[Résolu] - Installation du capteur de température sur USB
Salutations,
par souci de connaître et suivre un peu la température dans mon bureau, j’ai acheté ce petit capteur:
TEMPer V1.4
Mais après avoir regardé plusieurs sites, je n’ai pas réussi à l’installer :frowning:
Voici le contenu de mon dmesg:
[ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Linux version 3.2.0-4-686-pae (debian-kernel@lists.debian.org) (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP Debian 3.2.60-1+deb7u1 [ 0.000000] BIOS-provided physical RAM map: [ 0.000000] BIOS-e820: 0000000000000000 - 000000000009f800 (usable) [ 0.000000] BIOS-e820: 000000000009f800 - 00000000000a0000 (reserved) [ 0.000000] BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved) [ 0.000000] BIOS-e820: 0000000000100000 - 000000003fef0000 (usable) [ 0.000000] BIOS-e820: 000000003fef0000 - 000000003fefb000 (ACPI data) [ 0.000000] BIOS-e820: 000000003fefb000 - 000000003ff00000 (ACPI NVS) [ 0.000000] BIOS-e820: 000000003ff00000 - 000000003ff80000 (usable) [ 0.000000] BIOS-e820: 000000003ff80000 - 0000000040000000 (reserved) [ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec10000 (reserved) [ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved) [ 0.000000] BIOS-e820: 00000000ff800000 - 00000000ffc00000 (reserved) [ 0.000000] BIOS-e820: 00000000fffffc00 - 0000000100000000 (reserved) [ 0.000000] Notice: NX (Execute Disable) protection missing in CPU! [ 0.000000] SMBIOS 2.3 present. [ 0.000000] DMI: IBM 830781G/IBM, BIOS 24KT54AFR 06/04/2004 [ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved) [ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable) [ 0.000000] last_pfn = 0x3ff80 max_arch_pfn = 0x1000000 [ 0.000000] MTRR default type: uncachable [ 0.000000] MTRR fixed ranges enabled: [ 0.000000] 00000-9FFFF write-back [ 0.000000] A0000-BFFFF uncachable [ 0.000000] C0000-C7FFF write-protect [ 0.000000] C8000-E3FFF uncachable [ 0.000000] E4000-FFFFF write-protect [ 0.000000] MTRR variable ranges enabled: [ 0.000000] 0 base 000000000 mask FC0000000 write-back [ 0.000000] 1 base 03FF80000 mask FFFF80000 uncachable [ 0.000000] 2 disabled [ 0.000000] 3 disabled [ 0.000000] 4 disabled [ 0.000000] 5 disabled [ 0.000000] 6 disabled [ 0.000000] 7 disabled [ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106 [ 0.000000] found SMP MP-table at [c00f61d0] f61d0 [ 0.000000] initial memory mapped : 0 - 01a00000 [ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384 [ 0.000000] init_memory_mapping: 0000000000000000-00000000379fe000 [ 0.000000] 0000000000 - 0000200000 page 4k [ 0.000000] 0000200000 - 0037800000 page 2M [ 0.000000] 0037800000 - 00379fe000 page 4k [ 0.000000] kernel direct mapping tables up to 379fe000 @ 19f9000-1a00000 [ 0.000000] RAMDISK: 37adc000 - 37d66000 [ 0.000000] Allocated new RAMDISK: 37774000 - 379fdabf [ 0.000000] Move RAMDISK from 0000000037adc000 - 0000000037d65abe to 37774000 - 379fdabe [ 0.000000] ACPI: RSDP 000f6260 00014 (v00 PTLTD ) [ 0.000000] ACPI: RSDT 3fef73ec 00034 (v01 PTLTD RSDT 060400D0 LTP 00000000) [ 0.000000] ACPI: FACP 3fefaee2 00074 (v01 IBM NETVISTA 060400D0 PTL 00000001) [ 0.000000] ACPI: DSDT 3fef7420 03AC2 (v01 IBM Yelotail 060400D0 MSFT 0100000E) [ 0.000000] ACPI: FACS 3fefbfc0 00040 [ 0.000000] ACPI: TCPA 3fefaf56 00032 (v01 IBM NETVISTA 060400D0 PTL 00000001) [ 0.000000] ACPI: APIC 3fefaf88 00050 (v01 PTLTD ? APIC 060400D0 LTP 00000000) [ 0.000000] ACPI: BOOT 3fefafd8 00028 (v01 PTLTD $SBFTBL$ 060400D0 LTP 00000001) [ 0.000000] ACPI: Local APIC address 0xfee00000 [ 0.000000] 133MB HIGHMEM available. [ 0.000000] 889MB LOWMEM available. [ 0.000000] mapped low ram: 0 - 379fe000 [ 0.000000] low ram: 0 - 379fe000 [ 0.000000] Zone PFN ranges: [ 0.000000] DMA 0x00000010 -> 0x00001000 [ 0.000000] Normal 0x00001000 -> 0x000379fe [ 0.000000] HighMem 0x000379fe -> 0x0003ff80 [ 0.000000] Movable zone start PFN for each node [ 0.000000] early_node_map[3] active PFN ranges [ 0.000000] 0: 0x00000010 -> 0x0000009f [ 0.000000] 0: 0x00000100 -> 0x0003fef0 [ 0.000000] 0: 0x0003ff00 -> 0x0003ff80 [ 0.000000] On node 0 totalpages: 261887 [ 0.000000] free_area_init_node: node 0, pgdat c1412800, node_mem_map f6f73200 [ 0.000000] DMA zone: 32 pages used for memmap [ 0.000000] DMA zone: 0 pages reserved [ 0.000000] DMA zone: 3951 pages, LIFO batch:0 [ 0.000000] Normal zone: 1748 pages used for memmap [ 0.000000] Normal zone: 221994 pages, LIFO batch:31 [ 0.000000] HighMem zone: 268 pages used for memmap [ 0.000000] HighMem zone: 33894 pages, LIFO batch:7 [ 0.000000] Using APIC driver default [ 0.000000] ACPI: PM-Timer IO Port: 0x1008 [ 0.000000] ACPI: Local APIC address 0xfee00000 [ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled) [ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1]) [ 0.000000] ACPI: IOAPIC (id[0x01] address[0xfec00000] gsi_base[0]) [ 0.000000] IOAPIC[0]: apic_id 1, version 32, address 0xfec00000, GSI 0-23 [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level) [ 0.000000] ACPI: IRQ9 used by override. [ 0.000000] Using ACPI (MADT) for SMP configuration information [ 0.000000] SMP: Allowing 1 CPUs, 0 hotplug CPUs [ 0.000000] nr_irqs_gsi: 40 [ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000 [ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e0000 [ 0.000000] PM: Registered nosave memory: 00000000000e0000 - 0000000000100000 [ 0.000000] Allocating PCI resources starting at 40000000 (gap: 40000000:bec00000) [ 0.000000] Booting paravirtualized kernel on bare hardware [ 0.000000] setup_percpu: