Non autant pour moi, mailman fonctionne bien.
Il n’y a que l’interface web qui merdouille.
Dans le log apache, j’ai ça :
78.xxx.www.zzz - - [22/Mar/2016:22:13:08 +0100] "GET /listinfo HTTP/1.1" 404 503 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:45.0) Gecko/20100101 Firefox/45.0"
Voici mon fichier mm_cfg.py :
# -*- python -*-
# Copyright (C) 1998,1999,2000 by the Free Software Foundation, Inc.
# This program is free software; you can redistribute it and/or
# modify it under the terms of the GNU General Public License
# as published by the Free Software Foundation; either version 2
# of the License, or (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program; if not, write to the Free Software
# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA
# 02110-1301 USA
"""This is the module which takes your site-specific settings.
From a raw distribution it should be copied to mm_cfg.py. If you
already have an mm_cfg.py, be careful to add in only the new settings
you want. The complete set of distributed defaults, with annotation,
are in ./Defaults. In mm_cfg, override only those you want to
change, after the
from Defaults import *
line (see below).
Note that these are just default settings - many can be overridden via the
admin and user interfaces on a per-list or per-user basis.
Note also that some of the settings are resolved against the active list
setting by using the value as a format string against the
list-instance-object's dictionary - see the distributed value of
DEFAULT_MSG_FOOTER for an example."""
# Here's where we get the distributed defaults. #
# Put YOUR site-specific configuration below, in mm_cfg.py . #
# See Defaults.py for explanations of the values. #
# The name of the list Mailman uses to send password reminders
# and similar. Don't change if you want mailman-owner to be
# a valid local part.
MAILMAN_SITE_LIST = 'mailman'
# If you change these, you have to configure your http server
# accordingly (Alias and ScriptAlias directives in most httpds)
#DEFAULT_URL_PATTERN = 'http://%s/cgi-bin/mailman/'
DEFAULT_URL_PATTERN = 'http://%s/'
IMAGE_LOGOS = '/images/mailman/'
# Default domain for email addresses of newly created MLs
DEFAULT_EMAIL_HOST = 'listes.np11.org'
# Default host for web interface of newly created MLs
DEFAULT_URL_HOST = 'listes.np11.org'
# Required when setting any of its arguments.
add_virtualhost(DEFAULT_URL_HOST, DEFAULT_EMAIL_HOST)
# The default language for this server.
DEFAULT_SERVER_LANGUAGE = 'fr'
# Iirc this was used in pre 2.1, leave it for now
USE_ENVELOPE_SENDER = 0 # Still used?
# Unset send_reminders on newly created lists
DEFAULT_SEND_REMINDERS = 0
# Uncomment this if you configured your MTA such that it
# automatically recognizes newly created lists.
# (see /usr/share/doc/mailman/README.Exim4.Debian or
# /usr/share/mailman/postfix-to-mailman.py)
# MTA=None # Misnomer, suppresses alias output on newlist
# Uncomment if you use Postfix virtual domains (but not
# postfix-to-mailman.py), but be sure to see
# /usr/share/doc/mailman/README.Debian first.
MTA='Postfix'
# Uncomment if you want to filter mail with SpamAssassin. For
# more information please visit this website:
# http://www.jamesh.id.au/articles/mailman-spamassassin/
# GLOBAL_PIPELINE.insert(1, 'SpamAssassin')
# Note - if you're looking for something that is imported from mm_cfg, but you
# didn't find it above, it's probably in /usr/lib/mailman/Mailman/Defaults.py.
Voici mon fichier /etc/apache2/sites-enabled/mailman :
