Pour te repondre kna voila ce que cela donne.
[code] iwconfig
lo no wireless extensions.
eth0 no wireless extensions.
irda0 no wireless extensions.
wmaster0 no wireless extensions.
wlan0 IEEE 802.11 ESSID:""
Mode:Managed Frequency:2.412 GHz Access Point: Not-Associated
Tx-Power=27 dBm
Retry min limit:7 RTS thr:off Fragment thr=2352 B
Encryption key:off
Link Quality:0 Signal level:0 Noise level:0
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
puis
iwlist scan
[code] iwlist scan
lo Interface doesn’t support scanning.
eth0 Interface doesn’t support scanning.
irda0 Interface doesn’t support scanning.
wmaster0 Interface doesn’t support scanning.
wlan0 Scan completed :
Cell 01 - Address: 00:16:CF:1D:A6:F2
ESSID:"WANADOO"
Mode:Master
Channel:1
Frequency:2.412 GHz (Channel 1)
Quality=75/100 Signal level=-43 dBm Noise level=-91 dBm
Encryption key:on
Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 18 Mb/s
24 Mb/s; 36 Mb/s; 54 Mb/s; 6 Mb/s; 9 Mb/s
12 Mb/s; 48 Mb/s
Extra:tsf=0000000c6a31318a
ath_pci 202104 0
wlan 193040 1 ath_pci
ath_hal 300672 1 ath_pci
ath5k 87264 0
mac80211 139680 1 ath5k
cfg80211 21576 2 ath5k,mac80211
voila apprement ath5k est present.
Comment puis je le retirer, s’il faut le retirer bien sur.
