Bonsoir à tous,
Voilà je tente d’installer KDE4 mais je rencontre des problèmes de dépendances qui empêchent toute intallation:
j’ai ajouté ceci dans mon sources.list:
[code]## Experimental
#deb http://ftp.fr.debian.org/debian/ experimental main contrib non-free
#deb-src http://ftp.fr.debian.org/debian/ experimental main contrib non-free
Kde4
deb http://kde4.debian.net/ lenny main
j’avais essayé d’abord avec les sources experimental activées puis avec :
Mais çà ne fonctionnait pas.
J’ai alors activé la source pour les backports KD4 et voilà les erreurs:
[code]Reading state information… Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
Since you only requested a single operation it is extremely likely that
the package is simply not installable and a bug report against
that package should be filed.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
kde4: Depends: kde4-minimal (>= 1) but it is not going to be installed
Depends: kdeadmin (>= 4:4.1.0) but 4:3.5.9-2 is to be installed
Depends: kdeartwork (>= 4:4.1.0) but 4:3.5.9-3 is to be installed
Depends: kdegraphics (>= 4:4.1.0) but 4:3.5.9-3 is to be installed
Depends: kdeedu (>= 4:4.1.0) but 4:3.5.9-2 is to be installed
Depends: kdegames (>= 4:4.1.0) but 4:3.5.9-2 is to be installed
Depends: kdemultimedia (>= 4:4.1.0) but 4:3.5.9-2 is to be installed
Depends: kdenetwork (>= 4:4.1.0) but 4:3.5.9-4 is to be installed
Depends: kdeutils (>= 4:4.1.0) but 4:3.5.9-2 is to be installed
Depends: kdepim (>= 4:4.1.0) but 4:3.5.9-5 is to be installed
Depends: kdeplasma-addons (>= 4:4.1.0) but it is not going to be install
ed
Recommends: kdeaccessibility (>= 4:4.1.0) but 4:3.5.9-2 is to be install
ed
Recommends: kdesdk (>= 4:4.1.0) but it is not going to be installed
Recommends: kdetoys (>= 4:4.1.0) but 4:3.5.9-2 is to be installed
Recommends: kdewebdev (>= 4:4.1.0) but 4:3.5.9-3 is to be installed
E: Broken packages
Que dois-je faire?
Je suis en testing avec les sources SID dans mon sources.list et un fichier preferences donnant la priorité à Lenny.
Merci par avance de votre aide
