mon serveur x a encore planté !!!
ci-joint le resultat du log /var/log xfree86 :
XFree86 Version 4.3.0.1 (Debian 4.3.0.dfsg.1-14sarge3 20070107160638 jmm@galadriel)
Release Date: 15 August 2003
X Protocol Version 11, Revision 0, Release 6.6
Build Operating System: Linux 2.6.18-3-686 i686 [ELF]
Build Date: 07 January 2007
This version of XFree86 has been extensively modified by the Debian
Project, and is not supported by the XFree86 Project, Inc., in any
way. Bugs should be reported to the Debian Bug Tracking System; see
<URL: debian.org/Bugs/Reporting >.
We strongly encourage the use of the “reportbug” package and command
to ensure that bug reports contain as much useful information as
possible.
Before filing a bug report, you may want to consult the Debian X FAQ:
XHTML version: file:///usr/share/doc/xfree86-common/FAQ.xhtml
plain text version: file:///usr/share/doc/xfree86-common/FAQ.gz
Module Loader present
OS Kernel: Linux version 2.6.8-2-386 (horms@tabatha.lab.ultramonkey.org) (gcc version 3.3.5 (Debian 1:3.3.5-13)) #1 Tue Aug 16 12:46:35 UTC 2005
Markers: (–) probed, (**) from config file, (==) default setting,
(==) Log file: “/var/log/XFree86.0.log”, Time: Sat Jan 27 12:48:39 2007
(==) Using config file: "/etc/X11/XF86Config-4"
Parse error on line 77 of section Monitor in file /etc/X11/XF86Config-4
The HorizSync keyword must be followed by a list of numbers or ranges.
(EE) Problem parsing the config file
(EE) Error from xf86HandleConfigFile()
Fatal server error:
no screens found
When reporting a problem related to a server crash, please send
the full server output, not just the last messages.
This can be found in the log file “/var/log/XFree86.0.log”.
Please report problems to submit@bugs.debian.org.
Merci pour votre aide.
J’ ai réinstallé le même système : sarge avec xfree86 !
