Je viens de faire une mise a jour et la configuration de ma souris à été modifié. Je n’ai plus désormais que 2 boutons correctements configurer
[code]ash@seal:~$ xmodmap -pp
There are 11 pointer buttons defined.
Physical Button
Button Code
1 1
2 2
3 3
4 4
5 5
6 6
7 7
8 8
9 9
10 10
11 11
[/code]Alors que je suis censé en avoir 7
bouton gauche
bouton droit
bouton du milieu qui en comprend 3: roulette avant, roulette arriere, plus bouton du milieu.
bouton a gauche du bouton gauche
bouton a droite du bouton droite
Ma souris est une intellimouse optical de chez microsoft download.microsoft.com/download/ … _0412A.pdf
mon xorg.conf est Section "InputDevice"
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option "Device" "/dev/input/mice"
Option "Protocol" "ExplorerPS/2"
Option "Buttons" "7"
Option "ZAxisMapping" "6 7"
EndSection
mon startup.conf d’imwheel est
[code]# Configuration file for setting imwheel startup parameters.
Set this to “1” to make imwheel start along with your X session.
IMWHEEL_START=1
Specify the command line parameters to pass to imwheel.
Simply uncomment the bottom line, and if necessary replace
the default options with your own. A button spec of 0089
will grab the thumb buttons of most mice. 000089 should work
for mice with a scroll wheel with two axes.
#IMWHEEL_PARAMS="-b "0089"“
IMWHEEL_PARAMS=”-b “0067"”
et le imwheelrc est [code]# IMWheel Configuration file ($HOME/.imwheelrc or /etc/imwheelrc)
(GPL)Jon Atkins jcatki@jonatkins.org
Please read the README and/or imwheel(1) manpage for info
and this is best operated on using vim (as I said: It’s crunchy)
This is only for demonstration of the priority command…
See the other global Exclude command below for the one you want to use!
If this is activated it will only apps that have a lower priority
priority is based first on the priority command, then the position in this
file - the higher the line is in a file the higher in a priority class it is
thus for a default priority you can see that the position in the file is
important, but the priority command CAN appear anywahere in a window’s list
of translations, and the priority will be assigned to all translations below
it until either a new window is defined or the priority is set again.
#@Priority=-1000 #the default priority is zero, higher numbers take precedence
#@Exclude
#@Repeat
want it to type something?
this would type “Rofl” and press Return in any window
#,Up,Shift_L|R|-R|-Shift_L|O|-O|F|-F|L|-L|Return
This one rule can send button events, as if you used ZAxisMapping “4 5”
Make sure your XF86Config allows for the max buttons needed…
otherwise the events will NOT even be generated…
#, Up, Button4
#, Down, Button5
#, Left, Button6
#, Right, Button7
#, Thumb1, Button6
#, Thumb2, Button7
alternatively with Button numbers
#, Button4, Button4
#, Button5, Button5
#, Button6, Button6
#, Button7, Button7
#, Button6, Button6
#, Button7, Button7
#Thanks to Mathias Weyland mathias@weyland-wtal.de
"^mutt.*"
None, Up, Up
None, Down, Down
Control_L, Up, Page_Up
Control_L, Down, Page_Down
"^aterm"
None, Up, Shift_L|Page_Up
None, Down, Shift_L|Page_Down
Control_L, Up, Up
Control_L, Down, Down
"^Xplns"
None, Up, Left
None, Down, Right
Control_L, Up, Up
"^kvt"
"^Konsole"
"^XMcd"
None, Up, C
None, Down, Shift_L|C
"^XMMS_Player"
Shift_L, Up, Right
Shift_L, Down, Left
"^XMMS_Playlist"
Shift_L, Up, Page_Up
Shift_L, Down, Page_Down
"^xmms"
Alt_L, Up, Z
Alt_L, Down, B
Control_L, Up, V