NR_CPUS:32 nr_cpumask_bits:32 nr_cpu_ids:1 nr_node_ids:1 [ 0.000000] PERCPU: Embedded 14 pages/cpu @f6f5e000 s33280 r0 d24064 u57344 [ 0.000000] pcpu-alloc: s33280 r0 d24064 u57344 alloc=14*4096 [ 0.000000] pcpu-alloc: [0] 0 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 259839 [ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.2.0-4-686-pae root=UUID=6a99a340-21aa-4ccd-aa6a-0b8d36b8f7d5 ro quiet [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Initializing CPU#0 [ 0.000000] Initializing HighMem for node 0 (000379fe:0003ff80) [ 0.000000] Memory: 1030636k/1048064k available (2857k kernel code, 16912k reserved, 1342k data, 420k init, 136648k highmem) [ 0.000000] virtual kernel memory layout: [ 0.000000] fixmap : 0xffd36000 - 0xfffff000 (2852 kB) [ 0.000000] pkmap : 0xffa00000 - 0xffc00000 (2048 kB) [ 0.000000] vmalloc : 0xf81fe000 - 0xff9fe000 ( 120 MB) [ 0.000000] lowmem : 0xc0000000 - 0xf79fe000 ( 889 MB) [ 0.000000] .init : 0xc141b000 - 0xc1484000 ( 420 kB) [ 0.000000] .data : 0xc12ca6c0 - 0xc141a1c0 (1342 kB) [ 0.000000] .text : 0xc1000000 - 0xc12ca6c0 (2857 kB) [ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok. [ 0.000000] Hierarchical RCU implementation. [ 0.000000] RCU dyntick-idle grace-period acceleration is enabled. [ 0.000000] NR_IRQS:2304 nr_irqs:256 16 [ 0.000000] CPU 0 irqstacks, hard=f6808000 soft=f680a000 [ 0.000000] Console: colour VGA+ 80x25 [ 0.000000] console [tty0] enabled [ 0.000000] Fast TSC calibration using PIT [ 0.000000] Detected 2657.738 MHz processor. [ 0.004003] Calibrating delay loop (skipped), value calculated using timer frequency.. 5315.47 BogoMIPS (lpj=10630952) [ 0.004010] pid_max: default: 32768 minimum: 301 [ 0.004069] Security Framework initialized [ 0.004082] AppArmor: AppArmor disabled by boot time parameter [ 0.004104] Mount-cache hash table entries: 512 [ 0.004308] Initializing cgroup subsys cpuacct [ 0.004317] Initializing cgroup subsys memory [ 0.004330] Initializing cgroup subsys devices [ 0.004334] Initializing cgroup subsys freezer [ 0.004337] Initializing cgroup subsys net_cls [ 0.004340] Initializing cgroup subsys blkio [ 0.004350] Initializing cgroup subsys perf_event [ 0.004394] CPU0: Hyper-Threading is disabled [ 0.004400] mce: CPU supports 4 MCE banks [ 0.004416] CPU0: Thermal monitoring enabled (TM1) [ 0.004506] SMP alternatives: switching to UP code [ 0.011450] Freeing SMP alternatives: 8k freed [ 0.011459] ACPI: Core revision 20110623 [ 0.016108] Enabling APIC mode: Flat. Using 1 I/O APICs [ 0.016463] ..TIMER: vector=0x30 apic1=0 pin1=0 apic2=-1 pin2=-1 [ 0.020001] ..MP-BIOS bug: 8254 timer not connected to IO-APIC [ 0.020001] ...trying to set up timer (IRQ0) through the 8259A ... [ 0.020001] ..... (found apic 0 pin 0) ... [ 0.060247] ....... works. [ 0.060250] CPU0: Intel(R) Pentium(R) 4 CPU 2.66GHz stepping 07 [ 0.064003] Performance Events: Netburst events, Netburst P4/Xeon PMU driver. [ 0.064003] ... version: 0 [ 0.064003] ... bit width: 40 [ 0.064003] ... generic registers: 18 [ 0.064003] ... value mask: 000000ffffffffff [ 0.064003] ... max period: 0000007fffffffff [ 0.064003] ... fixed-purpose events: 0 [ 0.064003] ... event mask: 000000000003ffff [ 0.064003] NMI watchdog enabled, takes one hw-pmu counter. [ 0.064003] Brought up 1 CPUs [ 0.064003] Total of 1 processors activated (5315.47 BogoMIPS). [ 0.064003] devtmpfs: initialized [ 0.064003] PM: Registering ACPI NVS region at 3fefb000 (20480 bytes) [ 0.064003] print_constraints: dummy: [ 0.064003] NET: Registered protocol family 16 [ 0.064003] ACPI: bus type pci registered [ 0.064003] PCI: PCI BIOS revision 2.10 entry at 0xfd98d, last bus=2 [ 0.064003] PCI: Using configuration type 1 for base access [ 0.064003] bio: create slab <bio-0> at 0 [ 0.064003] ACPI: Added _OSI(Module Device) [ 0.064003] ACPI: Added _OSI(Processor Device) [ 0.064003] ACPI: Added _OSI(3.0 _SCP Extensions) [ 0.064003] ACPI: Added _OSI(Processor Aggregator Device) [ 0.064121] ACPI: EC: Look up EC in DSDT [ 0.065779] ACPI: Interpreter enabled [ 0.065790] ACPI: (supports S0 S1 S3 S4 S5) [ 0.065823] ACPI: Using IOAPIC for interrupt routing [ 0.090029] ACPI: No dock devices found. [ 0.090034] HEST: Table not found. [ 0.090042] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug [ 0.090844] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff]) [ 0.092459] pci_root PNP0A03:00: host bridge window [io 0x0000-0x0cf7] (ignored) [ 0.092464] pci_root PNP0A03:00: host bridge window [io 0x0d00-0xffff] (ignored) [ 0.092468] pci_root PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored) [ 0.092473] pci_root PNP0A03:00: host bridge window [mem 0x000cc000-0x000cffff] (ignored) [ 0.092476] pci_root PNP0A03:00: host bridge window [mem 0x000d0000-0x000d3fff] (ignored) [ 0.092480] pci_root PNP0A03:00: host bridge window [mem 0x000d4000-0x000d7fff] (ignored) [ 0.092484] pci_root PNP0A03:00: host bridge window [mem 0x000d8000-0x000dbfff] (ignored) [ 0.092488] pci_root PNP0A03:00: host bridge window [mem 0x000dc000-0x000dffff] (ignored) [ 0.092492] pci_root PNP0A03:00: host bridge window [mem 0x40000000-0xfebfffff] (ignored) [ 0.092516] pci 0000:00:00.0: [8086:2560] type 0 class 0x000600 [ 0.092527] pci 0000:00:00.0: reg 10: [mem 0xd0000000-0xdfffffff pref] [ 0.092609] pci 0000:00:01.0: [8086:2561] type 1 class 0x000604 [ 0.092685] pci 0000:00:1d.0: [8086:24c2] type 0 class 0x000c03 [ 0.092733] pci 0000:00:1d.0: reg 20: [io 0x1800-0x181f] [ 0.092777] pci 0000:00:1d.1: [8086:24c4] type 0 class 0x000c03 [ 0.092825] pci 0000:00:1d.1: reg 20: [io 0x1820-0x183f] [ 0.092865] pci 0000:00:1d.2: [8086:24c7] type 0 class 0x000c03 [ 0.092913] pci 0000:00:1d.2: reg 20: [io 0x1840-0x185f] [ 0.092967] pci 0000:00:1d.7: [8086:24cd] type 0 class 0x000c03 [ 0.092990] pci 0000:00:1d.7: reg 10: [mem 0xc0000000-0xc00003ff] [ 0.093080] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold [ 0.093101] pci 0000:00:1e.0: [8086:244e] type 1 class 0x000604 [ 0.093152] pci 0000:00:1f.0: [8086:24c0] type 0 class 0x000601 [ 0.093158] * The chipset may have PM-Timer Bug. Due to workarounds for a bug, [ 0.093160] * this clock source is slow. If you are sure your timer does not have [ 0.093161] * this bug, please use "acpi_pm_good" to disable the workaround [ 0.093234] pci 0000:00:1f.0: quirk: [io 0x1000-0x107f] claimed by ICH4 ACPI/GPIO/TCO [ 0.093241] pci 0000:00:1f.0: quirk: [io 0x1180-0x11bf] claimed by ICH4 GPIO [ 0.093261] pci 0000:00:1f.1: [8086:24cb] type 0 class 0x000101 [ 0.093277] pci 0000:00:1f.1: reg 10: [io 0x0000-0x0007] [ 0.093288] pci 0000:00:1f.1: reg 14: [io 0x0000-0x0003] [ 0.093299] pci 0000:00:1f.1: reg 18: [io 0x0000-0x0007] [ 0.093310] pci 0000:00:1f.1: reg 1c: [io 0x0000-0x0003] [ 0.093322] pci 0000:00:1f.1: reg 20: [io 0x1860-0x186f] [ 0.093333] pci 0000:00:1f.1: reg 24: [mem 0x00000000-0x000003ff] [ 0.093368] pci 0000:00:1f.3: [8086:24c3] type 0 class 0x000c05 [ 0.093418] pci 0000:00:1f.3: reg 20: [io 0x1880-0x189f] [ 0.093462] pci 0000:00:1f.5: [8086:24c5] type 0 class 0x000401 [ 0.093479] pci 0000:00:1f.5: reg 10: [io 0x1c00-0x1cff] [ 0.093490] pci 0000:00:1f.5: reg 14: [io 0x18c0-0x18ff] [ 0.093500] pci 0000:00:1f.5: reg 18: [mem 0xc0000c00-0xc0000dff] [ 0.093511] pci 0000:00:1f.5: reg 1c: [mem 0xc0000800-0xc00008ff] [ 0.093560] pci 0000:00:1f.5: PME# supported from D0 D3hot D3cold [ 0.093598] pci 0000:01:00.0: [102b:0525] type 0 class 0x000300 [ 0.093615] pci 0000:01:00.0: reg 10: [mem 0xe0000000-0xe1ffffff pref] [ 0.093624] pci 0000:01:00.0: reg 14: [mem 0xc0100000-0xc0103fff] [ 0.093634] pci 0000:01:00.0: reg 18: [mem 0xc0800000-0xc0ffffff] [ 0.093660] pci 0000:01:00.0: reg 30: [mem 0x00000000-0x0001ffff pref] [ 0.093724] pci 0000:00:01.0: PCI bridge to [bus 01-01] [ 0.093731] pci 0000:00:01.0: bridge window [mem 0xc0100000-0xc0ffffff] [ 0.093736] pci 0000:00:01.0: bridge window [mem 0xe0000000-0xe1ffffff pref] [ 0.093774] pci 0000:02:08.0: [8086:1039] type 0 class 0x000200 [ 0.093792] pci 0000:02:08.0: reg 10: [mem 0xc1000000-0xc1000fff] [ 0.093804] pci 0000:02:08.0: reg 14: [io 0x2000-0x203f] [ 0.093868] pci 0000:02:08.0: supports D1 D2 [ 0.093872] pci 0000:02:08.0: PME# supported from D0 D1 D2 D3hot D3cold [ 0.093909] pci 0000:00:1e.0: PCI bridge to [bus 02-02] (subtractive decode) [ 0.093915] pci 0000:00:1e.0: bridge window [io 0x2000-0x2fff] [ 0.093921] pci 0000:00:1e.0: bridge window [mem 0xc1000000-0xc10fffff] [ 0.093927] pci 0000:00:1e.0: bridge window [io 0x0000-0xffff] (subtractive decode) [ 0.093931] pci 0000:00:1e.0: bridge window [mem 0x00000000-0xfffffffff] (subtractive decode) [ 0.093946] pci_bus 0000:00: on NUMA node 0 [ 0.093951] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT] [ 0.094090] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.SLOT._PRT] [ 0.094278] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.AGP_._PRT] [ 0.094324] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x1e) [ 0.143262] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 7 9 10 *11 12 14 15) [ 0.143347] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 7 *9 10 11 12 14 15) [ 0.143430] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 *5 7 9 10 11 12 14 15) [ 0.143512] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 7 9 *10 11 12 14 15) [ 0.143599] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 9 10 *11 12 14 15) [ 0.143686] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled. [ 0.143774] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled. [ 0.143862] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 7 *9 10 11 12 14 15) [ 0.144070] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none [ 0.144075] vgaarb: loaded [ 0.144078] vgaarb: bridge control possible 0000:01:00.0 [ 0.144147] PCI: Using ACPI for IRQ routing [ 0.144153] PCI: pci_cache_line_size set to 64 bytes [ 0.144214] reserve RAM buffer: 000000000009f800 - 000000000009ffff [ 0.144218] reserve RAM buffer: 000000003fef0000 - 000000003fffffff [ 0.144222] reserve RAM buffer: 000000003ff80000 - 000000003fffffff [ 0.147073] pnp: PnP ACPI init [ 0.147105] ACPI: bus type pnp registered [ 0.147972] pnp 00:00: [bus 00-ff] [ 0.147976] pnp 00:00: [io 0x0000-0x0cf7 window] [ 0.147981] pnp 00:00: [io 0x0cf8-0x0cff] [ 0.147984] pnp 00:00: [io 0x0d00-0xffff window] [ 0.147988] pnp 00:00: [mem 0x000a0000-0x000bffff window] [ 0.147991] pnp 00:00: [mem 0x000c0000-0x000c3fff window] [ 0.147994] pnp 00:00: [mem 0x000c4000-0x000c7fff window] [ 0.147998] pnp 00:00: [mem 0x000c8000-0x000cbfff window] [ 0.148032] pnp 00:00: [mem 0x000cc000-0x000cffff window] [ 0.148036] pnp 00:00: [mem 0x000d0000-0x000d3fff window] [ 0.148040] pnp 00:00: [mem 0x000d4000-0x000d7fff window] [ 0.148043] pnp 00:00: [mem 0x000d8000-0x000dbfff window] [ 0.148046] pnp 00:00: [mem 0x000dc000-0x000dffff window] [ 0.148049] pnp 00:00: [mem 0x000e0000-0x000e3fff window] [ 0.148053] pnp 00:00: [mem 0x000e4000-0x000e7fff window] [ 0.148056] pnp 00:00: [mem 0x000e8000-0x000ebfff window] [ 0.148059] pnp 00:00: [mem 0x000ec000-0x000effff window] [ 0.148062] pnp 00:00: [mem 0x40000000-0xfebfffff