J’ai une nouvelle fois besoin de l’aide de ceux qui voudront bien me l’apporter pour quelques petites choses mais qui forment un seul et meme “problème” a mes yeux :
Mon chipset audio n’éétant pas détecté via alsaconf, j’ai regardé ce qui sortait de “dmesg | grep audio” et un lspci du meme métal. Pour lspci je n’obtiens rien, ce qui, m’est avis est plutot normal vu la sortie de dmesg :
$ dmesg | grep audio
CS4236+ soundcard not found or device busy
CS4232 soundcard not found or device busy
CS4231 soundcard not found or device busy
ESS AudioDrive ES18xx soundcard not found or device busy
ESS AudioDrive ES1688 soundcard not found or device busy
Sound Blaster 16 soundcard not found or device busy
Sound Blaster soundcard not found or device busy
sachant donc que “lspci | grep audio” ne me renvoie strictement rien et que un lspci simple me renvoie :
0000:00:00.0 RAM memory: nVidia Corporation: Unknown device 0369 (rev a1)
0000:00:01.0 ISA bridge: nVidia Corporation: Unknown device 0360 (rev a2)
0000:00:01.1 SMBus: nVidia Corporation: Unknown device 0368 (rev a2)
0000:00:01.2 RAM memory: nVidia Corporation: Unknown device 036a (rev a2)
0000:00:02.0 USB Controller: nVidia Corporation: Unknown device 036c (rev a1)
0000:00:02.1 USB Controller: nVidia Corporation: Unknown device 036d (rev a2)
0000:00:04.0 IDE interface: nVidia Corporation: Unknown device 036e (rev a1)
0000:00:05.0 IDE interface: nVidia Corporation: Unknown device 037f (rev a2)
0000:00:05.1 IDE interface: nVidia Corporation: Unknown device 037f (rev a2)
0000:00:05.2 IDE interface: nVidia Corporation: Unknown device 037f (rev a2)
0000:00:06.0 PCI bridge: nVidia Corporation: Unknown device 0370 (rev a2)
0000:00:06.1 0403: nVidia Corporation: Unknown device 0371 (rev a2)
0000:00:08.0 Bridge: nVidia Corporation: Unknown device 0373 (rev a2)
0000:00:0a.0 PCI bridge: nVidia Corporation: Unknown device 0376 (rev a2)
0000:00:0b.0 PCI bridge: nVidia Corporation: Unknown device 0374 (rev a2)
0000:00:0c.0 PCI bridge: nVidia Corporation: Unknown device 0374 (rev a2)
0000:00:0d.0 PCI bridge: nVidia Corporation: Unknown device 0378 (rev a2)
0000:00:0e.0 PCI bridge: nVidia Corporation: Unknown device 0375 (rev a2)
0000:00:0f.0 PCI bridge: nVidia Corporation: Unknown device 0377 (rev a2)
0000:01:07.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
0000:07:00.0 VGA compatible controller: nVidia Corporation: Unknown device 0393 (rev a1)
Donc a priori les différentes composantes de mon chip (dont le son mais il y a aussi le port ethernet qui ne l’est pas, le SATA et plein d’autres choses) ne sont , en règle générale, pas trop détectées.
Comme CM j’ai une Asus M2N-E et pour le moment je m’en étais remis au chip son intégré (nForce 570 ultra), tant que j’étais chez mongro$oft mais la c’est le cas de le dire : “c’est plus la meme chanson” ^^
A force d’écumer google j’ai trouvé diverses choses comme de recompiler mon ker avec certaines options ou de tout bonnement migrer en etch. Etant un novice confirmé (ma premiere deb c’est “mon pote qui sait faire” qui me l’a installée et en partie configurée) j’avoue que je nage un peu(voire meme totalement, ne sachant pas quelle solution est la plus viable) et je ne sais pas trop comment faire pour l’une ou l’autre des options vu qu’apparament nvidia n’a sorti de drivers que pour les nforce 1 à 3 et “pro” (et puis comme leurs installateurs ont mauvaise reput si je pouvais faire ca “proprement” ca serait pas de refus, quitte a metre les mains dans le cambouis).
J’aurais donc besoin de vos lumières si vous avez une idée sur la question et donc sur comment m’y prendre… le son ca parait annexe mais mon pc c’est ma “chaine hifi” depuis un bail … et pis ca me frustre de pouvoir faire tourner ma musique sous win et pas sous nux
Question subsidiaire : comment modifier le titre d’un topic qu’on a lancé ? (pas féru de forums a la base, sauf pour répondre aux autres ^^)
Merci d’avance.
, tu devrais même pousser sur :
(enfin, on est pas tous doués pareil hein ?!).