Control_L, Down, C
"^XATITV-GATOS"
None, Down, KP_Subtract
None, Up, KP_Add
"^Xman"
None, Down, F
Shift_L, Down, 3
None, Up, B
"^Gvi(m|ew)"
Alt_L, Up, Page_Up
Alt_L, Down, Page_Down
Shift_L, Up, Control_L|Y
Shift_L, Down, Control_L|E
#None, Up, Page_Up
#None, Down, Page_Down
#, Up, Button4
#, Down, Button5
, Left, Shift_L|Left
, Right, Shift_L|Right
, Thumb1, Shift_L|Left
, Thumb2, Shift_L|Right
"^VIM"
#None, Up, Page_Up
"^Eterm"
Alt_L, Up, Up
Alt_L, Down, Down
#Alt_L, Up, Shift_L|Page_Up
#Alt_L, Down, Shift_L|Page_Down
#"^GnomeTerminal"
#@Exclude
#@Repeat
#None, Up, Shift_L|Page_Up
#None, Down, Shift_L|Page_Down
"^NXTerm"
"^rxvt"
"^XTerm"
Alt_L, Up, Shift_R|Page_Up
Alt_L, Down, Shift_R|Page_Down
Alt_L, Left, Control_L|A
Alt_L, Right, Control_L|E
#Shift_L, Down, Shift_L|1
“^VMware”
@Exclude
#@Repeat
"^Mozilla-bin$"
None, Up, Button4
None, Down, Button5
None, Left, Alt_L|Left
None, Right, Alt_L|Right
If you want to scroll by a few lines then uncomment these 4 lines
and comment out the paging 4 lines below these!
Shift_L, Down, Page_Down, 1#, 1000, 1000
Shift_L, Up, Page_Up, 1#, 1000, 1000
None, Down, Down, 7#, 1000, 1000
None, Up, Up, 7#, 1000, 1000
If you don’t like page scrolling then comment these out and uncomment above!
#Shift_L, Down, Down, 7,
#Shift_L, Up, Up, 7,
#None, Down, Page_Down, 1,
#None, Up, Page_Up, 1,
Left/Right & Thumb stuff
None, Left, Left, 7,
None, Right, Right, 7,
None, Thumb1, Down, 7,
Shift_L, Thumb1, Up, 7,
None, Thumb2, Up, 7,
Shift_L, Thumb2, Down, 7,
“^Freespace.*”
, Up, Y
, Down, X
, Thumb1, H
, Thumb2, R
“^SDL_App”
#, Up, Button4
#, Down, Button5
, Thumb1, Home #many apps don’t understand Button > 5
, Thumb2, End #many apps don’t understand Button > 5
Thanks to shewp shewplx@pblx.net
“^Opera”
#@Repeat # let qt do it
None, Down, Down, 4, 100, 100
None, Up, Up, 4, 100, 100
None, Thumb1, Right
None, Thumb2, Left
“^Netscape.*”
, Thumb1, Alt_L|KP_Left
, Thumb2, Alt_L|KP_Right
#, Up, Button4
#, Down, Button5
“^Netscape”
If you don’t want to scroll by a few lines then comment out these 4 lines
and uncomment the paging 4 lines below these!
Shift_L, Down, Page_Down, 1, 1000, 1000
Shift_L, Up, Page_Up, 1, 1000, 1000
None, Down, Down, 7, 1000, 1000
None, Up, Up, 7, 1000, 1000
If you don’t like page scrolling then uncomment these
and comment out the 4 lines above!
#Shift_L, Down, Shift_L|Down, 7, 1000, 1000
#Shift_L, Up, Shift_L|Up, 7, 1000, 1000
#None, Down, Page_Down, 1, 1000, 1000
#None, Up, Page_Up, 1, 1000, 1000
None, Left, Left, 7, 1000, 1000
None, Right, Right, 7, 1000, 1000
None, Thumb1, Down, 7, 1000, 1000
Shift_L, Thumb1, Up, 7, 1000, 1000
None, Thumb2, Up, 7, 1000, 1000
Shift_L, Thumb2, Down, 7, 1000, 1000
“^Navigator”
#Alt_L, Down, Alt_L|Right
#Alt_L, Up, Alt_L|Left
Alt_L, Down, Right, 10, 1000, 1000
Alt_L, Up, Left, 10, 1000, 1000
Thanks to Paul J Collins sneakums@usa.net
"^emacs"
you may need Alt instead of Meta…
None, Down, Control_L|Meta_L|Shift_L|parenright
None, Up, Control_L|Meta_L|Shift_L|parenleft
Thanks to etienne grossmann etienne@isr.ist.utl.pt
“^Xftp”
, Down, j
, Up, k
“.* - Pan$”
, Left, Control_L|Button1
, Thumb1, Control_L|Button1
#, Up, Button4
#, Down, Button5
"^gv[ :]"
None, Up, Shift_L|space
None, Down, space
#"^Event Tester"
#@Repeat
#@Exclude
#, Left, Button6
#, Right, Button7
#, Thumb1, Button8
#, Thumb2, Button9
“^xv grab”
@Priority=1
@Exclude
"^XV.*"
None, Down, Tab
None, Up, Delete
“^Untitled”
if using wheel fifo, you may switch these.
