[Résolu]Installation de compiz-fusion
Bonsoir,
Quelqu’un aurait un tutoriel, qui fonctionne sans complication pour installer compiz fusion?
Cordialement,
Aley
P.S.: Je ne sais pas si ma carte graphique (nvidia 8400M) est reconnue!
Bon, tu pousses un peu le bouchon là non?
Alors, tout d’abord:
viewtopic.php?f=3&t=4657
Ensuite, commence par:
apt-cache search nvidia 8400M nvidia-glx - NVIDIA binary Xorg driver nvidia-glx-legacy-173xx - NVIDIA binary Xorg driver
Bon, tu vois, ta carte, il lui faut nvidia-glx ou nvidia-glx-legacy-173xx… Continuons:
apt-cache show nvidia-glx Package: nvidia-glx Description: NVIDIA binary Xorg driver These binary drivers provide optimized hardware acceleration of OpenGL applications via a direct-rendering X Server. AGP, PCIe, SLI, TV-out and flat panel displays are also supported. . Please see the nvidia-kernel-source package for building the kernel module required by this package. This will provide nvidia-kernel-<version> . The following GPU's are supported: GeForce 6800 Ultra, GeForce 6800, GeForce 6800 XE, GeForce 6800 XT GeForce 6800 GT, GeForce 6800 GS, Quadro FX 4000, GeForce 7800 GTX GeForce 7800 GT, GeForce 7800 GS, GeForce Go 7800, GeForce Go 7800 GTX Quadro FX 4500, GeForce 6800, GeForce 6800 LE, GeForce Go 6800, GeForce Go 6800 Ultra, Quadro FX Go1400, Quadro FX 3450/4000 SDI Quadro FX 1400, GeForce 6600 GT, GeForce 6600, GeForce 6200 GeForce 6600 LE, Quadro FX 3400/4400, GeForce PCX 5750, GeForce PCX 5900 GeForce PCX 5300/Quadro FX 330, Quadro NVS 280 PCI-E/Quadro FX 330 Quadro FX 1300, GeForce PCX 4300, GeForce 6600 VE, GeForce Go 6600 GeForce 6610 XL, GeForce Go 6600 TE/6200 TE, GeForce 6700 XL, GeForce Go 6600 GT, Quadro NVS 440, Quadro FX 550, Quadro FX 540, GeForce 6500, GeForce 6200 TurboCache(TM), GeForce 6200 LE, GeForce Go 6200 Quadro NVS 285, GeForce Go 6400, GeForce 8800 GTX, GeForce 8800 GTS Quadro FX 5600, Quadro FX 4600, GeForce 7300 LE, GeForce 7300 SE Quadro NVS 110M/GeForce Go 7300, GeForce Go 7400, Quadro NVS 110M Quadro NVS 120M, Quadro FX 350M, Quadro FX 350, GeForce 7300 GS GeForce 6150, GeForce 6150 LE, GeForce 6100, GeForce Go 6100, GeForce 7900 GTX, GeForce 7900 GT/GTO, GeForce 7900 GS, GeForce 7950 GX2 GeForce Go 7900 GS, GeForce Go 7900 GTX, Quadro FX 2500M, Quadro FX 1500M Quadro FX 5500, Quadro FX 3500, Quadro FX 1500, Quadro FX 4500 X2, GeForce 7600 GS, GeForce FX 5800 Ultra, GeForce FX 5800, Quadro FX 2000 Quadro FX 1000, GeForce FX 5600 Ultra, GeForce FX 5600, GeForce FX 5600XT GeForce FX Go5600, GeForce FX Go5650, Quadro FX Go700, GeForce FX 5200 GeForce FX 5200 Ultra, GeForce FX 5200, GeForce FX 5200LE, GeForce FX Go5200 GeForce FX Go5250, GeForce FX 5500, GeForce FX 5100, GeForce FX Go5200 32M/64M Quadro NVS 55/280 PCI, Quadro FX 500/FX 600, GeForce FX Go53xx, GeForce FX Go5100, GeForce FX 5900 Ultra, GeForce FX 5900, GeForce FX 5900XT GeForce FX 5950 Ultra, GeForce FX 5900ZT, Quadro FX 3000, Quadro FX 700 GeForce FX 5700 Ultra, GeForce FX 5700, GeForce FX 5700LE, GeForce FX 5700VE GeForce FX Go5700, Quadro FX Go1000, Quadro FX 1100, GeForce 7600 GT, GeForce 7600 