C’est encore moi
Suite à mes essais très concluant sur mon pc test je souhaiterais installer Debian sur mon pc principal.
En gros voilà la config : PackardBell imédia, disque dur de 160 Go, un disque dur externe Maxtor OneTouch 750 Go.
Pour compléter tout ça un petit lspci
lspci
00:00.0 Host bridge: VIA Technologies, Inc. K8M800 Host Bridge
00:00.1 Host bridge: VIA Technologies, Inc. K8M800 Host Bridge
00:00.2 Host bridge: VIA Technologies, Inc. K8M800 Host Bridge
00:00.3 Host bridge: VIA Technologies, Inc. K8M800 Host Bridge
00:00.4 Host bridge: VIA Technologies, Inc. K8M800 Host Bridge
00:00.7 Host bridge: VIA Technologies, Inc. K8M800 Host Bridge
00:01.0 PCI bridge: VIA Technologies, Inc. VT8237 PCI bridge [K8T800/K8T890 South]
00:0a.0 Modem: Smart Link Ltd. SmartLink SmartPCI562 56K Modem (rev 04)
00:0b.0 Network controller: RaLink RT2500 802.11g Cardbus/mini-PCI (rev 01)
00:0f.0 IDE interface: VIA Technologies, Inc. VIA VT6420 SATA RAID Controller (rev 80)
00:0f.1 IDE interface: VIA Technologies, Inc. VT82C586A/B/VT82C686/A/B/VT823x/A/C PIPC Bus Master IDE (rev 06)
00:10.0 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 81)
00:10.1 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 81)
00:10.2 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 81)
00:10.3 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 81)
00:10.4 USB Controller: VIA Technologies, Inc. USB 2.0 (rev 86)
00:11.0 ISA bridge: VIA Technologies, Inc. VT8237 ISA bridge [KT600/K8T800/K8T890 South]
00:11.5 Multimedia audio controller: VIA Technologies, Inc. VT8233/A/8235/8237 AC97 Audio Controller (rev 60)
00:13.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
00:18.0 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration
00:18.1 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Address Map
00:18.2 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] DRAM Controller
00:18.3 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Miscellaneous Control
01:00.0 VGA compatible controller: nVidia Corporation NV34 [GeForce FX 5200] (rev a1)
Sur mon disque dur j’ai déjà Ubuntu installé et j’hésite sur l’install de Debian.
Soit je dégage Ubuntu et je ne mets que Debian ( qui sera Etch au départ mais que je passerai surement en Sid),
Soit je fais un dual boot. En sachant que comme UBuntu est déjà installé, il va falloir que je créé une partition Debian. Mais comme je me connais je sais que je vais vite vouloir ne mettre que Debian. Donc je vais me retrouver coincé au niveau des partitions puisque même si je supprime la partition Ubuntu je vais me retrouver avec 80 Go non alloués qui seront à gauche ( copier une partition pour la déplacer et modifier le menu.lst je ne l’ai jamais fait donc je ne sais pas faire)
De plus mon appareil photo n’est, à priori pas reconnu, mais je ne me suis pas vraiment pencher sur le problème ( et pour le reste de mon matériel je ne sais pas, c’est pour ça que le dual boot me paraissait intéressant.)
Je stocke tous mes fichiers sur mon disque dur externe donc même si je fais une gaffe il n’y aurait pas de perte.
Donc que me conseillez-vous ?
Merci.
