Voila mon problème:
Je souhaite avoir du dual head avec le driver Ati libre
Mais pas moyen: Je n’arrive à avoir que du mode clone. J’ai essayer avec mergedfb ou xinerama, pas moyen
Config:
Portable avec un écran 1280x800, et une ati 9600 (modèle R350)
Ecran sur port VGA, un 1024x768
Mon Xorg.conf
# xorg.conf (xorg X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the xorg.conf manual page.
# (Type "man xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
# sudo dpkg-reconfigure -phigh xserver-xorg
Section "Files"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "fr"
Option "XkbVariant" "latin9"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option "Device" "/dev/input/mice"
Option "Protocol" "ExplorerPS/2"
Option "Emulate3Buttons" "true"
EndSection
Identifier "Synaptics Touchpad"
Driver "synaptics"
Option "SendCoreEvents" "true"
Option "Device" "/dev/psaux"
Option "Protocol" "auto-dev"
Option "HorizScrollDelta" "0"
EndSection
Section "Device"
Identifier "ATI Technologies Inc RV350 [Mobility Radeon 9600 M10]"
Driver "ati"
BusID "PCI:1:0:0"
# Option "ColorTiling" "1"
Option "GARTSize" "64"
Option "MergedFB" "true"
Option "MonitorLayout" "LVDS, VGA-0"
# Option "MergedDPI" "100 100"
Option "CRT2Position" "RightOf"
EndSection
Section "Monitor"
Identifier "Écran générique"
Option "DPMS"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "ATI Technologies Inc RV350 [Mobility Radeon 9600 M10]"
Monitor "Écran générique"
DefaultDepth 24
SubSection "Display"
Modes "1280x800"
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
InputDevice "Synaptics Touchpad"
EndSection
Je suis sous Lenny, avec des morceaux de Sid, comme XORG 7.3
Une partie de la sortie de Xorg.0.log
(WW) RADEON(0): Option "MergedFB" is not used
(WW) RADEON(0): Option "MonitorLayout" is not used
, mais une 9600 n’est pas une R350. Enfin aucune des deux n’est gèrée en 3D.
