Hello !
Voilà le problème, j’essaie d’installer kaffeine à partir des sources car n’est plus accessible depuis Aptitude …
J’essaie depuis…
d’installer à l’aide des sources mais je ne comprends pas les erreurs… je complète p’tit bout par p’tit bout mais toujours sans réel résultat.
Voici le dernier retour :
waouh:/home/nous/kaffeine-0.7.1# ./configure
checking build system type… i686-pc-linux-gnu
checking host system type… i686-pc-linux-gnu
checking target system type… i686-pc-linux-gnu
checking for a BSD-compatible install… /usr/bin/install -c
checking for -p flag to install… yes
checking whether build environment is sane… yes
checking for gawk… gawk
checking whether make sets $(MAKE)… yes
checking for kde-config… /usr/bin/kde-config
kde-config: Unknown option ‘–libsuffix’.
kde-config: Use --help to get a list of available command line options.
checking where to install… /usr (as returned by kde-config)
checking for style of include used by make… GNU
checking for gcc… gcc
checking for C compiler default output file name… a.out
checking whether the C compiler works… yes
checking whether we are cross compiling… no
checking for suffix of executables…
checking for suffix of object files… o
checking whether we are using the GNU C compiler… yes
checking whether gcc accepts -g… yes
checking for gcc option to accept ANSI C… none needed
checking dependency style of gcc… gcc3
checking how to run the C preprocessor… gcc -E
checking for g++… no
checking for c++… no
checking for gpp… gpp
checking whether we are using the GNU C++ compiler… no
checking whether gpp accepts -g… no
checking dependency style of gpp… none
checking whether gcc is blacklisted… no
checking whether gpp supports -Wmissing-format-attribute… no
checking whether gcc supports -Wmissing-format-attribute… yes
checking whether gpp supports -Wundef… no
checking whether gpp supports -Wno-long-long… no
checking whether gpp supports -Wnon-virtual-dtor… no
checking how to run the C++ preprocessor… /lib/cpp
configure: error: C++ preprocessor “/lib/cpp” fails sanity check
See `config.log’ for more details.
Donc j’ai deux questions, si possible :
Que dois-je faire dans l’immédiat ?
Qu’ai-je fait lors de l’installation de la Testing pour que je ne puis compiler facilement ?
Par avance merci !
