J’ai un PC ayant les caractéristiques suivantes :
CPU AMD Athlon II X2 250 64 bits
carte graphique NVidia GeForce GT 710
disque SSD de 120Go où j’ai installé debian 8.5
RAM 6 Go
1 disque dur 1 To
écran : philips 170S
L’affichage actuel a une résolution de 1024x768 alors que l’écran peut supporter 1280x1024. Je ne peux pas le modifier
J’ai lancé nvidia-detect pour voir quel driver m’était conseillé et j’ai eu cette réponse
Detected NVIDIA GPUs: 01:00.0 VGA compatible controller [0300]: NVIDIA Corporation Device [10de:128b] (rev a1) Uh oh. Your card is not supported by any driver version up to 340.96. A newer driver may add support for your card. Newer driver releases may be available in backports.
Voici le Xorg.0.log
[ 5.922]
X.Org X Server 1.16.4
Release Date: 2014-12-20
[ 5.922] X Protocol Version 11, Revision 0
[ 5.922] Build Operating System: Linux 3.16.0-4-amd64 x86_64 Debian
[ 5.922] Current Operating System: Linux gaia 3.16.0-4-amd64 #1 SMP Debian 3.16.36-1 (2016-07-04) x86_64
[ 5.922] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.16.0-4-amd64 root=UUID=f75d12f3-f409-4204-977c-1e97afe896c5 ro quiet
[ 5.922] Build Date: 11 February 2015 12:32:02AM
[ 5.922] xorg-server 2:1.16.4-1 (http://www.debian.org/support)
[ 5.922] Current version of pixman: 0.32.6
[ 5.922] Before reporting problems, check http://wiki.x.org
[ 5.922] Markers: (--) probed, (**) from config file, (==) default setting,
[ 5.922] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Jul 20 12:38:01 2016
[ 5.924] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 5.925] (==) No Layout section. Using the first Screen section.
[ 5.925] (==) No screen section available. Using defaults.
[ 5.925] (**) |-->Screen "Default Screen Section" (0)
[ 5.925] (**) | |-->Monitor "<default monitor>"
[ 5.926] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 5.926] (==) Automatically adding devices
[ 5.926] (==) Automatically enabling devices
[ 5.926] (==) Automatically adding GPU devices
[ 5.927] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 5.927] Entry deleted from font path.
[ 5.933] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
[ 5.933] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 5.933] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 5.933] (II) Loader magic: 0x7f0e48649d80
[ 5.933] (II) Module ABI versions:
[ 5.933] X.Org ANSI C Emulation: 0.4
[ 5.933] X.Org Video Driver: 18.0
[ 5.933] X.Org XInput driver : 21.0
[ 5.933] X.Org Server Extension : 8.0
[ 5.934] (--) PCI:*(0:1:0:0) 10de:128b:1462:8c93 rev 161, Mem @ 0xfd000000/16777216, 0xf0000000/134217728, 0xfa000000/33554432, I/O @ 0x0000d800/128, BIOS @ 0x????????/524288
[ 5.935] (II) LoadModule: "glx"
[ 5.942] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 5.953] (II) Module glx: vendor="X.Org Foundation"
[ 5.953] compiled for 1.16.4, module version = 1.0.0
[ 5.953] ABI class: X.Org Server Extension, version 8.0
[ 5.953] (==) AIGLX enabled
[ 5.953] (==) Matched nouveau as autoconfigured driver 0
[ 5.953] (==) Matched nv as autoconfigured driver 1
[ 5.953] (==) Matched modesetting as autoconfigured driver 2
