Avant tout voici ma configuration Debian SID :
$ uname -a
Linux pchome 2.6.24-1-amd64 #1 SMP Mon Feb 11 13:47:43 UTC 2008 x86_64 GNU/Linux
$ lspci
00:00.0 Host bridge: nVidia Corporation Unknown device 0070 (rev c1)
00:00.1 RAM memory: nVidia Corporation Unknown device 007f (rev a1)
00:00.2 RAM memory: nVidia Corporation Unknown device 0075 (rev a1)
00:00.3 RAM memory: nVidia Corporation Unknown device 006f (rev a1)
00:00.4 RAM memory: nVidia Corporation Unknown device 00b4 (rev a1)
00:01.0 RAM memory: nVidia Corporation Unknown device 0076 (rev a1)
00:01.1 RAM memory: nVidia Corporation Unknown device 0078 (rev a1)
00:01.2 RAM memory: nVidia Corporation Unknown device 0079 (rev a1)
00:01.3 RAM memory: nVidia Corporation Unknown device 007a (rev a1)
00:01.4 RAM memory: nVidia Corporation Unknown device 007b (rev a1)
00:01.5 RAM memory: nVidia Corporation Unknown device 007c (rev a1)
00:01.6 RAM memory: nVidia Corporation Unknown device 007d (rev a1)
00:02.0 PCI bridge: nVidia Corporation Unknown device 007e (rev a2)
00:04.0 PCI bridge: nVidia Corporation Unknown device 007e (rev a2)
00:05.0 PCI bridge: nVidia Corporation Unknown device 007e (rev a2)
00:06.0 PCI bridge: nVidia Corporation Unknown device 007e (rev a2)
00:07.0 PCI bridge: nVidia Corporation Unknown device 007e (rev a2)
00:09.0 RAM memory: nVidia Corporation MCP51 Host Bridge (rev a2)
00:0a.0 ISA bridge: nVidia Corporation MCP51 LPC Bridge (rev a2)
00:0a.1 SMBus: nVidia Corporation MCP51 SMBus (rev a2)
00:0a.2 RAM memory: nVidia Corporation MCP51 Memory Controller 0 (rev a2)
00:0b.0 USB Controller: nVidia Corporation MCP51 USB Controller (rev a2)
00:0b.1 USB Controller: nVidia Corporation MCP51 USB Controller (rev a2)
00:0d.0 IDE interface: nVidia Corporation MCP51 IDE (rev a1)
00:0e.0 IDE interface: nVidia Corporation MCP51 Serial ATA Controller (rev a1)
00:0f.0 IDE interface: nVidia Corporation MCP51 Serial ATA Controller (rev a1)
00:10.0 PCI bridge: nVidia Corporation MCP51 PCI Bridge (rev a2)
00:10.1 Audio device: nVidia Corporation MCP51 High Definition Audio (rev a2)
01:00.0 VGA compatible controller: nVidia Corporation G70 [GeForce 7300 GT] (rev a1)
06:06.0 FireWire (IEEE 1394): Texas Instruments TSB82AA2 IEEE-1394b Link Layer Controller (rev 01)
06:0c.0 Ethernet controller: Marvell Technology Group Ltd. 88E8001 Gigabit Ethernet Controller (rev 13)
Mon post est à la fois un appel à l’aide pour un pb de carte graphique mais aussi un appel à information sur la gestion des versions de noyau…
En fait, tout commence suite à l’installation de supertuxkart pour mon fiston préféré. Le jeu tourne très très mal alors qu’il y a qq temps ca marchait nickel.
Je me suis donc dit que les drivers et la configuration de ma carte graphique (geforce 7300) avait sauté…
J’ai parcouru le forum et lu différents posts qui me laissent supposer que le problème est dû au fait que récemment l’upgrade a installé une nouvelle version de noyau.
Voici mon /boot:
$ ls -l /boot/
total 29220
-rw-r--r-- 1 root root 64915 mai 4 2007 config-2.6.18-4-amd64
-rw-r--r-- 1 root root 79389 fév 11 14:51 config-2.6.24-1-amd64
drwxr-xr-x 2 root root 4096 fév 15 19:32 grub
-rw-r--r-- 1 root root 5514494 jan 5 16:18 initrd.img-2.6.18-4-amd64
-rw-r--r-- 1 root root 5516886 déc 5 20:11 initrd.img-2.6.18-4-amd64.bak
-rw-r--r-- 1 root root 6644705 fév 15 19:32 initrd.img-2.6.24-1-amd64
-rw-r--r-- 1 root root 6691677 fév 10 18:37 initrd.img-2.6.24-1-amd64.bak
-rw-r--r-- 1 root root 972672 mai 4 2007 System.map-2.6.18-4-amd64
-rw-r--r-- 1 root root 1158480 fév 11 14:51 System.map-2.6.24-1-amd64
-rw-r--r-- 1 root root 1514181 mai 4 2007 vmlinuz-2.6.18-4-amd64
-rw-r--r-- 1 root root 1667832 fév 11 14:51 vmlinuz-2.6.24-1-amd64
Concernant la configuration de la carte graphique, j’espère m’en sortir avec ce post :http://forum.debian-fr.org/viewtopic.php?f=8&t=1682.
Manque juste que je sais pas comment vérifier si c’est réellement un pb de gestion de ma carte graphique ?!
Par contre, j’ai vraiement du mal à comprendre comment Linux fait pour gérer les différentes versions de noyau, les modules installés (installé pour un noyau seulement ?), etc. Pourquoi faut-il reconfigurer la carte graphique lorsqu’un nouveau noyau est installé ?
Donc cela est peut-être un peu prétentieux de ma part, mais auriez-vous qq liens pour pourrait me donner une idée de comment ca marche tout ca (gestion des versions de noyau, gestion des modules, …) ? Ou est-ce de la folie ? Meme un bouquin peut être ?
Espérant que ce post ne vous paraisse pas trop stupide …
Merci de votre aide et de vos conseils.
