[résolu]lire et enregistrer un flux réseau
je voudrais lire une vidéo en streaming depuis VLC pour pouvoir profiter de l’option “diffuser/sauvegarder” qui permet d’enregister un flux.
J’arrive très bien à lire cette vidéo (le JT de 20H trouvé sur ce site) avec mplayer mais pas avec vlc comme le montre les logs suivants :
avec mplayer : [code]$ mplayer mms://a988.v101995.c10199.e.vm.akamaistream.net/7/988/10199/3f97c7e6/ftvigrp.download.akamai.com/10199/horsgv/regions/siege/infos/f2/20h/HD_20h_20080909.wmv
MPlayer 1.0rc2-4.2.3-DFSG-free © 2000-2007 MPlayer Team
CPU: Intel® Pentium® M processor 1600MHz (Family: 6, Model: 9, Stepping: 5)
CPUflags: MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1
Compiled with runtime CPU detection.
mplayer: could not connect to socket
mplayer: No such file or directory
Failed to open LIRC support. You will not be able to use your remote control.
Playing mms://a988.v101995.c10199.e.vm.akamaistream.net/7/988/10199/3f97c7e6/ftvigrp.download.akamai.com/10199/horsgv/regions/siege/infos/f2/20h/HD_20h_20080909.wmv.
STREAM_ASF, URL: mms://a988.v101995.c10199.e.vm.akamaistream.net/7/988/10199/3f97c7e6/ftvigrp.download.akamai.com/10199/horsgv/regions/siege/infos/f2/20h/HD_20h_20080909.wmv
Resolving a988.v101995.c10199.e.vm.akamaistream.net for AF_INET6…
Couldn’t resolve name for AF_INET6: a988.v101995.c10199.e.vm.akamaistream.net
Resolving a988.v101995.c10199.e.vm.akamaistream.net for AF_INET…
Connecting to server a988.v101995.c10199.e.vm.akamaistream.net[84.53.183.77]: 1755…
connect error: No route to host
Connecting to server a988.v101995.c10199.e.vm.akamaistream.net[84.53.183.70]: 80…
Connecting to server a988.v101995.c10199.e.vm.akamaistream.net[84.53.183.77]: 80…
Cache size set to 1975 KBytes
Cache fill: 18.64% (376832 bytes)
ASF file format detected.
[asfheader] Audio stream found, -aid 1
[asfheader] Video stream found, -vid 2
[asfheader] Video stream found, -vid 3
VIDEO: [WMV3] 384x216 24bpp 1000.000 fps 377.0 kbps (46.0 kbyte/s)
Clip info:
name: Journal de 20h 09-09-08
author:
copyright:
open: No such file or directory
[MGA] Couldn’t open: /dev/mga_vid
[VO_TDFXFB] This driver only supports the 3Dfx Banshee, Voodoo3 and Voodoo 5.
[VO_3DFX] Unable to open /dev/3dfx.
Opening video decoder: [dmo] DMO video codecs
DMO dll supports VO Optimizations 0 1
DMO dll might use previous sample when requested
GetOutput r=0x0 size:248832 align:1
StreamCount r=0x0 1 1
Decoder supports the following formats: YV12 YUY2 UYVY YVYU RGB8 RGB555 RGB565 RGB24 RGB32
Decoder is capable of YUV output (flags 0x1b)
VDec: vo config request - 384 x 216 (preferred colorspace: Packed YUY2)
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is undefined - no prescaling applied.