#, Up, Button4
#, Down, Button5
#with these
, Up, Page_Up
, Down, Page_Down
(end of switch)
, Thumb1, Home
, Thumb2, End
“^No Title”
#, Up, Button4
#, Down, Button5
#with these
, Up, Page_Up
, Down, Page_Down
(end of switch)
, Left, Home
, Right, End
, Thumb1, Home
, Thumb2, End
#"(null)"
if using wheel fifo, you may want the 2nd group
#, Up, Button4
#, Down, Button5
#, Left, Button6
#, Right, Button7
#, Thumb1, Button8
#, Thumb2, Button9
2nd group (old keys…)
#, Up, Page_Up
#, Down, Page_Down
#, Left, Home
#, Right, End
#, Thumb1, Home
#, Thumb2, End
(end of switch)
send event to the window manager when in the root window…
“(root)”
, Up, Control_L|N
, Down, Control_L|P
, Thumb1, Alt_L|Left
, Thumb2, Alt_L|Right
Uncommment the following to exclude by default.
Then you will have to add new apps all the time, but will retain any built-in
wheel functionality contained in some KDE and other newer programs.
This kinda defeats the original purpose of the program!
#@Priority=-1000
#@Exclude
#@Repeat
These are the defaults, but note that the defaults for the right side of the
keyboard are still handled within the program, unless you add the
combinations desired here. (except for the None modifier of course!)
If this section is deleted then the hardcoded defaults will be used, which
are the same thing.
Modifying these has global effects, but doesn’t override what is above.
#@Priority=-1001
#, Up, Button4
#, Down, Button5
#None, Left, Left
#None, Right, Right
#None, Up, Page_Up
#Shift_L, Left, Left
#Shift_L, Right, Right
#Shift_L, Up, Up
Control_L, Left, Left, 2
Control_L, Right, Right, 2
Control_L, Up, Page_Up, 2
Control_L, Down, Page_Down, 2
#Shift_L|Control_L, Left, Left, 5
#Shift_L|Control_L, Right, Right, 5
#Shift_L|Control_L, Up, Page_Up, 5
#Shift_L|Control_L, Down, Page_Down, 5
Alt_L, Left, Left, 10
Alt_L, Right, Right, 10
Alt_L, Up, Left, 10
#Shift_L| Alt_L, Left, Left
#Shift_L| Alt_L, Right, Right
#Shift_L| Alt_L, Up, Left
#Shift_L| Alt_L, Down, Right
Control_L|Alt_L, Left, Left. 20
Control_L|Alt_L, Right, Right. 20
Control_L|Alt_L, Up, Left. 20
Control_L|Alt_L, Down, Right. 20
#Shift_L|Control_L|Alt_L, Left, Left, 50
#Shift_L|Control_L|Alt_L, Right, Right, 50
#Shift_L|Control_L|Alt_L, Up, Left, 50
#Shift_L|Control_L|Alt_L, Down, Right, 50
#, Thumb1, Home
#, Thumb2, End
vim:ts=4:shiftwidth=4:syntax=sh
None, Up, Alt_L|Left
None, Down, Alt_L|Right
"(null)"
None, Down, Alt_L|Right [/code]J’ai essayer de suivre le tuto de ghostintheshell forum.debian-fr.org/viewtopic.php?t=1657 mais ca fait planter mon serveur X et apres impossible de se logguer je suis obliger de retirer /etc/X11/Xsession.d/63xmodmapQuelqu’un aurais une idée, je suis un peu a court la???