GS, GeForce 7300 GT, GeForce Go 7600, Quadro FX 560, GeForce 7050 PV / NVIDIA nForce 630a, GeForce 7025 / NVIDIA nForce 630a, GeForce 8600 GTS, GeForce 8600 GT, GeForce 8600M GT, GeForce 8600M GS, GeForce 8500 GT, GeForce 8400 GS, GeForce 8400M GT, GeForce 8400M GS, GeForce 8400M G, GeForce 8300 GS, Quadro FX 1600M, Quadro FX 570M, Quadro FX 360M, Quadro NVS 320M, Quadro NVS 140M, Quadro NVS 135M, Quadro NVS 130M . See /usr/share/doc/nvidia-glx/README.txt.gz for a complete list of supported GPUs and PCIIDs
ensuite intéresse toi à module-assistant… et pis comme tu n’es pas anglophobe:
wiki.debian.org/NvidiaGraphicsDrivers
wiki.debian.org/NvidiaGraphicsDr … reedrivers
exécutes ce script tu n’auras plus de doute sur la version du driver proprio à utiliser:
wiki.debian.org/NvidiaGraphicsDr … ersions.sh
Puis installe ce qui va bien:
wiki.debian.org/NvidiaGraphicsDr … -assistant
Je te laisse lire et exécuter les instructions du WIKI pour la suite. Dis nous si ça marche!
Ensuite pour installer et configurer compiz:
wiki.debian.org/Compiz
[quote=“Aley”]Bonsoir,
Cordialement,
Aley
P.S.: Je ne sais pas si ma carte graphique (nvidia 8400M) est reconnue![/quote]
C’est une super réponse, merci ziouplaboum! Par contre je te dirai cela dimanche soir…
C’est à dire que j’ai suivi un tutoriel à la noix de cajou hier soir, et je me suis retrouvé à reconfigurer mon xorg et mon gdm … Heureusement, j’ai appris les bases sur Ubuntu, j’ai voulu passer à Debian, pour réellement avoir plus de liberté et puis plus de sécurité, car sous Ubuntu, l’utilisateur fait directement parti des “sudousers” c’est pas terrible je pense.
En tout cas merci encore !
Cordialement,
Aley
[quote=“Aley”]…sous Ubuntu, l’utilisateur fait directement parti des “sudousers” c’est pas terrible je pense.
…[/quote]Pas forcément, ensuite c’est une question d’usage… sudo n’est pas le diable. Administrer en sudo n’est pas forcément “dangereux”, tout est question de pratiques et d’habitudes. Mais le fait d’avoir un même mot de passe pour un utilisateur lambda et pour l’admin, moi ça me plaît pas.
De toute façon, sudo ou pas, quand on fait des choses en “root” il faut faire gaffe, l’avantage de sudo c’est que tu es obligé de taper “sudo” devant tes commandes, même s’il ne va pas tout le temps te demander de mdp alors que si tu “su” il y a de fortes chances qu’en voulant aller vite tu finisses par te planter en faisant une action dangereuse en pensant être simple utilisateur (genre se gourrer de terminal) et commettre l’irréparable : “rm -r / toto” au lieu de “rm -r /toto” :stuck_out_tongue:
Donc quoiqu’il arrive il faudra toujours faire attention à pas laisser faire n’importe quoi à ses mimines, histoire de pas paner une installation (c’est comme ça que j’ai fait un “rm *” dans /bin une fois … je parle d’expérience :stuck_out_tongue:)
J’ai pas vraiment eu de mal moi, j’ai installé mes drivers graphiques, ensuite dans Synaptic j’ai sélectionner tous les paquets de Compiz, une fois le tout installé j’ai fait compiz --replace et c’était bon.
Merci encore ziouplaboum, ça fonctionne du tonnerre!
Nickel!
