[Résolu]installation et configuration carte wifi Ralink
Bonsoir!
Je suis depuis peu sous debian et je ne parviens pas à installer et à configurer ma carte wi-fi!
J’ai une debian etch
en tapant “uname -a”, j’obtiens ceci “2.6.18-5-686 #1 SMP Fri Jun 1 00:47:00 UTC 2007 i686 GNU/Linux”
en tapant “lspci” j’obtiens : “00:00.0 Host bridge: Intel Corporation 945G/GZ/P/PL Express Memory Controller Hub (rev 02)
00:01.0 PCI bridge: Intel Corporation 945G/GZ/P/PL Express PCI Express Root Port (rev 02)
00:1b.0 Audio device: Intel Corporation 82801G (ICH7 Family) High Definition Audio Controller (rev 01)
00:1c.0 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 1 (rev 01)
00:1c.1 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 2 (rev 01)
00:1d.0 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI #1 (rev 01)
00:1d.1 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI #2 (rev 01)
00:1d.2 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI #3 (rev 01)
00:1d.3 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI #4 (rev 01)
00:1d.7 USB Controller: Intel Corporation 82801G (ICH7 Family) USB2 EHCI Controller (rev 01)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev e1)
00:1f.0 ISA bridge: Intel Corporation 82801GB/GR (ICH7 Family) LPC Interface Bridge (rev 01)
00:1f.1 IDE interface: Intel Corporation 82801G (ICH7 Family) IDE Controller (rev 01)
00:1f.2 IDE interface: Intel Corporation 82801GB/GR/GH (ICH7 Family) Serial ATA Storage Controller IDE (rev 01)
00:1f.3 SMBus: Intel Corporation 82801G (ICH7 Family) SMBus Controller (rev 01)
01:02.0 Network controller: RaLink RT2561/RT61 rev B 802.11g
02:00.0 Ethernet controller: Unknown device 1969:2048 (rev a0)
04:00.0 VGA compatible controller: nVidia Corporation Unknown device 0402 (rev a1)”
et en tapant “ifconfig”, j’obtiens : “lo Lien encap:Boucle locale
RX packets:74 errors:0 dropped:0 overruns:0 frame:0
TX packets:74 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:5140 (5.0 KiB) TX bytes:5140 (5.0 KiB)”
De plus, je possède un cd contenant les pilotes d’installation pour windows mais aussi pour linux ayant pour nom: “PCI PCM Linux_STA_Drv1.0.3.0.tar”
Je ne sais pas du tout comment m’y prendre pour installer et pour paramétrer ma carte,
Merci d’avance pour voter aide.
Utilise les pilotes de serialmonkey, ils fonctionnent très bien (lis le readme):
rt2x00.serialmonkey.com/rt61-cvs-daily.tar.gz
merci pour ta réponse,
alors j’ai suivi ce que tu m’a dit mais…
il ne veut pas me le compiler:
“amroth@amrothdesk:~/Desktop/rt61-cvs-2007092816/Module$ make
make: *** /lib/modules/2.6.18-5-686/build: Aucun fichier ou répertoire de ce type. Arrêt.
rt61.ko failed to build!
make: *** [module] Erreur 1”
Merci a toi!!!
Les paquets marchent
j’ai le meme problème, et je n’ai pas compris ta phrase les paquets marchent!!!
Merci d’expliciter.
Salut, j’ai tout simplement voulu dire que les paquets étaient les bons pour ma carte.
J’ai simplement installé les paquets “linux-headers” (par l’intermédiaire de la synaptic ou apt-get en ligne de commande) pour la version de mon noyau afin de créer les entetes de mon noyau (d’après ce que j’ai compris…). Ensuite tu peux compiler sans problèmes tes paquets!!!
En espérant que cela t’aide et que je n’ai pas dit de bétises!
