Merci Jabba.
Finalement me voici ce dimanche.
Parce que ma fille a eu à son anniversaire (aujourd’hui) un lecteur mp3
donc je le branche et je ne peux pas ecrire dessus.
fdisk -l donne :
[quote]fdisk -l
Disk /dev/hda: 40.0 GB, 40007761920 bytes
255 heads, 63 sectors/track, 4864 cylinders
/dev/hda1 * 1 4735 38033856 83 Linux
/dev/hda2 4736 4864 1036192+ 5 Extended
/dev/hda5 4736 4864 1036161 82 Linux swap / Solaris
Disk /dev/sda: 254 MB, 254657024 bytes
8 heads, 61 sectors/track, 1019 cylinders
Units = cylinders of 488 * 512 = 249856 bytes
This doesn’t look like a partition table
Probably you selected the wrong device.
/dev/sda1 ? 3831499 4177174 84344761 69 Unknown
Partition 1 has different physical/logical beginnings (non-Linux?):
phys=(68, 13, 10) logical=(3831498, 5, 37)
Partition 1 has different physical/logical endings:
phys=(288, 115, 43) logical=(4177173, 7, 36)
Partition 1 does not end on cylinder boundary.
/dev/sda2 ? 3486721 7318445 934940732+ 73 Unknown
Partition 2 has different physical/logical beginnings (non-Linux?):
phys=(371, 114, 37) logical=(3486720, 1, 61)
Partition 2 has different physical/logical endings:
phys=(366, 32, 33) logical=(7318444, 4, 30)
Partition 2 does not end on cylinder boundary.
/dev/sda3 ? 6 6 0 74 Unknown
Partition 3 has different physical/logical beginnings (non-Linux?):
phys=(371, 114, 37) logical=(5, 2, 12)
Partition 3 has different physical/logical endings:
phys=(372, 97, 50) logical=(5, 2, 11)
Partition 3 does not end on cylinder boundary.
/dev/sda4 1 7039167 1717556736 0 Empty
Partition 4 has different physical/logical beginnings (non-Linux?):
phys=(0, 0, 0) logical=(0, 0, 1)
Partition 4 has different physical/logical endings:
phys=(0, 0, 0) logical=(7039166, 7, 37)
Partition 4 does not end on cylinder boundary.
Partition table entries are not in disk order
J’essaye de le monter j’ai ce message [quote][mntent]: warning: no final newline at the end of /etc/fstab
mount: I could not determine the filesystem type, and none was specified
Please check that the disk is entered correctly.[/quote]
J’ai ajouté dans le etc/fstab: cette ligne :/dev/sda /mnt auto rw,user,noauto 0 0
J’ai aussi ça : [quote]/home/eric# mount /dev/sda /mnt
mpl69-1-82-232-141-252:/home/eric# mount /mnt
mount: you must specify the filesystem type
Voilà, un p’tit coup de main, merci !
