
A port range is expressed as :.
This column is ignored if PROTOCOL = all but must be
entered if any of the following ields are supplied.
In that case, it is suggested that this field contain
If your kernel contains multi-port match support, then
only a single Netfilter rule will be generated if in
this list and the CLIENT PORT(S) list below:
1. There are 15 or less ports listed.
2. No port ranges are included.
Otherwise, a separate rule will be generated for each
port.
CLIENT PORT(S) (Optional) Port(s) used by the client. If omitted,
any source port is acceptable. Specified as a comma-
separated list of port names, port numbers or port
ranges.
If you don’t want to restrict client ports but need to
specify an ORIGINAL DEST in the next column, then
place “-” in this column.
this list and the DEST PORT(S) list above:
port.
ORIGINAL DEST (0ptional) – If ACTION is DNAT[-] or REDIRECT[-]
then if included and different from the IP
address given in the SERVER column, this is an address
on some interface on the firewall and connections to
that address will be forwarded to the IP and port
specified in the DEST column.
A comma-separated list of addresses may also be used.
This is usually most useful with the REDIRECT target
where you want to redirect traffic destined for
particular set of hosts.
Finally, if the list of addresses begins with “!” then
the rule will be followed only if the original
destination address in the connection request does not
match any of the addresses listed.
For other actions, this column may be included and may
contain one or more addresses (host or network)
separated by commas. Address ranges are not allowed.
When this column is supplied, rules are generated
that require that the original destination address
matches one of the listed addresses. This feature is
most useful when you want to generate a filter rule
that corresponds to a DNAT- or REDIRECT- rule. In this
usage, the list of addresses should not begin with “!”.
See http://shorewall.net/PortKnocking.html for an
example of using an entry in this column with a
user-defined action rule.
RATE LIMIT You may rate-limit the rule by placing a value in
this colume:
where is the number of connections per
(“sec” or “min”) and is the
largest burst permitted. If no is given,
a value of 5 is assumed. There may be no
no whitespace embedded in the specification.
Example: 10/sec:20
USER/GROUP This column may only be non-empty if the SOURCE is
the firewall itself.
The column may contain:
When this column is non-empty, the rule applies only
if the program generating the output is running under
the effective and/or specified (or is
NOT running under that id if “!” is given).
Examples:
joe #program must be run by joe
:kids #program must be run by a member of
#the ‘kids’ group
!:kids #program must not be run by a member
#of the ‘kids’ group
+upnpd #program named upnpd (This feature was
#removed from Netfilter in kernel
#version 2.6.14).
Example: Accept SMTP requests from the DMZ to the internet
#ACTION SOURCE DEST PROTO DEST SOURCE ORIGINAL
# PORT PORT(S) DEST
ACCEPT dmz net tcp smtp
Example: Forward all ssh and http connection requests from the
internet to local system 192.168.1.3
# PORT PORT(S) DEST
DNAT net loc:192.168.1.3 tcp ssh,http
Example: Forward all http connection requests from the internet
to local system 192.168.1.3 with a limit of 3 per second and
a maximum burst of 10
#ACTION SOURCE DEST PROTO DEST SOURCE ORIGINAL RATE
# PORT PORT(S) DEST LIMIT
DNAT net loc:192.168.1.3 tcp http - - 3/sec:10
Example: Redirect all locally-originating www connection requests to
port 3128 on the firewall (Squid running on the firewall
system) except when the destination address is 192.168.2.2
# PORT PORT(S) DEST
REDIRECT loc 3128 tcp www - !192.168.2.2
Example: All http requests from the internet to address
130.252.100.69 are to be forwarded to 192.168.1.3
# PORT PORT(S) DEST
DNAT net loc:192.168.1.3 tcp 80 - 130.252.100.69
Example: You want to accept SSH connections to your firewall only
from internet IP addresses 130.252.100.69 and 130.252.100.70
# PORT PORT(S) DEST
ACCEPT net:130.252.100.69,130.252.100.70 $FW \
tcp 22[/code]
merci :wink:
Euh, un # c’est un commentaire, il fait quoi là en fait ton shorewall?
Dis donc: tu n’ass pas déjà posé cette question sans avoir de réponse ?
Tu ne pouvais pas faire un up, plutôt que de recréer un fil ?
Une petite description du réseau et des services serait la bien venue pour pouvoir aider à établir des règles iptables. Shorewall je n’y connais rien :p!
quote="thialme"
Shorewall je n’y connais rien :p![/quote] Personne n’y connait rien ici: mafia m’a fait déjà il me semble un fil qui a trainé un bail sans réponse, et il s’obstine à ne pas vouloir se plonger dans iptables.
fin bon, peut être qu’un shorewaller passera un jour dans le coin, qui sait ?
[quote=“mattotop”]quote="thialme"
fin bon, peut être qu’un shorewaller passera un jour dans le coin, qui sait ?[/quote]
Pourtant c’est intéressant de s’y plonger dans iptables, et puis il ne faut pas forcément sortir une armée de règles pour avoir un firewall.
Il va bien finir par craquer :smt003
pour toi iptables c est mieux :question: bon si tu as un tuto install je premd merci
C’est pas que c’est mieux, c’est que tous les parefeux sont basés dessus.
Sinon, un tuto ?
Ca:
viewtopic.php?f=8&t=1901
et sinon: man iptables.
