Merci beaucoup, je viens d’apprendre un nouveau truc^^
Néanmoins, mon système ne réagit pas lorsque je mets un cd, ce qui n’était pas le cas sous ubuntu gusty par exemple. J’ai essayé gnome baker qui me renvoit ça en sortie :
[code]wodim: No write mode specified.
wodim: Asuming -tao mode.
wodim: Future versions of wodim may have different drive dependent defaults.
wodim: Operation not permitted. Warning: Cannot raise RLIMIT_MEMLOCK limits.scsidev: '/dev/hda’
devname: '/dev/hda’
scsibus: -2 target: -2 lun: -2
Linux sg driver version: 3.5.27
Wodim version: 1.1.6
SCSI buffer size: 64512
Beginning DMA speed test. Set CDR_NODMATEST environment variable if device
communication breaks or freezes immediately after that.
TOC Type: 3 = CD-ROM XA mode 2
Device type : Removable CD-ROM
Version : 0
Response Format: 2
Capabilities :
Vendor_info : 'MATSHITA’
Identification : 'DVD-RAM UJ-850S '
Revision : '1.61’
Device seems to be: Generic mmc2 DVD-R/DVD-RW.
Current: 0x0009 (CD-R)
Profile: 0x0012 (DVD-RAM)
Profile: 0x002B (DVD+R/DL)
Profile: 0x001B (DVD+R)
Profile: 0x001A (DVD+RW)
Profile: 0x0016 (DVD-R/DL layer jump recording)
Profile: 0x0015 (DVD-R/DL sequential recording)
Profile: 0x0013 (DVD-RW restricted overwrite)
Profile: 0x0014 (DVD-RW sequential recording)
Profile: 0x0011 (DVD-R sequential recording)
Profile: 0x0010 (DVD-ROM)
Profile: 0x000A (CD-RW)
Profile: 0x0009 (CD-R) (current)
Profile: 0x0008 (CD-ROM)
Profile: 0x0002 (Removable disk)
Using generic SCSI-3/mmc CD-R/CD-RW driver (mmc_cdr).
Driver flags : MMC-3 SWABAUDIO BURNFREE
Supported modes: TAO PACKET SAO
Drive buf size : 1310720 = 1280 KB
FIFO size : 12582912 = 12288 KB
Speed set to 1411 KB/s
4 seconds. 3 seconds. 2 seconds. 1 seconds. 0 seconds. Operation starts.
Waiting for reader process to fill input buffer … input buffer ready.
Performing OPC…
Starting new track at sector: 1287
Errno: 0 (Success), write_g1 scsi sendcmd: no error
CDB: 2A 00 00 00 05 07 00 00 1F 00
status: 0x2 (CHECK CONDITION)
Sense Bytes: 70 00 05 00 00 00 00 0A 00 AD 00 00 64 00 00 00
Sense Key: 0x5 Illegal Request, Segment 0
Sense Code: 0x64 Qual 0x00 (illegal mode for this track) Fru 0x0
Sense flags: Blk 0 (not valid)
resid: 63488
cmd finished after 0.003s timeout 40s
wodim: A write error occured.
wodim: Please properly read the error message above.
write track data: error after 0 bytes
Writing time: 9.062s
Average write speed 196.5x.
Fixating…
Errno: 0 (Success), close track/session scsi sendcmd: no error
CDB: 5B 00 02 00 00 00 00 00 00 00
Sense Bytes: 70 00 05 00 00 00 00 0A 00 00 00 00 72 03 00 00
Sense Code: 0x72 Qual 0x03 (session fixation error - incomplete track in session) Fru 0x0
cmd finished after 0.003s timeout 480s
Fixating time: 0.004s
wodim: Cannot fixate disk.
wodim: fifo had 192 puts and 1 gets.
wodim: fifo was 0 times empty and 0 times full, min fill was 100%.
BURN-Free was never needed.
