Bonsoir à tous !
Voilà, depuis deux jours j’ai un message au démarrage de ma session graphique m’avertissant d’un Kernel failure. Quand je zieute un peu dmesg, les seules choses suspectes que je trouve sont :
[ 0.244015] ACPI: bus type pci registered
[ 0.244015] PCI: MCFG configuration 0: base e0000000 segment 0 buses 0 - 255
[ 0.244015] PCI: Not using MMCONFIG.
[ 0.244015] PCI: PCI BIOS revision 3.00 entry at 0xf0031, last bus=4
[ 0.244015] PCI: Using configuration type 1 for base access
[ 0.244015] Setting up standard PCI resources
[ 0.244015] ACPI: EC: Look up EC in DSDT
[ 0.252997] ACPI: Interpreter enabled
[ 0.252999] ACPI: (supports S0 S1 S3 S4 S5)
[ 0.253013] ACPI: Using IOAPIC for interrupt routing
[ 0.253063] PCI: MCFG configuration 0: base e0000000 segment 0 buses 0 - 255
[ 0.255223] PCI: MCFG area at e0000000 reserved in ACPI motherboard resources
[ 0.255226] PCI: Using MMCONFIG for extended config space
[ 0.264016] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.264016] pci 0000:00:1f.0: quirk: region 0800-087f claimed by ICH6 ACPI/GPIO/TCO
[ 0.264016] pci 0000:00:1f.0: quirk: region 0480-04bf claimed by ICH6 GPIO
[ 0.264016] PCI: Transparent bridge - 0000:00:1e.0
[ 0.264016] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.264016] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P2._PRT]
[ 0.264016] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P1._PRT]
[ 0.264185] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P9._PRT]
[ 0.264293] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P4._PRT]
[ 0.280017] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 10 *11 12 14 15)
[ 0.280017] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 *10 11 12 14 15)
[ 0.280017] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 *5 6 7 10 11 12 14 15)
[ 0.280017] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 10 11 12 *14 15)
[ 0.280134] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[ 0.280248] ACPI: PCI Interrupt Link [LNKF] (IRQs *3 4 5 6 7 10 11 12 14 15)
[ 0.280362] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 10 11 12 14 *15)
[ 0.281956] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 *7 10 11 12 14 15)
[ 0.282978] ACPI Warning (tbutils-0217): Incorrect checksum in table [OEMB] - A7, should be A6 [20080321]
[ 0.283008] Linux Plug and Play Support v0.97 (c) Adam Belay
[ 0.283467] pnp: PnP ACPI init
[ 0.283473] ACPI: bus type pnp registered
[ 0.285498] pnp: PnP ACPI: found 14 devices
[ 0.285498] ACPI: ACPI bus type pnp unregistered
[ 0.285498] PnPBIOS: Disabled by ACPI PNP
[ 0.285498] PCI: Using ACPI for IRQ routing
[ 0.289871] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0
[ 0.289879] hpet0: 4 64-bit timers, 14318180 Hz
[ 0.290913] ACPI: RTC can wake from S4
[ 0.297896] system 00:01: iomem range 0xfed14000-0xfed19fff has been reserved
[ 0.297909] system 00:06: ioport range 0x290-0x297 has been reserved
[ 0.297919] system 00:07: ioport range 0x4d0-0x4d1 has been reserved
[ 0.297923] system 00:07: ioport range 0x800-0x87f has been reserved
[ 0.297928] system 00:07: ioport range 0x480-0x4bf has been reserved
[ 0.297933] system 00:07: iomem range 0xfed1c000-0xfed1ffff has been reserved
[ 0.297937] system 00:07: iomem range 0xfed20000-0xfed3ffff has been reserved
[ 0.297942] system 00:07: iomem range 0xfed50000-0xfed8ffff has been reserved
[ 0.297946] system 00:07: iomem range 0xffa00000-0xffafffff has been reserved
[ 0.297950] system 00:07: iomem range 0xffb00000-0xffbfffff has been reserved
[ 0.297955] system 00:07: iomem range 0xffe00000-0xffefffff has been reserved
[ 0.297959] system 00:07: iomem range 0xfff00000-0xfffffffe could not be reserved
[ 0.297971] system 00:0a: iomem range 0xfec00000-0xfec00fff has been reserved
[ 0.297978] system 00:0a: iomem range 0xfee00000-0xfee00fff could not be reserved
[ 0.297989] system 00:0c: iomem range 0xe0000000-0xefffffff has been reserved
[ 0.297998] system 00:0d: iomem range 0x0-0x9ffff could not be reserved
[ 0.298003] system 00:0d: iomem range 0xc0000-0xcffff could not be reserved
[ 0.298007] system 00:0d: iomem range 0xe0000-0xfffff could not be reserved
[ 0.298012] system 00:0d: iomem range 0x100000-0x7fffffff could not be reserved
Plus loin :
[ 2.376110] ehci_hcd 0000:00:1d.7: debug port 1
[ 2.376110] PCI: cache line size of 32 is not supported by device 0000:00:1d.7
Puis tout à la fin :
Je dois m’inquiéter ou c’est bénin ? J’avoue avoir essayé de comprendre, mais ça reste opaque pour moi
Je peux aussi poster le résultat complet de dmesg, au besoin, mais je n’arrive pas à joindre le txt à ce message…
Merci d’avance