[ 5.953] (==) Matched fbdev as autoconfigured driver 3
[ 5.953] (==) Matched vesa as autoconfigured driver 4
[ 5.953] (==) Assigned the driver to the xf86ConfigLayout
[ 5.953] (II) LoadModule: "nouveau"
[ 5.957] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[ 5.959] (II) Module nouveau: vendor="X.Org Foundation"
[ 5.959] compiled for 1.16.0, module version = 1.0.11
[ 5.959] Module class: X.Org Video Driver
[ 5.959] ABI class: X.Org Video Driver, version 18.0
[ 5.959] (II) LoadModule: "nv"
[ 5.960] (WW) Warning, couldn't open module nv
[ 5.960] (II) UnloadModule: "nv"
[ 5.960] (II) Unloading nv
[ 5.960] (EE) Failed to load module "nv" (module does not exist, 0)
[ 5.960] (II) LoadModule: "modesetting"
[ 5.960] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 5.961] (II) Module modesetting: vendor="X.Org Foundation"
[ 5.961] compiled for 1.16.4, module version = 0.9.0
[ 5.961] Module class: X.Org Video Driver
[ 5.961] ABI class: X.Org Video Driver, version 18.0
[ 5.961] (II) LoadModule: "fbdev"
[ 5.961] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 5.963] (II) Module fbdev: vendor="X.Org Foundation"
[ 5.963] compiled for 1.15.99.904, module version = 0.4.4
[ 5.963] Module class: X.Org Video Driver
[ 5.963] ABI class: X.Org Video Driver, version 18.0
[ 5.963] (II) LoadModule: "vesa"
[ 5.963] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 5.964] (II) Module vesa: vendor="X.Org Foundation"
[ 5.964] compiled for 1.15.99.904, module version = 2.3.3
[ 5.964] Module class: X.Org Video Driver
[ 5.964] ABI class: X.Org Video Driver, version 18.0
[ 5.964] (II) NOUVEAU driver Date: Thu Aug 28 03:57:48 2014 +0200
[ 5.964] (II) NOUVEAU driver for NVIDIA chipset families :
[ 5.964] RIVA TNT (NV04)
[ 5.964] RIVA TNT2 (NV05)
[ 5.964] GeForce 256 (NV10)
[ 5.964] GeForce 2 (NV11, NV15)
[ 5.964] GeForce 4MX (NV17, NV18)
[ 5.964] GeForce 3 (NV20)
[ 5.964] GeForce 4Ti (NV25, NV28)
[ 5.964] GeForce FX (NV3x)
[ 5.964] GeForce 6 (NV4x)
[ 5.964] GeForce 7 (G7x)
[ 5.964] GeForce 8 (G8x)
[ 5.964] GeForce GTX 200 (NVA0)
[ 5.964] GeForce GTX 400 (NVC0)
[ 5.964] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 5.964] (II) FBDEV: driver for framebuffer: fbdev
[ 5.964] (II) VESA: driver for VESA chipsets: vesa
[ 5.964] (++) using VT number 7
[ 5.967] (EE) [drm] KMS not enabled
[ 5.967] (EE) open /dev/dri/card0: No such file or directory
[ 5.967] (WW) Falling back to old probe method for modesetting
[ 5.967] (II) Loading sub module "fbdevhw"
[ 5.967] (II) LoadModule: "fbdevhw"
[ 5.967] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 5.968] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 5.968] compiled for 1.16.4, module version = 0.0.2
[ 5.968] ABI class: X.Org Video Driver, version 18.0
[ 5.968] (EE) open /dev/fb0: No such file or directory
[ 5.968] (WW) Falling back to old probe method for fbdev
[ 5.968] (II) Loading sub module "fbdevhw"
[ 5.968] (II) LoadModule: "fbdevhw"
[ 5.968] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 5.968] (EE) Screen 0 deleted because of no matching config section.
