salut !
je vais vous dire … , je ne sais meme pas par ou commencer… j’ai tellement tout essayer que je vais forcement oublier des trucs.
alors pour commencer : je suis sous Debian Etch 2.6.18-3-486 (installé sur une architecture 686 mais le noyau 686 ne fonctionne pas chez moi sur un pentium M )
LSPCI :00:00.0 Host bridge: Intel Corporation Mobile 915GM/PM/GMS/910GML Express Processor to DRAM Controller (rev 03)
00:01.0 PCI bridge: Intel Corporation Mobile 915GM/PM Express PCI Express Root Port (rev 03)
00:1b.0 Audio device: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) High Definition Audio Controller (rev 03)
00:1d.0 USB Controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #1 (rev 03)
00:1d.1 USB Controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #2 (rev 03)
00:1d.2 USB Controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #3 (rev 03)
00:1d.3 USB Controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #4 (rev 03)
00:1d.7 USB Controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB2 EHCI Controller (rev 03)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev d3)
00:1f.0 ISA bridge: Intel Corporation 82801FBM (ICH6M) LPC Interface Bridge (rev 03)
00:1f.1 IDE interface: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) IDE Controller (rev 03)
00:1f.3 SMBus: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) SMBus Controller (rev 03)
01:00.0 VGA compatible controller: nVidia Corporation NV43 [GeForce Go 6200 TurboCache] (rev a1)
06:03.0 CardBus bridge: Texas Instruments PCI7420 CardBus Controller
06:03.2 FireWire (IEEE 1394): Texas Instruments PCI7x20 1394a-2000 OHCI Two-Port PHY/Link-Layer Controller
06:03.3 Mass storage controller: <pci_lookup_name: buffer too small>
06:04.0 Network controller: Intel Corporation PRO/Wireless 2200BG Network Connection (rev 05)
06:08.0 Ethernet controller: Intel Corporation 82562ET/EZ/GT/GZ - PRO/100 VE (LOM) Ethernet Controller Mobile (rev 03)
mon XORG ( enfin , un parmis tant d’autre ) :[code]# nvidia-xconfig: X configuration file generated by nvidia-xconfig
nvidia-xconfig: version 1.0 (buildmeister@builder3) Fri Dec 15 10:12:14 PST 2006
/etc/X11/xorg.conf (xorg X Window System server configuration file)
This file was generated by dexconf, the Debian X Configuration tool, using
values from the debconf database.
Edit this file with caution, and see the /etc/X11/xorg.conf manual page.
(Type “man /etc/X11/xorg.conf” at the shell prompt.)
This file is automatically updated on xserver-xorg package upgrades only
if it has not been modified since the last upgrade of the xserver-xorg
package.
If you have edited this file but would like it to be automatically updated
again, run the following command:
sudo dpkg-reconfigure -phigh xserver-xorg
Section "ServerLayout"
Identifier "Default Layout"
Screen “Default Screen” 0 0
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
InputDevice "Synaptics Touchpad"
EndSection
Section “Files”
path to defoma fonts
FontPath "/usr/share/fonts/X11/misc"
FontPath "/usr/X11R6/lib/X11/fonts/misc"
FontPath "/usr/share/fonts/X11/cyrillic"
FontPath "/usr/X11R6/lib/X11/fonts/cyrillic"
FontPath "/usr/share/fonts/X11/100dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/share/fonts/X11/75dpi/:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
FontPath "/usr/share/fonts/X11/Type1"
FontPath "/usr/X11R6/lib/X11/fonts/Type1"
FontPath "/usr/share/fonts/X11/100dpi"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi"
FontPath "/usr/share/fonts/X11/75dpi"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi"
FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
Load "i2c"
Load "bitmap"
Load "ddc"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option “XkbRules” "xorg"
Option “XkbModel” "pc105"