window] [ 0.148145] pnp 00:00: Plug and Play ACPI device, IDs PNP0a03 (active) [ 0.148267] pnp 00:01: [io 0x0010-0x001f] [ 0.148271] pnp 00:01: [io 0x0024-0x0025] [ 0.148274] pnp 00:01: [io 0x0028-0x0029] [ 0.148277] pnp 00:01: [io 0x002c-0x002d] [ 0.148280] pnp 00:01: [io 0x002e-0x002f] [ 0.148282] pnp 00:01: [io 0x0030-0x0031] [ 0.148285] pnp 00:01: [io 0x0034-0x0035] [ 0.148288] pnp 00:01: [io 0x0038-0x0039] [ 0.148291] pnp 00:01: [io 0x003c-0x003d] [ 0.148294] pnp 00:01: [io 0x004e-0x004f] [ 0.148297] pnp 00:01: [io 0x0050-0x0053] [ 0.148300] pnp 00:01: [io 0x0072-0x0077] [ 0.148302] pnp 00:01: [io 0x0080] [ 0.148305] pnp 00:01: [io 0x0090-0x009f] [ 0.148308] pnp 00:01: [io 0x00a4-0x00a5] [ 0.148311] pnp 00:01: [io 0x00a8-0x00a9] [ 0.148313] pnp 00:01: [io 0x00ac-0x00ad] [ 0.148316] pnp 00:01: [io 0x00b0-0x00b5] [ 0.148319] pnp 00:01: [io 0x00b8-0x00b9] [ 0.148322] pnp 00:01: [io 0x00bc-0x00bd] [ 0.148325] pnp 00:01: [io 0x04d0-0x04d1] [ 0.148327] pnp 00:01: [io 0xfe00] [ 0.148330] pnp 00:01: [io 0x0800-0x087f] [ 0.148333] pnp 00:01: [io 0x1000-0x107f] [ 0.148336] pnp 00:01: [io 0x1100-0x111f] [ 0.148339] pnp 00:01: [io 0x1180-0x11bf] [ 0.148342] pnp 00:01: [mem 0xeffffc00] [ 0.148434] system 00:01: [io 0x04d0-0x04d1] has been reserved [ 0.148438] system 00:01: [io 0xfe00] has been reserved [ 0.148442] system 00:01: [io 0x0800-0x087f] has been reserved [ 0.148446] system 00:01: [io 0x1000-0x107f] has been reserved [ 0.148452] system 00:01: [io 0x1100-0x111f] has been reserved [ 0.148456] system 00:01: [io 0x1180-0x11bf] has been reserved [ 0.148462] system 00:01: [mem 0xeffffc00] has been reserved [ 0.148466] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.148482] pnp 00:02: [io 0x0000-0x000f] [ 0.148486] pnp 00:02: [io 0x0081-0x008f] [ 0.148489] pnp 00:02: [io 0x00c0-0x00df] [ 0.148492] pnp 00:02: [dma 4] [ 0.148539] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active) [ 0.148555] pnp 00:03: [io 0x00f0-0x00fe] [ 0.148573] pnp 00:03: [irq 13] [ 0.148612] pnp 00:03: Plug and Play ACPI device, IDs PNP0c04 (active) [ 0.148629] pnp 00:04: [io 0x0070-0x0071] [ 0.148636] pnp 00:04: [irq 8] [ 0.148676] pnp 00:04: Plug and Play ACPI device, IDs PNP0b00 (active) [ 0.148691] pnp 00:05: [io 0x0061] [ 0.148729] pnp 00:05: Plug and Play ACPI device, IDs PNP0800 (active) [ 0.148947] pnp 00:06: [mem 0xff800000-0xffffffff] [ 0.148991] pnp 00:06: Plug and Play ACPI device, IDs INT0800 (active) [ 0.149069] pnp 00:07: [io 0x0060] [ 0.149073] pnp 00:07: [io 0x0064] [ 0.149080] pnp 00:07: [irq 1] [ 0.149132] pnp 00:07: Plug and Play ACPI device, IDs PNP0303 (active) [ 0.149234] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.153128] pnp 00:09: [irq 12] [ 0.154252] pnp 00:09: Plug and Play ACPI device, IDs PNP0f13 (active) [ 0.156108] system 00:0a: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.160079] pnp 00:0b: [io 0x03f0-0x03f5] [ 0.160084] pnp 00:0b: [io 0x03f7] [ 0.160092] pnp 00:0b: [irq 6] [ 0.160095] pnp 00:0b: [dma 2] [ 0.161547] pnp 00:0b: Plug and Play ACPI device, IDs PNP0700 (active) [ 0.169954] pnp 00:0c: [io 0x0378-0x037f] [ 0.169960] pnp 00:0c: [io 0x0778-0x077f] [ 0.169967] pnp 00:0c: [irq 7] [ 0.169970] pnp 00:0c: [dma 1] [ 0.172144] pnp 00:0c: Plug and Play ACPI device, IDs PNP0401 (active) [ 0.174281] pnp: PnP ACPI: found 13 devices [ 0.174285] ACPI: ACPI bus type pnp unregistered [ 0.174291] PnPBIOS: Disabled by ACPI PNP [ 0.213051] Switching to clocksource acpi_pm [ 0.213085] PCI: max bus depth: 1 pci_try_num: 2 [ 0.213123] pci 0000:00:1f.1: BAR 5: assigned [mem 0x40000000-0x400003ff] [ 0.213134] pci 0000:01:00.0: BAR 6: assigned [mem 0xc0120000-0xc013ffff pref] [ 0.213138] pci 0000:00:01.0: PCI bridge to [bus 01-01] [ 0.213144] pci 0000:00:01.0: bridge window [mem 0xc0100000-0xc0ffffff] [ 0.213150] pci 0000:00:01.0: bridge window [mem 0xe0000000-0xe1ffffff pref] [ 0.213158] pci 0000:00:1e.0: PCI bridge to [bus 02-02] [ 0.213162] pci 0000:00:1e.0: bridge window [io 0x2000-0x2fff] [ 0.213169] pci 0000:00:1e.0: bridge window [mem 0xc1000000-0xc10fffff] [ 0.213198] pci 0000:00:1e.0: setting latency timer to 64 [ 0.213203] pci_bus 0000:00: resource 0 [io 0x0000-0xffff] [ 0.213207] pci_bus 0000:00: resource 1 [mem 0x00000000-0xfffffffff] [ 0.213210] pci_bus 0000:01: resource 1 [mem 0xc0100000-0xc0ffffff] [ 0.213214] pci_bus 0000:01: resource 2 [mem 0xe0000000-0xe1ffffff pref] [ 0.213218] pci_bus 0000:02: resource 0 [io 0x2000-0x2fff] [ 0.213221] pci_bus 0000:02: resource 1 [mem 0xc1000000-0xc10fffff] [ 0.213224] pci_bus 0000:02: resource 4 [io 0x0000-0xffff] [ 0.213228] pci_bus 0000:02: resource 5 [mem 0x00000000-0xfffffffff] [ 0.213308] NET: Registered protocol family 2 [ 0.213408] IP route cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.213880] TCP established hash table entries: 131072 (order: 8, 1048576 bytes) [ 0.215320] TCP bind hash table entries: 65536 (order: 7, 524288 bytes) [ 0.215320] TCP: Hash tables configured (established 131072 bind 65536) [ 0.215320] TCP reno registered [ 0.215330] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 0.215365] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 0.215595] NET: Registered protocol family 1 [ 0.215912] pci 0000:01:00.0: Boot video device [ 0.215928] pci 0000:02:08.0: Firmware left e100 interrupts enabled; disabling [ 0.215935] PCI: CLS 32 bytes, default 64 [ 0.216076] Unpacking initramfs... [ 0.316790] Freeing initrd memory: 2600k freed [ 0.321694] Simple Boot Flag at 0x6c set to 0x1 [ 0.322312] audit: initializing netlink socket (disabled) [ 0.322336] type=2000 audit(1406010676.320:1): initialized [ 0.337880] highmem bounce pool size: 64 pages [ 0.337889] HugeTLB registered 2 MB page size, pre-allocated 0 pages [ 0.338343] VFS: Disk quotas dquot_6.5.2 [ 0.338382] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 0.338474] msgmni has been set to 1751 [ 0.338702] alg: No test for stdrng (krng) [ 0.338747] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253) [ 0.338753] io scheduler noop registered [ 0.338756] io scheduler deadline registered [ 0.338768] io scheduler cfq registered (default) [ 0.338913] pci_hotplug: PCI Hot Plug PCI Core version: 0.5 [ 0.338948] pciehp: PCI Express Hot Plug Controller Driver version: 0.4 [ 0.338952] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5 [ 0.339300] ERST: Table is not found! [ 0.339304] GHES: HEST is not enabled! [ 0.339324] isapnp: Scanning for PnP cards... [ 0.693290] isapnp: No Plug & Play device found [ 0.693404] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled [ 0.693997] Linux agpgart interface v0.103 [ 0.694151] agpgart-intel 0000:00:00.0: Intel 845G Chipset [ 0.705689] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xd0000000 [ 0.705916] i8042: PNP: PS/2 Controller [PNP0303:KBC,PNP0f13:PSM] at 0x60,0x64 irq 1,12 [ 0.707737] serio: i8042 KBD port at 0x60,0x64 irq 1 [ 0.707749] serio: i8042 AUX port at 0x60,0x64 irq 12 [ 0.707929] mousedev: PS/2 mouse device common for all mice [ 0.707996] rtc_cmos 00:04: RTC can wake from S4 [ 0.708152] rtc_cmos 00:04: rtc core: registered rtc_cmos as rtc0 [ 0.708178] rtc0: alarms up to one month, y3k, 114 bytes nvram [ 0.708197] cpuidle: using governor ladder [ 0.708200] cpuidle: using governor menu [ 0.708495] TCP cubic registered [ 0.708527] NET: Registered protocol family 10 [ 0.709183] Mobile IPv6 [ 0.709187] NET: Registered protocol family 17 [ 0.709193] Registering the dns_resolver key type [ 0.709236] Using IPI No-Shortcut mode [ 0.709391] PM: Hibernation image not present or could not be loaded. [ 0.709407] registered taskstats version 1 [ 0.709831] rtc_cmos 00:04: setting system clock to 2014-07-22 06:31:17 UTC (1406010677) [ 0.709896] Initializing network drop monitor service [ 0.710051] Freeing unused kernel memory: 420k freed [ 0.710730] Write protecting the kernel text: 2860k [ 0.710771] Write protecting the kernel read-only data: 1084k [ 0.740421] udevd[44]: starting version 175 [ 0.852752] SCSI subsystem initialized [ 0.916322] thermal LNXTHERM:00: registered as thermal_zone0 [ 0.916327] ACPI: Thermal Zone [THM0] (64 C) [ 0.919393] libata version 3.00 loaded. [ 0.920218] ata_piix 0000:00:1f.1: version 2.13 [ 0.920238] ata_piix 0000:00:1f.1: enabling device (0005 -> 0007) [ 0.920328] ata_piix 0000:00:1f.1: setting latency timer to 64 [ 0.923417] scsi0 : ata_piix [ 0.930441] scsi1 : ata_piix [ 0.931400] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0x1860 irq 14 [ 0.931405] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0x1868 irq 15 [ 1.096696] ata2.00: ATAPI: OEM CD-ROM F522E, 1.04, max UDMA/33 [ 1.097219] ata1.00: ATA-5: FUJITSU MPF3102AT, 0028, max UDMA/66 [ 1.097224] ata1.00: 20015856 sectors, multi 16: LBA [ 1.104339] ata2.00: configured for UDMA/33 [ 1.112696] ata1.00: configured for UDMA/66 [ 1.112876] scsi 0:0:0:0: Direct-Access ATA FUJITSU MPF3102A 0028 PQ: 0 ANSI: 5 [ 1.113705] scsi 1:0:0:0: CD-ROM OEM CD-ROM F522E 1.04 PQ: 0 ANSI: 5 [ 1.129727] sd 0:0:0:0: [sda] 20015856 512-byte logical blocks: (10.2 GB/9.54 GiB) [ 1.129805] sd 0:0:0:0: [sda] Write Protect is off [ 1.129810] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00 [ 1.129843] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 1.176047] sda: sda1 sda2 < sda5 sda6 > [ 1.176844] sd 0:0:0:0: [sda] Attached SCSI disk [ 1.336038] Refined TSC clocksource calibration: 2657.812 MHz. [ 1.336069] Switching to clocksource tsc [ 2.361494] PM: Starting manual resume from disk [ 2.361501] PM: Hibernation image partition 8:5 present [ 2.361504] PM: Looking for hibernation image. [ 2.375923] PM: Image not found (code -22) [ 2.375927] PM: Hibernation image not present or could not be loaded. [ 2.447335] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null) [ 5.099942] udevd[296]: starting version 175 [ 5.916879] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/PNP0C0C:00/input/input0 [ 5.916890] ACPI: Power Button [PWRB] [ 5.916981] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1 [ 5.916987] ACPI: Power Button [PWRF] [ 6.022356] usbcore: registered new interface driver usbfs [ 6.022398] usbcore: registered new interface driver hub [ 6.025809] usbcore: registered new device driver usb [ 6.041173] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 6.041248] ehci_hcd 0000:00:1d.7: setting latency timer to 64 [ 6.041254] ehci_hcd 0000:00:1d.7: EHCI Host Controller [ 6.041296] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 1 [ 6.045228] ehci_hcd 0000:00:1d.7: cache line size of 32 is not supported [ 6.053901] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xc0000000 [ 6.092071] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00 [ 6.092150] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 6.092154] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 6.092158] usb usb1: Product: EHCI Host Controller [ 6.092161] usb usb1: Manufacturer: Linux 3.2.0-4-686-pae ehci_hcd [ 6.092164] usb usb1: SerialNumber: 0000:00:1d.7 [ 6.092373] hub 1-0:1.0: USB hub found [ 6.092381] hub 1-0:1.0: 6 ports detected [ 6.092709] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4 [ 6.360475] uhci_hcd: USB Universal Host Controller Interface driver [ 6.360566] uhci_hcd 0000:00:1d.0: setting latency timer to 64 [ 6.360572] uhci_hcd 0000:00:1d.0: UHCI Host Controller [ 6.360595] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2 [ 6.360646] uhci_hcd 0000:00:1d.0: irq 16, io base 0x00001800 [ 6.360712] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001 [ 6.360717] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 6.360720] usb usb2: Product: UHCI Host Controller [ 6.360723] usb usb2: Manufacturer: Linux 3.2.0-4-686-pae uhci_hcd [ 6.360726] usb usb2: SerialNumber: 0000:00:1d.0 [ 6.363147] hub 2-0:1.0: USB hub found [ 6.363158] hub 2-0:1.0: 2 ports detected [ 6.363289] uhci_hcd 0000:00:1d.1: setting latency timer to 64 [ 6.363294] uhci_hcd 0000:00:1d.1: UHCI Host Controller [ 6.363307] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3 [ 6.363357] uhci_hcd 0000:00:1d.1: irq 19, io base 0x00001820 [ 6.363407] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001 [ 6.363411] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 6.363415] usb usb3: Product: UHCI Host Controller [ 6.363418] usb usb3: Manufacturer: Linux 3.2.0-4-686-pae uhci_hcd [ 6.363421] usb usb3: SerialNumber: 0000:00:1d.1 [ 6.363745] hub 3-0:1.0: USB hub found [ 6.363752] hub 3-0:1.0: 2 ports detected [ 6.363859] uhci_hcd 0000:00:1d.2: setting latency timer to 64 [ 6.363864] uhci_hcd 0000:00:1d.2: UHCI Host Controller [ 6.363875] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4 [ 6.363915] uhci_hcd 0000:00:1d.2: irq 18, io base 0x00001840 [ 6.363971] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001 [ 6.363976] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 6.363979] usb usb4: Product: UHCI Host Controller [ 6.363982] usb usb4: Manufacturer: Linux 3.2.0-4-686-pae uhci_hcd [ 6.363985] usb usb4: SerialNumber: 0000:00:1d.2 [ 6.366176] hub 4-0:1.0: USB hub found [ 6.366187] hub 4-0:1.0: 2 ports detected [ 6.672034] usb 3-1: new low-speed USB device number 2 using uhci_hcd [ 6.848065] usb 3-1: New USB device found, idVendor=049f, idProduct=0070 [ 6.848072] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 6.848075] usb 3-1: Product: USB Keyboard [ 6.848078] usb 3-1: Manufacturer: Compaq [ 6.848831] sr0: scsi3-mmc drive: 0x/48x cd/rw xa/form2 cdda tray [ 6.848838] cdrom: Uniform CD-ROM driver Revision: 3.20 [ 6.849556] sr 1:0:0:0: Attached scsi CD-ROM sr0 [ 6.891389] snd_intel8x0 0000:00:1f.5: setting latency timer to 64 [ 6.924535] Driver for 1-wire Dallas network protocol. [ 6.936483] sd 0:0:0:0: Attached scsi generic sg0 type 0 [ 6.936652] sr 1:0:0:0: Attached scsi generic sg1 type 5 [ 6.960101] usb 4-1: new low-speed USB device number 2 using uhci_hcd [ 6.967784] FDC 0 is a post-1991 82077 [ 6.968879] input: PC Speaker as /devices/platform/pcspkr/input/input2 [ 7.016400] parport_pc 00:0c: reported by Plug and Play ACPI [ 7.016460] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE] [ 7.023551] intel_rng: Firmware space is locked read-only. If you can't or [ 7.023553] intel_rng: don't want to disable this in firmware setup, and if [ 7.023555] intel_rng: you are certain that your system has a functional [ 7.023557] intel_rng: RNG, try using the 'no_fwh_detect' option. [ 7.033335] e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI [ 7.033340] e100: Copyright(c) 1999-2006 Intel Corporation [ 7.058827] e100 0000:02:08.0: eth0: addr 0xc1000000, irq 20, MAC addr 00:09:6b:8f:1a:9c [ 7.115759] iTCO_vendor_support: vendor-support=0 [ 7.119187] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07 [ 7.119301] iTCO_wdt: Found a ICH4 TCO device (Version=1, TCOBASE=0x1060) [ 7.120950] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0) [ 7.135848] usb 4-1: New USB device found, idVendor=0c45, idProduct=7401 [ 7.135855] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 7.135858] usb 4-1: Product: TEMPerV1.4 [ 7.135861] usb 4-1: Manufacturer: RDing [ 7.228449] matrox_w1 0000:01:00.0: Matrox G400 GPIO transport layer for 1-wire. [ 7.312054] intel8x0_measure_ac97_clock: measured 53453 usecs (2576 samples) [ 7.312059] intel8x0: clocking to 48000 [ 7.313530] ACPI: resource 0000:00:1f.3 [io 0x1880-0x189f] conflicts with ACPI region SMBR [io 0x1880-0x1887] [ 7.313535] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver [ 8.174654] input: ImPS/2 Generic Wheel Mouse as /devices/platform/i8042/serio1/input/input3 [ 8.364755] input: Compaq USB Keyboard as /devices/pci0000:00/0000:00:1d.1/usb3/3-1/3-1:1.0/input/input4 [ 8.365017] generic-usb 0003:049F:0070.0001: input,hidraw0: USB HID v1.10 Keyboard [Compaq USB Keyboard] on usb-0000:00:1d.1-1/input0 [ 8.400327] input: Compaq USB Keyboard as /devices/pci0000:00/0000:00:1d.1/usb3/3-1/3-1:1.1/input/input5 [ 8.401030] generic-usb 0003:049F:0070.0002: input,hiddev0,hidraw1: USB HID v1.10 Device [Compaq USB Keyboard] on usb-0000:00:1d.1-1/input1 [ 8.417152] input: RDing TEMPerV1.4 as /devices/pci0000:00/0000:00:1d.2/usb4/4-1/4-1:1.0/input/input6 [ 8.418646] generic-usb 0003:0C45:7401.0003: input,hidraw2: USB HID v1.10 Keyboard [RDing TEMPerV1.4] on usb-0000:00:1d.2-1/input0 [ 8.432415] generic-usb 0003:0C45:7401.0004: hiddev0,hidraw3: USB HID v1.10 Device [RDing TEMPerV1.4] on usb-0000:00:1d.2-1/input1 [ 8.432454] usbcore: registered new interface driver usbhid [ 8.432457] usbhid: USB HID core driver [ 10.250263] Adding 999420k swap on /dev/sda5. Priority:-1 extents:1 across:999420k [ 10.278507] EXT4-fs (sda1): re-mounted. Opts: (null) [ 