[ 5.968] (II) UnloadModule: "modesetting"
[ 5.968] (II) UnloadModule: "fbdev"
[ 5.968] (II) UnloadSubModule: "fbdevhw"
[ 5.968] (II) Loading sub module "vbe"
[ 5.968] (II) LoadModule: "vbe"
[ 5.968] (II) Loading /usr/lib/xorg/modules/libvbe.so
[ 5.969] (II) Module vbe: vendor="X.Org Foundation"
[ 5.969] compiled for 1.16.4, module version = 1.1.0
[ 5.969] ABI class: X.Org Video Driver, version 18.0
[ 5.969] (II) Loading sub module "int10"
[ 5.969] (II) LoadModule: "int10"
[ 5.969] (II) Loading /usr/lib/xorg/modules/libint10.so
[ 5.971] (II) Module int10: vendor="X.Org Foundation"
[ 5.971] compiled for 1.16.4, module version = 1.0.0
[ 5.971] ABI class: X.Org Video Driver, version 18.0
[ 5.971] (II) VESA(0): initializing int10
[ 5.977] (II) VESA(0): Primary V_BIOS segment is: 0xc000
[ 6.125] (II) VESA(0): VESA BIOS detected
[ 6.125] (II) VESA(0): VESA VBE Version 3.0
[ 6.125] (II) VESA(0): VESA VBE Total Mem: 16384 kB
[ 6.125] (II) VESA(0): VESA VBE OEM: NVIDIA
[ 6.125] (II) VESA(0): VESA VBE OEM Software Rev: 128.40
[ 6.125] (II) VESA(0): VESA VBE OEM Vendor: NVIDIA Corporation
[ 6.125] (II) VESA(0): VESA VBE OEM Product: GK208 Board - 21320014
[ 6.125] (II) VESA(0): VESA VBE OEM Product Rev: Chip Rev
[ 6.382] (II) VESA(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 6.382] (==) VESA(0): Depth 24, (--) framebuffer bpp 32
[ 6.382] (==) VESA(0): RGB weight 888
[ 6.382] (==) VESA(0): Default visual is TrueColor
[ 6.382] (==) VESA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 6.382] (II) Loading sub module "ddc"
[ 6.382] (II) LoadModule: "ddc"
[ 6.382] (II) Module "ddc" already built-in
[ 6.388] (II) VESA(0): VESA VBE DDC supported
[ 6.388] (II) VESA(0): VESA VBE DDC Level none
[ 6.388] (II) VESA(0): VESA VBE DDC transfer in appr. 0 sec.
[ 6.456] (II) VESA(0): VESA VBE DDC read failed
[ 6.456] (II) VESA(0): Searching for matching VESA mode(s):
[ 6.464] Mode: 101 (640x480)
[ 6.473] Mode: 103 (800x600)
[ 6.477] Mode: 104 (1024x768)
[ 6.495] Mode: 10e (320x200)
[ 6.499] *Mode: 10f (320x200)
[ 6.503] Mode: 111 (640x480)
[ 6.512] Mode: 114 (800x600)
[ 6.521] Mode: 117 (1024x768)
[ 6.525] *Mode: 118 (1024x768)
[ 6.529] Mode: 11a (1280x1024)
[ 6.529] ModeAttributes: 0x3bf
[ 6.529] WinAAttributes: 0x7
[ 6.529] WinBAttributes: 0x0
[ 6.529] WinGranularity: 64
[ 6.529] WinSize: 64
[ 6.529] WinASegment: 0xa000
[ 6.529] WinBSegment: 0x0
[ 6.529] WinFuncPtr: 0xc00081e9
[ 6.529] BytesPerScanline: 2560
[ 6.529] XResolution: 1280
[ 6.529] YResolution: 1024
[ 6.529] XCharSize: 8
[ 6.529] YCharSize: 16
[ 6.529] NumberOfPlanes: 1
[ 6.529] BitsPerPixel: 16
[ 6.529] NumberOfBanks: 1
[ 6.529] MemoryModel: 6
[ 6.529] BankSize: 0
[ 6.529] NumberOfImages: 1
[ 6.529] RedMaskSize: 5
[ 6.529] RedFieldPosition: 11
[ 6.529] GreenMaskSize: 6
[ 6.529] GreenFieldPosition: 5
[ 6.529] BlueMaskSize: 5
[ 6.529] BlueFieldPosition: 0
[ 6.529] RsvdMaskSize: 0
[ 6.529] RsvdFieldPosition: 0
[ 6.529] DirectColorModeInfo: 0
[ 6.529] PhysBasePtr: 0xfb000000
[ 6.529] LinBytesPerScanLine: 2560
[ 6.529] BnkNumberOfImagePages: 1
[ 6.529] LinNumberOfImagePages: 1
[ 6.529] LinRedMaskSize: 5
[ 6.529] LinRedFieldPosition: 11
[ 6.529] LinGreenMaskSize: 6
