J’ai un problème; mon man fonctionne partiellement. J’ai les pages man des commandes, de certaines fonctions en C et pas les fonctions standards du C.
dmon@lenny:~$ man scanf
No manual entry for scanf
dmon@lenny:~$ man strln
No manual entry for strlen
dmon@lenny:~$ dpkg -l | grep man
ii acpid 1.0.6-16 Utilities for using ACPI power management
ii acroread-l10n-de 8.1.3-0.0 German language package for acroread
ii ant-optional-gcj 1.7.0-6 Java based build tool like make - API documentation and manual
ii aptitude 0.4.11.10-1lenny1.1+b1 terminal-based package manager
ii cpio 2.9-14 GNU cpio -- a program to manage archives of files
ii cron 3.0pl1-105 management of regular background processing
ii cups-bsd 1.3.8-1lenny2 Common UNIX Printing System(tm) - BSD commands
ii debconf 1.5.24 Debian configuration management system
rc dirmngr 1.0.2-1 server for managing certificate revocation lists
ii doc-base 0.8.16 utilities to manage online documentation
ii dpkg 1.14.22 Debian package management system
ii dynagen 0.10.1-2 Cisco 7200 Router Emulator Command Line Interface
rc file-roller 2.22.4-2 an archive manager for GNOME
ii gcc-doc-base 4.3.2.nf1-1 several GNU manual pages
rc gnome-power-manager 2.22.1-3 frontend for gnome-powermanager
ii gnome-volume-manager 2.22.1-1 GNOME daemon to auto-mount and manage media devices
ii hdparm 8.9-2 tune hard disk parameters for high performance
ii imagemagick 7:6.3.7.9.dfsg1-2.1 image manipulation programs
rc kalarm 4:3.5.9-5 KDE alarm message, command and email scheduler
ii kdm 4:3.5.9.dfsg.1-5 X display manager for KDE
ii kget 4:3.5.10-2 download manager for KDE
rc khangman 4:3.5.9-2 the classical hangman game for KDE
rc klickety 4:3.5.10-1 A Clickomania-like game for KDE
rc kmousetool 4:3.5.9-2 KDE mouse manipulation tool for the disabled
ii kommander 4:3.5.9-3 visual dialog builder and executor tool
ii konqueror 4:3.5.9.dfsg.1-5 KDE's advanced file manager, web browser and document viewer
rc kpackage 4:3.5.9-2 KDE package management tool
ii kpowersave 0.7.3-3 HAL based power management applet for KDE
rc ksig 4:3.5.9-2 graphical tool for managing multiple email signatures
ii ksmserver 4:3.5.9.dfsg.1-5 session manager for KDE
ii kwalletmanager 4:3.5.10-2 wallet manager for KDE
rc kwifimanager 4:3.5.9-4 wireless lan manager for KDE
ii kwin 4:3.5.9.dfsg.1-5 the KDE window manager
ii libbcel-java 5.2-3 Analyze, create, and manipulate (binary) Java class files
ii libcommons-beanutils-java 1.8.0~beta-1 utility for manipulating JavaBeans
ii libcompress-zlib-perl 2.015-1 Perl module for creation and manipulation of gzip files
ii libconsole 1:0.2.3dbs-65.1 Shared libraries for Linux console and font manipulation
ii libcroco3 0.6.1-2 a generic Cascading Style Sheet (CSS) parsing and manipulation
ii libept0 0.5.26 High-level library for managing Debian package information
ii libgnome-window-settings1 1:2.22.2.1-2 Utility library for getting window manager settings
ii libgnomekbd-common 2.22.0-1 GNOME library to manage keyboard configuration - common files
ii libgnomekbd2 2.22.0-1 GNOME library to manage keyboard configuration - shared librar
ii libisccc30 1:9.4.2-10+lenny1 Command Channel Library used by BIND
ii libisccc40 1:9.5.0.dfsg.P2-4 Command Channel Library used by BIND
ii liblcms1 1.17.dfsg-1 Color management library
ii libmagick10 7:6.3.7.9.dfsg1-2.1 image manipulation library
ii libnm-glib0 0.6.6-2 network management framework (GLib shared library)
ii libnm-util0 0.6.6-2 network management framework (shared library)
ii libpixman-1-0 0.10.0-2 pixel-manipulation library for X and cairo
ii libsemanage1 2.0.25-2 shared libraries used by SELinux policy manipulation tools
ii libss2 1.41.3-1 command-line interface parsing library
ii libtar 1.2.11-5 C library for manipulating tar archives
ii libuser-identity-perl 0.92-2 manages different identities/roles used by a physical person
ii libxcursor1 1:1.1.9-1 X cursor management library
ii libxkbfile1 1:1.0.5-1 X11 keyboard file manipulation library
ii man-db 2.5.2-3 on-line manual pager
ii man2html 1.6f-3 browse man pages in your web browser
ii manpages 3.07-1 Manual pages about using a GNU/Linux system
ii manpages-fr 3.07.1-1 French version of the manual pages about using GNU/Linux
ii menu-xdg 0.3 freedesktop.org menu compliant window manager scripts
ii module-init-tools 3.4-1 tools for managing Linux kernel modules
ii monodoc-gtk2.0-manual 2.12.1-2 compiled XML documentation for GTK# 2.10
ii monodoc-manual 1.9-2 compiled XML documentation from the Mono project
ii mount 2.13.1.1-1 Tools for mounting and manipulating filesystems
ii mtools 3.9.11-1 Tools for manipulating MSDOS files
ii nautilus 2.20.0-7 file manager and graphical shell for GNOME
ii ncurses-bin 5.7-2 terminal-related programs and man pages
ii network-manager 0.6.6-2 network management framework daemon
ii network-manager-gnome 0.6.6-2 network management framework (GNOME frontend)
ii pkg-config 0.22-1 manage compile and link flags for libraries
ii pm-utils 1.1.2.4-1 utilities and scripts for power management
ii po-debconf 1.0.15 manage translated Debconf templates files with gettext
ii postgresql-client-common 91 manager for multiple PostgreSQL client versions
ii postgresql-common 91 PostgreSQL database-cluster manager
ii postgresql-doc 8.3.5-1 documentation for the PostgreSQL database management system
ii postgresql-doc-8.3 8.3.5-1 documentation for the PostgreSQL database management system
ii powermgmt-base 1.30+nmu1 Common utils and configs for power management
ii python-semanage 2.0.25-2 Python bindings for SELinux policy manipulation tools
ii smbfs 2:3.2.4-1 mount and umount commands for the smbfs (for kernels >= than 2
ii synaptic 0.62.1 Graphical package manager
ii system-tools-backends 2.6.0-2 System Tools to manage computer configuration -- scripts
ii tcl8.4 8.4.19-2 Tcl (the Tool Command Language) v8.4 - run-time files
ii tcl8.5 8.5.3-2 Tcl (the Tool Command Language) v8.5 - run-time files
ii twm 1:1.0.4-2 Tab window manager
ii udev 0.125-7 /dev/ and hotplug management daemon
rc wireless-tools 29-1.1 Tools for manipulating Linux Wireless Extensions
ii wodim 9:1.1.9-1 command line CD/DVD writing tool
rc xli 1.17.0+20061110-2 command line tool for viewing images in X11
ii xsltproc 1.1.24-2 XSLT command line processor
ii zoo 2.10-21 manipulate zoo archives
dmon@lenny:~$
Alors que man socket fonctionne très bien.
Je ne vois pas quel paquet mettre.