10.809674] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro [ 10.981497] loop: module loaded [ 12.766138] EXT4-fs (sda6): mounted filesystem with ordered data mode. Opts: (null) [ 14.376696] RPC: Registered named UNIX socket transport module. [ 14.376701] RPC: Registered udp transport module. [ 14.376704] RPC: Registered tcp transport module. [ 14.376707] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 14.451255] FS-Cache: Loaded [ 14.686128] FS-Cache: Netfs 'nfs' registered for caching [ 14.727516] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). [ 15.045148] ADDRCONF(NETDEV_UP): eth0: link is not ready [ 15.048169] e100 0000:02:08.0: eth0: NIC Link is Up 100 Mbps Half Duplex [ 15.048433] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ 21.212217] Bluetooth: Core ver 2.16 [ 21.212285] NET: Registered protocol family 31 [ 21.212288] Bluetooth: HCI device and connection manager initialized [ 21.212293] Bluetooth: HCI socket layer initialized [ 21.212296] Bluetooth: L2CAP socket layer initialized [ 21.212962] Bluetooth: SCO socket layer initialized [ 21.271725] Bluetooth: RFCOMM TTY layer initialized [ 21.271734] Bluetooth: RFCOMM socket layer initialized [ 21.271738] Bluetooth: RFCOMM ver 1.11 [ 21.639403] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 21.639409] Bluetooth: BNEP filters: protocol multicast [ 25.872016] eth0: no IPv6 routers present [ 30.445655] [drm] Initialized drm 1.1.0 20060810 [ 30.513347] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010). [ 30.513353] [drm] No driver support for vblank timestamp query. [ 30.513359] [drm] Initialized mga 3.2.1 20051102 for 0000:01:00.0 on minor 0 [ 30.514771] agpgart-intel 0000:00:00.0: AGP 2.0 bridge [ 30.514795] agpgart-intel 0000:00:00.0: putting AGP V2 device into 1x mode [ 30.514831] matrox_w1 0000:01:00.0: putting AGP V2 device into 1x mode [ 30.552036] [drm] Initialized card for AGP DMA. [ 31.033635] platform mga_warp.0: firmware: agent loaded matrox/g400_warp.fw into memory [ 1464.360053] usb 4-1: USB disconnect, device number 2 [ 1478.520021] usb 4-1: new low-speed USB device number 3 using uhci_hcd [ 1478.695963] usb 4-1: New USB device found, idVendor=0c45, idProduct=7401 [ 1478.695969] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 1478.695973] usb 4-1: Product: TEMPerV1.4 [ 1478.695976] usb 4-1: Manufacturer: RDing [ 1478.714467] input: RDing TEMPerV1.4 as /devices/pci0000:00/0000:00:1d.2/usb4/4-1/4-1:1.0/input/input7 [ 1478.714937] generic-usb 0003:0C45:7401.0005: input,hidraw2: USB HID v1.10 Keyboard [RDing TEMPerV1.4] on usb-0000:00:1d.2-1/input0 [ 1478.729576] generic-usb 0003:0C45:7401.0006: hiddev0,hidraw3: USB HID v1.10 Device [RDing TEMPerV1.4] on usb-0000:00:1d.2-1/input1 [ 2549.772261] i2c /dev entries driver
Auriez-vous des conseils/idées pour éclairer ma lanterne ?
Merci d’avance.
je suppose que ut as lu ceci
packages.debian.org/sid/lm-sensors
doc.ubuntu-fr.org//lm-sensors?redirect=1
dans la sortie de dmesg, j’ai du mal à retrouver le usbiID complet de ton appareil.
Peux tu STP faire un
update-usbids lsusb -vv
Qu’indique la commande
Specs
[quote] 3. FUNCTION&FEATURE
New:
*Die-casting electroplating shell, superb waterproof, agile induction
*gold USB
*measure rang: -55~+125C/ -67~257F
*sensor is LM75
  • fixed installation holes[/quote]
Nom du module du noyau : lm75.
Extrait des sources du noyau, hwmon/Kconfig à propos de LM75
[code]
config SENSORS_LM75
tristate "National Semiconductor LM75 and compatibles"
depends on I2C
depends on THERMAL || !THERMAL_OF
help
If you say yes here you get support for one common type of
temperature sensor chip, with models including:
	- Analog Devices ADT75
	- Dallas Semiconductor DS75, DS1775 and DS7505
	- Global Mixed-mode Technology (GMT) G751
	- Maxim MAX6625 and MAX6626
	- Microchip MCP980x
	- National Semiconductor LM75, LM75A
	- NXP's LM75A
	- ST Microelectronics STDS75
	- TelCom (now Microchip) TCN75
	- Texas Instruments TMP100, TMP101, TMP105, TMP75, TMP175,
	  TMP275
  This driver supports driver model based binding through board
  specific I2C device tables.
  It also supports the "legacy" style of driver binding.  To use
  that with some chips which don't replicate LM75 quirks exactly,
  you may need the "force" module parameter.
  This driver can also be built as a module.  If so, the module
  will be called lm75.[/code]
Documentation/hwmon/userspace-tools
[quote]
Introduction
Most mainboards have sensor chips to monitor system health (like temperatures,
voltages, fans speed). They are often connected through an I2C bus, but some
are also connected directly through the ISA bus.
The kernel drivers make the data from the sensor chips available in the /sys
virtual filesystem. Userspace tools are then used to display the measured
values or configure the chips in a more friendly manner.
Lm-sensors
Core set of utilities that will allow you to obtain health information,
setup monitoring limits etc. You can get them on their homepage
lm-sensors.org/ or as a package from your Linux distribution.
If from website:
Get lm-sensors from project web site. Please note, you need only userspace
part, so compile with “make user” and install with “make user_install”.
General hints to get things working:
  1. get lm-sensors userspace utils
  2. compile all drivers in I2C and Hardware Monitoring sections as modules
    in your kernel
  3. run sensors-detect script, it will tell you what modules you need to load.
  4. load them and run “sensors” command, you should see some results.