[ 6.529] LinGreenFieldPosition: 5
[ 6.529] LinBlueMaskSize: 5
[ 6.529] LinBlueFieldPosition: 0
[ 6.529] LinRsvdMaskSize: 0
[ 6.529] LinRsvdFieldPosition: 0
[ 6.529] MaxPixelClock: 229500000
[ 6.534] *Mode: 11b (1280x1024)
[ 6.534] ModeAttributes: 0x3bf
[ 6.534] WinAAttributes: 0x7
[ 6.534] WinBAttributes: 0x0
[ 6.534] WinGranularity: 64
[ 6.534] WinSize: 64
[ 6.534] WinASegment: 0xa000
[ 6.534] WinBSegment: 0x0
[ 6.534] WinFuncPtr: 0xc00081e9
[ 6.534] BytesPerScanline: 5120
[ 6.534] XResolution: 1280
[ 6.534] YResolution: 1024
[ 6.534] XCharSize: 8
[ 6.534] YCharSize: 16
[ 6.534] NumberOfPlanes: 1
[ 6.534] BitsPerPixel: 32
[ 6.534] NumberOfBanks: 1
[ 6.534] MemoryModel: 6
[ 6.534] BankSize: 0
[ 6.534] NumberOfImages: 1
[ 6.534] RedMaskSize: 8
[ 6.534] RedFieldPosition: 16
[ 6.534] GreenMaskSize: 8
[ 6.534] GreenFieldPosition: 8
[ 6.534] BlueMaskSize: 8
[ 6.534] BlueFieldPosition: 0
[ 6.534] RsvdMaskSize: 8
[ 6.534] RsvdFieldPosition: 24
[ 6.534] DirectColorModeInfo: 0
[ 6.534] PhysBasePtr: 0xfb000000
[ 6.534] LinBytesPerScanLine: 5120
[ 6.534] BnkNumberOfImagePages: 1
[ 6.534] LinNumberOfImagePages: 1
[ 6.534] LinRedMaskSize: 8
[ 6.534] LinRedFieldPosition: 16
[ 6.534] LinGreenMaskSize: 8
[ 6.534] LinGreenFieldPosition: 8
[ 6.534] LinBlueMaskSize: 8
[ 6.534] LinBlueFieldPosition: 0
[ 6.534] LinRsvdMaskSize: 8
[ 6.534] LinRsvdFieldPosition: 24
[ 6.534] MaxPixelClock: 229500000
[ 6.538] Mode: 130 (320x200)
[ 6.542] Mode: 131 (320x400)
[ 6.546] Mode: 132 (320x400)
[ 6.550] *Mode: 133 (320x400)
[ 6.554] Mode: 134 (320x240)
[ 6.559] Mode: 135 (320x240)
[ 6.563] *Mode: 136 (320x240)
[ 6.567] Mode: 13d (640x400)
[ 6.571] *Mode: 13e (640x400)
[ 6.575] Mode: 145 (1600x1200)
[ 6.575] ModeAttributes: 0x3bf
[ 6.575] WinAAttributes: 0x7
[ 6.575] WinBAttributes: 0x0
[ 6.575] WinGranularity: 64
[ 6.575] WinSize: 64
[ 6.575] WinASegment: 0xa000
[ 6.576] WinBSegment: 0x0
[ 6.576] WinFuncPtr: 0xc00081e9
[ 6.576] BytesPerScanline: 1600
[ 6.576] XResolution: 1600
[ 6.576] YResolution: 1200
[ 6.576] XCharSize: 8
[ 6.576] YCharSize: 16
[ 6.576] NumberOfPlanes: 1
[ 6.576] BitsPerPixel: 8
[ 6.576] NumberOfBanks: 1
[ 6.576] MemoryModel: 4
[ 6.576] BankSize: 0
[ 6.576] NumberOfImages: 1
[ 6.576] RedMaskSize: 0
[ 6.576] RedFieldPosition: 0
[ 6.576] GreenMaskSize: 0
[ 6.576] GreenFieldPosition: 0
[ 6.576] BlueMaskSize: 0
[ 6.576] BlueFieldPosition: 0
[ 6.576] RsvdMaskSize: 0
[ 6.576] RsvdFieldPosition: 0
[ 6.576] DirectColorModeInfo: 0
[ 6.576] PhysBasePtr: 0xfb000000
[ 6.576] LinBytesPerScanLine: 1600
[ 6.576] BnkNumberOfImagePages: 1
[ 6.576] LinNumberOfImagePages: 1
[ 6.576] LinRedMaskSize: 0
[ 6.576] LinRedFieldPosition: 0
[ 6.576] LinGreenMaskSize: 0
[ 6.576] LinGreenFieldPosition: 0
[ 6.576] LinBlueMaskSize: 0
[ 6.576] LinBlueFieldPosition: 0
[ 6.576] LinRsvdMaskSize: 0
[ 6.576] LinRsvdFieldPosition: 0
[ 6.576] MaxPixelClock: 229500000
[ 6.580] Mode: 146 (1600x1200)
[ 6.580] ModeAttributes: 0x3bf
[ 6.580] WinAAttributes: 0x7
[ 6.580] WinBAttributes: 0x0
[ 6.580] WinGranularity: 64
[ 6.580] WinSize: 64
[ 6.580] WinASegment: 0xa000
[ 6.580] WinBSegment: 0x0
[ 6.580] WinFuncPtr: 0xc00081e9
[ 6.580] BytesPerScanline: 3200