# Sample configuration for Debian mailman with Apache
# We can find mailman here:
#ScriptAlias /cgi-bin/mailman/ /usr/lib/cgi-bin/mailman/
# And the public archives:
Alias /pipermail/ /var/lib/mailman/archives/public/
# Logos:
Alias /images/mailman/ /usr/share/images/mailman/
# Use this if you don't want the "cgi-bin" component in your URL:
# In case you want to access mailman through a shorter URL you should enable
# this:
#ScriptAlias /mailman/ /usr/lib/cgi-bin/mailman/
ScriptAlias / /usr/lib/cgi-bin/mailman/
# In this case you need to set the DEFAULT_URL_PATTERN in
# /etc/mailman/mm_cfg.py to http://%s/mailman/ for the cookie
# authentication code to work. Note that you need to change the base
# URL for all the already-created lists as well.
<Directory /usr/lib/cgi-bin/mailman/>
AllowOverride None
Options ExecCGI
AddHandler cgi-script .cgi
Order allow,deny
Allow from all
</Directory>
<Directory /var/lib/mailman/archives/public/>
Options FollowSymlinks
AllowOverride None
Order allow,deny
Allow from all
</Directory>
<Directory /usr/share/images/mailman/>
AllowOverride None
Order allow,deny
Allow from all
</Directory>
## The following describes how to configure mailman on
## a dedicated virtual host, courtesy Marco d'Itri.
# Add these lines in /etc/mailman/mm_cfg.py:
#DEFAULT_EMAIL_HOST = 'lists.example.net'
#DEFAULT_URL_HOST = 'lists.example.net'
#DEFAULT_URL_PATTERN = 'http://%s/'
#<VirtualHost *>
<VirtualHost *:80 *:443>
ServerName listes.np11.org
DocumentRoot /var/www/lists
ErrorLog /var/log/apache2/lists-error.log
CustomLog /var/log/apache2/lists-access.log combined
<Directory /var/lib/mailman/archives/>
Options FollowSymLinks
AllowOverride None
</Directory>
ScriptAlias /admin /usr/lib/cgi-bin/mailman/admin
ScriptAlias /admindb /usr/lib/cgi-bin/mailman/admindb
ScriptAlias /confirm /usr/lib/cgi-bin/mailman/confirm
ScriptAlias /create /usr/lib/cgi-bin/mailman/create
ScriptAlias /edithtml /usr/lib/cgi-bin/mailman/edithtml
ScriptAlias /listinfo /usr/lib/cgi-bin/mailman/listinfo
ScriptAlias /options /usr/lib/cgi-bin/mailman/options
ScriptAlias /private /usr/lib/cgi-bin/mailman/private
ScriptAlias /rmlist /usr/lib/cgi-bin/mailman/rmlist
ScriptAlias /roster /usr/lib/cgi-bin/mailman/roster
ScriptAlias /subscribe /usr/lib/cgi-bin/mailman/subscribe
ScriptAlias / /usr/lib/cgi-bin/mailman/listinfo
<IfModule mod_rewrite.c>
RewriteEngine on
# Redirect to SSL if available
<IfModule mod_ssl.c>
RewriteCond %{HTTPS} !^on$ [NC]
RewriteRule . https://%{HTTP_HOST}%{REQUEST_URI} [L]
</IfModule>
# Redirect root access to mailman list
RewriteRule ^$ /listinfo [R=permanent,L]
RewriteRule ^/$ /listinfo [R=permanent,L]
</IfModule>
</VirtualHost>
Et pour finir mon fichier /etc/apache2/apache2.conf :
