J’ai peut-etree trouvé une piste :
# dmesg | grep bcm43
bcm43xx driver
bcm43xx: Chip ID 0x4301, rev 0x0
bcm43xx: Number of cores: 5
bcm43xx: Core 0: ID 0x812, rev 0x2, vendor 0x4243, disabled
bcm43xx: Core 1: ID 0x80d, rev 0x0, vendor 0x4243, enabled
bcm43xx: Core 2: ID 0x806, rev 0x2, vendor 0x4243, disabled
bcm43xx: Core 3: ID 0x807, rev 0x1, vendor 0x4243, disabled
bcm43xx: Core 4: ID 0x804, rev 0x3, vendor 0x4243, enabled
bcm43xx: PHY connected
bcm43xx: Detected PHY: Version: 0, Type 1, Revision 4
bcm43xx: Detected Radio: ID: 2205317f (Manuf: 17f Ver: 2053 Rev: 2)
bcm43xx: Radio turned off
bcm43xx: Error: Microcode “bcm43xx_microcode2.fw” not available or load failed.
bcm43xx: core_up for active 802.11 core failed (-2)
bcm43xx: set security called, .level = 0, .enabled = 0, .encrypt = 0
Si j’ai bien compris, c’est le driver “bcm43xx” que je devrais utiliser en remplacement de “ndiswrapper”; mais si le “firmware” correspondant est manquant … ???
Qu’en pensez-vous ?