[ 6.580] XResolution: 1600
[ 6.580] YResolution: 1200
[ 6.580] XCharSize: 8
[ 6.580] YCharSize: 16
[ 6.580] NumberOfPlanes: 1
[ 6.580] BitsPerPixel: 16
[ 6.580] NumberOfBanks: 1
[ 6.580] MemoryModel: 6
[ 6.580] BankSize: 0
[ 6.580] NumberOfImages: 1
[ 6.580] RedMaskSize: 5
[ 6.580] RedFieldPosition: 11
[ 6.580] GreenMaskSize: 6
[ 6.580] GreenFieldPosition: 5
[ 6.580] BlueMaskSize: 5
[ 6.580] BlueFieldPosition: 0
[ 6.580] RsvdMaskSize: 0
[ 6.580] RsvdFieldPosition: 0
[ 6.580] DirectColorModeInfo: 0
[ 6.580] PhysBasePtr: 0xfb000000
[ 6.580] LinBytesPerScanLine: 3200
[ 6.580] BnkNumberOfImagePages: 1
[ 6.580] LinNumberOfImagePages: 1
[ 6.580] LinRedMaskSize: 5
[ 6.580] LinRedFieldPosition: 11
[ 6.580] LinGreenMaskSize: 6
[ 6.580] LinGreenFieldPosition: 5
[ 6.580] LinBlueMaskSize: 5
[ 6.580] LinBlueFieldPosition: 0
[ 6.580] LinRsvdMaskSize: 0
[ 6.580] LinRsvdFieldPosition: 0
[ 6.580] MaxPixelClock: 229500000
[ 6.584] *Mode: 14a (1600x1200)
[ 6.584] ModeAttributes: 0x3bf
[ 6.584] WinAAttributes: 0x7
[ 6.584] WinBAttributes: 0x0
[ 6.584] WinGranularity: 64
[ 6.584] WinSize: 64
[ 6.584] WinASegment: 0xa000
[ 6.584] WinBSegment: 0x0
[ 6.584] WinFuncPtr: 0xc00081e9
[ 6.584] BytesPerScanline: 6400
[ 6.584] XResolution: 1600
[ 6.584] YResolution: 1200
[ 6.584] XCharSize: 8
[ 6.584] YCharSize: 16
[ 6.584] NumberOfPlanes: 1
[ 6.584] BitsPerPixel: 32
[ 6.584] NumberOfBanks: 1
[ 6.584] MemoryModel: 6
[ 6.584] BankSize: 0
[ 6.584] NumberOfImages: 1
[ 6.584] RedMaskSize: 8
[ 6.584] RedFieldPosition: 16
[ 6.584] GreenMaskSize: 8
[ 6.584] GreenFieldPosition: 8
[ 6.584] BlueMaskSize: 8
[ 6.584] BlueFieldPosition: 0
[ 6.584] RsvdMaskSize: 8
[ 6.584] RsvdFieldPosition: 24
[ 6.584] DirectColorModeInfo: 0
[ 6.584] PhysBasePtr: 0xfb000000
[ 6.584] LinBytesPerScanLine: 6400
[ 6.584] BnkNumberOfImagePages: 1
[ 6.584] LinNumberOfImagePages: 1
[ 6.584] LinRedMaskSize: 8
[ 6.584] LinRedFieldPosition: 16
[ 6.584] LinGreenMaskSize: 8
[ 6.584] LinGreenFieldPosition: 8
[ 6.584] LinBlueMaskSize: 8
[ 6.584] LinBlueFieldPosition: 0
[ 6.584] LinRsvdMaskSize: 8
[ 6.584] LinRsvdFieldPosition: 24
[ 6.584] MaxPixelClock: 229500000
[ 6.584]
[ 6.584] (II) VESA(0): Total Memory: 256 64KB banks (16384kB)
[ 6.584] (II) VESA(0): <default monitor>: Using default hsync range of 31.50-48.00 kHz
[ 6.584] (II) VESA(0): <default monitor>: Using default vrefresh range of 50.00-70.00 Hz
[ 6.584] (II) VESA(0): <default monitor>: Using default maximum pixel clock of 65.00 MHz
[ 6.584] (WW) VESA(0): Unable to estimate virtual size
[ 6.584] (II) VESA(0): Not using built-in mode "1600x1200" (no mode of this name)
[ 6.584] (II) VESA(0): Not using built-in mode "1280x1024" (no mode of this name)
[ 6.584] (II) VESA(0): Not using built-in mode "1024x768" (no mode of this name)
[ 6.584] (II) VESA(0): Not using built-in mode "800x600" (no mode of this name)
[ 6.584] (II) VESA(0): Not using built-in mode "640x480" (no mode of this name)
[ 6.584] (II) VESA(0): Not using built-in mode "640x400" (no mode of this name)
[ 6.584] (II) VESA(0): Not using built-in mode "320x400" (no mode of this name)
[ 6.584] (II) VESA(0): Not using built-in mode "320x240" (no mode of this name)