Option “XkbLayout” "fr"
Option “XkbVariant” "latin9"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option “Device” "/dev/input/mice"
Option “Protocol” "ImPS/2"
Option “Emulate3Buttons” "true"
EndSection
Identifier "Synaptics Touchpad"
Driver "synaptics"
Option “SendCoreEvents” "true"
Option “Device” "/dev/psaux"
Option “Protocol” "auto-dev"
Option “HorizScrollDelta” "0"
EndSection
Section "Monitor"
Identifier "Écran générique"
HorizSync 28.0 - 64.0
VertRefresh 43.0 - 60.0
Option "DPMS"
EndSection
Section "Device"
Identifier "nVidia Corporation NV43 [GeForce Go 6200/6400]"
Driver "nvidia"
Option “XAANoOffscreenPixmaps” “true”# Optional if NVIDIA drivers are used
Option “AddARGBGLXVisuals” "On"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "nVidia Corporation NV43 [GeForce Go 6200/6400]"
Monitor "Écran générique"
DefaultDepth 16
SubSection "Display"
Depth 1
Modes "1280x800"
EndSubSection
Depth 4
Modes "1280x800"
EndSubSection
Depth 8
Modes "1280x800"
EndSubSection
Depth 15
Modes "1280x800"
EndSubSection
Depth 16
Modes "1280x800"
EndSubSection
Depth 24
Modes "1280x800"
EndSubSection
EndSection
Section "Extensions"
Option “Composite” "Enable"
EndSection
alors je vais essayer de vous passer les détails inutiles, en gros j’ai installer les drivers nvidia de toutes les façons possibles a ma connaissance ( en fait 2
) j’ai tester le 9746 + le Legacy + encore la version d’avant…
j’ai aussi essayer d’installer les drivers avec cette methode : http://forum.debian-fr.org/viewtopic.php?t=4985&start=0&postdays=0&postorder=asc&highlight=
j’ai tester tous les tutos qui trainent sur google pour installer beryl, j’ai meme tester ce tuto avec xgl et compiz : http://sonique54.free.fr/xgl/xgl_fr.htm
en gros le probleme est toujours le meme je lance beryl-manager et il m’est impossible de basculer le gestionnaire de fenetres sur “BERYL” si j’y arrive en decochant la gestion de crash et bien le cpu monte a 100% j’ai la 3D mais je vous laisse imaginer dans quelles conditions… mon cube fait un tour en 5 minutes…
la plupart du temps je n’ai pas d’entourage au fenetres enfin c’est la grosse catha quoi…
j’ai exactement le meme probleme sous sabayon-gentoo.
pour info : j’ai beryl qui tourne sous ubuntu et kubuntu et comme ont dit ça rox ! c’est ultra fluide et mon petit pc portable le supporte vachement bien donc… le probleme ne viens pas du matos… ( sous ubuntu et kubuntu j’ai un noyau 386. y a t il un noyau 386 sous debian ? je n’en ai pas vu dans Synaptic , il y a, à mon avis de grande chance pour que le probleme vienne de là )
quand je lance beryl-manager dans un terminal j’obtiens : [code]beryl-manager
morpheus@Mitika:~$ sh: glxinfo: command not found
(beryl-manager:4952): Gtk-WARNING **: Impossible de trouver le moteur de thème dans module_path : « lighthouseblue »
et quand j’essai de faire basculer le gestionnaire de fenetres sur “Beryl” j’obtiens : [code]Avertissement du gestionnaire de fenêtres : Perte de la connexion avec le visuel « :0.0 » ;
le serveur X a probablement été arrêté ou vous avez tué/détruit
le gestionnaire de fenêtres.
- Beryl system compatiblity check *
Detected xserver : NVIDIA
Checking Display :0.0 …
Checking for XComposite extension : passed (v0.3)
Checking for XDamage extension : passed
Checking for RandR extension : passed
Checking for XSync extension : passed
Checking Screen 0 …
Xlib: extension “GLX” missing on display “:0.0”.
Root visual is not a GL visual
Avertissement du gestionnaire de fenêtres : Log level 16: Impossible de trouver le moteur de thème dans module_path : « lighthouseblue »
voilà , si vous me donnez pas la soluce, moi je jette l’éponge
ps : svp soyez indulgent si je dis des conneries je debarque sous debian et je debute en informatique.
ui au moins 2x