# This is the main Apache server configuration file. It contains the
# configuration directives that give the server its instructions.
# See http://httpd.apache.org/docs/2.4/ for detailed information about
# the directives and /usr/share/doc/apache2/README.Debian about Debian specific
# hints.
# Summary of how the Apache 2 configuration works in Debian:
# The Apache 2 web server configuration in Debian is quite different to
# upstream's suggested way to configure the web server. This is because Debian's
# default Apache2 installation attempts to make adding and removing modules,
# virtual hosts, and extra configuration directives as flexible as possible, in
# order to make automating the changes and administering the server as easy as
# possible.
# It is split into several files forming the configuration hierarchy outlined
# below, all located in the /etc/apache2/ directory:
# /etc/apache2/
# |-- apache2.conf
# | `-- ports.conf
# |-- mods-enabled
# | |-- *.load
# | `-- *.conf
# |-- conf-enabled
# | `-- *.conf
# `-- sites-enabled
# `-- *.conf
# * apache2.conf is the main configuration file (this file). It puts the pieces
# together by including all remaining configuration files when starting up the
# web server.
# * ports.conf is always included from the main configuration file. It is
# supposed to determine listening ports for incoming connections which can be
# customized anytime.
# * Configuration files in the mods-enabled/, conf-enabled/ and sites-enabled/
# directories contain particular configuration snippets which manage modules,
# global configuration fragments, or virtual host configurations,
# respectively.
# They are activated by symlinking available configuration files from their
# respective *-available/ counterparts. These should be managed by using our
# helpers a2enmod/a2dismod, a2ensite/a2dissite and a2enconf/a2disconf. See
# their respective man pages for detailed information.
# * The binary is called apache2. Due to the use of environment variables, in
# the default configuration, apache2 needs to be started/stopped with
# /etc/init.d/apache2 or apache2ctl. Calling /usr/bin/apache2 directly will not
# work with the default configuration.
# Global configuration
# ServerRoot: The top of the directory tree under which the server's
# configuration, error, and log files are kept.
# NOTE! If you intend to place this on an NFS (or otherwise network)
# mounted filesystem then please read the Mutex documentation (available
# at <URL:http://httpd.apache.org/docs/2.4/mod/core.html#mutex>);
# you will save yourself a lot of trouble.
# Do NOT add a slash at the end of the directory path.
#ServerRoot "/etc/apache2"
# The accept serialization lock file MUST BE STORED ON A LOCAL DISK.
Mutex file:${APACHE_LOCK_DIR} default
# PidFile: The file in which the server should record its process
# identification number when it starts.
# This needs to be set in /etc/apache2/envvars
PidFile ${APACHE_PID_FILE}
# Timeout: The number of seconds before receives and sends time out.
Timeout 300
# KeepAlive: Whether or not to allow persistent connections (more than
# one request per connection). Set to "Off" to deactivate.
KeepAlive On
# MaxKeepAliveRequests: The maximum number of requests to allow
# during a persistent connection. Set to 0 to allow an unlimited amount.
# We recommend you leave this number high, for maximum performance.
MaxKeepAliveRequests 100
# KeepAliveTimeout: Number of seconds to wait for the next request from the
# same client on the same connection.
KeepAliveTimeout 5
# These need to be set in /etc/apache2/envvars
User ${APACHE_RUN_USER}
Group ${APACHE_RUN_GROUP}
# HostnameLookups: Log the names of clients or just their IP addresses
# e.g., www.apache.org (on) or 204.62.129.132 (off).
# The default is off because it'd be overall better for the net if people
# had to knowingly turn this feature on, since enabling it means that
# each client request will result in AT LEAST one lookup request to the
# nameserver.
HostnameLookups Off
# ErrorLog: The location of the error log file.
# If you do not specify an ErrorLog directive within a <VirtualHost>
# container, error messages relating to that virtual host will be
# logged here. If you *do* define an error logfile for a <VirtualHost>
# container, that host's errors will be logged there and not here.
ErrorLog ${APACHE_LOG_DIR}/error.log
# LogLevel: Control the severity of messages logged to the error_log.
# Available values: trace8, ..., trace1, debug, info, notice, warn,
# error, crit, alert, emerg.
# It is also possible to configure the log level for particular modules, e.g.
# "LogLevel info ssl:warn"
LogLevel warn
# Include module configuration:
IncludeOptional mods-enabled/*.load
IncludeOptional mods-enabled/*.conf
# Include list of ports to listen on
Include ports.conf
# Sets the default security model of the Apache2 HTTPD server. It does
# not allow access to the root filesystem outside of /usr/share and /var/www.
# The former is used by web applications packaged in Debian,
# the latter may be used for local directories served by the web server. If
# your system is serving content from a sub-directory in /srv you must allow
# access here, or in any related virtual host.
<Directory />
AllowOverride None
Require all denied
</Directory>
<Directory /usr/share>
AllowOverride None
Require all granted
</Directory>
<Directory /var/www/>
Options Indexes FollowSymLinks
AllowOverride None
Require all granted
</Directory>
#<Directory /srv/>
# Options Indexes FollowSymLinks
# AllowOverride None
# Require all granted
#</Directory>
# AccessFileName: The name of the file to look for in each directory
# for additional configuration directives. See also the AllowOverride
# directive.
AccessFileName .htaccess
# The following lines prevent .htaccess and .htpasswd files from being
# viewed by Web clients.
<FilesMatch "^\.ht">
Require all denied
</FilesMatch>
# The following directives define some format nicknames for use with
# a CustomLog directive.
# These deviate from the Common Log Format definitions in that they use %O
# (the actual bytes sent including headers) instead of %b (the size of the
# requested file), because the latter makes it impossible to detect partial
# requests.
# Note that the use of %{X-Forwarded-For}i instead of %h is not recommended.
# Use mod_remoteip instead.
LogFormat "%v:%p %h %l %u %t \"%r\" %>s %O \"%{Referer}i\" \"%{User-Agent}i\"" vhost_combined
LogFormat "%h %l %u %t \"%r\" %>s %O \"%{Referer}i\" \"%{User-Agent}i\"" combined
LogFormat "%h %l %u %t \"%r\" %>s %O" common
LogFormat "%{Referer}i -> %U" referer
LogFormat "%{User-agent}i" agent
# Include of directories ignores editors' and dpkg's backup files,
# see README.Debian for details.
# Include generic snippets of statements
IncludeOptional conf-enabled/*.conf
# Include the virtual host configurations:
IncludeOptional sites-enabled/*.conf
# vim: syntax=apache ts=4 sw=4 sts=4 sr noet