[ 6.584] (II) VESA(0): Not using built-in mode "320x200" (no mode of this name)
[ 6.584] (WW) VESA(0): No valid modes left. Trying less strict filter...
[ 6.584] (II) VESA(0): <default monitor>: Using hsync range of 31.50-48.00 kHz
[ 6.584] (II) VESA(0): <default monitor>: Using vrefresh range of 50.00-70.00 Hz
[ 6.584] (II) VESA(0): <default monitor>: Using maximum pixel clock of 65.00 MHz
[ 6.586] (II) VESA(0): Not using built-in mode "1600x1200" (hsync out of range)
[ 6.586] (II) VESA(0): Not using built-in mode "1280x1024" (hsync out of range)
[ 6.586] (II) VESA(0): Not using built-in mode "640x400" (hsync out of range)
[ 6.586] (II) VESA(0): Not using built-in mode "320x400" (hsync out of range)
[ 6.586] (II) VESA(0): Not using built-in mode "320x240" (illegal horizontal timings)
[ 6.586] (II) VESA(0): Not using built-in mode "320x200" (illegal horizontal timings)
[ 6.586] (--) VESA(0): Virtual size is 1024x768 (pitch 1024)
[ 6.586] (**) VESA(0): *Built-in mode "1024x768"
[ 6.586] (**) VESA(0): *Built-in mode "800x600"
[ 6.586] (**) VESA(0): *Built-in mode "640x480"
[ 6.586] (==) VESA(0): DPI set to (96, 96)
[ 6.586] (II) VESA(0): Attempting to use 60Hz refresh for mode "1024x768" (118)
[ 6.588] (II) VESA(0): Attempting to use 60Hz refresh for mode "800x600" (115)
[ 6.591] (II) VESA(0): Attempting to use 60Hz refresh for mode "640x480" (112)
[ 6.593] (**) VESA(0): Using "Shadow Framebuffer"
[ 6.593] (II) Loading sub module "shadow"
[ 6.593] (II) LoadModule: "shadow"
[ 6.593] (II) Loading /usr/lib/xorg/modules/libshadow.so
[ 6.594] (II) Module shadow: vendor="X.Org Foundation"
[ 6.594] compiled for 1.16.4, module version = 1.1.0
[ 6.594] ABI class: X.Org ANSI C Emulation, version 0.4
[ 6.594] (II) Loading sub module "fb"
[ 6.594] (II) LoadModule: "fb"
[ 6.594] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 6.596] (II) Module fb: vendor="X.Org Foundation"
[ 6.596] compiled for 1.16.4, module version = 1.0.0
[ 6.596] ABI class: X.Org ANSI C Emulation, version 0.4
[ 6.596] (==) Depth 24 pixmap format is 32 bpp
[ 6.596] (II) Loading sub module "int10"
[ 6.596] (II) LoadModule: "int10"
[ 6.596] (II) Loading /usr/lib/xorg/modules/libint10.so
[ 6.596] (II) Module int10: vendor="X.Org Foundation"
[ 6.596] ABI class: X.Org Video Driver, version 18.0
[ 6.596] (II) VESA(0): initializing int10
[ 6.602] (II) VESA(0): Primary V_BIOS segment is: 0xc000
[ 6.745] (II) VESA(0): VESA BIOS detected
[ 6.745] (II) VESA(0): VESA VBE Version 3.0
[ 6.745] (II) VESA(0): VESA VBE Total Mem: 16384 kB
[ 6.745] (II) VESA(0): VESA VBE OEM: NVIDIA
[ 6.745] (II) VESA(0): VESA VBE OEM Software Rev: 128.40
[ 6.745] (II) VESA(0): VESA VBE OEM Vendor: NVIDIA Corporation
[ 6.745] (II) VESA(0): VESA VBE OEM Product: GK208 Board - 21320014
[ 6.745] (II) VESA(0): VESA VBE OEM Product Rev: Chip Rev
[ 6.745] (II) VESA(0): virtual address = 0x7f0e401a6000,
physical address = 0xfb000000, size = 16777216
[ 6.774] (II) VESA(0): Setting up VESA Mode 0x118 (1024x768)
[ 6.918] (==) VESA(0): Default visual is TrueColor
[ 6.921] (==) VESA(0): Backing store enabled
[ 6.921] (==) VESA(0): DPMS enabled
