Salut à tous,
Voila, j’ai récuperé le disque qui était en réparation et j’ai installé Debian testing dessus. Tous c’est bien passé et cela fonctionne correctement. Seul problème qui me reste la gravure. je vous donne le message d’erreure que j’ai lors d’une tentatve de gravure, pour le cas ou. Je vois que l’on me parle de scsi alors que je suis en ide.
[quote]cdrecord: No write mode specified.
cdrecord: Asuming -tao mode.
cdrecord: Future versions of cdrecord may have different drive dependent defaults.
cdrecord: Continuing in 5 seconds…
cdrecord: Warning: Running on Linux-2.6.12-1-386
cdrecord: There are unsettled issues with Linux-2.5 and newer.
cdrecord: If you have unexpected problems, please try Linux-2.4 or Solaris.
cdrecord: Operation not permitted. WARNING: Cannot set RR-scheduler
cdrecord: Permission denied. WARNING: Cannot set priority using setpriority().
cdrecord: WARNING: This causes a high risk for buffer underruns.
scsidev: '/dev/hdd’
devname: '/dev/hdd’
scsibus: -2 target: -2 lun: -2
Warning: Open by ‘devname’ is unintentional and not supported.
Linux sg driver version: 3.5.27
Error: Cannot gain SYS_RAWIO capability.Is cdrecord installed SUID root?
cdrecord: Warning: using inofficial version of libscg (ubuntu-0.8ubuntu1 ‘@(#)scsitransp.c 1.91 04/06/17 Copyright 1988,1995,2000-2004 J. Schilling’).
SCSI buffer size: 64512
cdrecord: Asked for SCSI I/O buffer size 64512 bytes, could only get 20480.
cdrecord: This version of cdrecord does not include DVD-R/DVD-RW support code.
cdrecord: See /usr/share/doc/cdrecord/README.DVD.Debian for details on DVD support.
Cdrecord-Clone 2.01.01a03 (i686-pc-linux-gnu) Copyright © 1995-2005 Joerg Schilling
NOTE: this version of cdrecord is an inofficial (modified) release of cdrecord
and thus may have bugs that are not present in the original version.
Please send bug reports and support requests to cdrtools@packages.debian.org.
The original author should not be bothered with problems of this version.
TOC Type: 3 = CD-ROM XA mode 2
Using libscg version ‘ubuntu-0.8ubuntu1’.
atapi: 1
Device type : Removable CD-ROM
Version : 0
Response Format: 2
Capabilities :
Vendor_info : 'TDK '
Identifikation : 'DVDRW882N '
Revision : '2.35’
Device seems to be: Generic mmc2 DVD-R/DVD-RW.
Current: 0x000A
Profile: 0x002B
Profile: 0x001B
Profile: 0x001A
Profile: 0x0014
Profile: 0x0013
Profile: 0x0011
Profile: 0x0010
Profile: 0x000A (current)
Profile: 0x0009
Profile: 0x0008 (current)
Using generic SCSI-3/mmc CD-R/CD-RW driver (mmc_cdr).
Driver flags : MMC-3 SWABAUDIO BURNFREE
Supported modes: TAO PACKET SAO SAO/R96R RAW/R96R
Drive buf size : 1343488 = 1312 KB
FIFO size : 4194304 = 4096 KB
cdrecord: Operation not permitted. Cannot send SCSI cmd via ioctl
Track 01: data 86 MB padsize: 30 KB
Total size: 99 MB (09:50.65) = 44299 sectors
Lout start: 99 MB (09:52/49) = 44299 sectors
Si vous avez une idée, elle sera la bien venu.
Jean 8)
