Pour le touchpad, j’ai utilisé ces deux pages:
souris-libre.fr/savoir_faire … ad_fr.html
wiki.ubuntu.com/X/Config/Input
Je n’ai pas activé le srcolling, le bouton du milieu, ni l’émulation du clic droit sur le pad. Clic gauche simple et double clic, c’est tout. Pour le clic droit, j’utilise le vrai clic du pad.
La version du gestionnaire de pad, xserver-xorg-input-synaptics , est celle de Jessie.
J’ai installé le paquet xinput, version Jessie.
Via le premier lien, les prériph qu’il y a:
root@zone:/home/stef# xinput --list
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ PS/2 Generic Mouse id=12 [slave pointer (2)]
⎣ Virtual core keyboard id=3 [master keyboard (2)]
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
↳ Power Button id=6 [slave keyboard (3)]
↳ Video Bus id=7 [slave keyboard (3)]
↳ Sleep Button id=8 [slave keyboard (3)]
↳ USB2.0 UVC HD Webcam id=9 [slave keyboard (3)]
↳ Asus WMI hotkeys id=10 [slave keyboard (3)]
↳ AT Translated Set 2 keyboard id=11 [slave keyboard (3)]
↳ ACPI Virtual Keyboard Device id=13 [slave keyboard (3)]
Les réglages du pad
root@zone:/home/stef# xinput --list-props 12
Device 'PS/2 Generic Mouse':
Device Enabled (138): 1
Coordinate Transformation Matrix (140): 1.000000, 0.000000, 0.000000, 0.000000, 1.000000, 0.000000, 0.000000, 0.000000, 1.000000
Device Accel Profile (263): 0
Device Accel Constant Deceleration (264): 1.000000
Device Accel Adaptive Deceleration (265): 1.000000
Device Accel Velocity Scaling (266): 10.000000
Device Product ID (259): 2, 1
Device Node (260): "/dev/input/event12"
Evdev Axis Inversion (267): 0, 0
Evdev Axes Swap (269): 0
Axis Labels (270): "Rel X" (148), "Rel Y" (149)
Button Labels (271): "Button Left" (141), "Button Middle" (142), "Button Right" (143), "Button Wheel Up" (144), "Button Wheel Down" (145)
Evdev Scrolling Distance (272): 0, 0, 0
Evdev Middle Button Emulation (273): 0
Evdev Middle Button Timeout (274): 50
Evdev Third Button Emulation (275): 0
Evdev Third Button Emulation Timeout (276): 1000
Evdev Third Button Emulation Button (277): 3
Evdev Third Button Emulation Threshold (278): 20
Evdev Wheel Emulation (279): 0
Evdev Wheel Emulation Axes (280): 0, 0, 4, 5
Evdev Wheel Emulation Inertia (281): 10
Evdev Wheel Emulation Timeout (282): 200
Evdev Wheel Emulation Button (283): 4
Evdev Drag Lock Buttons (284): 0
Via le second lien, etat des boutons virtuels du pad:
root@zone:/home/stef# xinput get-button-map 12
1 2 3 4 5
Et ensuite, pour le réglage, je ne suis plus sûr, j’ai tâtonné, et ça dépend de ce que tu veux faire…
xinput set-button-map 12 1 0 3 ? pour désactiver le bouton du milieu virtuel - je n’ai âs souvenir d’avoir eu un blocage.
Pour le gestionnaire de fichiers, j’utilise spacefm, je doute de pouvoir t’aider si tu utilises gnome3 que je ne connais pas du tout.