[ 6.922] (==) RandR enabled
[ 6.927] (II) SELinux: Disabled on system
[ 6.928] (II) AIGLX: Screen 0 is not DRI2 capable
[ 6.928] (EE) AIGLX: reverting to software rendering
[ 7.037] (II) AIGLX: Loaded and initialized swrast
[ 7.037] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 7.119] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[ 7.119] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 7.120] (II) LoadModule: "evdev"
[ 7.120] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 7.123] (II) Module evdev: vendor="X.Org Foundation"
[ 7.123] compiled for 1.16.0, module version = 2.9.0
[ 7.123] Module class: X.Org XInput Driver
[ 7.123] ABI class: X.Org XInput driver, version 21.0
[ 7.123] (II) Using input driver 'evdev' for 'Power Button'
[ 7.123] (**) Power Button: always reports core events
[ 7.123] (**) evdev: Power Button: Device: "/dev/input/event3"
[ 7.124] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 7.124] (--) evdev: Power Button: Found keys
[ 7.124] (II) evdev: Power Button: Configuring as keyboard
[ 7.124] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input4/event3"
[ 7.124] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 7.124] (**) Option "xkb_rules" "evdev"
[ 7.124] (**) Option "xkb_model" "pc105"
[ 7.124] (**) Option "xkb_layout" "fr"
[ 7.124] (**) Option "xkb_variant" "latin9"
[ 7.153] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 7.153] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 7.153] (II) Using input driver 'evdev' for 'Power Button'
[ 7.153] (**) Power Button: always reports core events
[ 7.153] (**) evdev: Power Button: Device: "/dev/input/event2"
[ 7.153] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 7.153] (--) evdev: Power Button: Found keys
[ 7.153] (II) evdev: Power Button: Configuring as keyboard
[ 7.153] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input3/event2"
[ 7.153] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 7.153] (**) Option "xkb_rules" "evdev"
[ 7.154] (**) Option "xkb_model" "pc105"
[ 7.154] (**) Option "xkb_layout" "fr"
[ 7.154] (**) Option "xkb_variant" "latin9"
[ 7.155] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event14)
[ 7.155] (II) No input driver specified, ignoring this device.
[ 7.155] (II) This device may have been added with another device file.
[ 7.156] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event15)
[ 7.156] (II) No input driver specified, ignoring this device.
[ 7.156] (II) This device may have been added with another device file.
[ 7.156] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event5)
[ 7.157] (II) config/udev: Adding input device HDA ATI SB Line Out Front (/dev/input/event9)
[ 7.157] (II) No input driver specified, ignoring this device.
[ 7.157] (II) This device may have been added with another device file.
[ 7.157] (II) config/udev: Adding input device HDA ATI SB Line Out Surround (/dev/input/event10)
[ 7.157] (II) config/udev: Adding input device HDA ATI SB Line Out CLFE (/dev/input/event11)
[ 7.157] (II) config/udev: Adding input device HDA ATI SB Line Out Side (/dev/input/event12)
[ 7.158] (II) No input driver specified, ignoring this device.