  5. fix sensors.conf, labels, limits, fan divisors
  6. if any more problems consult FAQ, or documentation
Other utilities
If you want some graphical indicators of system health look for applications
like: gkrellm, ksensors, xsensors, wmtemp, wmsensors, wmgtemp, ksysguardd,
hardware-monitor
If you are server administrator you can try snmpd or mrtgutils.[/quote]
Retenons ces pistes :
  • The kernel drivers make the data from the sensor chips available in the /sys virtual filesystem
    Sonder /sys .
  • run sensors-detect script, it will tell you what modules you need to load.
    Installer lm-sensors puis lancer le script [mono]sensors-detect[/mono] pour la détection.
  • look for applications like: gkrellm, ksensors, xsensors, wmtemp, wmsensors, wmgtemp, ksysguard …
    Installe un de ces programmes comme xsensors.
Sous réserve que le constructeur n’ait pas interposé un autre chip entre le LM75 et l’extérieur …
[quote=“piratebab”]Bonjour,
update-usbids lsusb -vv[/quote]
root@Debian:~# update-usbids --2014-07-22 11:34:42-- http://www.linux-usb.org/usb.ids Résolution de www.linux-usb.org (www.linux-usb.org)... 216.34.181.97 Connexion vers www.linux-usb.org (www.linux-usb.org)|216.34.181.97|:80...échec: Connexion refusée. update-usbids: download failed
Je pense que mon proxy bloque.
Mais j’ai téléchargé le fichier usb.ids (que dois-je/puis-je en faire ?)
[code]root@Debian:~# lsusb -vv
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0 Unused
bDeviceProtocol 0 Full speed (or root) hub
bMaxPacketSize0 64
idVendor 0x1d6b Linux Foundation
idProduct 0x0002 2.0 root hub
bcdDevice 3.02
iManufacturer 3 Linux 3.2.0-4-686-pae ehci_hcd
iProduct 2 EHCI Host Controller
iSerial 1 0000:00:1d.7
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 25
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 9 Hub
bInterfaceSubClass 0 Unused
bInterfaceProtocol 0 Full speed (or root) hub
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0004 1x 4 bytes
bInterval 12
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 6
wHubCharacteristic 0x000a
No power switching (usb 1.0)
Per-port overcurrent protection
bPwrOn2PwrGood 10 * 2 milli seconds
bHubContrCurrent 0 milli Ampere
DeviceRemovable 0x00
PortPwrCtrlMask 0xff
Hub Port Status:
Port 1: 0000.0100 power
Port 2: 0000.0100 power
Port 3: 0000.0100 power
Port 4: 0000.0100 power
Port 5: 0000.0100 power
Port 6: 0000.0100 power
Device Status: 0x0001
Self Powered
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceClass 9 Hub
bMaxPacketSize0 64
idProduct 0x0001 1.1 root hub
bcdDevice 3.02
iManufacturer 3 Linux 3.2.0-4-686-pae uhci_hcd
iProduct 2 UHCI Host Controller
iSerial 1 0000:00:1d.0
bLength 9
bDescriptorType 2
wTotalLength 25
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0002 1x 2 bytes
bInterval 255
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 2
bPwrOn2PwrGood 1 * 2 milli seconds
Hub Port Status:
Self Powered
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceClass 9 Hub
bMaxPacketSize0 64
bcdDevice 3.02
iSerial 1 0000:00:1d.1
bLength 9
bDescriptorType 2
wTotalLength 25
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 255
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 2
Hub Port Status:
Port 1: 0000.0303 lowspeed power enable connect
Port 2: 0000.0303 lowspeed power enable connect
Self Powered
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceClass 9 Hub
bMaxPacketSize0 64
bcdDevice 3.02
iSerial 1 0000:00:1d.2
bLength 9
bDescriptorType 2
wTotalLength 25
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 255
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 2
Hub Port Status:
Self Powered
Bus 003 Device 002: ID 049f:0070 Compaq Computer Corp.
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 8
idVendor 0x049f Compaq Computer Corp.
idProduct 0x0070
bcdDevice 1.00
iManufacturer 1 Compaq
iProduct 2 USB Keyboard
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 59
bNumInterfaces 2
iConfiguration 0
bmAttributes 0xa0
(Bus Powered)
Remote Wakeup
MaxPower 100mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 3 Human Interface Device
bInterfaceSubClass 1 Boot Interface Subclass
bInterfaceProtocol 1 Keyboard
iInterface 0
HID Device Descriptor:
bLength 9
bDescriptorType 33
bcdHID 1.10
bCountryCode 33 US
bNumDescriptors 1
bDescriptorType 34 Report
wDescriptorLength 65
Report Descriptors:
** UNAVAILABLE **
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0008 1x 8 bytes
bInterval 10
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 1
bInterfaceSubClass 0 No Subclass
bInterfaceProtocol 0 None
iInterface 0
bLength 9
bDescriptorType 33
bcdHID 1.10
bCountryCode 33 US
bNumDescriptors 1
wDescriptorLength 118
Report Descriptors:
** UNAVAILABLE **
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 10
Device Status: 0x0000
(Bus Powered)
Bus 003 Device 003: ID 0c45:7401 Microdia
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 8
idVendor 0x0c45 Microdia
idProduct 0x7401
bcdDevice 0.01
iManufacturer 1 RDing
iProduct 2 TEMPerV1.4
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 59
bNumInterfaces 2
iConfiguration 0
bmAttributes 0xa0
(Bus Powered)
Remote Wakeup
MaxPower 100mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 9
bDescriptorType 33
bcdHID 1.10
bCountryCode 0 Not supported
bNumDescriptors 1
Report Descriptors:
** UNAVAILABLE **
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 10
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 1
bInterfaceProtocol 2 Mouse
iInterface 0
bLength 9
bDescriptorType 33
bcdHID 1.10
bNumDescriptors 1
wDescriptorLength 41
Report Descriptors:
** UNAVAILABLE **
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 10
(Bus Powered)[/code]
root@Debian:~# lsusb -t /: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=uhci_hcd/2p, 12M /: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=uhci_hcd/2p, 12M |__ Port 1: Dev 2, If 0, Class=HID, Driver=usbhid, 1.5M |__ Port 1: Dev 2, If 1, Class=HID, Driver=usbhid, 1.5M |__ Port 2: Dev 3, If 0, Class=HID, Driver=usbhid, 1.5M |__ Port 2: Dev 3, If 1, Class=HID, Driver=usbhid, 1.5M /: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=uhci_hcd/2p, 12M /: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ehci_hcd/6p, 480M
Il s’agit du 0c45:7401, qui est reconnu, pas besoin donc de mettre à jour tes usb ids.
A partir de là, tu peux faire des recherches, et tu tombes par exemple sur:
penguinsunbound.com/User:goeko/Temp_Sensor
ou ça
github.com/vzaliva/temper-python
Je vais tester tout ça puis je vous dis.
Je n’ai pas réussi en utilisant ces deux liens.
Mais je viens de réussir avec celui-ci:
TEMPER USB 1.1.2
Maintenant je vais essayer de l’intégrer à ma barre de tâches sous LXDE.