VO: [xv] 384x216 => 384x216 Planar YV12
Selected video codec: [wmv9dmo] vfm: dmo (Windows Media Video 9 DMO)
Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders
AUDIO: 44100 Hz, 2 ch, s16le, 64.0 kbit/4.54% (ratio: 8005->176400)
Selected audio codec: [ffwmav2] afm: ffmpeg (DivX audio v2 (FFmpeg))
[AO_ALSA] alsa-lib: pcm_hw.c:1132:(snd_pcm_hw_open) open /dev/snd/pcmC0D0p failed: Device or resource busy
[AO_ALSA] alsa-lib: pcm_dmix.c:996:(snd_pcm_dmix_open) unable to open slave
[AO_ALSA] Playback open error: Device or resource busy
[AO OSS] audio_setup: Can’t open audio device /dev/dsp: Device or resource busy
[AO ESD] esd_open_sound failed: No such file or directory
[JACK] cannot open server
[AO SDL] Samplerate: 44100Hz Channels: Stereo Format s16le
[AO SDL] Unable to open audio: No available audio device
Opening /dev/dvb/adapter0/audio0
DVB AUDIO DEVICE: No such file or directory
AO: [null] 44100Hz 2ch s16le (2 bytes per sample)
Starting playback…
A: 6.2 V: 6.2 A-V: -0.002 ct: -0.045 30/ 30 11% 9% 1.6% 0 0 17%
Exiting… (Quit)
[/code]Avec VLC : $ vlc mms://a988.v101995.c10199.e.vm.akamaistream.net/7/988/10199/3f97c7e6/ftvigrp.download.akamai.com/10199/horsgv/regions/siege/infos/f2/20h/HD_20h_20080909.wmv VLC media player 0.8.6e Janus [00000285] main access error: Connection to a988.v101995.c10199.e.vm.akamaistream.net port 1755 failed: Connexion terminée par expiration du délai d'attente [00000285] access_mms access error: failed to open a connection (tcp) [00000285] main access error: Connection to a988.v101995.c10199.e.vm.akamaistream.net port 1755 failed: Aucun chemin d'accès pour atteindre l'hôte cible [00000285] access_mms access error: failed to open a connection (tcp) [00000285] access_mms access error: cannot connect to server [00000285] access_mms access error: cannot read data [00000285] access_mms access error: error: HTTP/1.0 400 Bad Request [00000285] access_mms access error: cannot start stream [00000282] main input error: no suitable access module for `mms://a988.v101995.c10199.e.vm.akamaistream.net/7/988/10199/3f97c7e6/ftvigrp.download.akamai.com/10199/horsgv/regions/siege/infos/f2/20h/HD_20h_20080909.wmv' [00000273] main playlist: nothing to play [00000273] main playlist: stopping playback Enregister la vidéo avec mimms me diriez-vous, seulement je ne peux pas car je dispose d’une connection restreint et que le port utilisé par mimms est bloqué. J’espérais que VLC utilisait un autre port et que je puisse l’enregister, on dirait qu’il n’en est rien vu qu’il n’arrive même pas à le lire.
Donc ma question c’est : Pourquoi VLC ne lit pas cette vidéo (est-ce comme je le suppose un problème de ports bloqués)
et aussi : connaissez-vous un logiciel qui peut enregister un flux en utilisant un port qui est susceptible de ne pas être bloqué ?
merci beaucoup ça marche
mencoder tout comme mplayer doit utiliser des ports qui ne sont pas bloqués.
Une petite question : ta commande capte le flux et enregistrer l’audio en mp3 et la vidéo en mpeg4 avec des paramètres d’assez haute qualité. Si je baisse ces paramètres (bitrate par exemple) est-ce que ma vidéo sera plus rapidement enregistrer ou est-ce que, comme c’est un flux, le temps d’enregistrement de varie pas ou presque pas ? (je ne peux pas tester en ce moment)
De plus, le man de mencoder ne me renseigne pas sur -ffourcc DIVX, que fais cette partie de la commande ?
Simple, le ffourcc impose le code fourcc (si!) du fichier. À une époque, il y avait des soucis avec mencoder là dessus, avec ce fourcc, je bétonne!. Sinon, pouir ta question, l’enregistrement s’arrete avec la fin du flux et le temps ne dépend pas des «bitrates»
merci beaucoup pour toutes ces réponses
@sidell
question stupide tu n as toujours pas reussi a lire le lien avec VLC? moi non plus j ai la meme erreur… ;(
ben j’ai pas réessayer vu que j’avais une solution de rechange…