[ 7.158] (II) This device may have been added with another device file.
[ 7.158] (II) config/udev: Adding input device HDA ATI SB Front Headphone (/dev/input/event13)
[ 7.158] (II) config/udev: Adding input device HDA ATI SB Front Mic (/dev/input/event6)
[ 7.158] (II) config/udev: Adding input device HDA ATI SB Rear Mic (/dev/input/event7)
[ 7.159] (II) config/udev: Adding input device HDA ATI SB Line (/dev/input/event8)
[ 7.159] (II) No input driver specified, ignoring this device.
[ 7.159] (II) This device may have been added with another device file.
[ 7.159] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event0)
[ 7.159] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 7.159] (II) Using input driver 'evdev' for 'AT Translated Set 2 keyboard'
[ 7.159] (**) AT Translated Set 2 keyboard: always reports core events
[ 7.159] (**) evdev: AT Translated Set 2 keyboard: Device: "/dev/input/event0"
[ 7.159] (--) evdev: AT Translated Set 2 keyboard: Vendor 0x1 Product 0x1
[ 7.159] (--) evdev: AT Translated Set 2 keyboard: Found keys
[ 7.159] (II) evdev: AT Translated Set 2 keyboard: Configuring as keyboard
[ 7.159] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input0/event0"
[ 7.159] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 8)
[ 7.159] (**) Option "xkb_rules" "evdev"
[ 7.159] (**) Option "xkb_model" "pc105"
[ 7.159] (**) Option "xkb_layout" "fr"
[ 7.159] (**) Option "xkb_variant" "latin9"
[ 7.160] (II) config/udev: Adding input device ImPS/2 Generic Wheel Mouse (/dev/input/event1)
[ 7.160] (**) ImPS/2 Generic Wheel Mouse: Applying InputClass "evdev pointer catchall"
[ 7.160] (II) Using input driver 'evdev' for 'ImPS/2 Generic Wheel Mouse'
[ 7.160] (**) ImPS/2 Generic Wheel Mouse: always reports core events
[ 7.160] (**) evdev: ImPS/2 Generic Wheel Mouse: Device: "/dev/input/event1"
[ 7.161] (--) evdev: ImPS/2 Generic Wheel Mouse: Vendor 0x2 Product 0x5
[ 7.161] (--) evdev: ImPS/2 Generic Wheel Mouse: Found 3 mouse buttons
[ 7.161] (--) evdev: ImPS/2 Generic Wheel Mouse: Found scroll wheel(s)
[ 7.161] (--) evdev: ImPS/2 Generic Wheel Mouse: Found relative axes
[ 7.161] (--) evdev: ImPS/2 Generic Wheel Mouse: Found x and y relative axes
[ 7.161] (II) evdev: ImPS/2 Generic Wheel Mouse: Configuring as mouse
[ 7.161] (II) evdev: ImPS/2 Generic Wheel Mouse: Adding scrollwheel support
[ 7.161] (**) evdev: ImPS/2 Generic Wheel Mouse: YAxisMapping: buttons 4 and 5
[ 7.161] (**) evdev: ImPS/2 Generic Wheel Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 7.161] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input2/event1"
[ 7.161] (II) XINPUT: Adding extended input device "ImPS/2 Generic Wheel Mouse" (type: MOUSE, id 9)
[ 7.161] (II) evdev: ImPS/2 Generic Wheel Mouse: initialized for relative axes.
[ 7.161] (**) ImPS/2 Generic Wheel Mouse: (accel) keeping acceleration scheme 1
[ 7.161] (**) ImPS/2 Generic Wheel Mouse: (accel) acceleration profile 0
[ 7.161] (**) ImPS/2 Generic Wheel Mouse: (accel) acceleration factor: 2.000
[ 7.161] (**) ImPS/2 Generic Wheel Mouse: (accel) acceleration threshold: 4
[ 7.162] (II) config/udev: Adding input device ImPS/2 Generic Wheel Mouse (/dev/input/mouse0)
[ 7.162] (II) No input driver specified, ignoring this device.
[ 7.162] (II) This device may have been added with another device file.
[ 7.162] (II) config/udev: Adding input device PC Speaker (/dev/input/event4)
J’ai l’impression que le driver nouveau et les pilotes propriétaires proposés
ne gère pas la carte
Que puis-je faire ?
Cordialement
