[quote]capucine@coquille:/$ avidemux
LARGE FILE AVAILABLE : 1 offset
Locales for avidemux appear to be in
I18N : _File
Avidemux 2, v 2.1.1
fixounet.free.fr/avidemux
Code : Mean & JSC
GFX : Nestor Di , nestordi@augcyl.org
Testing : Jakub Misak
FreeBSD : Anish Mistry, amistry@am-productions.biz
Arcc X86 X86_64 activated.
Registering Encoders
Mjpeg encoder registred
Xvid-4 encoder registred
FFMPEG encoder registred
3 encoder registered
Initializing global xvid 4
xvid build:xvid-1.1.0-beta2
xvid thread:0
xvid SIMD supported:(f7)
MMX
MMXEXT
SSE
3DNOW
3DNOWEXT
Checking cpu capabilities
Cpu has MMX
Cpu has 3DNOW
Cpu has MMXEXT
Cpu has SSE
End of cpu capabilities check
Using /home/capucine/.avidemux as base directory for prefs/jobs/…
Found 15 video encoder
Found 9 audio encoder
Initializing postproc
Deleting post proc
updating post proc
Enabled type:3 strength:3
Registering Filters
Using dummy audio device
Global SDL init…
Spidermonkey initialized.
(avidemux:6679): Pango-WARNING **: Invalid UTF-8 string passed to pango_layout_set_text()
Canonizing null string ??? (//)
Images stat:___________Max memory consumed (MB) : 0
Current memory consumed (MB) : 0
Max image used : 0
Cur image used : 0
#0 0x407060f2 in g_on_error_stack_trace () from /usr/lib/libglib-2.0.so.0
#1 0x080a8907 in sig_segfault_handler ()
#2
#3 0x0840bca9 in simplify_path ()
#4 0x0840be14 in PathCanonize ()
#5 0x0840bb1b in fileReadWrite ()
#6 0x0840b7f4 in GUI_FileSelRead ()
#7 0x080a46b6 in HandleAction ()
#8 0x406622a6 in g_cclosure_marshal_VOID__VOID ()
#9 0x40650736 in g_closure_invoke () from /usr/lib/libgobject-2.0.so.0
#10 0x40661dcf in g_signal_emit_by_name () from /usr/lib/libgobject-2.0.so.0
#11 0x40660e9c in g_signal_emit_valist () from /usr/lib/libgobject-2.0.so.0
#12 0x40661216 in g_signal_emit_by_name () from /usr/lib/libgobject-2.0.so.0
#13 0x40434299 in gtk_tool_button_get_type () from /usr/lib/libgtk-x11-2.0.so.0
#14 0x406622a6 in g_cclosure_marshal_VOID__VOID ()
#15 0x40650736 in g_closure_invoke () from /usr/lib/libgobject-2.0.so.0
#16 0x40661dcf in g_signal_emit_by_name () from /usr/lib/libgobject-2.0.so.0
#17 0x40660e9c in g_signal_emit_valist () from /usr/lib/libgobject-2.0.so.0
#18 0x40661126 in g_signal_emit () from /usr/lib/libgobject-2.0.so.0
#19 0x402c6655 in gtk_button_clicked () from /usr/lib/libgtk-x11-2.0.so.0
#20 0x402c74da in _gtk_button_paint () from /usr/lib/libgtk-x11-2.0.so.0
#21 0x406622a6 in g_cclosure_marshal_VOID__VOID ()
#22 0x406509c9 in g_cclosure_new_swap () from /usr/lib/libgobject-2.0.so.0
#23 0x40650736 in g_closure_invoke () from /usr/lib/libgobject-2.0.so.0
#24 0x40661651 in g_signal_emit_by_name () from /usr/lib/libgobject-2.0.so.0
#25 0x40660e9c in g_signal_emit_valist () from /usr/lib/libgobject-2.0.so.0
#26 0x40661126 in g_signal_emit () from /usr/lib/libgobject-2.0.so.0
#27 0x402c65c5 in gtk_button_released () from /usr/lib/libgtk-x11-2.0.so.0
#28 0x402c7383 in _gtk_button_paint () from /usr/lib/libgtk-x11-2.0.so.0
#29 0x4038c99e in _gtk_marshal_BOOLEAN__BOXED ()
#30 0x406509c9 in g_cclosure_new_swap () from /usr/lib/libgobject-2.0.so.0
#31 0x40650736 in g_closure_invoke () from /usr/lib/libgobject-2.0.so.0
#32 0x40661855 in g_signal_emit_by_name () from /usr/lib/libgobject-2.0.so.0
#33 0x40660c8c in g_signal_emit_valist () from /usr/lib/libgobject-2.0.so.0
#34 0x40661126 in g_signal_emit () from /usr/lib/libgobject-2.0.so.0
#35 0x4047bd87 in gtk_widget_send_expose () from /usr/lib/libgtk-x11-2.0.so.0
#36 0x4038b4b2 in gtk_propagate_event () from /usr/lib/libgtk-x11-2.0.so.0
#37 0x4038a306 in gtk_main_do_event () from /usr/lib/libgtk-x11-2.0.so.0
#38 0x40588825 in _gdk_events_queue () from /usr/lib/libgdk-x11-2.0.so.0
#39 0x4071c582 in g_main_depth () from /usr/lib/libglib-2.0.so.0
#40 0x4071d5f8 in g_main_context_dispatch () from /usr/lib/libglib-2.0.so.0
#41 0x4071d930 in g_main_context_dispatch () from /usr/lib/libglib-2.0.so.0
#42 0x4071ded3 in g_main_loop_run () from /usr/lib/libglib-2.0.so.0
#43 0x40389bb3 in gtk_main () from /usr/lib/libgtk-x11-2.0.so.0
#44 0x080a8840 in main ()
Voila ma console si ca peut aider…
